  4. 似乎第一步就发散了,是我的初边条设置的有问题吗?
9 帖子 2 发布者 8.7k 浏览
  • 火 离线
    火 离线
    火山口玩泥巴
    是基于tutorial里面的waterChannel改的算例,模型是二维的一个溢洪道,边界条件就在原先的基础上改了一点:
    //alpha.water
    dimensions      [0 0 0 0 0 0 0];
    internalField   uniform 0;
    boundaryField
        inlet
            type            fixedValue;
            value           uniform 1;
        walls
            type            zeroGradient;
        outlet
            type            zeroGradient;
            value           uniform 0;
        atmosphere
            type            inletOutlet;
            inletValue      uniform 0;
            value           uniform 0;
        BaseAndTop
            type            empty;
    //k
    internalField   uniform 0.0001;
    boundaryField
        inlet
            type            fixedValue;
            intensity       0.05;
        walls
        outlet
            type            inletOutlet;
        BaseAndTop
            type            empty;
            type            inletOutlet;
            inletValue      $internalField;
    //nut
    boundaryField
        walls
            value           uniform 0;
        BaseAndTop
            type            empty;
            type            calculated;
            value           uniform 0;
    //omega
    dimensions      [0 0 -1 0 0 0 0];
    internalField   uniform 0.003;
    boundaryField
        inlet
            type            fixedValue;
        walls
            type            omegaWallFunction;
        outlet
            type            inletOutlet;
        BaseAndTop
            type            empty;
            type            inletOutlet;
    //p_rgh
    boundaryField
        atmosphere
            type            totalPressure;
            p0              uniform 0;
        inlet
            type            zeroGradient;
        outlet
            type            fixedValue;
            value           uniform 0;
        BaseAndTop
            type            empty;
        walls
            value           uniform 0;
    //s
    boundaryField
        inlet
            type            fixedValue;
            value           uniform 0;
        walls
            type            zeroGradient;
        outlet
            type            zeroGradient;
            value           uniform 0;
        atmosphere
            type            inletOutlet;
            value           uniform 0;
        BaseAndTop
            type            empty;
    //U
    boundaryField
        inlet
            type            flowRateInletVelocity;
            volumetricFlowRate constant 50;
        walls
            type            noSlip;
        atmosphere
        outlet
            type            inletOutlet;
            inletValue      uniform (0 0 0);
        BaseAndTop
            type            empty;
    第一个迭代是个情况:
    Starting time loop
    Courant Number mean: 0.000528922 max: 0.136511
    Interface Courant Number mean: 0 max: 0
    deltaT = 0.0120048
    Time = 0.0120048
    PIMPLE: iteration 1
    smoothSolver:  Solving for alpha.water, Initial residual = 1, Final residual = 0.000281706, No Iterations 1000
    Phase-1 volume fraction = 0.00125164  Min(alpha.water) = 0  Max(alpha.water) = 1
    MULES: Correcting alpha.water
    Phase-1 volume fraction = 0.00125164  Min(alpha.water) = -2.54212e-24  Max(alpha.water) = 1
    GAMG:  Solving for p_rgh, Initial residual = 1, Final residual = 2.7816e+83, No Iterations 50
    time step continuity errors : sum local = 3.5015e+80, global = 2.12903e+77, cumulative = 2.12903e+77
    请问大佬们,这是边界条件的问题吗?
  • 火 离线
    火 离线
    火山口玩泥巴
    模型是这样的:
  • 火 离线
    火 离线
    火山口玩泥巴
    还有一点疑问,就是初始条件字典里的".*"是不是就是代表上文所有未定义的边界呢?
    *代表零个到多个任意字符
    第一步发散应该就是设置问题
    火 1 条回复 最后回复
  • 火 离线
    火 离线
    火山口玩泥巴
    @李东岳 就是类似linux的通配符是吗?谢谢老师。
    设置问题是指初边条件还是离散格式求解设置什么的吗?还是说都有可能的?🙏
    边界条件有很大关系。
    火 1 条回复 最后回复
  • 火 离线
    火 离线
    火山口玩泥巴
    @李东岳 好的老师,请问您有什么推荐的介绍openfoam边界条件的文章帖子吗,我找了很多但大多都讲得有些碎片化,不够系统。
    边界条件设置比较靠经验。理论跟设置这个中间断层很大。所以你会有碎片化,不够系统的感觉。边界条件这个理论基本看完了之后没啥用。:-)
    火 1 条回复 最后回复
  • 火 离线
    火 离线
    火山口玩泥巴
    @李东岳 好的谢谢老师,课题组只有我一个做这个没有师兄师姐传授经验😢,所以是得多看看文章吗?
