  4. 执行Mach出现not implement的错误
1 帖子 1 发布者 3.8k 浏览
    Aeronastro
    写于 最后由 Aeronastro 编辑
    在后处理求解马赫数的时候,用Mach执行,但出现如下的错误:
    Time = 0.00056
        type            hePsiThermo;
        mixture         pureMixture;
        transport       sutherland;
        thermo          eConst;
        equationOfState perfectGas;
        specie          specie;
    --> FOAM FATAL ERROR:
    Not Implemented
        Trying to construct an genericFvPatchField on patch boundaryInner of field e
        From function genericFvPatchField<Type>::genericFvPatchField(const fvPatch& p, const DimensionedField<Type, volMesh>& iF)
        in file genericFvPatchField/genericFvPatchField.C at line 44.
    FOAM aborting
    #0  Foam::error::printStack(Foam::Ostream&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libOpenFOAM.so"
    #1  Foam::error::abort() in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libOpenFOAM.so"
    #2  Foam::fvPatchField<double>::addpatchConstructorToTable<Foam::genericFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libgenericPatchFields.so"
    #3  Foam::fvPatchField<double>::New(Foam::word const&, Foam::word const&, Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/bin/Mach"
    #4  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::GeometricBoundaryField(Foam::fvBoundaryMesh const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::List<Foam::word> const&, Foam::List<Foam::word> const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libfluidThermophysicalModels.so"
    #5  Foam::heThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::eConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::heThermo(Foam::fvMesh const&, Foam::word const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libfluidThermophysicalModels.so"
    #6  Foam::fluidThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::eConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libfluidThermophysicalModels.so"
    #7  Foam::fluidThermo::New(Foam::fvMesh const&, Foam::word const&) in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/lib/libfluidThermophysicalModels.so"
    #8  ? in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/bin/Mach"
    #9  ? in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/bin/Mach"
    #10  ? in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/bin/Mach"
    #11  __libc_start_main in "/lib64/libc.so.6"
    #12  ? in "/WORK/app/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64IccDPOpt/bin/Mach"
    Aborted (core dumped)
    这种情况我之前是没有遇到过的,于是检查了一下Mach.C的源码:
    #include "calc.H"
    #include "fluidThermo.H"
    void Foam::calc(const argList& args, const Time& runTime, const fvMesh& mesh)
        bool writeResults = !args.optionFound("noWrite");
        IOobject Uheader
            "U",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ
        IOobject Theader
            "T",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ
        // Check U and T exists
        if (Uheader.headerOk() && Theader.headerOk())
            autoPtr<volScalarField> MachPtr;
            volVectorField U(Uheader, mesh);
            if
                    "thermophysicalProperties",
                    runTime.constant(),
                    mesh
                ).headerOk()
                // thermophysical Mach
                autoPtr<fluidThermo> thermo
                    fluidThermo::New(mesh)
                volScalarField Cp(thermo->Cp());
                volScalarField Cv(thermo->Cv());
                MachPtr.set
                    new volScalarField
                            "Ma",
                            runTime.timeName(),
                            mesh
                        mag(U)/(sqrt((Cp/Cv)*(Cp - Cv)*thermo->T()))
            else
                // thermodynamic Mach
                   IOdictionary thermoProps
                        "thermodynamicProperties",
                        runTime.constant(),
                        mesh,
                        IOobject::MUST_READ_IF_MODIFIED,
                        IOobject::NO_WRITE
                dimensionedScalar R(thermoProps.lookup("R"));
                dimensionedScalar Cv(thermoProps.lookup("Cv"));
                volScalarField T(Theader, mesh);
                MachPtr.set
                    new volScalarField
                            "Ma",
                            runTime.timeName(),
                            mesh
                        mag(U)/(sqrt(((Cv + R)/Cv)*R*T))
            Info<< "Mach max : " << max(MachPtr()).value() << endl;
            if (writeResults)
                MachPtr().write();
        else
            Info<< "    Missing U or T" << endl;
        Info<< "\nEnd\n" << endl;
    代码中只要有U,T 和热力学模型就好了,不知道为什么错误提示要构造e这个场?谢谢各位!
