  4. 相同snappyHexMeshDict和地形stl条件下,blockMeshDict增大导致网格划分失败
8 帖子 2 发布者 9.5k 浏览
    wsy11
    如题,我使用相同snappyhexmesh文件来对blocckmesh网格和地形stl文件进行划分,当范围选择为2000m*2000m*630m时(case1),可以进行正常的网格划分和运算; 当范围增大到3000m*3000m*630m时(case2),无法进行正常运算,case2会发散。
    (具体算例文件:wcase.zip ,stl文件文件过大无法上传)
    (只修改了xmin,xmax,ymin,ymax,并且网格大小也一致,而且两个case划分好网格以后checkMesh都没问题)。
    运行结果如下:
    case1正常运行
    case2发散:
    Time = 178s
    smoothSolver:  Solving for Ux, Initial residual = 0.446597, Final residual = 0.0256856, No Iterations 3
    smoothSolver:  Solving for Uy, Initial residual = 0.422256, Final residual = 0.0231428, No Iterations 3
    smoothSolver:  Solving for Uz, Initial residual = 0.497265, Final residual = 0.0275248, No Iterations 3
    GAMG:  Solving for p, Initial residual = 0.0065485, Final residual = 0.000418695, No Iterations 4
    time step continuity errors : sum local = 1.68504e+18, global = 1.42803e+16, cumulative = 9.69486e+16
    ExecutionTime = 15.72 s  ClockTime = 18 s
    Time = 179s
    [38] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
    [38] #1  Foam::sigFpe::sigHandler(int) at ??:?
    [38] #2  ? in "/lib64/libc.so.6"
    [38] #3  Foam::pow3(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
    [38] #4  void Foam::pow3<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
    [38] #5  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::pow3<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
    [38] #6  Foam::LESModels::WALE<Foam::incompressibleMomentumTransportModel>::k(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
    [38] #7  Foam::LESModels::WALE<Foam::incompressibleMomentumTransportModel>::correctNut() at ??:?
    [38] #8  ? at ??:?
    [38] #9  __libc_start_main in "/lib64/libc.so.6"
    [38] #10  ? at ??:?
    [m3cn2707:519656:0:519656] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2))
    ==== backtrace ====
        0  /usr/lib64/libucs.so.0(+0x17970) [0x2b9da57c4970]
        1  /usr/lib64/libucs.so.0(+0x17c23) [0x2b9da57c4c23]
        2  /lib64/libc.so.6(gsignal+0x37) [0x2b9c34fa7387]
        3  /public1/home/sch10341/soft/openfoam10/OpenFOAM-10/platforms/linux64IcxDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam4pow3ERNS_5FieldIdEERKNS_5UListIdEE+0xae) [0x2b9c340b32ee]
        4  /public1/home/sch10341/soft/openfoam10/OpenFOAM-10/platforms/linux64IcxDPInt32Opt/lib/libincompressibleMomentumTransportModels.so(_ZN4Foam4pow3INS_12fvPatchFieldENS_7volMeshEEEvRNS_14GeometricFieldIdT_T0_EERKS6_+0x31) [0x2b9c30c1c421]
        5  /public1/home/sch10341/soft/openfoam10/OpenFOAM-10/platforms/linux64IcxDPInt32Opt/lib/libincompressibleMomentumTransportModels.so(_ZN4Foam4pow3INS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS7_+0x188) [0x2b9c30c1bad8]
        6  /public1/home/sch10341/soft/openfoam10/OpenFOAM-10/platforms/linux64IcxDPInt32Opt/lib/libincompressibleMomentumTransportModels.so(_ZNK4Foam9LESModels4WALEINS_36incompressibleMomentumTransportModelEE1kERKNS_14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEEE+0x758) [0x2b9c30cb6da8]
        7  /public1/home/sch10341/soft/openfoam10/OpenFOAM-10/platforms/linux64IcxDPInt32Opt/lib/libincompressibleMomentumTransportModels.so(_ZN4Foam9LESModels4WALEINS_36incompressibleMomentumTransportModelEE10correctNutEv+0x12d) [0x2b9c30cb637d]
        8  simpleFoam() [0x43326c]
        9  /lib64/libc.so.6(__libc_start_main+0xf5) [0x2b9c34f93555]
       10  simpleFoam() [0x41c588]
    1、checkMesh结果如图所示:
    case1:
    case2:
    2、blcokMeshDict文件如下所示:
    case1:
    backgroundMesh
        xMin   4000;
        xMax   6100;
        yMin   4400;
        yMax   6500;
        zMin     -60;
        zMax   600;
        xCells  70;
        yCells  70;
        zCells  22;
    convertToMeters 1;
    vertices
        ($!backgroundMesh/xMin $!backgroundMesh/yMin $!backgroundMesh/zMin)
        ($!backgroundMesh/xMax $!backgroundMesh/yMin $!backgroundMesh/zMin)
        ($!backgroundMesh/xMax $!backgroundMesh/yMax $!backgroundMesh/zMin)
        ($!backgroundMesh/xMin $!backgroundMesh/yMax $!backgroundMesh/zMin)
        ($!backgroundMesh/xMin $!backgroundMesh/yMin $!backgroundMesh/zMax)
        ($!backgroundMesh/xMax $!backgroundMesh/yMin $!backgroundMesh/zMax)
        ($!backgroundMesh/xMax $!backgroundMesh/yMax $!backgroundMesh/zMax)
        ($!backgroundMesh/xMin $!backgroundMesh/yMax $!backgroundMesh/zMax)
    blocks
        hex (0 1 2 3 4 5 6 7)
            $!backgroundMesh/xCells
            $!backgroundMesh/yCells
            $!backgroundMesh/zCells
        simpleGrading (1 1 1)
    boundary
        west
            type patch;
            faces
                (0 3 7 4)
        east
            type patch;
            faces
                (1 5 6 2)
        south
            type patch;
            faces
                (0 4 5 1)
        north
            type patch;
            faces
                (3 2 6 7)
        ground
            type wall;
            faces
                (0 1 2 3)
        top
            type patch;
            faces
                (4 7 6 5)
    case2:(只修改了xmin,xmax,ymin,ymax)
    backgroundMesh
    backgroundMesh
            xMin   3500;
            xMax   6500;
            yMin   4000;
            yMax   7000;
            zMin     -60;
            zMax   600;
            xCells  100;
            yCells  100;
            zCells  22;
        convertToMeters 1;
        vertices
        blocks
        boundary
            west
                type patch;
                faces
                    (0 3 7 4)
            east
                type patch;
                faces
                    (1 5 6 2)
            south
                type patch;
                faces
                    (0 4 5 1)
            north
                type patch;
                faces
                    (3 2 6 7)
            ground
                type wall;
                faces
                    (0 1 2 3)
            top
                type patch;
                faces
                    (4 7 6 5)
    3、snappyHexMeshDict文件如下:
    // Which of the steps to run
    castellatedMesh true;
    snap            true;
    addLayers       false;
    // Geometry. Definition of all surfaces. All surfaces are of class
    // searchableSurface.
    // Surfaces are used
    // - to specify refinement for any mesh cell intersecting it
    // - to specify refinement for any mesh cell inside/outside/near
    // - to 'snap' the mesh boundary to the surface
    geometry
        terrain
            type triSurfaceMesh;
            file "km8LS.stl";
    // Settings for the castellatedMesh generation.
    castellatedMeshControls
        // Refinement parameters
        // If local number of cells is >= maxLocalCells on any processor
        // switches from from refinement followed by balancing
        // (current method) to (weighted) balancing before refinement.
        maxLocalCells 100000;
        // Overall cell limit (approximately). Refinement will stop immediately
        // upon reaching this number so a refinement level might not complete.
        // Note that this is the number of cells before removing the part which
        // is not 'visible' from the keepPoint. The final number of cells might
        // actually be a lot less.
        maxGlobalCells 2000000;
        // The surface refinement loop might spend lots of iterations
        // refining just a few cells. This setting will cause refinement
        // to stop if <= minimumRefine are selected for refinement. Note:
        // it will at least do one iteration (unless the number of cells
        // to refine is 0)
        minRefinementCells 0;
        // Allow a certain level of imbalance during refining
        // (since balancing is quite expensive)
        // Expressed as fraction of perfect balance (= overall number of cells /
        // nProcs). 0=balance always.
        maxLoadUnbalance 0.10;
        // Number of buffer layers between different levels.
        // 1 means normal 2:1 refinement restriction, larger means slower
        // refinement.
        nCellsBetweenLevels 1;
        // Explicit feature edge refinement
        // Specifies a level for any cell intersected by its edges.
        // This is a featureEdgeMesh, read from constant/geometry for now.
        features
            //    file "someLine.eMesh";
            //    level 2;
        // Surface based refinement
        // Specifies two levels for every surface. The first is the minimum level,
        // every cell intersecting a surface gets refined up to the minimum level.
        // The second level is the maximum level. Cells that 'see' multiple
        // intersections where the intersections make an
        // angle > resolveFeatureAngle get refined up to the maximum level.
        refinementSurfaces
            terrain
                // Surface-wise min and max refinement level
                level (2 2);
                // Optional region-wise level specification
                regions
                    windTurbine
                        level (3 3);
                //- Optional angle to detect small-large cell situation
                //  perpendicular to the surface. Is the angle of face w.r.t.
                //  the local surface normal. Use on flat(ish) surfaces only.
                //  Otherwise leave out or set to negative number.
                // perpendicularAngle 10;
                //- Optional faceZone and (for closed surface) cellZone with
                //  how to select the cells that are in the cellZone
                //  (inside / outside / specified insidePoint)
                // faceZone sphere;
                // cellZone sphere;
                // mode        inside;  // outside/insidePoint
        resolveFeatureAngle 30;
        // Region-wise refinement
        // Specifies refinement level for cells in relation to a surface. One of
        // three modes
        // - distance. 'levels' specifies per distance to the surface the
        //   wanted refinement level. The distances need to be specified in
        //   descending order.
        // - inside. 'levels' is only one entry and only the level is used. All
        //   cells inside the surface get refined up to the level. The surface
        //   needs to be closed for this to be possible.
        // - outside. Same but cells outside.
        refinementRegions
            // sphere.stl
            //    mode distance;
            //    levels ((1.0 5) (2.0 3));
        // Mesh selection
        // After refinement patches get added for all refinementSurfaces and
        // all cells intersecting the surfaces get put into these patches. The
        // section reachable from the insidePoint is kept.
        // NOTE: This point should never be on a face, always inside a cell, even
        // after refinement.
        insidePoint (5000 5500 300);
        // Whether any faceZones (as specified in the refinementSurfaces)
        // are only on the boundary of corresponding cellZones or also allow
        // free-standing zone faces. Not used if there are no faceZones.
    // Settings for the snapping.
    snapControls
        //- Number of patch smoothing iterations before finding correspondence
        //  to surface
        nSmoothPatch 3;
        //- Relative distance for points to be attracted by surface feature point
        //  or edge. True distance is this factor times local
        //  maximum edge length.
        tolerance 4.0;
        //- Number of mesh displacement relaxation iterations.
        nSolveIter 30;
        //- Maximum number of snapping relaxation iterations. Should stop
        //  before upon reaching a correct mesh.
        nRelaxIter 5;
    // Settings for the layer addition.
    addLayersControls
        // Are the thickness parameters below relative to the undistorted
        // size of the refined cell outside layer (true) or absolute sizes (false).
        relativeSizes true;
        // Per final patch (so not geometry!) the layer information
        layers
        // Expansion factor for layer mesh
        expansionRatio 1.0;
        // Wanted thickness of final added cell layer. If multiple layers
        // is the thickness of the layer furthest away from the wall.
        // Relative to undistorted size of cell outside layer.
        // See relativeSizes parameter.
        finalLayerThickness 0.3;
        // Minimum thickness of cell layer. If for any reason layer
        // cannot be above minThickness do not add layer.
        minThickness 0.25;
        // If points get not extruded do nGrow layers of connected faces that are
        // also not grown. This helps convergence of the layer addition process
        // close to features.
        // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
        nGrow 0;
        // Advanced settings
        // When not to extrude surface. 0 is flat surface, 90 is when two faces
        // are perpendicular
        featureAngle 60;
        // Maximum number of snapping relaxation iterations. Should stop
        nRelaxIter 5;
        // Number of smoothing iterations of surface normals
        nSmoothSurfaceNormals 1;
        // Number of smoothing iterations of interior mesh movement direction
        nSmoothNormals 3;
        // Smooth layer thickness over surface patches
        nSmoothThickness 10;
        // Stop layer growth on highly warped cells
        maxFaceThicknessRatio 0.5;
        // Reduce layer growth where ratio thickness to medial
        // distance is large
        maxThicknessToMedialRatio 0.3;
        // Angle used to pick up medial axis points
        // Note: changed(corrected) w.r.t 16x! 90 degrees corresponds to 130 in 16x.
        minMedianAxisAngle 90;
        // Create buffer region for new layer terminations
        nBufferCellsNoExtrude 0;
        // Overall max number of layer addition iterations. The mesher will exit
        // if it reaches this number of iterations; possibly with an illegal
        // mesh.
        nLayerIter 50;
        // Max number of iterations after which relaxed meshQuality controls
        // get used. Up to nRelaxIter it uses the settings in meshQualityControls,
        // after nRelaxIter it uses the values in meshQualityControls::relaxed.
        nRelaxedIter 20;
    // Generic mesh quality settings. At any undoable phase these determine
    // where to undo.
    meshQualityControls
        //- Maximum non-orthogonality allowed. Set to 180 to disable.
        maxNonOrtho 65;
        //- Max skewness allowed. Set to <0 to disable.
        maxBoundarySkewness 20;
        maxInternalSkewness 4;
        //- Max concaveness allowed. Is angle (in degrees) below which concavity
        //  is allowed. 0 is straight face, <0 would be convex face.
        //  Set to 180 to disable.
        maxConcave 80;
        //- Minimum cell pyramid volume relative to min bounding box length^3
        //  Set to a fraction of the smallest cell volume expected.
        //  Set to very negative number (e.g. -1e30) to disable.
        minVol -1e30;
        //- Minimum quality of the tet formed by the face-centre
        //  and variable base point minimum decomposition triangles and
        //  the cell centre.  Set to very negative number (e.g. -1e30) to
        //  disable.
        //     <0 = inside out tet,
        //      0 = flat tet
        //      1 = regular tet
        minTetQuality 1e-30;
        //- Minimum face twist. Set to <-1 to disable. dot product of face normal
        //  and face centre triangles normal
        minTwist 0.05;
        //- Minimum normalised cell determinant
        //  1 = hex, <= 0 = folded or flattened illegal cell
        minDeterminant 0.001;
        //- minFaceWeight (0 -> 0.5)
        minFaceWeight 0.05;
        //- minVolRatio (0 -> 1)
        minVolRatio 0.01;
        //- Number of error distribution iterations
        nSmoothScale 4;
        //- Amount to scale back displacement at error points
        errorReduction 0.75;
        relaxed
            maxNonOrtho 75;
    mergeTolerance 1e-6;
    wsy11
    找到问题所在了:是划分网格时出现的问题,但是仍然解决不了
    如图:blockMeshDict设置相同范围(3000m3000m600m时),但是网格大小不同时(网格大小图一:100m,图二:60m),网格变小会导致划分失败(如图,地面仍然为平面,而不是stl文件)
    图一:
    图二:底面变成真实地形
    刚 1 条回复 最后回复
  • 刚 离线
    刚 离线
    刚开始学流体力学
    在 中回复了 wsy11 最后由 编辑
    @wsy11 你好,我做的和你一样的基于真实地形的风场模拟,我也是遇到了运行一段时间发散的问题,现在打算把网格弄得稀疏一些
    wsy11
    在 中回复了 刚开始学流体力学 最后由 编辑
    @刚开始学流体力学
    我也是把网格量减少了,可以成功运行一段时间,但是运行一段时间后还是发散,请问您是多大的地形,以及运行多长的模拟?
    刚 1 条回复 最后回复
  • 刚 离线
    刚 离线
    刚开始学流体力学
    在 中回复了 wsy11 最后由 编辑
    @wsy11 我的是6000 * 2000 * 600,现在能运行到160s左右,你使用的是哪个求解器,方便的话可以加个联系方式交流嘛
    W 2 条回复 最后回复
    wsy11
    在 中回复了 刚开始学流体力学 最后由 wsy11 编辑
    @刚开始学流体力学
    我看了您之前的帖子,咱们是一个方向的,我也是在处理wrf+CFD的问题
    wsy11
    此回复已被删除!
    刚 1 条回复 最后回复
  • 刚 离线
    刚 离线
    刚开始学流体力学
    在 中回复了 wsy11 最后由 编辑
    @wsy11 好的,稍等,我提交了
