  3. CFD彩虹条
  4. [全奖博士招生] 英国谢菲尔德大学CFD方向全奖博士招生 (化工/多相流/传热传质)
已定时 已固定 已锁定 已移动 CFD彩虹条
1 帖子 1 发布者 2.7k 浏览
  • P 离线
    P 离线
    Peng
    写于 最后由 Peng 编辑
    英国谢菲尔德大学(The University of sheffield)Energy2050团队(http://energy2050.ac.uk)在招一个做CFD方向的全奖博士,做旋转填料床反应器捕捉二氧化碳的CFD仿真研究,对此职位感兴趣的研究生或者优秀本科毕业生可以申请(可直博),目前的申请截止日期是2022年7月22日(可能推迟),如来不及,入学时间可推迟到明年一月。
    谢菲尔德大学,世界百强名校,著名的CFD仿真软件Fluent的发源地,课题组学术氛围很好,适合静心搞科研。课题组在CFD领域有几十年的研究基础,在CCUS领域有丰富的研究资源,课题紧扣国内火热的"双碳"主题,该细分方向组里有7年的研究基础了,可以在前人的基础上接着做。
    具体招聘信息如下:
    We have a fully funded PhD studentship and look for applicants open to both UK and international students: Engineering doctorate (EngD): Predicting performance of intensified carbon capture inside rotating packed beds using CFD modelling
    If you know any good students from China, or the UK, please encourage them to apply.
    Any questions then let them to contact Professor Lin Ma: https://www.sheffield.ac.uk/mecheng/people/academic/lin-ma
    The advert is on findaphd.com: https://www.findaphd.com, search for the project 搜索 predicting performance of intensified carbon capture inside rotating packed beds using cfd modelling。
    或直接通过以下链接:https://www.findaphd.com/phds/project/engineering-doctorate-engd-predicting-performance-of-intensified-carbon-capture-inside-rotating-packed-beds-using-cfd-modelling/?p145128#opennewwindow
    Please make sure that they apply through the university of sheffield website: https://www.sheffield.ac.uk/postgraduate/phd/apply/applying.
    课题介绍:
    Carbon capture is considered the only technology able to decarbonise the hard-to-abate industries. many of these industries utilise legacy sites with little space for large new unit operations required in conventional carbon capture. rotating packed beds (RPB) look to solve this problem by intensifying carbon capture and reducing the footprint required by up to ten times, while also significantly decreasing the capital cost of these units. when combined with proprietary solvents, it is believed the cost of capture can be reduced to $30/tonne CO2 in some cases, helping to enable the rapid uptake of carbon capture and progression towards net zero.
    RPB are a novel technology that utilise the principles of process intensification to enhance the performance of mass transfer processes between fluids. given the application of rpb to the field of CO2 capture is relatively new, there is uncertainty regarding the impact of different process variables on the performance of the rpb that would otherwise require a significant amount of practical experimentation to investigate. computational fluid dynamics can enable the process to be accurately modelled, allowing for quick and inexpensive prediction of performance under various conditions.
    In this project a rotating packed bed absorber will be modelled in ansys fluent, with validation of the model’s outputs through use of the 1 tonnes of co2 per day (TPD) pilot-scale rotating packed bed absorber at the university of sheffield’s translational energy research centre. Initial research will involve investigating the impact of operational conditions and physical properties of the solvent on capture performance. As the project continues, the scope will widen to include sensitivity analysis of design parameters and the impact of scaling the RPB absorber on the existing project outputs and learnings. Additionally, further rotating unit operations could also be investigated.
    This project will utilise and develop your knowledge surrounding CFD modelling, mass and heat transfer, reaction kinetics and chemical equilibria. You will work closely with carbon clean, a global leader in the development of carbon capture technology and pioneers in the use of RPB for industrial decarbonisation. Your findings could directly impact the design and operation of commercial working carbon capture facilities, supporting the pathway to net zero.
    We are seeking applicants to start in september 2022.
    The project will be part of the EPSRC-supported centre for doctoral training in resilient decarbonised fuel energy systems. The student who undertakes it will be one of a cohort of over 50 students in a broad range of disciplines across the universities of sheffield, nottingham and cardiff.
    The research work will be based in the energy research group within the department of mechanical engineering and the translational energy research centre (TERC) at sheffield which is a brand new, high profile, innovation focused national research facility. You will be working within an exciting and dynamic group with approximately over 60 researchers undertaking a broad area of energy research with approximately three years' extensive research time in industry, preparing for high-level careers in the energy sector.
    Funding notes
    The studentship will cover full university fees and a tax-free, enhanced annual stipend of £20,352, including £16,062 (2022/2023) a year for four years and a stipend enhancement of £3,750 per annum.
    英国的全奖机会非常少,机会难得,欢迎各位优秀的CFDer申请!
