  3. Pimple中对速度场的操作
Pimple中对速度场的操作
10 帖子 3 发布者 3.2k 浏览
  • I 在线
    I 在线
    ice_flow
    各位老师好,
    我在pimple的速度场中自己添加了一个扰动变量,编译可以通过,但是运行算例时会报错。
    检查了很久不知道问题出在哪里,请大家帮忙。
    这个是我在pimple算法的UEqn.H文件中添加的扰动UB:
    // Solve the Momentum equation
    MRF.correctBoundaryVelocity(U);
    tmp<fvVectorMatrix> tUEqn
        fvm::ddt(U) + fvm::div(phiB, U)+ fvm::div(phi, UB)
      + MRF.DDt(U)
      + turbulence->divDevReff(U)
        fvOptions(U)
    fvVectorMatrix& UEqn = tUEqn.ref();
    单纯增加了一项变量,所以在主函数里面做了定义:
     // Define phiB and UB
        volVectorField UB
                "UB",
                runTime.timeName(),
                mesh,
                IOobject::READ_IF_PRESENT,
                IOobject::AUTO_WRITE
            mesh,
            dimensionedVector("UB", dimVelocity, vector::zero)
        surfaceScalarField phiB
                "phiB",
                runTime.timeName(),
                mesh,
            mesh
    编译是能够顺利通过的,运行算例的时候报错如下:
    --> FOAM FATAL ERROR: (openfoam-2206)
    Incompatible fields for operation
        [U] + [UB]
        From void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam::fvMatrix<Type>&, const char*) [with Type = Foam::Vector<double>]
        in file /home/lb/v2206/OpenFOAM-v2206/src/finiteVolume/lnInclude/fvMatrix.C at line 1886.
    FOAM aborting
    #1  Foam::error::simpleExit(int, bool) at ??:?
    #2  void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::fvMatrix<Foam::Vector<double> > const&, char const*) in ~/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/dirpimpleFoam
    #3  ? in ~/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/dirpimpleFoam
    #4  ? in ~/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/dirpimpleFoam
    #5  ? in /lib/x86_64-linux-gnu/libc.so.6
    #6  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    #7  ? in ~/v2206/OpenFOAM-v2206/platforms/linux64GccDPInt32Opt/bin/dirpimpleFoam
    Aborted (core dumped)
    提示场不匹配,所以我在循环的前后把两个场都打印了:
    Starting time loop
    UB field type: N4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEE
    U field type: N4Foam14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEE
    UB field dimension: [0 1 -1 0 0 0 0]
    U field dimension: [0 1 -1 0 0 0 0]
    Courant Number mean: 0 max: 0
    Time = 0.005
    PIMPLE: iteration 1
        From Foam::fvMatrix<Type>::fvMatrix(const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::dimensionSet&) [with Type = Foam::Vector<double>]
        in file /home/lb/v2206/OpenFOAM-v2206/src/finiteVolume/lnInclude/fvMatrix.C at line 360
        Constructing fvMatrix<Type> for field U
        Constructing fvMatrix<Type> for field UB
        From Foam::fvMatrix<Type>::~fvMatrix() [with Type = Foam::Vector<double>]
        in file /home/lb/v2206/OpenFOAM-v2206/src/finiteVolume/lnInclude/fvMatrix.C at line 458
        Destroying fvMatrix<Type> for field U
        [U] + [UB]
    FOAM aborting
    可以看到初始状态的两个场是类型一致的
    但是进入第一个速度修正之后就报错了,说明这里出了问题。但是根据我自己的理解,后面的速度修正是通过添加网格运动,压力边界这些源项进行的,并没有改变速度的类型。或许变成矩阵了,但这些操作同时作用在两个场上,不知道问题出现在哪里。
    后面我又用icofoam做了相同的修改,是可以运行的,感觉是在网格运动上吗,但是调试代码中也没有出现对应的报错,十分困扰。
    fvm::div(phi, UB)改成fvc::div(phi, UB)
    http://dyfluid.com/index.html
  • I 在线
    I 在线
    ice_flow
    可以了!谢谢老师。是因为这个fvm::div(phi, UB)迭代里只能有一个变量吗。
    你的方程是对U进行离散,fvm::div(phi, UB)还对UB进行离散。一个方程不能进行两个未知数的离散。
    I 1 条回复 最后回复
  • I 在线
    I 在线
    ice_flow
    @李东岳 明白了,谢谢老师!
    R 1 条回复 最后回复
  • R 离线
    R 离线
    Rachel0096
    在 中回复了 ice_flow 最后由 Rachel0096 编辑
    @ice_flow 您好,我也遇到了类似的问题,可以向您请教吗?这是对openfoam2.3.x版本中coalChemistryFoam的改写。大致也是在一个方程中,有两个不同的变量,编译可以通过,但在计算式出现报错incompatible fields for operation [N2] == [N2]。个人感觉也是同样的问题,但不是很清楚要如何去更改。YiEqn部分代码如下:
        for(label i=0; i<Y.size(); i++)
                // volScalarField Yi   = Ysf[nsf][i];
                volScalarField Ymean = Y[i];
                volScalarField tempYi
                        Y[i].name(),
                        runTime.timeName(),
                        mesh,
                        IOobject::NO_READ,
                        IOobject::NO_WRITE
                    0*Y[0],
                    "zeroGradient"
                tempYi = Ysf[nsf][i];
                WienerTermYi = pow(2*gamma,0.5)*( fvc::grad(tempYi) & dW_sf);
                fvScalarMatrix YiEqn
                      fvm::ddt(rho, tempYi)
                    + mvConvection->fvmDiv(phi, tempYi)
                    - fvm::laplacian(turbulence->muEff()/Sct, tempYi)
                      coalParcels.SYi(i, Ymean)
                    + combustion->R(Ymean)
                    + fvOptions(rho, Ymean)
    		        + (rho*WienerTermYi/deltaT)
                YiEqn.relax();
                fvOptions.constrain(YiEqn);
                YiEqn.solve(mesh.solver("tempYi"));
                YiEqn.solve();
                fvOptions.correct(tempYi);
                tempYi.max(0.0);
    	        Ysf[nsf][i] = tempYi;
                Yt += tempYi;
    I 1 条回复 最后回复
    incompatible fields for operation [N2] == [N2]这是单位不一致。你植入的代码对应的方程单位不一致。你查查
    啊说错了,不是单位不一致,是赋值不统一。代码太多了,判断下哪一行有错误然后再进一步debug
  • I 在线
    I 在线
    ice_flow
    在 中回复了 Rachel0096 最后由 李东岳 编辑
    @Rachel0096 这是多组分计算吗,我觉得你要检查下N2组分的初始定义,或者在程序里输出看一下是不是预想的值。我这里的问题是出现了多变量,应该不太一样。
    类似这样
    Info << "N2 field range: " << min(Y["N2"]).value()
         << " to " << max(Y["N2"]).value() << endl;
  • R 离线
    R 离线
    Rachel0096
    感谢老师们!这里确实是多变量的计算,类似于把单个组分场拆分为很多不同的场来计算,但是输入相同的源项,所以会有两种不同的Y在同一个方程里。程序就是在方程这一步出现了错误,我试试各位老师的方法,多输出一些内容看看哪里出问题了。
