  3. 求助,做动网格遇到问题,,找不到原因了
求助,做动网格遇到问题,,找不到原因了
1 帖子 1 发布者 1.4k 浏览
  • 红豆沙红 离线
    红豆沙红 离线
    红豆沙
    Create time
    Create mesh for time = 0
    Selecting dynamicFvMesh dynamicMotionSolverFvMesh
    Selecting motion solver: sixDoFRigidBodyMotion
    Selecting sixDoFSolver symplectic
    Translational constraint tensor (1 -0 -0 -0 1 -0 -0 -0 -624)
    Rotational constraint tensor (0 0 0 0 0 0 0 0 0)
    PIMPLE: No corrector convergence criteria found
            Calculations will do 2 corrections
    PIMPLE: Operating solver in transient mode with 2 outer correctors
    Reading field p
    Reading field U
    Selecting laminar stress model Stokes
    No MRF models present
    Constructing face velocity Uf
    Courant Number mean: 0.000625613 max: 0.10552
    fieldAverage fieldAverage1:
        Starting averaging at time 0
    forces forces1:
    forces forceCoeffs1:
    forceCoeffs forceCoeffs1:
    Starting time loop
    deltaT = 0.005
    Time = 0.005
    PIMPLE: Iteration 1
    forces forces:
    #3  Foam::sixDoFSolvers::symplectic::solve(bool, Foam::Vector<double> const&, Foam::Vector<double> const&, double, double) at ??:?
    #4  Foam::sixDoFRigidBodyMotion::update(bool, Foam::Vector<double> const&, Foam::Vector<double> const&, double, double) at ??:?
    #5  Foam::sixDoFRigidBodyMotionSolver::solve() at ??:?
    #6  Foam::motionSolver::newPoints() at ??:?
    #7  Foam::dynamicMotionSolverFvMesh::update() at ??:?
    #8  ? in "/home/z/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
    #9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #10  ? in "/home/z/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/pimpleFoam"
    浮点数例外 (核心已转储)
    世界那么大,怎能不去看看
