  3. 分享以及讨论 欧拉拉格朗日模型中 ParcelCollector
7 帖子 2 发布者 5.6k 浏览
  • 星 离线
    星 离线
    星星星星晴
    下面是我修改的ParcelCollector.C 及.H 基于OF4.1
    目的是通过在domain中建立一个面(同心圆或多边形),对碰到该面的parcel进行一些统计。
    原code中只计算了mass 以及massflowrate。
    我在做喷雾,在validation中需要做一个sauter mean diameter(D32)VS axial diameter 的图。
    在试过其他方法并没有特别好的效果的情况下,试着修改了一下parcelcollector这个cloudfunction。
    #include "ParticleCollector.H"
    #include "Pstream.H"
    #include "surfaceWriter.H"
    #include "unitConversion.H"
    #include "Random.H"
    #include "triangle.H"
    #include "cloud.H"
    // * * * * * * * * * * * * * Private Member Functions  * * * * * * * * * * * //
    template<class CloudType>
    void Foam::ParticleCollector<CloudType>::makeLogFile
        const faceList& faces,
        const Field<point>& points,
        const Field<scalar>& area
        // Create the output file if not already created
        if (log_)
            if (debug)
                Info<< "Creating output file" << endl;
            if (Pstream::master())
                // Create directory if does not exist
                mkDir(this->writeTimeDir());
                // Open new file at start up
                outputFilePtr_.reset
                    new OFstream(this->writeTimeDir()/(type() + ".dat"))
                outputFilePtr_()
                    << "# Source     : " << type() << nl
                    << "# Bins       : " << faces.size() << nl
                    << "# Total area : " << sum(area) << nl;
                outputFilePtr_()
                    << "# Geometry   :" << nl
                    << tab << "Bin"
                    << tab << "(Centre_x Centre_y Centre_z)"
                    << tab << "Area"
                    << nl;
                forAll(faces, i)
                    outputFilePtr_()
                        << tab << i
                        << tab << faces[i].centre(points)
                        << tab << area[i]
                        << nl;
                outputFilePtr_()
                    << '#' << nl
                    << "# Output format:" << nl;
                forAll(faces, i)
                    word id = Foam::name(i);
                    word binId = "bin_" + id;
                    outputFilePtr_()
                        << tab << "Time"
                        << tab << binId
                        << tab << "mass[" << id << "]"
                        << tab << "massFlowRate[" << id << "]"
                        << tab << "D3[" << id << "]"
                        << tab << "D2[" << id << "]"
                        << endl;
    void Foam::ParticleCollector<CloudType>::initPolygons
        const List<Field<point>>& polygons
        mode_ = mtPolygon;
        label nPoints = 0;
        forAll(polygons, polyI)
            label np = polygons[polyI].size();
            if (np < 3)
                FatalIOErrorInFunction(this->coeffDict())
                    << "polygons must consist of at least 3 points"
                    << exit(FatalIOError);
            nPoints += np;
        label pointOffset = 0;
        points_.setSize(nPoints);
        faces_.setSize(polygons.size());
        faceTris_.setSize(polygons.size());
        area_.setSize(polygons.size());
        forAll(faces_, facei)
            const Field<point>& polyPoints = polygons[facei];
            face f(identity(polyPoints.size()) + pointOffset);
            UIndirectList<point>(points_, f) = polyPoints;
            area_[facei] = f.mag(points_);
            DynamicList<face> tris;
            f.triangles(points_, tris);
            faceTris_[facei].transfer(tris);
            faces_[facei].transfer(f);
            pointOffset += polyPoints.size();
    void Foam::ParticleCollector<CloudType>::initConcentricCircles()
        mode_ = mtConcentricCircle;
        vector origin(this->coeffDict().lookup("origin"));
        radius_ = this->coeffDict().lookup("radius");
        nSector_ = readLabel(this->coeffDict().lookup("nSector"));
        label nS = nSector_;
        vector refDir;
        if (nSector_ > 1)
            refDir = this->coeffDict().lookup("refDir");
            refDir -= normal_[0]*(normal_[0] & refDir);
            refDir /= mag(refDir);
        else
            // set 4 quadrants for single sector cases
            nS = 4;
            vector tangent = Zero;
            scalar magTangent = 0.0;
            Random rnd(1234);
            while (magTangent < SMALL)
                vector v = rnd.vector01();
                tangent = v - (v & normal_[0])*normal_[0];
                magTangent = mag(tangent);
            refDir = tangent/magTangent;
        scalar dTheta = 5.0;
        scalar dThetaSector = 360.0/scalar(nS);
        label intervalPerSector = max(1, ceil(dThetaSector/dTheta));
        dTheta = dThetaSector/scalar(intervalPerSector);
        label nPointPerSector = intervalPerSector + 1;
        label nPointPerRadius = nS*(nPointPerSector - 1);
        label nPoint = radius_.size()*nPointPerRadius;
        label nFace = radius_.size()*nS;
        // add origin
        nPoint++;
        points_.setSize(nPoint);
        faces_.setSize(nFace);
        area_.setSize(nFace);
        coordSys_ = cylindricalCS("coordSys", origin, normal_[0], refDir, false);
        List<label> ptIDs(identity(nPointPerRadius));
        points_[0] = origin;
        // points
        forAll(radius_, radI)
            label pointOffset = radI*nPointPerRadius + 1;
            for (label i = 0; i < nPointPerRadius; i++)
                label pI = i + pointOffset;
                point pCyl(radius_[radI], degToRad(i*dTheta), 0.0);
                points_[pI] = coordSys_.globalPosition(pCyl);
        // faces
        DynamicList<label> facePts(2*nPointPerSector);
            if (radI == 0)
                for (label secI = 0; secI < nS; secI++)
                    facePts.clear();
                    // append origin point
                    facePts.append(0);
                    for (label ptI = 0; ptI < nPointPerSector; ptI++)
                        label i = ptI + secI*(nPointPerSector - 1);
                        label id = ptIDs.fcIndex(i - 1) + 1;
                        facePts.append(id);
                    label facei = secI + radI*nS;
                    faces_[facei] = face(facePts);
                    area_[facei] = faces_[facei].mag(points_);
            else
                    facePts.clear();
                    label offset = (radI - 1)*nPointPerRadius + 1;
                        label id = offset + ptIDs.fcIndex(i - 1);
                        facePts.append(id);
                    for (label ptI = nPointPerSector-1; ptI >= 0; ptI--)
                        label id = offset + nPointPerRadius + ptIDs.fcIndex(i - 1);
                        facePts.append(id);
    void Foam::ParticleCollector<CloudType>::collectParcelPolygon
        const point& p1,
        const point& p2
    ) const
        label dummyNearType = -1;
        label dummyNearLabel = -1;
            const label facePoint0 = faces_[facei][0];
            const point& pf = points_[facePoint0];
            const scalar d1 = normal_[facei] & (p1 - pf);
            const scalar d2 = normal_[facei] & (p2 - pf);
            if (sign(d1) == sign(d2))
                // did not cross polygon plane
                continue;
            // intersection point
            const point pIntersect = p1 + (d1/(d1 - d2))*(p2 - p1);
            const List<face>& tris = faceTris_[facei];
            // identify if point is within poly bounds
            forAll(tris, triI)
                const face& tri = tris[triI];
                triPointRef t
                    points_[tri[0]],
                    points_[tri[1]],
                    points_[tri[2]]
                if (t.classify(pIntersect, dummyNearType, dummyNearLabel))
                    hitFaceIDs_.append(facei);
    void Foam::ParticleCollector<CloudType>::collectParcelConcentricCircles
        const point& p1,
        const point& p2
    ) const
        label secI = -1;
        const scalar d1 = normal_[0] & (p1 - coordSys_.origin());
        const scalar d2 = normal_[0] & (p2 - coordSys_.origin());
            // did not cross plane
            return;
        // intersection point in cylindrical co-ordinate system
        const point pCyl = coordSys_.localPosition(p1 + (d1/(d1 - d2))*(p2 - p1));
        scalar r = pCyl[0];
        if (r < radius_.last())
            label radI = 0;
            while (r > radius_[radI])
                radI++;
            if (nSector_ == 1)
                secI = 4*radI;
            else
                scalar theta = pCyl[1] + constant::mathematical::pi;
                secI =
                    nSector_*radI
                  + floor
                        scalar(nSector_)*theta/constant::mathematical::twoPi
        hitFaceIDs_.append(secI);
    void Foam::ParticleCollector<CloudType>::write()
        const fvMesh& mesh = this->owner().mesh();
        const Time& time = mesh.time();
        scalar timeNew = time.value();
        scalar timeElapsed = timeNew - timeOld_;
        totalTime_ += timeElapsed;
        const scalar alpha = (totalTime_ - timeElapsed)/totalTime_;
        const scalar beta = timeElapsed/totalTime_;
            massFlowRate_[facei] =
                alpha*massFlowRate_[facei] + beta*mass_[facei]/timeElapsed;
            massTotal_[facei] += mass_[facei];
            d3Total_[facei] += d3_[facei];
            d2Total_[facei] += d2_[facei];
        const label proci = Pstream::myProcNo();
        Field<scalar> faceMassTotal(mass_.size(), 0.0);
        this->getModelProperty("massTotal", faceMassTotal);
        Field<scalar> faceMassFlowRate(massFlowRate_.size(), 0.0);
        this->getModelProperty("massFlowRate", faceMassFlowRate);
        Field<scalar> faceD3Total(d3_.size(), 0.0);
        this->getModelProperty("d3Total", faceD3Total);
        Field<scalar> faceD2Total(d2_.size(), 0.0);
        this->getModelProperty("d2Total", faceD2Total);
        scalar sumTotalMass = 0.0;
        scalar sumAverageMFR = 0.0;
        scalar sumTotalD3 = 0.0;
        scalar sumTotalD2 = 0.0;
            scalarList allProcMass(Pstream::nProcs());
            allProcMass[proci] = massTotal_[facei];
            Pstream::gatherList(allProcMass);
            faceMassTotal[facei] += sum(allProcMass);
            scalarList allProcMassFlowRate(Pstream::nProcs());
            allProcMassFlowRate[proci] = massFlowRate_[facei];
            Pstream::gatherList(allProcMassFlowRate);
            faceMassFlowRate[facei] += sum(allProcMassFlowRate);
            scalarList allProcD3(Pstream::nProcs());
            allProcD3[proci] = d3Total_[facei];
            Pstream::gatherList(allProcD3);
            faceD3Total[facei] += sum(allProcD3);
            scalarList allProcD2(Pstream::nProcs());
            allProcD2[proci] = d2Total_[facei];
            Pstream::gatherList(allProcD2);
            faceD2Total[facei] += sum(allProcD2);
            sumTotalMass += faceMassTotal[facei];
            sumAverageMFR += faceMassFlowRate[facei];
            sumTotalD3 += faceD3Total[facei];
            sumTotalD2 += faceD2Total[facei];
            //- Display values for each face
            if (outputFilePtr_.valid())
                outputFilePtr_()
                    << time.timeName()
                    << tab << facei
                    << tab << faceMassTotal[facei]
                    << tab << faceMassFlowRate[facei]
                    << tab << faceD3Total[facei]
                    << tab << faceD2Total[facei]
                    << endl;
        Info<< "    sum(total mass) = "             << sumTotalMass     << nl
            << "    sum(average mass flow rate) = " << sumAverageMFR    << nl
            << "    sum(total d3) = "               << sumTotalD3       << nl
            << "    sum(total d2) = "               << sumTotalD2       << nl
            << "    radius.size = "                 << radius_.size()   << nl
            << endl;
        if (surfaceFormat_ != "none")
                autoPtr<surfaceWriter> writer(surfaceWriter::New(surfaceFormat_));
                writer->write
                    this->writeTimeDir(),
                    "collector",
                    points_,
                    faces_,
                    "massTotal",
                    faceMassTotal,
                    false
                writer->write
                    "collector",
                    points_,
                    faces_,
                    "massFlowRate",
                    faceMassFlowRate,
                    false
                 writer->write
                    "collector",
                    points_,
                    faces_,
                    "d3Total",
                    faceD3Total,
                    false
                 writer->write
                    "collector",
                    points_,
                    faces_,
                    "d2Total",
                    faceD2Total,
                    false
        if (resetOnWrite_)
            Field<scalar> dummy(faceMassTotal.size(), 0.0);
            this->setModelProperty("massTotal", dummy);
            this->setModelProperty("massFlowRate", dummy);
            this->setModelProperty("d3Total", dummy);
            this->setModelProperty("d2Total", dummy);
            timeOld_ = timeNew;
            totalTime_ = 0.0;
        else
            this->setModelProperty("massTotal", faceMassTotal);
            this->setModelProperty("massFlowRate", faceMassFlowRate);
            this->setModelProperty("d3Total", faceD3Total);
            this->setModelProperty("d2Total", faceD2Total);
            mass_[facei] = 0.0;
            massTotal_[facei] = 0.0;
            massFlowRate_[facei] = 0.0;
            d3_[facei] = 0.0;
            d3Total_[facei] = 0.0;
            d2_[facei] = 0.0;
            d2Total_[facei] = 0.0;
    // * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
    Foam::ParticleCollector<CloudType>::ParticleCollector
        const dictionary& dict,
        CloudType& owner,
        const word& modelName
        CloudFunctionObject<CloudType>(dict, owner, modelName, typeName),
        mode_(mtUnknown),
        parcelType_(this->coeffDict().lookupOrDefault("parcelType", -1)),
        removeCollected_(this->coeffDict().lookup("removeCollected")),
        points_(),
        faces_(),
        faceTris_(),
        nSector_(0),
        radius_(),
        coordSys_(false),
        normal_(),
        negateParcelsOppositeNormal_
            readBool(this->coeffDict().lookup("negateParcelsOppositeNormal"))
        surfaceFormat_(this->coeffDict().lookup("surfaceFormat")),
        resetOnWrite_(this->coeffDict().lookup("resetOnWrite")),
        totalTime_(0.0),
        mass_(),
        massTotal_(),
        massFlowRate_(),
        d3_(),
        d2_(),
        d3Total_(),
        d2Total_(),
        log_(this->coeffDict().lookup("log")),
        outputFilePtr_(),
        timeOld_(owner.mesh().time().value()),
        hitFaceIDs_()
        normal_ /= mag(normal_);
        word mode(this->coeffDict().lookup("mode"));
        if (mode == "polygon")
            List<Field<point>> polygons(this->coeffDict().lookup("polygons"));
            initPolygons(polygons);
            vector n0(this->coeffDict().lookup("normal"));
            normal_ = vectorField(faces_.size(), n0);
        else if (mode == "polygonWithNormal")
            List<Tuple2<Field<point>, vector>> polygonAndNormal
            List<Field<point>> polygons(polygonAndNormal.size());
            normal_.setSize(polygonAndNormal.size());
                polygons[polyI] = polygonAndNormal[polyI].first();
                normal_[polyI] = polygonAndNormal[polyI].second();
                normal_[polyI] /= mag(normal_[polyI]) + ROOTVSMALL;
        else if (mode == "concentricCircle")
            normal_ = vectorField(1, n0);
            initConcentricCircles();
        else
                << "Unknown mode " << mode << ".  Available options are "
                << "polygon, polygonWithNormal and concentricCircle"
        mass_.setSize(faces_.size(), 0.0);
        massTotal_.setSize(faces_.size(), 0.0);
        massFlowRate_.setSize(faces_.size(), 0.0);
        d3_.setSize(faces_.size(), 0.0);
        d2_.setSize(faces_.size(), 0.0);
        d3Total_.setSize(faces_.size(), 0.0);
        d2Total_.setSize(faces_.size(), 0.0);
        makeLogFile(faces_, points_, area_);
        const ParticleCollector<CloudType>& pc
        CloudFunctionObject<CloudType>(pc),
        mode_(pc.mode_),
        parcelType_(pc.parcelType_),
        removeCollected_(pc.removeCollected_),
        points_(pc.points_),
        faces_(pc.faces_),
        faceTris_(pc.faceTris_),
        nSector_(pc.nSector_),
        radius_(pc.radius_),
        coordSys_(pc.coordSys_),
        normal_(pc.normal_),
        negateParcelsOppositeNormal_(pc.negateParcelsOppositeNormal_),
        surfaceFormat_(pc.surfaceFormat_),
        resetOnWrite_(pc.resetOnWrite_),
        totalTime_(pc.totalTime_),
        mass_(pc.mass_),
        massTotal_(pc.massTotal_),
        massFlowRate_(pc.massFlowRate_),
        d3_(pc.d3_),
        d2_(pc.d2_),
        d3Total_(pc.d3Total_),
        d2Total_(pc.d2Total_),
        log_(pc.log_),
        outputFilePtr_(),
        timeOld_(0.0),
        hitFaceIDs_()
    // * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
    Foam::ParticleCollector<CloudType>::~ParticleCollector()
    void Foam::ParticleCollector<CloudType>::postMove
        parcelType& p,
        const label celli,
        const scalar dt,
        const point& position0,
        bool& keepParticle
        if ((parcelType_ != -1) && (parcelType_ != p.typeId()))
            return;
        // slightly extend end position to avoid falling within tracking tolerances
        const point position1 = position0 + 1.0001*(p.position() - position0);
        hitFaceIDs_.clear();
        switch (mode_)
            case mtPolygon:
                collectParcelPolygon(position0, position1);
                break;
            case mtConcentricCircle:
                collectParcelConcentricCircles(position0, position1);
                break;
            default:
        forAll(hitFaceIDs_, i)
            label facei = hitFaceIDs_[i];
            scalar m = p.nParticle() * p.mass();
            scalar d3p = p.nParticle() * p.d() * p.d()* p.d();
            scalar d2p = p.nParticle() * p.d() * p.d();
            if (negateParcelsOppositeNormal_)
                vector Uhat = p.U();
                Uhat /= mag(Uhat) + ROOTVSMALL;
                if ((Uhat & normal_[facei]) < 0)
                    m *= -1.0;
            // add mass contribution
            mass_[facei] += m;
            d2_[facei] += d2p;
            d3_[facei] += d3p;
            if (nSector_ == 1)
                mass_[facei + 1] += m;
                mass_[facei + 2] += m;
                mass_[facei + 3] += m;
                d2_[facei + 1] += d2p;
                d2_[facei + 2] += d2p;
                d2_[facei + 3] += d2p;
                d3_[facei + 1] += d3p;
                d3_[facei + 2] += d3p;
                d3_[facei + 3] += d3p;
            if (removeCollected_)
                keepParticle = false;
    #ifndef ParticleCollector_H
    #define ParticleCollector_H
    #include "CloudFunctionObject.H"
    #include "cylindricalCS.H"
    #include "face.H"
    #include "Switch.H"
    #include "OFstream.H"
    namespace Foam
                          Class ParticleCollector Declaration
    class ParticleCollector
        public CloudFunctionObject<CloudType>
    public:
        enum modeType
            mtPolygon,
            mtConcentricCircle,
            mtUnknown
    private:
        // Private Data
            // Typedefs
                //- Convenience typedef for parcel type
                typedef typename CloudType::parcelType parcelType;
            //- Collector mode type
            modeType mode_;
            //- Index of parcel types to collect (-1 by default = all particles)
            const label parcelType_;
            //- Flag to remove collected particles
            Switch removeCollected_;
            //- List of points
            Field<point> points_;
            //- List of faces
            List<face> faces_;
            // Polygon collector
                //- Triangulation of faces
                List<List<face>> faceTris_;
            // Concentric circles collector
                //- Number of sectors per circle
                label nSector_;
                //- List of radii
                List<scalar> radius_;
                //- Cylindrical co-ordinate system
                cylindricalCS coordSys_;
            //- Face areas
            Field<scalar> area_;
            //- Polygon normal vector per face
            Field<vector> normal_;
            //- Remove mass of parcel travelling in opposite direction to normal_
            bool negateParcelsOppositeNormal_;
            //- Surface output format
            const word surfaceFormat_;
            //- Flag to indicate whether data should be reset/cleared on writing
            Switch resetOnWrite_;
            //- Total time
            scalar totalTime_;
            //- Mass storage
            List<scalar> mass_;
            //- Mass total storage
            List<scalar> massTotal_;
            //- Mass flow rate storage
            List<scalar> massFlowRate_;
            List<scalar> d3_;
            List<scalar> d2_;
            List<scalar> d3Total_;
            List<scalar> d2Total_;
            //- Flag to indicate whether data should be written to file
            Switch log_;
            //- Output file pointer
            autoPtr<OFstream> outputFilePtr_;
            //- Last calculation time
            scalar timeOld_;
            //- Work list to store which faces are hit
            mutable DynamicList<label> hitFaceIDs_;
        // Private Member Functions
            //- Helper function to create log files
            void makeLogFile
            //- Initialise polygon collectors
            void initPolygons(const List<Field<point>>& polygons);
            //- Initialise concentric circle collectors
            void initConcentricCircles();
            //- Collect parcels in polygon collectors
            void collectParcelPolygon
                const point& p1,
                const point& p2
            ) const;
            //- Collect parcels in concentric circle collectors
            void collectParcelConcentricCircles
                const point& p1,
                const point& p2
            ) const;
    protected:
        // Protected Member Functions
            //- Write post-processing info
            void write();
    public:
        //- Runtime type information
        TypeName("particleCollector");
        // Constructors
            //- Construct from dictionary
            ParticleCollector
                CloudType& owner,
            //- Construct copy
            ParticleCollector(const ParticleCollector<CloudType>& pc);
            //- Construct and return a clone
            virtual autoPtr<CloudFunctionObject<CloudType>> clone() const
                return autoPtr<CloudFunctionObject<CloudType>>
                    new ParticleCollector<CloudType>(*this)
        //- Destructor
        virtual ~ParticleCollector();
        // Member Functions
            // Access
                //- Return const access to the reset on write flag
                inline const Switch& resetOnWrite() const;
            // Evaluation
                //- Post-move hook
                virtual void postMove
                    parcelType& p,
                    const label celli,
                    const scalar dt,
                    bool& keepParticle
    } // End namespace Foam
    #include "ParticleCollectorI.H"
    #ifdef NoRepository
        #include "ParticleCollector.C"
    #endif
    #endif
    游荡
  • 星 离线
    星 离线
    星星星星晴
    现在的情况是这样的,在相同位置有不同的particlecollector,但是得到的数据就完全不同。
     particleCollector1
            type            particleCollector;
            mode            concentricCircle;
            origin          (0.0 0.0 0.975);
            radius          (0.19999);
            nSector         1;
            refDir          (1 0 0);
            normal          (0 0 1);
            negateParcelsOppositeNormal no;
            removeCollected no;
            surfaceFormat   vtk;
            resetOnWrite    no;
            log             yes;
     particleCollector2
            radius          (0.0005 0.0015 0.0025 0.0035
    0.0045 0.0055 0.0065 0.0075
    0.0085 0.0095 0.0105 0.0115
    0.0125 0.0135 0.0145 0.0155
    0.0165 0.0175 0.0185 0.0195
    0.0205 0.0215 0.0225 0.0235
    0.0245 0.0255 0.0265 0.0275
    0.0285 0.0295 0.0305 0.05
    0.075 0.1 0.15 0.19999);
            nSector         1;
            refDir          (1 0 0);
            normal          (0 0 1);
            removeCollected no;
            surfaceFormat   vtk;
            resetOnWrite    no;
            log             yes;
     particleCollector3
            radius          (0.0005 0.0015 0.0025 0.0035 0.05 0.075 0.1 0.15 0.19999);
            nSector         1;
            refDir          (1 0 0);
            normal          (0 0 1);
            removeCollected no;
            surfaceFormat   vtk;
            resetOnWrite    no;
            log             yes;
    输出结果如下。
        sum(total mass) = 1.75085e-05
        sum(average mass flow rate) = 0.0875421
        sum(total d3) = 3.34387e-08
        sum(total d2) = 0.000615982
        radius.size = 1
        nSector_ = 1
        sum(total mass) = 3.51273e-05
        sum(average mass flow rate) = 0.175637
        sum(total d3) = 6.70882e-08
        sum(total d2) = 0.00122567
        radius.size = 36
        nSector_ = 1
        sum(total mass) = 1.51653e-05
        sum(average mass flow rate) = 0.0758266
        sum(total d3) = 2.89636e-08
        sum(total d2) = 0.000605451
        radius.size = 9
        nSector_ = 1
    如果说 mass和 massflow rate是相同的话,我可以理解,因为这个是原生的部分,我并没有修改什么,但是现在就输出成这个样子,我就很费解了。。希望大神能帮忙看一下
    游荡
    chengan.wangC 1 条回复 最后回复
  • chengan.wangC 在线
    chengan.wangC 在线
    chengan.wang
    在 中回复了 星星星星晴 最后由 编辑
    @星星星星晴 相同的位置统计数据不一样,这个您找到原因了么?有点晕,不知道该怎么统计数据了。还有您的验证validation,sauter mean diameter(D32)VS axial diameter 的图,方便发出来做为一个标准验证么?
    星 1 条回复 最后回复
  • 星 离线
    星 离线
    星星星星晴
    在 中回复了 chengan.wang 最后由 编辑
    @chengan-wang 我在别的帖子和你说过啦,我后来不用particlecollector这个原生的,就是输出文件,对文件的数据分析,python matlab,excel都行,剩下就是统计了
    游荡
  • chengan.wangC 在线
    chengan.wangC 在线
    chengan.wang
    在 中回复了 星星星星晴 最后由 编辑
    @星星星星晴 您好,我有几个参数想请教您,
    1.您的算例中radius分别设定1个,36个和9个数据,代表采集不同同心圆的数据?
    2.nSector,自带算例设成10, 您设的是1。源代码里面Number of sectors per circle,这个怎么考虑
    3.refDir代表啥意思呢?好像跟nSector数量还有关系
    打扰了
    星 1 条回复 最后回复
  • 星 离线
    星 离线
    星星星星晴
    @chengan-wang 不好意思,我研究了我能用的部分我就再没看了,如果你研究明白了,可以分享一下。自己查code,做几个实验code
    游荡
  • chengan.wangC 在线
    chengan.wangC 在线
    chengan.wang
    在 中回复了 星星星星晴 最后由 编辑
    @星星星星晴 感觉nSector不能设为1,最后输出的sum(total mass),sum(average mass flow rate)是nSector>1的4倍左右。
        if (nSector_ > 1)
        else
            nS = 4;
            vector tangent = vector::zero;
            Random rnd(1234);
    可能跟源代码中nS = 4;有关系
