  4. 速度残差
速度残差
3 帖子 2 发布者 4.6k 浏览
    hongjiewang
    写于 最后由 hongjiewang 编辑
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 1.00985e-16, No Iterations 15
    smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 1.07542e-16, No Iterations 15
    请问我求解算例的时候,发现速度的第一次迭代残差都是1。
    我用相同的求解器跑了其他的算例,速度的第一次残差也是0.1的量级。
    请问如何优化这种问题~
    第一次是1没问题。0.1也没问题。这非常正常。不需要优化。
    H 1 条回复 最后回复
    hongjiewang
    @李东岳 谢谢老师回复~
    老师可以帮我看一下这个错误怎么修改吗,按照您之前的一个帖子,定义了一个随时间变化的热流边界~
        HEATED
            type       externalWallHeatFluxTemperature;
            mode     flux;
            q            coded;       // Heat flux
            code
                 scalar q=*this;
                 scalar t = this->db().time().value();
                 if(t >= 0 && t<=1.5)
                      q = 180000;
                 else if(t<=3)
    	          q = 200000;
    	     else if(t<=4.5)
    	          q = 250000;
    	     else if(t<=6)
    	          q = 300000;
    	     else
    	          q = 0;
    	     q.writeEntry("", os);
            value           uniform 300;
            kappaMethod     lookup;
            kappa           "K";
    /home/dyfluid/OpenFOAM/dyfluid-v2006/run/bianhuaQ/0/SOLID/T.boundaryField.HEATED:32:23: error: cannot convert ‘const Foam::PatchFunction1Types::qPatchFunction1ScalarField’ to ‘Foam::scalar’ {aka ‘double’} in initialization
    /home/dyfluid/OpenFOAM/dyfluid-v2006/run/bianhuaQ/0/SOLID/T.boundaryField.HEATED:33:31: error: ‘const class Foam::PatchFunction1Types::qPatchFunction1ScalarField’ has no member named ‘db’
    /home/dyfluid/OpenFOAM/dyfluid-v2006/run/bianhuaQ/0/SOLID/T.boundaryField.HEATED:55:9: error: request for member ‘writeEntry’ in ‘q’, which is of non-class type ‘Foam::scalar’ {aka ‘double’}
    /home/dyfluid/OpenFOAM/dyfluid-v2006/run/bianhuaQ/0/SOLID/T.boundaryField.HEATED:55:24: error: ‘os’ was not declared in this scope; did you mean ‘cos’?
