  4. OpenFOAM中的pout与reduce
1 帖子 1 发布者 1.8k 浏览
       \\    /   O peration     |
        \\  /    A nd           | Copyright (C) 2011-2015 OpenFOAM Foundation
         \\/     M anipulation  |
    License
        This file is part of OpenFOAM.
        OpenFOAM is free software: you can redistribute it and/or modify it
        under the terms of the GNU General Public License as published by
        the Free Software Foundation, either version 3 of the License, or
        (at your option) any later version.
        OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
        ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
        FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
        for more details.
        You should have received a copy of the GNU General Public License
        along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
    #include "fvCFD.H"
        #include "setRootCase.H"
        #include "createTime.H"
        #include "createMesh.H"
        // For a case being run in parallel, the domain is decomposed into several
        // processor meshes. Each of them is run in a separate process and holds
        // instances of objects like mesh, U or p just as in a single-threaded (serial)
        // computation. These will have different sizes, of course, as they hold
        // fewer elements than the whole, undecomposed, mesh.
        // Pout is a stream to which each processor can write, unlike Info which only
        // gets used by the head process (processor0)
        Pout << "Hello from processor " << Pstream::myProcNo() << "! I am working on "
             << mesh.C().size() << " cells" << endl;
        // To exchange information between processes, special OpenMPI routines need
        // to be called.
        // This goes over each cell in the subdomain and integrates their volume.
        scalar meshVolume(0.);
        forAll(mesh.V(),cellI)
            meshVolume += mesh.V()[cellI];
        // Add the values from all processes together
        Pout << "Mesh volume on this processor: " << meshVolume << endl;
        reduce(meshVolume, sumOp<scalar>());
        Info << "Total mesh volume on all processors: " << meshVolume
            // Note how the reudction operation may be done in place without defning
            // a temporary variable, where appropriate.
             << " over " << returnReduce(mesh.C().size(), sumOp<label>()) << " cells" << endl;
        // During the reduction stage, different operations may be carried out, summation,
        // described by the sumOp template, being one of them.
        // Other very useful operations are minOp and maxOp.
        // Note how the type
        // of the variable must be added to make an instance of the template, here
        // this is done by adding <scalar> in front of the brackets.
        // Custom reduction operations are easy to implement but need fluency in
        // object-oriented programming in OpenFOAM, so we'll skip this for now.
        // Spreading a value across all processors is done using a scatter operation.
        Pstream::scatter(meshVolume);
        Pout << "Mesh volume on this processor is now " << meshVolume << endl;
        // It is often useful to check the distribution of something across all
        // processors. This may be done using a list, with each element of it
        // being written to by only one processor.
        List<label> nInternalFaces (Pstream::nProcs()), nBoundaries (Pstream::nProcs());
        nInternalFaces[Pstream::myProcNo()] = mesh.Cf().size();
        nBoundaries[Pstream::myProcNo()] = mesh.boundary().size();
        // The list may then be gathered on the head node as
        Pstream::gatherList(nInternalFaces);
        Pstream::gatherList(nBoundaries);
        // Scattering a list is also possbile
        Pstream::scatterList(nInternalFaces);
        Pstream::scatterList(nBoundaries);
        // It can also be useful to do things on the head node only
        // (in this case this is meaningless since we are using Info, which already
        // checks this and executes on the head node).
        // Note how the gathered lists hold information for all processors now.
        if (Pstream::master())
            forAll(nInternalFaces,i)
                Info << "Processor " << i << " has " << nInternalFaces[i]
                     << " internal faces and " << nBoundaries[i] << " boundary patches" << endl;
        // As the mesh is decomposed, interfaces between processors are turned
        // into patches, meaning each subdomain sees a processor boundary as a
        // boundary condition.
        forAll(mesh.boundary(),patchI)
            Pout << "Patch " << patchI << " named " << mesh.boundary()[patchI].name() << endl;
        // When looking for processor patches, it is useful to check their type,
        // similarly to how one can check if a patch is of empty type
            const polyPatch& pp = mesh.boundaryMesh()[patchI];
            if (isA<processorPolyPatch>(pp))
                     << " is definitely a processor boundary!" << endl;
        // this is an example implementation of the code from tutoral 2 which
        // has been adjusted to run in parallel. Each difference is highlighted
        // as a NOTE.
        // It is conventional in OpenFOAM to move large parts of code to separate
        // .H files to make the code of the solver itself more readable. This is not
        // a standard C++ practice, as header files are normally associated with
        // declarations rather than definitions.
        // A very common include, apart from the setRootCase, createTime, and createMesh,
        // which are generic, is createFields, which is often unique for each solver.
        // Here we've moved all of the parts of the code dealing with setting up the fields
        // and transport constants into this include file.
        #include "createFields.H"
        // pre-calculate geometric information using field expressions rather than
        // cell-by-cell assignment.
        const dimensionedVector originVector("x0", dimLength, vector(0.05,0.05,0.005));
        volScalarField r (mag(mesh.C()-originVector));
        // NOTE: we need to get a global value; convert from dimensionedScalar to scalar
        const scalar rFarCell = returnReduce(max(r).value(), maxOp<scalar>());
        scalar f (1.);
        Info<< "\nStarting time loop\n" << endl;
        while (runTime.loop())
            Info<< "Time = " << runTime.timeName() << nl << endl;
            // assign values to the field;
            // sin function expects a dimensionless argument, hence need to convert
            // current time using .value().
            // r has dimensions of length, hence the small value being added to it
            // needs to match that.
            // Finally, the result has to match dimensions of pressure, which are
            // m^2 / s^-2/
            p = Foam::sin(2.*constant::mathematical::pi*f*runTime.time().value())
                / (r/rFarCell + dimensionedScalar("small", dimLength, 1e-12))
                * dimensionedScalar("tmp", dimensionSet(0, 3, -2, 0, 0), 1.);
            // NOTE: this is needed to update the values on the processor boundaries.
            // If this is not done, the gradient operator will get confused around the
            // processor patches.
            p.correctBoundaryConditions();
            // calculate velocity from gradient of pressure
            U = fvc::grad(p)*dimensionedScalar("tmp", dimTime, 1.);
            runTime.write();
        Info<< "End\n" << endl;
        return 0;
