  4. rhoPimpleFoam计算飞机跑几步就发散
4 帖子 3 发布者 5.8k 浏览
  • 好 离线
    好 离线
    好好科研
    各位大佬,我参考文献 3rd High-Lift Workshop Summary Paper - OpenFOAM, STAR-CCM+ & LAVA simulations on Unstructured Grids链接https://arc.aiaa.org/doi/10.2514/6.2018-1253。用rhoPimpleFoam计算飞机,但是算了几步就发散了,希望各位大佬帮忙看看是fvSchemes和fvSolution的问题嘛,还是nut、nuTilda设置的问题。
    目前用的是作者上传到会议网站的网格,按照文章里说的,采用的是SA模型,以及动量和湍流项采用的是二阶迎风。
    Courant Number mean: 1.4881475e-08 max: 1.8237221
    Time = 3.2e-09
    * PIMPLE: Iteration 1
    DILUPBiCGStab:  Solving for Ux, Initial residual = 2.421018e-11, Final residual = 2.421018e-11, No Iterations 0
    DILUPBiCGStab:  Solving for Uy, Initial residual = 2.1538356e-10, Final residual = 2.1538356e-10, No Iterations 0
    DILUPBiCGStab:  Solving for Uz, Initial residual = 2.0979924e-10, Final residual = 2.0979924e-10, No Iterations 0
    DILUPBiCGStab:  Solving for e, Initial residual = 4.1760218e-08, Final residual = 2.1963671e-13, No Iterations 1
    GAMG:  Solving for p, Initial residual = 7.5844072e-07, Final residual = 7.5844072e-07, No Iterations 0
    time step continuity errors : sum local = 5.0250634e-11, global = 5.0210593e-11, cumulative = 3.7505015e-09
    GAMG:  Solving for p, Initial residual = 7.5844071e-07, Final residual = 7.5844071e-07, No Iterations 0
    time step continuity errors : sum local = 5.0250633e-11, global = 5.0210593e-11, cumulative = 3.8007121e-09
    PIMPLE: Iteration 2
    DILUPBiCGStab:  Solving for Ux, Initial residual = 1.3321419e-08, Final residual = 1.002751e-14, No Iterations 1
    DILUPBiCGStab:  Solving for Uy, Initial residual = 6.2117311e-09, Final residual = 6.2117311e-09, No Iterations 0
    DILUPBiCGStab:  Solving for Uz, Initial residual = 1.4225061e-10, Final residual = 1.4225061e-10, No Iterations 0
    DILUPBiCGStab:  Solving for e, Initial residual = 1.5129023e-07, Final residual = 2.4037934e-13, No Iterations 1
    GAMG:  Solving for p, Initial residual = 1.5142431e-06, Final residual = 1.5142431e-06, No Iterations 0
    time step continuity errors : sum local = 1.0032647e-10, global = 1.0025895e-10, cumulative = 3.900971e-09
    time step continuity errors : sum local = 1.0032647e-10, global = 1.0025895e-10, cumulative = 4.00123e-09
    PIMPLE: Iteration 3
    DILUPBiCGStab:  Solving for Ux, Initial residual = 2.4133e-08, Final residual = 2.8587861e-14, No Iterations 1
    DILUPBiCGStab:  Solving for Uy, Initial residual = 1.1420948e-08, Final residual = 1.9949995e-14, No Iterations 1
    DILUPBiCGStab:  Solving for Uz, Initial residual = 1.4399722e-10, Final residual = 1.4399722e-10, No Iterations 0
    DILUPBiCGStab:  Solving for e, Initial residual = 1.3956424e-07, Final residual = 2.3199397e-13, No Iterations 1
    [73] #0  Foam::error::printStack(Foam::Ostream&)sh: addr2line: command not found
     addr2line failed
    [73] #1  Foam::sigFpe::sigHandler(int)sh: addr2line: command not found
     addr2line failed
    [73] #2  ?sh: addr2line: command not found
     addr2line failed
    [73] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate()sh: addr2line: command not found
     addr2line failed
    [73] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct()sh: addr2line: command not found
     addr2line failed
    [73] #5  ?sh: addr2line: command not found
     addr2line failed
    [73] #6  __libc_start_mainsh: addr2line: command not found
     addr2line failed
    [73] #7  ?sh: addr2line: command not found
     addr2line failed
    Fatal error in PMPI_Waitall: Unknown error class, error stack:
    PMPI_Waitall(405).....................: MPI_Waitall(count=40, req_array=0x3c75cd0, status_array=0x1) failed
    MPIR_Waitall_impl(181)................: fail failed
    MPIDU_Complete_posted_with_error(1710): Process failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=22, req_array=0x3966230, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=52, req_array=0x304c450, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=46, req_array=0x355b680, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=36, req_array=0x3dfabb0, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=40, req_array=0x349e540, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=26, req_array=0x3bd5ce0, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=12, req_array=0x3f18790, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=18, req_array=0x3f97b30, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=14, req_array=0x345ac20, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=32, req_array=0x3df8960, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=28, req_array=0x4316400, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=28, req_array=0x2fe0f30, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=50, req_array=0x3a36c60, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=24, req_array=0x3f6c5f0, status_array=0x1) failed
    PMPI_Waitall(405).....................: MPI_Waitall(count=24, req_array=0x520edf0, status_array=0x1) failed
    slurmd[cn10696]: *** STEP 17962804.0 KILLED AT 2021-12-21T17:17:15 WITH SIGNAL 9 ***
    slurmd[cn10696]: *** STEP 17962804.0 KILLED AT 2021-12-21T17:17:16 WITH SIGNAL 9 ***
    fvSchmes
    ddtSchemes
        default         Euler;
    gradSchemes
        default         Gauss linear;
        limited         cellLimited Gauss linear 1;
        grad(U)         $limited;
        grad(k)         $limited;
        grad(omega)     $limited;
    divSchemes
        default         none;
        div(phi,U)      Gauss linearUpwind grad(U);//Gauss linearUpwind limited;
        turbulence      Gauss linearUpwind default;//Gauss linearUpwind limited;
        energy          Gauss linearUpwind default;//Gauss linearUpwind limited;
        div(phi,k)      $turbulence;
        div(phi,omega)  $turbulence;
        div(phi,e)      $energy;
        div(phi,K)      $energy;
        div(phi,Ekp)    $energy;
        div(phi,nuTilda)  $energy;
        div(phiv,p)     Gauss upwind;
        div((phi|interpolate(rho)),p) Gauss upwind;
        div(((rho*nuEff)*dev2(T(grad(U)))))    Gauss linear;
    laplacianSchemes
        default         Gauss linear limited 0.5;//Gauss linear corrected;
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         limited 0.5;//corrected;
    wallDist
        method meshWave;
    fvSolution
    solvers
        p
            solver          GAMG;
            smoother        GaussSeidel;
            tolerance       1e-5;
            relTol          0.01;
    		nPreSweeps      0;
    		nPostSweeps     2;
    		cacheAgglomeration  on;
    		agglomerator      faceAreaPair;
    		ncellsInCoarsetLevel      1000;
    		mergeLevels          1;
        pFinal
            $p;
            relTol          0;
        "(rho|U|k|omega|e)"
            solver          PBiCGStab;
            preconditioner  DILU;
            tolerance       1e-8;
            relTol          0.0;
        "(rho|U|k|omega|e|nuTilda)Final"
            $U;
            relTol          0;
    SIMPLE
        residualControl
            p               1e-5;
            U               1e-5;
            "(k|omega|e)"   1e-5;
        nNonOrthogonalCorrectors 3;
        pMinFactor      0.1;
        pMaxFactor      2;
    PIMPLE
        nCorrectors              2;
        nOuterCorrectors         3;
        pMinFactor      0.1;
        pMaxFactor      2;
    relaxationFactors
    	p       0.3;
    	U       0.7;
    	k       0.7;
    	omega   0.7;
    nut
    internalField   uniform 0;
    boundaryField
        freestream
            type            calculated;
            value           uniform 0;
        wall
            value           uniform 0;
        #includeEtc "caseDicts/setConstraintTypes"
    nuTilda
    boundaryField
        freestream
            type            inletOutlet;
            inletValue      $internalField;
        wall
            type            fixedValue;
            value           uniform 0;
        symmetry
            type            symmetry;
    CT
    请问解决了吗?我也遇到这个问题了
    如果网格小的话,可以把算例上传我试试
    http://dyfluid.com/openfoam.html
    CT
    看不出具体原因,只能一步一步排查,最后减小时间步长,可以运行.
