  4. OpenFOAM.org系列国内满速下载地址
2 帖子 1 发布者 6.8k 浏览
    这些国内软件包都是直接fork国外github上面的OpenFOAM。因为有时候github访问不上去。就fork到国内。
    下列地址可直接使用git clone,例如,打开终端,在终端直接将下面的复制进去:
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-6.git
    即可在本地创建ThirdParty-6文件夹。如果提示你没有git,那么输入下面的即可:
    sudo apt install git
    正常的话是下图这样:
    相关git地址:
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-12.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-11.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-10.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-9.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-8.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-7.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-6.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-5.x.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-4.x.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-3.0.x.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-2.3.0.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-2.2.0.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-2.1.1.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-2.1.0.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-2.0.0.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-1.7.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-1.6.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-1.5.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-1.4.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-1.3.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-1.2.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-1.1.git
    第三方包地址:
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-12.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-11.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-10.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-9.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-8.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-7.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-5.x.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-3.0.x.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-2.1.1.git
    在下载的时候,需要下载相应的OpenFOAM与相应版本的第三方包
    如果有人需要scotch_6.0.3: scotch_6.0.3.tar.gz
  • 李东岳李 李东岳 被引用 于这个主题
  • H HITSC30 被引用 于这个主题
    这个是ESI-OpenCFD版本
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-v2412.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-v2312.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-v2306.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-v2206.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-v2106.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-v2012.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-v2006.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-v1912.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-v1906.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-v1712.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/OpenFOAM-v1706.git
    第三方包地址:
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-v2212.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-v2206.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-v2106.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-v2012.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-v2006.git
    git clone https://e.coding.net/dyfluid/OpenFOAM/ThirdParty-v1906.git
  • 亦 亦又 被引用 于这个主题
