  4. openfoam运行报错
openfoam运行报错
4 帖子 3 发布者 5.8k 浏览
    SHUKK
    我使用的codedfixedvalue对非均匀速度场进行编程,但是用simpleFoam运算时候,出现了无法运行的错误。有人遇到过这种情况吗?
    [15] [14] #0  Foam::error::printStack(Foam::Ostream&)#0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [14] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [15] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [14] #2  ? at ??:?
    [15] #2  ? in /lib64/libpthread.so.0
    [14] #3  ? in /lib64/libm.so.6
    [14] #4  Foam::uinletFixedValueFvPatchVectorField::updateCoeffs() in /lib64/libpthread.so.0
    [15] #3  ? in /lib64/libm.so.6
    [15] #4  Foam::uinletFixedValueFvPatchVectorField::updateCoeffs() at ~/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/UListI.H:251
    [14] #5  Foam::codedFixedValueFvPatchField<Foam::Vector<double> >::updateCoeffs() at ~/OpenFOAM/OpenFOAM-v2012/src/OpenFOAM/lnInclude/UListI.H:251
    [15] #5  Foam::codedFixedValueFvPatchField<Foam::Vector<double> >::updateCoeffs() at ??:?
    [14] #6  Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:?
    [14] #7   at ??:?
    [15] #6  ?Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:?
    [14] #8   at ??:?
    [15] #7  ?? at ??:?
    [15] #8   at ??:?
    [14] #9  __libc_start_main? in /lib64/libc.so.6
    [14] #10   at ??:?
    [15] #9  __libc_start_main? in /lib64/libc.so.6
    [15] #10   at ??:?
    [hpws15:115156] *** Process received signal ***
    [hpws15:115156] Signal: Floating point exception (8)
    [hpws15:115156] Signal code:  (-6)
    [hpws15:115156] Failing at address: 0x3ea0001c1d4
    [hpws15:115156] [ 0] /lib64/libpthread.so.0(+0xf630)[0x7f4ef7e2d630]
    [hpws15:115156] [ 1] /lib64/libpthread.so.0(raise+0x2b)[0x7f4ef7e2d4fb]
    [hpws15:115156] [ 2] /lib64/libpthread.so.0(+0xf630)[0x7f4ef7e2d630]
    [hpws15:115156] [ 3] /lib64/libm.so.6(+0x7750)[0x7f4ef8258750]
    [hpws15:115156] [ 4] /home/user3/LFK/RANS/321/dynamicCode/platforms/linux64Gcc72DPInt32Opt/lib/libuinlet_054614152f293d9b8c67805883eace4adb3f1d70.so(_ZN4Foam34uinletFixedValueFvPatchVectorField12updateCoeffsEv+0x5b)[0x7f4ed4cae64b]
    [hpws15:115156] [ 5] /home/user3/OpenFOAM/OpenFOAM-v2012/platforms/linux64Gcc72DPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam27codedFixedValueFvPatchFieldINS_6VectorIdEEE12updateCoeffsEv+0x3d)[0x7f4efca8cafd]
    [hpws15:115156] [ 6] simpleFoam(_ZN4Foam8fvMatrixINS_6VectorIdEEEC1ERKNS_14GeometricFieldIS2_NS_12fvPatchFieldENS_7volMeshEEERKNS_12dimensionSetE+0x33c)[0x4478ac]
    [hpws15:115156] [ 7] simpleFoam[0x447a0a]
    [hpws15:115156] [ 8] simpleFoam[0x4260ca]
    [hpws15:115156] [ 9] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f4ef7a72555]
    [hpws15:115156] [10] simpleFoam[0x42868a]
    [hpws15:115156] *** End of error message ***
    ? at ??:?
    [hpws15:115157] *** Process received signal ***
    [hpws15:115157] Signal: Floating point exception (8)
    [hpws15:115157] Signal code:  (-6)
    [hpws15:115157] Failing at address: 0x3ea0001c1d5
    [hpws15:115157] [ 0] /lib64/libpthread.so.0(+0xf630)[0x7ff13139c630]
    [hpws15:115157] [ 1] /lib64/libpthread.so.0(raise+0x2b)[0x7ff13139c4fb]
    [hpws15:115157] [ 2] /lib64/libpthread.so.0(+0xf630)[0x7ff13139c630]
    [hpws15:115157] [ 3] /lib64/libm.so.6(+0x7750)[0x7ff1317c7750]
    [hpws15:115157] [ 4] /home/user3/LFK/RANS/321/dynamicCode/platforms/linux64Gcc72DPInt32Opt/lib/libuinlet_054614152f293d9b8c67805883eace4adb3f1d70.so(_ZN4Foam34uinletFixedValueFvPatchVectorField12updateCoeffsEv+0x5b)[0x7ff10e03364b]
    [hpws15:115157] [ 5] /home/user3/OpenFOAM/OpenFOAM-v2012/platforms/linux64Gcc72DPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam27codedFixedValueFvPatchFieldINS_6VectorIdEEE12updateCoeffsEv+0x3d)[0x7ff135ffbafd]
    [hpws15:115157] [ 6] simpleFoam(_ZN4Foam8fvMatrixINS_6VectorIdEEEC1ERKNS_14GeometricFieldIS2_NS_12fvPatchFieldENS_7volMeshEEERKNS_12dimensionSetE+0x33c)[0x4478ac]
    [hpws15:115157] [ 7] simpleFoam[0x447a0a]
    [hpws15:115157] [ 8] simpleFoam[0x4260ca]
    [hpws15:115157] [ 9] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7ff130fe1555]
    [hpws15:115157] [10] simpleFoam[0x42868a]
    [hpws15:115157] *** End of error message ***
    mpirun noticed that process rank 15 with PID 0 on node hpws15 exited on signal 8 (Floating point exception).
    codedfixedvalue怎么写的
    SHUKK
    @李东岳李东岳老师,我看编写应该是没有问题的
    k
           value           uniform 0.375; //default value
           name            kinlet; //name of new BC type
           code
               const fvPatch& boundaryPatch = this->patch();
               scalarField& vf = *this;
               forAll(vf, i)
                   scalar z = boundaryPatch.Cf()[i].y();
                   scalar D1 = -1.061;
                   scalar D2 = 5.744;
                   scalar alpha = 0.25;
                   vf[i] = sqrt(D1*pow(z*400, alpha) + D2);
    omega
            value           uniform 0.1; //default value
            name            omegainlet; //name of new BC type
            code
                forAll(vf, i)
                    scalar ur = 11.0;
                    scalar Cmu = 0.06;
                    scalar zr = 160;
                    scalar u = ur*pow(z*400/zr, alpha);
                    vf[i] = (alpha/sqrt(Cmu))*u/z;
    u
            value           uniform (0 0 0); //default value
            name            uinlet; //name of new BC type
            code
                vectorField& vf = *this;
                forAll(vf, i)
                    //scalar uStar = 0.511;
                    //scalar z0 = 2.25e-4;
                    //scalar kappa = 0.42;
                    //vf[i].x() = uStar/kappa*log((z + z0)/z0);
                    //vf[i].y() = 0.0;
                    //vf[i].z() = 0.0;
                    scalar ur = 11.0;
                    scalar zr = 160;
                    vf[i].x() = ur*pow(z*400/zr, alpha);
                    vf[i].y() = 0.0;
                    vf[i].z() = 0.0;
    hh
    你好,你这个问题解决了吗?
