  4. ICEM里面的网格包含INTERFACE转换问题
4 帖子 2 发布者 4.4k 浏览
    zzq704
    请问各位老师和同学,在ICEM里面分块画的网格,所以包含interface,在openfoam里面打算用cyclicAMI面来设置。但用createPatch -overwrite命令的时候为什么出了下面的错误。
    nm@nm:~/OpenFOAM/nm/cavityceshi2/cavity$ createPatch -overwrite
        \\  /    A nd           | Version:  9
         \\/     M anipulation  |
    Build  : 9-710dba47639b
    Exec   : createPatch -overwrite
    Date   : Mar 15 2022
    Time   : 17:40:27
    Host   : "nm"
    PID    : 9550
    I/O    : uncollated
    Case   : /home/nm/OpenFOAM/nm/cavityceshi2/cavity
    nProcs : 1
    Create time
    Create polyMesh for time = 0
    Reading "createPatchDict"
    Adding new patch IF1 as patch 7 from
        type            cyclicAMI;
        neighbourPatch  IF2;
        transform       noOrdering;
    --> FOAM FATAL ERROR:
    noOrdering not found in table.  Valid entries:
    4
    unspecified
    rotational
    none
    translational
        From function const T& Foam::HashTable<T, Key, Hash>::operator[](const Key&) const [with T = unsigned int; Key = Foam::word; Hash = Foam::string::hash]
        in file lnInclude/HashTableI.H at line 126.
    FOAM exiting
    Z 1 条回复 最后回复
    zzq704
    在 中回复了 zzq704 最后由 李东岳 编辑
    这是我的createPatchDict文件。
    |  \\    /   O peration     | Version:  5                                     |
        version     2.0;
        format      ascii;
        class       dictionary;
        object      createPatchDict;
    pointSync false;
    patches
            name IF1;        //交界面的名字
            patchInfo
                type             cyclicAMI;        //交界面类型
                neighbourPatch   IF2;           //与之相匹配的交界面名字
            constructFrom        patches;          //使用patches的方法创建cyclicAMI
            patches              (INTERFACE2);    //patches的名字
            name IF2;
            patchInfo
                type             cyclicAMI;
                neighbourPatch   IF1;
            patches              (INTERFACE2.1);
    把你的noOrdering改成none,估计你这个openfoam版本用的不一样
    Z 1 条回复 最后回复
    zzq704
    好的,我试试。感谢回复:146:
