  4. 在运行olaFlow的waveMakerFlume时,出现浮点数例外(核心已转储)的错误,但是并未对算例进行修改
olaflow
5 帖子 2 发布者 5.7k 浏览
    lalalala
    我在运行olaFlow的waveMakerFlume时,出现浮点数例外(核心已转储)的错误,但是并未对算例进行修改,运行其他动网格的算例时也会出现这种情况,各位老师们知道是怎么回事吗/(ㄒoㄒ)/~~
    这是出现的错误:
    blockMesh meshing...
    Preparing 0 folder...
    Setting the fields...
    Creating flap wavemaker movement...
    Running...
    #2  ? in /lib/x86_64-linux-gnu/libc.so.6
    #3  Foam::scalarProduct<double, double>::type Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
    #4  Foam::PCG::scalarSolve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    #5  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    #7  Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:?
    #8  Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:?
    #9  ? in ~/OpenFOAM/user-v2006/platforms/linux64GccDPInt32Opt/bin/olaDyMFlow
    #10  ? in /lib/x86_64-linux-gnu/libc.so.6
    #11  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    #12  ? in ~/OpenFOAM/user-v2006/platforms/linux64GccDPInt32Opt/bin/olaDyMFlow
    ./runCaseFlap: 第 21 行:  6957 浮点数例外         (核心已转储) olaDyMFlow > olaDyMFlow.log
    Simulation complete.
    如果标准算例没有修改就报错。那就是bug。
    lalalala
    谢谢老师,那有可能是我的安装版本/编译的问题吗
    不清楚。看起来就是bug。但是我不确定你能不能找到他们了还。
    lalalala
    @李东岳 好的,谢谢老师!!
