  4. cyclicAMI:旋转周期边界设置问题
3 帖子 2 发布者 3.0k 浏览
    Hope
    我在在设置旋转周期边界时遇到了以下问题:
    我使用的是一个openfoam外开发的求解器,求解C3X叶栅的模拟,在使用相同的边界条件时,当设置叶片两个周期性边界为对称边界时,求解一切正常,但将其改为cyclicAMI时则计算无法进行,个人角度感觉是边界条件设置的问题,尝试过在·boundary文件中设置separationVector等,均会出下以下错误:
    Create time
    Create mesh for time = 0
    Steady-state analysis detected
    pseudoTime: tolerance = 1e-10, relTol = 1e-10
    Local timestepping selected
        type            hePsiThermo;
        mixture         pureMixture;
        transport       const;
        thermo          hConst;
        equationOfState perfectGas;
        specie          specie;
    AMI: Creating addressing and weights between 18620 source faces and 18620 target faces
    AMI: Patch source sum(weights) min:0 max:1.84903 average:0.999732
    AMI: Patch target sum(weights) min:0.030709 max:1.15763 average:0.994612
    #2  ? in /lib/x86_64-linux-gnu/libc.so.6
    #3  ? at ??:?
    #4  ? at ??:?
    #5  Foam::psiThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:?
    #6  ? at ??:?
    #7  Foam::psiThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:?
    #8  ? in ~/OpenFOAM/duan-v2112/platforms/linux64GccDPInt32Opt/bin/dbnsFoam
    #9  ? in /lib/x86_64-linux-gnu/libc.so.6
    #10  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    #11  ? in ~/OpenFOAM/duan-v2112/platforms/linux64GccDPInt32Opt/bin/dbnsFoam
    Floating point exception
    网格的质量没有问题,boundary处设置的条件如下:
        blade
            type            wall;
            inGroups        1(wall);
            nFaces          25088;
            startFace       6512669;
        inlet
            type            patch;
            nFaces          8526;
            startFace       6537757;
        outlet
            type            patch;
            nFaces          8526;
            startFace       6546283;
        Lower_periodicity
            type            cyclicAMI;
            inGroups        1(cyclicAMI);
            nFaces          18620;
            startFace       6554809;
    	matchTolerance  0.0001;
            transform       rotational;
            neighbourPatch  Upper_periodicity;
            rotationAxis    (1 0 0);
            rotationCentre  (0 0 0);
        Upper_periodicity
            type            cyclicAMI;
            nFaces          18620;
            startFace       6573429;
            neighbourPatch  Lower_periodicity;
        back
            type            wall;
            inGroups        1(wall);
            nFaces          22363;
            startFace       6592049;
        front
            type            wall;
            inGroups        1(wall);
            nFaces          22363;
            startFace       6614412;
    同时也尝试过将cyclicAMI改为cyclic,但是两个边界的网格差异过大,有以下问题:
    Create time
    --> FOAM FATAL ERROR: (openfoam-2112 patch=220610)
    face 0 area does not match neighbour by 68.9656% -- possible face ordering problem.
    patch:Lower_periodicity my area:6.66444e-09 neighbour area:1.36797e-08 matching tolerance:0.1
    Mesh face:6554809 fc:(-0.0309194 -0.0589349 119.957)
    Neighbour fc:(-0.0196249 0.058833 119.957)
    If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file.
    Rerun with cyclic debug flag set for more information.
        From void Foam::cyclicPolyPatch::calcTransforms(const primitivePatch&, const pointField&, const vectorField&, const pointField&, const vectorField&)
        in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 215.
    FOAM exiting
    望大佬帮忙解答下困惑。
    博士生涯收敛
    如果网格没问题的话,把你的cyclicAMI的matchTolerance调大到10
    H 1 条回复 最后回复
    Hope
    @李东岳 谢谢李老师,网格检查过了,没有问题,把cyclicAMI的边界设置为symmetry是可以计算的。刚才按照您的建议试过了,也还是报相同的错误,错误信息如下:
    |  \\    /   O peration     | Version:  2112                                  |
    Build  : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112
    Arch   : "LSB;label=32;scalar=64"
    Exec   : dbnsFoam
    Date   : Jun 06 2024
    Time   : 18:13:40
    Host   : DESKTOP-H49IU2O
    PID    : 137843
    I/O    : uncollated
    Case   : /home/duan/JIA_Xiaotong/ICSFoam-master/tutorials/test_5
    nProcs : 1
    trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
    fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
    Create time
        type            hePsiThermo;
        transport       const;
        thermo          hConst;
        specie          specie;
    #3  ? at ??:?
    #4  ? at ??:?
    #6  ? at ??:?
    老师,有没有可能是因为叶栅模型的旋转半径太大(120m)导致的呢?
    博士生涯收敛
