  4. 3200万网格算例测试(ANSYS Fluent版本)
8 帖子 2 发布者 11.4k 浏览
  • B 离线
    B 离线
    BINFeng
    算例文件下载地址 https://pan.baidu.com/s/1Y3TEk31at763xwD7pyCsTQ?pwd=v3tv
  • B 离线
    B 离线
    BINFeng
    测试设备NVIDIA DGX-1 8xV100 32GB
    CPU:8/40 2x Xeon E5 2698 v4
    GPU:Nvidia Tesla V100 x8
    超线程:关闭
    RAM:500GB
    系统:Ubuntu 20.04 LTS
    Fluent版本:Fluent 2023R1 Linux64
    打开Native GPU 模式
    GPU数量:8
    迭代步数:40
    Performance Timer for 40 iterations on 8 compute nodes
      Average wall-clock time per iteration:                0.748 sec
      Global reductions per iteration:                          0 ops
      Global reductions time per iteration:                 0.000 sec (0.0%)
      Message count per iteration:                              0 messages
      Data transfer per iteration:                          0.000 MB
      LE solves per iteration:                                  0 solves
      LE wall-clock time per iteration:                     0.000 sec (0.0%)
      LE global solves per iteration:                           0 solves
      LE global wall-clock time per iteration:              0.000 sec (0.0%)
      LE global matrix maximum size:                            0
      AMG cycles per iteration:                             0.000 cycles
      Relaxation sweeps per iteration:                          0 sweeps
      Relaxation exchanges per iteration:                       0 exchanges
      LE early protections (stall) per iteration:           0.000 times
      LE early protections (divergence) per iteration:      0.000 times
      Total SVARS touched:                                    366
      Total wall-clock time:                               29.934 sec
    Simulation wall-clock time for 40 iterations 56.57831 sec
  • B 离线
    B 离线
    BINFeng
    显存占用
    神速。。。GPU那面是可以任何算例都调用么?
    B 1 条回复 最后回复
  • B 离线
    B 离线
    BINFeng
    @李东岳 根据用户手册,GPU求解器对湍流模型、边界条件等有较多的限制
    34.9.1. Models
    The following models are supported by the Fluent GPU Solver:
    Thermal energy and CHT. See Modeling Thermal Energy.
    Species transport without reactions. See Species Transport Without Reactions.
    The GPU solver supports the following turbulence models:
    Laminar
    Standard and realizable k-epsilon
    k-omega GEKO and k-omega SST
    Large Eddy Simulation (LES)
    For the LES turbulence model, the following sub-grid scale models are supported:
    Smagorinsky-Lilly
    WALE
    Stress-Blended Eddy Simulation (SBES)
    34.9.2. Material Properties
    Material properties defined with the following settings are supported by the Fluent GPU Solver:
    constant
    ideal-gas
    incompressible-ideal-gas
    boussinesq
    polynomial
    piecewise-linear
    piecewise-polynomial
    sutherland viscosity law
    34.9.3. Solver Settings
    This section decribes the general solver settings and solution methods that are supported by the Fluent GPU Solver.
    The following general solver settings are supported:
    Pressure-Based solver
    Absolute velocity formulation
    Steady and Transient flows
    For instructions on specifying the solver settings above see General Task Page.
    The following solution methods are supported:
    SIMPLE and SIMPLEC pressure-velocity coupling schemes. See Pressure-Based Solver Settings for details.
    First-order and second-order spatial discretization schemes. See Choosing the Spatial Discretization Scheme for details.
    The Bounded Central Differencing spatial discretization scheme is supported and becomes available when Large Eddy Simulation (LES), Stress-Blended Eddy Simulation (SBES), or URANS turbulence models are enabled. For more information see Modeling Turbulence.
    First order and second order implicit transient formulations are supported for incompressible transient cases.
    34.9.4. Cell Zone and Boundary Conditions
    This section outlines the cell zone and boundary conditions supported by the Fluent GPU Solver.
    The following boundary condition settings are supported:
    Wall
    Stationary Wall and Moving Wall, including Rotational wall motion. See Wall Boundary Conditions.
    Thermal conditions. See Thermal Boundary Conditions at Walls.
    Translational Periodic boundary condition with or without a non-conformal mesh interface. See Periodic Boundary Conditions for details.
    Inlet
    Velocity-inlet (incompressible). See Defining the Velocity.
    Pressure-inlet. See Pressure Inlet Boundary Conditions.
    Mass-flow-inlet (incompressible). See Mass-Flow Inlet Boundary Conditions.
    Outlet
    Pressure-outlet. See Pressure Outlet Boundary Conditions
    Mass-flow-outlet (incompressible). See Mass-Flow Outlet Boundary Conditions
    Symmetry. See Symmetry Boundary Conditions.
    Porous Jump. See Porous Jump Boundary Conditions.
    Intake Fan. See Intake Fan Boundary Conditions.
    Outlet Vent. See Outlet Vent Boundary Conditions.
    For the supported boundary conditions listed above, boundary condition settings can be defined as constant or with a profile, as outlined in Profiles.
    The Fluent GPU Solver supports fluid cell zones with the following settings:
    Constant Source Terms. See Defining Mass, Momentum, Energy, and Other Sources.
    Porous Zone. See Porous Media Conditions.
    有点意思。不过现在这个V100现在太贵了。前几天我问供应商说我们这种批发的客户拿都是10万一个。要是dell那面买V100的机器,估计得20 30万一台了。。
    B 1 条回复 最后回复
  • B 离线
    B 离线
    BINFeng
    @李东岳 V100已经出来快5年了,现在国内主流是A800和H800,前两天联想代理说OEM的GPU服务器8卡A800 90万
    在 中回复了 BINFeng 最后由 编辑
    @BINFeng 啊我看了一下,说错了说错了,H100显卡,20多万一个... 我记成了v100
