  4. 关于snappyHexMesh网格无法很好snap贴合的咨询
3 帖子 2 发布者 4.3k 浏览
  • DY大世界D 离线
    DY大世界D 离线
    DY大世界
    各位大神,我目前使用snappyHexMesh划分一个流场网格,网格内的三角形是外部导入的stl文件。
    blochMeshDict字典为
    scale   1.0;
    vertices
        (-500 -400 -200)
        (1500 -400 -200)
        (-500 1000 -200)
        (1500 1000 -200)
        (-500 -400 400)
        (1500 -400 400)
        (-500 1000 400)
        (1500 1000 400)
    blocks
        hex (0 1 3 2 4 5 7 6) (100 70 30) simpleGrading (1 1 1)
    edges
    boundary
        left
            type patch;
            faces
                (0 4 6 2)
        right
            type patch;
            faces
                (5 1 3 7)
        frontAndBack
            type empty;
            faces
                (0 2 3 1)
                (4 5 7 6)
    mergePatchPairs
    surfaceFeatureExtractDict文件为
    wedge.stl
        // How to obtain raw features (extractFromFile || extractFromSurface)
        extractionMethod    extractFromSurface;
        // Mark edges whose adjacent surface normals are at an angle less
        // than includedAngle as features
        // - 0  : selects no edges
        // - 180: selects all edges
        includedAngle       150;
        // Write options
        // Write features to obj format for postprocessing
        writeObj            yes;
    snappyHexMeshDict文件为
    castellatedMesh true;
    snap            true;
    addLayers       false;
    // Geometry. Definition of all surfaces. All surfaces are of class
    // searchableSurface.
    // Surfaces are used
    // - to specify refinement for any mesh cell intersecting it
    // - to specify refinement for any mesh cell inside/outside/near
    // - to 'snap' the mesh boundary to the surface
    geometry
        wedge.stl
            type triSurfaceMesh;
            name wedge;
        box
            type    searchableBox;
            min  (-200 -200 -100);
            max  (1200 800 200);
    // Settings for the castellatedMesh generation.
    castellatedMeshControls
        // Refinement parameters
        // If local number of cells is >= maxLocalCells on any processor
        // switches from from refinement followed by balancing
        // (current method) to (weighted) balancing before refinement.
        maxLocalCells 100000;
        // Overall cell limit (approximately). Refinement will stop immediately
        // upon reaching this number so a refinement level might not complete.
        // Note that this is the number of cells before removing the part which
        // is not 'visible' from the keepPoint. The final number of cells might
        // actually be a lot less.
        maxGlobalCells 2000000;
        // The surface refinement loop might spend lots of iterations refining just a
        // few cells. This setting will cause refinement to stop if <= minimumRefine
        // are selected for refinement. Note: it will at least do one iteration
        // (unless the number of cells to refine is 0)
        minRefinementCells 0;
        // Number of buffer layers between different levels.
        // 1 means normal 2:1 refinement restriction, larger means slower
        // refinement.
        nCellsBetweenLevels 1;
        // Explicit feature edge refinement
        // Specifies a level for any cell intersected by its edges.
        // This is a featureEdgeMesh, read from constant/triSurface for now.
        features
                file "wedge.extendedFeatureEdgeMesh";
                level 1;
        // Surface based refinement
        // Specifies two levels for every surface. The first is the minimum level,
        // every cell intersecting a surface gets refined up to the minimum level.
        // The second level is the maximum level. Cells that 'see' multiple
        // intersections where the intersections make an
        // angle > resolveFeatureAngle get refined up to the maximum level.
        refinementSurfaces
            wedge
                // Surface-wise min and max refinement level
                level (2 3);
        resolveFeatureAngle 30;
        // Region-wise refinement
        // Specifies refinement level for cells in relation to a surface. One of
        // three modes
        // - distance. 'levels' specifies per distance to the surface the
        //   wanted refinement level. The distances need to be specified in
        //   descending order.
        // - inside. 'levels' is only one entry and only the level is used. All
        //   cells inside the surface get refined up to the level. The surface
        //   needs to be closed for this to be possible.
        // - outside. Same but cells outside.
        refinementRegions
            box
                mode inside;
                levels ((1E15 1));
        // Mesh selection
        // After refinement patches get added for all refinementSurfaces and
        // all cells intersecting the surfaces get put into these patches. The
        // section reachable from the locationInMesh is kept.
        // NOTE: This point should never be on a face, always inside a cell, even
        // after refinement.
        // This is an outside point locationInMesh (-0.033 -0.033 0.0033);
        locationInMesh (-48 -38 -18); // Inside point
        // Whether any faceZones (as specified in the refinementSurfaces)
        // are only on the boundary of corresponding cellZones or also allow
        // free-standing zone faces. Not used if there are no faceZones.
    // Settings for the snapping.
    snapControls
        //- Number of patch smoothing iterations before finding correspondence
        //  to surface
        nSmoothPatch 3;
        //- Relative distance for points to be attracted by surface feature point
        //  or edge. True distance is this factor times local
        //  maximum edge length.
        tolerance 40;
        //- Number of mesh displacement relaxation iterations.
        nSolveIter 300;
        //- Maximum number of snapping relaxation iterations. Should stop
        //  before upon reaching a correct mesh.
        nRelaxIter 5;
        // Feature snapping
            //- Number of feature edge snapping iterations.
            //  Leave out altogether to disable.
            nFeatureSnapIter 30;
            //- Detect (geometric) features by sampling the surface
            implicitFeatureSnap false;
            //- Use castellatedMeshControls::features
            explicitFeatureSnap true;
            //- Detect features between multiple surfaces
            //  (only for explicitFeatureSnap, default = false)
            multiRegionFeatureSnap true;
    // Settings for the layer addition.
    addLayersControls
        // Are the thickness parameters below relative to the undistorted
        // size of the refined cell outside layer (true) or absolute sizes (false).
        relativeSizes true;
        // Per final patch (so not geometry!) the layer information
        layers
            "wedge_.*"
                nSurfaceLayers 1;
        // Expansion factor for layer mesh
        expansionRatio 1.0;
        // Minimum thickness of cell layer. If for any reason layer
        // cannot be above minThickness do not add layer.
        // See relativeSizes parameter.
        minThickness 0.25;
    // Generic mesh quality settings. At any undoable phase these determine
    // where to undo.
    meshQualityControls
        #include "meshQualityDict"
        // Optional : some meshing phases allow usage of relaxed rules.
        // See e.g. addLayersControls::nRelaxedIter.
        relaxed
            //- Maximum non-orthogonality allowed. Set to 180 to disable.
            maxNonOrtho 75;
        // Advanced
        //- Number of error distribution iterations
        nSmoothScale 4;
        //- Amount to scale back displacement at error points
        errorReduction 0.75;
    // Advanced
    // Write flags
    writeFlags
        scalarLevels    // write volScalarField with cellLevel for postprocessing
        layerSets       // write cellSets, faceSets of faces in layer
        layerFields     // write volScalarField for layer coverage
    // Merge tolerance. Is fraction of overall bounding box of initial mesh.
    // Note: the write tolerance needs to be higher than this.
    mergeTolerance 1E-6;
    但是在三角形固体边界处网格畸变很大,贴合总是不好,感觉就是没有贴合
    调试了很多次都是这样,搞不懂是什么原因,希望各位老师指点。感谢!
    我看你画的是二维的blockMesh,改成三维的就好了,snappyHexMesh做二维网格不能用你用的这种方法,会出现你这个问题。需要做成三维的,再投影成2伟的
    DY大世界D 1 条回复 最后回复
  • DY大世界D 离线
    DY大世界D 离线
    DY大世界
    @东岳 感谢李老师解答,我再试试
