  4. output value vs paraFoam?
1 帖子 1 发布者 2.1k 浏览
  • K 离线
    K 离线
    kimy
    I am checking that the variables outbut from source code in solver and I found the differences between output and paraFoam. I cannot understand why it happened? The follow is my codes in simpleFoam.C:
    **const dimensionedScalar myZero("myZero", dimensionSet(0,0,0,0,0,0,0),scalar(0) );
    volScalarField k0=myZeroturbulence->k();
    volScalarField nut0=myZero
    turbulence->nut();
    volScalarField nu0=myZero*turbulence->nu();
    const label patchID = mesh.boundaryMesh().findPatchID("wall");
    const tmp<scalarField> tnuw = turbulence->nu(patchID);
    const scalarField& nuw = tnuw();
    const tmp<scalarField> tnutw = turbulence->nut(patchID);
    const scalarField& nutw = tnutw();
    const fvPatchVectorField& Uw = turbulence->U().boundaryField()[patchID];
    const scalarField magGradUw(mag(Uw.snGrad()));
    for (int j=0; j<nut0.size(); j++)
    if (j<=(nutw.size()/2-1)) {nut0[j]=nutw[j]; nu0[j]=nuw[j];}
    if (j>=(mesh.cells().size()-nutw.size()/2)&&j<=mesh.cells().size()-1) {nut0[j]=nutw[j-(mesh.cells().size()-nutw.size())];nu0[j]=nuw[j-(mesh.cells().size()-nutw.size())];}
    volVectorField Uww=U*myZero;
    const fvPatchList& patches = mesh.boundary();
    labelList wallList;
    wallList.clear();
    forAll(patches, patchi)
    const fvPatch& curPatch = patches[patchi];
    if (isType<wallFvPatch>(curPatch))
    forAll(curPatch, facei)
    label faceCelli = curPatch.faceCells()[facei];
    wallList.resize(wallList.size()+1);
    wallList[wallList.size()-1]=faceCelli;
    forAll(wallList,i)
    Uww[wallList[i]] = U[wallList[i]];
    volScalarField uz = Uww.component(vector::Z);
    volVectorField SG = uz*vector(0,0,1);
    volScalarField magGradUww=mag(SG)/myY;
    k0=((nut0+nu0)*magGradUww/0.3);
    Info<<"k0="<<k0<<endl;
    Info<<"nut0="<<nut0<<endl;
    Info<<"nutw="<<nutw<<endl;
    Info<<"magGradUww="<<magGradUww<<endl;
    Info<<"magGradUw="<<magGradUw<<endl;
    Info<<"tauw="<<(nut0+nu0)magGradUww<<endl;
    Info<<"Uw="<<Uw<<endl;
    nutw and magGradUw are copied from nutkwallfunction. In the end, wallshearstress in the paraFoam is not the same as (nut0+nu0)*magGradUww.
