  4. 关于复杂形状三维流体域的计算问题
关于复杂形状三维流体域的计算问题
2 帖子 1 发布者 2.1k 浏览
    Stan同学
    请教各位老师和同学们:
    在一个三维复杂流体域案例的计算中,部分流体域形状较为复杂,网格采用snappyhexmesh生成,网格数量六百五十万左右,checkMesh结果OK,边界设置检查无误。计算到30s左右时出现不收敛的情况。下面为计算过程输出信息中的最后的几个不收敛时间步以及最后的部分报错信息(因为字符限制,后续部分在评论中)。请教各位老师和同学们,报错信息表示了计算模型哪方面的问题以及如何去调整。
    Courant Number mean: 0.0811704 max: 339375
    Interface Courant Number mean: 0.0331014 max: 90043
    deltaT = 3.36389e-15
    Time = 33.5117
    PIMPLE: iteration 1
    alpha.water BC on patch inlet
    MULES: Solving for alpha.water
    Phase-1 volume fraction = 0.647158  Min(alpha.water) = -6.71024e-20  Max(alpha.water) = 1.00032
    Phase-1 volume fraction = 0.647158  Min(alpha.water) = -3.42344e-19  Max(alpha.water) = 1.00032
    Velocity BC on patch inlet
    3D_3D Absorption BC on patch outlet
    "Correction Levels" 25( 1.75485 1.85601 1.55984 1.59708 1.56351 1.52502 1.52423 1.52653 1.39188 1.24439 1.50892 1.18572 0.917495 0.860397 1.13003 1.02722 1.37729 1.65376 1.86368 2.10405 2.20481 1.7503 1.49513 1.47808 1.62577 )
    3D_3D Absorption BC on patch frontAndBack
    "Correction Levels" 25( -4.53749 -4.14273 -0.130794 1.00985 2.2047 3.62849 4.42181 3.58968 1.44737 -1.07649 -3.04945 -3.68013 -1.06624 0.682384 1.53162 2.34454 2.25524 0.924583 0.698287 1.05531 0.708991 0.277332 -0.286046 -0.200047 1.10636 )
    DICPCG:  Solving for p_rgh, Initial residual = 0.999205, Final residual = 0.0470571, No Iterations 149
    DICPCG:  Solving for p_rgh, Initial residual = 0.000705545, Final residual = 2.50405e-05, No Iterations 3
    time step continuity errors : sum local = 2.35881e+12, global = 0.00174181, cumulative = 0.00137343
    DICPCG:  Solving for p_rgh, Initial residual = 0.000172039, Final residual = 7.00718e-06, No Iterations 8
    DICPCG:  Solving for p_rgh, Initial residual = 0.00146033, Final residual = 1.3504e-05, No Iterations 1
    time step continuity errors : sum local = 1.56951e+12, global = 0.000252718, cumulative = 0.00162615
    DICPCG:  Solving for p_rgh, Initial residual = 0.000155355, Final residual = 6.95743e-06, No Iterations 8
    DICPCG:  Solving for p_rgh, Initial residual = 0.00108953, Final residual = 9.66053e-08, No Iterations 238
    time step continuity errors : sum local = 1.34352e+10, global = -6.4846e+08, cumulative = -6.4846e+08
    smoothSolver:  Solving for epsilon, Initial residual = 1, Final residual = 9.98979e-09, No Iterations 675
    bounding epsilon, min: -3.65743e+29 max: 3.75536e+54 average: 2.82799e+48
    smoothSolver:  Solving for k, Initial residual = 6.76611e-05, Final residual = 1.66848e-08, No Iterations 1000
    bounding k, min: 3.91848e-41 max: 6.52827e+46 average: 3.19235e+40
    ExecutionTime = 43544.6 s  ClockTime = 43560 s
    Courant Number mean: 1.67126e+13 max: 3.55514e+19
    Interface Courant Number mean: 3.87388e+12 max: 3.55514e+19
    deltaT = 4.25793e-35
    Time = 33.5117
    PIMPLE: iteration 1
    Phase-1 volume fraction = 0.647158  Min(alpha.water) = -1.56077e-21  Max(alpha.water) = 1.00032
    DICPCG:  Solving for p_rgh, Initial residual = 1, Final residual = 47.0446, No Iterations 1001
    DICPCG:  Solving for p_rgh, Initial residual = 0.000216109, Final residual = 9.48986e-06, No Iterations 3
    time step continuity errors : sum local = 4.08786e+21, global = 873386, cumulative = -6.47586e+08
    DICPCG:  Solving for p_rgh, Initial residual = 4.95933e-05, Final residual = 2.30123e-06, No Iterations 12
    DICPCG:  Solving for p_rgh, Initial residual = 0.000358529, Final residual = 1.65707e-05, No Iterations 5
    time step continuity errors : sum local = 2.78772e+21, global = 1.35102e+07, cumulative = -6.34076e+08
    DICPCG:  Solving for p_rgh, Initial residual = 8.00534e-05, Final residual = 3.79662e-06, No Iterations 26
    DICPCG:  Solving for p_rgh, Initial residual = 0.000430357, Final residual = 9.90187e-08, No Iterations 152
    time step continuity errors : sum local = 7.72207e+18, global = 1.04902e+18, cumulative = 1.04902e+18
    smoothSolver:  Solving for epsilon, Initial residual = 1, Final residual = 9.99364e-09, No Iterations 967
    bounding epsilon, min: -1.30423e+57 max: 3.78086e+105 average: 1.05636e+99
    smoothSolver:  Solving for k, Initial residual = 0.999975, Final residual = 3.70498e-05, No Iterations 1000
    bounding k, min: 1.10387e-72 max: 5.9365e+94 average: 3.93865e+88
    ExecutionTime = 43557.5 s  ClockTime = 43573 s
    Courant Number mean: 6.08378e+22 max: 5.54233e+28
    Interface Courant Number mean: 8.58371e+21 max: 4.62459e+28
    deltaT = 3.45715e-64
    Time = 33.5117
    PIMPLE: iteration 1
    DICPCG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.0479307, No Iterations 15
    [75] #0  Foam::error::printStack(Foam::Ostream&)[78] #0  Foam::error::printStack(Foam::Ostream&)[79] #0  Foam::error::printStack(Foam::Ostream&)[82] #0  Foam::error::printStack(Foam::Ostream&)[83] #0  Foam::error::printStack(Foam::Ostream&)[90] #0  Foam::error::printStack(Foam::Ostream&)[91] #0  Foam::error::printStack(Foam::Ostream&)[94] #0  Foam::error::printStack(Foam::Ostream&)[95] #0  Foam::error::printStack(Foam::Ostream&)[96] #0  Foam::error::printStack(Foam::Ostream&)[97] #0  Foam::error::printStack(Foam::Ostream&)[100] #0  Foam::error::printStack(Foam::Ostream&)[119] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [95] #1  Foam::sigFpe::sigHandler(int) at ??:?
     at ??:?
     at ??:?
     at ??:?
    [83] #1  Foam::sigFpe::sigHandler(int)[90] #1  Foam::sigFpe::sigHandler(int)[91] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [97] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [78] #1  Foam::sigFpe::sigHandler(int) at ??:?
     at ??:?
     at ??:?
    [82] #1  Foam::sigFpe::sigHandler(int)[100] #1  Foam::sigFpe::sigHandler(int)[96] #1  Foam::sigFpe::sigHandler(int)[119] #1  Foam::sigFpe::sigHandler(int) at ??:?
     at ??:?
    [94] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [75] #1  Foam::sigFpe::sigHandler(int)[79] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [83] #2  ? at ??:?
    [91] #2  ? at ??:?
    [96] #2  ? at ??:?
    [119] #2  ? at ??:?
    [90] #2  ? at ??:?
    [97] #2  ? at ??:?
    [100] #2  ? at ??:?
    [82] #2  ? at ??:?
    [78] #2  ? at ??:?
    [95] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
    [91] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&)[83] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) in "/lib/x86_64-linux-gnu/libc.so.6"
    [97] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&)[119] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
    [79] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
    [90] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) in "/lib/x86_64-linux-gnu/libc.so.6"
    [100] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&)[82] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&)[96] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
    [75] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
    [95] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
    [94] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
    [78] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
    [91] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const[79] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
     at ??:?
     at ??:?
    [97] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const[119] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [83] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const[75] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&)[90] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [82] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const[94] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
    [100] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [96] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [95] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [78] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
     at ??:?
     at ??:?
    [119] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[97] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[79] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
     at ??:?
    [90] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
    [82] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[96] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
     at ??:?
     at ??:?
    [94] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [83] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[100] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[91] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
    [78] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
    [75] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
     at ??:?
    [95] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)[79] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
    [94] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
    [97] #6   at ??:?
    [119] #6   at ??:?
    [82] #6   at ??:?
    [96] #6   at ??:?
    [90] #6   at ??:?
    [83] #6   at ??:?
    [100] #6  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
    Foam::fvMatrix<double>::solve(Foam::dictionary const&)[75] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
    [91] #6  Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
    [78] #6  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
    [97] #7   at ??:?
    [119] #7   at ??:?
    [82] #7   at ??:?
    [95] #6   at ??:?
    [79] #6   at ??:?
    [90] #7   at ??:?
    [100] #7  Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&)??? at ??:?
    [83] #7   at ??:?
    [96] #7  ?? at ??:?
    [91] #7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
    [94] #6  Foam::fvMatrix<double>::solve(Foam::dictionary const&)?? at ??:?
    [119] #8  __libc_start_main at ??:?
    [82] #8  __libc_start_main at ??:?
    [90] #8  __libc_start_main at ??:?
    [97] #8  __libc_start_main at ??:?
    [100] #8  __libc_start_main at ??:?
    [78] #7   at ??:?
    [75] #6  ? at ??:?
    [95] #7   at ??:?
    [79] #7   in "/lib/x86_64-linux-gnu/libc.so.6"
    [82] #9   in "/lib/x86_64-linux-gnu/libc.so.6"
    [119] #9   at ??:?
    [83] #8  __libc_start_main at ??:?
    [96] #8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    [97] #9   in "/lib/x86_64-linux-gnu/libc.so.6"
    [90] #9   in "/lib/x86_64-linux-gnu/libc.so.6"
    [100] #9  ?Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve(Foam::dictionary const&)?? at ??:?
    [91] #8  __libc_start_main?? in "/lib/x86_64-linux-gnu/libc.so.6"
    [83] #9  ? in "/lib/x86_64-linux-gnu/libc.so.6"
    [96] #9  ?? at ??:?
    Stan同学
    下面为后续的报错信息,辛苦各位同学和老师,感谢!!!
    [ubuntu:330341] *** Process received signal ***
     at ??:?
    [ubuntu:330453] *** Process received signal ***
    [ubuntu:330341] Signal: Floating point exception (8)
    [ubuntu:330341] Signal code:  (-6)
    [ubuntu:330341] Failing at address: 0x3e800050a65
     at ??:?
    [94] #7   at ??:?
    [78] #8  __libc_start_main[ubuntu:330341] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fcc84b7e4c0]
    [ubuntu:330341] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fcc84b7e438]
    [ubuntu:330341] [ 2] [ubuntu:330453] Signal: Floating point exception (8)
    [ubuntu:330453] Signal code:  (-6)
    [ubuntu:330453] Failing at address: 0x3e800050ad5
    [ubuntu:330453] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f6677a5d4c0]
    [ubuntu:330453] [ 1] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fcc84b7e4c0]
    [ubuntu:330341] [ 3] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f6677a5d438]
    [ubuntu:330453] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f6677a5d4c0]
    [ubuntu:330453] [ 3] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7fcc86035f1d]
    [ubuntu:330341] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7f6678f14f1d]
    [ubuntu:330453] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7fcc85e4234b]
    [ubuntu:330341] [ 5]  at ??:?
    [ubuntu:330402] *** Process received signal ***
    /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7f6678d2134b]
    [ubuntu:330453] [ 5] [ubuntu:330402] Signal: Floating point exception (8)
    [ubuntu:330402] Signal code:  (-6)
    [ubuntu:330402] Failing at address: 0x3e800050aa2
    [ubuntu:330402] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f923bdb74c0]
    [ubuntu:330402] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f923bdb7438]
    [ubuntu:330402] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f923bdb74c0]
    [ubuntu:330402] [ 3] ?/opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7fcc8855fbab]
    [ubuntu:330341] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330341] [ 7] olaFlow[0x44db4e]
    [ubuntu:330341] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fcc84b69840]
    [ubuntu:330341] [ 9] olaFlow[0x456269]
    [ubuntu:330341] *** End of error message ***
    /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7f667b43ebab]
    [ubuntu:330453] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330453] [ 7] olaFlow[0x44db4e]
    [ubuntu:330453] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f6677a48840]
    [ubuntu:330453] [ 9] olaFlow[0x456269]
    [ubuntu:330453] *** End of error message ***
    /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7f923d26ef1d]
    [ubuntu:330402] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7f923d07b34b]
    [ubuntu:330402] [ 5] ? in "/lib/x86_64-linux-gnu/libc.so.6"
    [91] #9   at ??:?
    [75] #7   at ??:?
    [95] #8  __libc_start_main/opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7f923f798bab]
    [ubuntu:330402] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330402] [ 7] olaFlow[0x44db4e]
    [ubuntu:330402] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f923bda2840]
    [ubuntu:330402] [ 9] olaFlow[0x456269]
    [ubuntu:330402] *** End of error message ***
     at ??:?
    [ubuntu:330384] *** Process received signal ***
    [ubuntu:330384] Signal: Floating point exception (8)
    [ubuntu:330384] Signal code:  (-6)
    [ubuntu:330384] Failing at address: 0x3e800050a90
    [ubuntu:330384] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f861028e4c0]
    [ubuntu:330384] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f861028e438]
    [ubuntu:330384] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f861028e4c0]
    [ubuntu:330384] [ 3]  at ??:?
    [ubuntu:330417] *** Process received signal ***
    [ubuntu:330417] Signal: Floating point exception (8)
    [ubuntu:330417] Signal code:  (-6)
    [ubuntu:330417] Failing at address: 0x3e800050ab1
    [ubuntu:330417] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f72e021f4c0]
    [ubuntu:330417] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f72e021f438]
    [ubuntu:330417] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f72e021f4c0]
    [ubuntu:330417] [ 3] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7f8611745f1d]
    [ubuntu:330384] [ 4]  at ??:?
    [79] #8  __libc_start_main/opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7f861155234b]
    [ubuntu:330384] [ 5] ?/opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7f72e16d6f1d]
    [ubuntu:330417] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7f72e14e334b]
    [ubuntu:330417] [ 5] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7f8613c6fbab]
    [ubuntu:330384] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330384] [ 7] olaFlow[0x44db4e]
    [ubuntu:330384] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f8610279840]
    [ubuntu:330384] [ 9] olaFlow[0x456269]
    [ubuntu:330384] *** End of error message ***
    [78] #9  /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7f72e3c00bab]
    [ubuntu:330417] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330417] [ 7] olaFlow[0x44db4e]
    [ubuntu:330417] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f72e020a840]
    [ubuntu:330417] [ 9] olaFlow[0x456269]
    [ubuntu:330417] *** End of error message ***
     at ??:?
    [ubuntu:330407] *** Process received signal ***
    [ubuntu:330407] Signal: Floating point exception (8)
    [ubuntu:330407] Signal code:  (-6)
    [ubuntu:330407] Failing at address: 0x3e800050aa7
     at ??:?
    [ubuntu:330316] *** Process received signal ***
    [ubuntu:330316] Signal: Floating point exception (8)
    [ubuntu:330316] Signal code:  (-6)
    [ubuntu:330316] Failing at address: 0x3e800050a4c
    [ubuntu:330407] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f7ed4e984c0]
    [ubuntu:330407] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f7ed4e98438]
    [ubuntu:330407] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f7ed4e984c0]
    [ubuntu:330407] [ 3] [ubuntu:330316] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f43261c64c0]
    [ubuntu:330316] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f43261c6438]
    [ubuntu:330316] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f43261c64c0]
    [ubuntu:330316] [ 3]  in "/lib/x86_64-linux-gnu/libc.so.6"
    [95] #9  /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7f7ed634ff1d]
    [ubuntu:330407] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7f432767df1d]
    [ubuntu:330316] [ 4] ?/opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7f7ed615c34b]
    [ubuntu:330407] [ 5] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7f432748a34b]
    [ubuntu:330316] [ 5]  in "/lib/x86_64-linux-gnu/libc.so.6"
    [79] #9  /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7f7ed8879bab]
    [ubuntu:330407] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330407] [ 7] olaFlow[0x44db4e]
    [ubuntu:330407] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f7ed4e83840]
    [ubuntu:330407] [ 9] olaFlow[0x456269]
    [ubuntu:330407] *** End of error message ***
    /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7f4329ba7bab]
    [ubuntu:330316] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330316] [ 7] olaFlow[0x44db4e]
    [ubuntu:330316] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f43261b1840]
    [ubuntu:330316] [ 9] olaFlow[0x456269]
    [ubuntu:330316] *** End of error message ***
    ?? at ??:?
    [94] #8  __libc_start_main?? at ??:?
    [ubuntu:330379] *** Process received signal ***
    [ubuntu:330379] Signal: Floating point exception (8)
    [ubuntu:330379] Signal code:  (-6)
    [ubuntu:330379] Failing at address: 0x3e800050a8b
    [ubuntu:330379] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fd834b6e4c0]
    [ubuntu:330379] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fd834b6e438]
    [ubuntu:330379] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fd834b6e4c0]
    [ubuntu:330379] [ 3]  in "/lib/x86_64-linux-gnu/libc.so.6"
    [94] #9  /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7fd836025f1d]
    [ubuntu:330379] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7fd835e3234b]
    [ubuntu:330379] [ 5]  at ??:?
    [ubuntu:330323] *** Process received signal ***
    [ubuntu:330323] Signal: Floating point exception (8)
    [ubuntu:330323] Signal code:  (-6)
    [ubuntu:330323] Failing at address: 0x3e800050a53
    [ubuntu:330323] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fdf7c7694c0]
    [ubuntu:330323] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fdf7c769438]
    [ubuntu:330323] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fdf7c7694c0]
    [ubuntu:330323] [ 3] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7fdf7dc20f1d]
    [ubuntu:330323] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7fd83854fbab]
    [ubuntu:330379] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330379] [ 7] olaFlow[0x44db4e]
    [ubuntu:330379] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fd834b59840]
    [ubuntu:330379] [ 9] olaFlow[0x456269]
    [ubuntu:330379] *** End of error message ***
    /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7fdf7da2d34b]
    [ubuntu:330323] [ 5]  at ??:?
    [75] #8  __libc_start_main/opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7fdf8014abab]
    [ubuntu:330323] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330323] [ 7] olaFlow[0x44db4e]
    [ubuntu:330323] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fdf7c754840]
    [ubuntu:330323] [ 9] olaFlow[0x456269]
    [ubuntu:330323] *** End of error message ***
    ? at ??:?
    [ubuntu:330389] *** Process received signal ***
    [ubuntu:330389] Signal: Floating point exception (8)
    [ubuntu:330389] Signal code:  (-6)
    [ubuntu:330389] Failing at address: 0x3e800050a95
     at ??:?
    [ubuntu:330311] *** Process received signal ***
    [ubuntu:330311] Signal: Floating point exception (8)
    [ubuntu:330311] Signal code:  (-6)
    [ubuntu:330311] Failing at address: 0x3e800050a47
    [ubuntu:330311] [ 0] [ubuntu:330389] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fe3de54b4c0]
    [ubuntu:330389] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fe3de54b438]
    [ubuntu:330389] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fe3de54b4c0]
    [ubuntu:330389] [ 3] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fa2535b84c0]
    [ubuntu:330311] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fa2535b8438]
    [ubuntu:330311] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fa2535b84c0]
    [ubuntu:330311] [ 3] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7fe3dfa02f1d]
    [ubuntu:330389] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7fa254a6ff1d]
    [ubuntu:330311] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7fa25487c34b]
    [ubuntu:330311] [ 5] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7fe3df80f34b]
    [ubuntu:330389] [ 5] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7fa256f99bab]
    [ubuntu:330311] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330311] [ 7] olaFlow[0x44db4e]
    [ubuntu:330311] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fa2535a3840]
    [ubuntu:330311] [ 9] olaFlow[0x456269]
    [ubuntu:330311] *** End of error message ***
    /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7fe3e1f2cbab]
    [ubuntu:330389] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330389] [ 7] olaFlow[0x44db4e]
    [ubuntu:330389] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fe3de536840]
    [ubuntu:330389] [ 9] olaFlow[0x456269]
    [ubuntu:330389] *** End of error message ***
    [75] #9  [93] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [ubuntu:330400] *** Process received signal ***
    [ubuntu:330400] Signal: Floating point exception (8)
    [ubuntu:330400] Signal code:  (-6)
    [ubuntu:330400] Failing at address: 0x3e800050aa0
    [ubuntu:330400] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7ff1e15af4c0]
    [ubuntu:330400] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7ff1e15af438]
    [ubuntu:330400] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7ff1e15af4c0]
    [ubuntu:330400] [ 3] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7ff1e2a66f1d]
    [ubuntu:330400] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7ff1e287334b]
    [ubuntu:330400] [ 5] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7ff1e4f90bab]
    [ubuntu:330400] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330400] [ 7] olaFlow[0x44db4e]
    [ubuntu:330400] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7ff1e159a840]
    [ubuntu:330400] [ 9] olaFlow[0x456269]
    [ubuntu:330400] *** End of error message ***
    ? at ??:?
    [ubuntu:330305] *** Process received signal ***
    [ubuntu:330305] Signal: Floating point exception (8)
    [ubuntu:330305] Signal code:  (-6)
    [ubuntu:330305] Failing at address: 0x3e800050a41
    [ubuntu:330305] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fac1b5164c0]
    [ubuntu:330305] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fac1b516438]
    [ubuntu:330305] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7fac1b5164c0]
    [ubuntu:330305] [ 3] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7fac1c9cdf1d]
    [ubuntu:330305] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7fac1c7da34b]
    [ubuntu:330305] [ 5] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7fac1eef7bab]
    [ubuntu:330305] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330305] [ 7] olaFlow[0x44db4e]
    [ubuntu:330305] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fac1b501840]
    [ubuntu:330305] [ 9] olaFlow[0x456269]
    [ubuntu:330305] *** End of error message ***
    [109] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [93] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [93] #2  ? at ??:?
    [109] #1  Foam::sigFpe::sigHandler(int) in "/lib/x86_64-linux-gnu/libc.so.6"
    [93] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
    [109] #2  ? at ??:?
    [93] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/lib/x86_64-linux-gnu/libc.so.6"
    [109] #3  double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
    [93] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
    [109] #4  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    [109] #5  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
    [93] #6  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
    [93] #7   at ??:?
    [109] #6  ?Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
    [93] #8  __libc_start_main at ??:?
    [109] #7  ? in "/lib/x86_64-linux-gnu/libc.so.6"
    [93] #9  --------------------------------------------------------------------------
     at ??:?
    [109] #8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    [109] #9  ? at ??:?
    [ubuntu:330431] *** Process received signal ***
    ? at ??:?
    [ubuntu:330390] *** Process received signal ***
    [ubuntu:330431] Signal: Floating point exception (8)
    [ubuntu:330431] Signal code:  (-6)
    [ubuntu:330431] Failing at address: 0x3e800050abf
    [ubuntu:330431] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f9bda55a4c0]
    [ubuntu:330431] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f9bda55a438]
    [ubuntu:330431] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f9bda55a4c0]
    [ubuntu:330431] [ 3] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7f9bdba11f1d]
    [ubuntu:330431] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7f9bdb81e34b]
    [ubuntu:330431] [ 5] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7f9bddf3bbab]
    [ubuntu:330431] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330431] [ 7] olaFlow[0x44db4e]
    [ubuntu:330431] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f9bda545840]
    [ubuntu:330431] [ 9] olaFlow[0x456269]
    [ubuntu:330431] *** End of error message ***
    [ubuntu:330390] Signal: Floating point exception (8)
    [ubuntu:330390] Signal code:  (-6)
    [ubuntu:330390] Failing at address: 0x3e800050a96
    [ubuntu:330390] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f944a96c4c0]
    [ubuntu:330390] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7f944a96c438]
    [ubuntu:330390] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354c0)[0x7f944a96c4c0]
    [ubuntu:330390] [ 3] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7sumProdIdEEdRKNS_5UListIT_EES5_+0x2d)[0x7f944be23f1d]
    [ubuntu:330390] [ 4] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam3PCG5solveERNS_5FieldIdEERKS2_h+0xb0b)[0x7f944bc3034b]
    [ubuntu:330390] [ 5] /opt/OpenFOAM-5.0/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0x15b)[0x7f944e34dbab]
    [ubuntu:330390] [ 6] olaFlow(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x191)[0x4db5f1]
    [ubuntu:330390] [ 7] olaFlow[0x44db4e]
    [ubuntu:330390] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7f944a957840]
    [ubuntu:330390] [ 9] olaFlow[0x456269]
    [ubuntu:330390] *** End of error message ***
    mpirun noticed that process rank 95 with PID 0 on node ubuntu exited on signal 8 (Floating point exception).
