  3. foamextend5.0求解器编译报错显示”expected unqualified-id before ‘if’“
4 帖子 1 发布者 2.1k 浏览
    yuanliangwojt
    写于 最后由 yuanliangwojt 编辑
    #include "fvCFD.H"
    #include "MULES.H"
    #include "subCycle.H"
    #include "interfaceProperties.H"
    #include "twoPhaseMixture.H"
    #include "turbulenceModel.H"
    #include "dynamicFvMesh.H"
    #include "pimpleControl.H"
    #include "immersedBoundaryPolyPatch.H"
    #include "immersedBoundaryFvPatch.H"
    #include "emptyFvPatch.H"
    #   include "setRootCase.H"
    #   include "createTime.H"
    #   include "createDynamicFvMesh.H"
        pimpleControl pimple(mesh);
    #   include "readGravitationalAcceleration.H"
    #   include "initContinuityErrs.H"
    #   include "createIbMasks.H"
    #   include "createFields.H"
    #   include "createControls.H"
    #   include "correctPhi.H"
    #   include "CourantNo.H"
    #   include "setInitialDeltaT.H"
    我在foamextend5.0环境下编写具有IBM方法的两相流求解器,是在foamextend5.0自带的求解器pimpleDyMIbFoam基础上修改的,以上是一部分主程序代码,我在foam extend5.0环境下编译这个求解器,显示如下错误,是在我上边发的代码的第33行fa0baa3f-b089-4732-9121-f06d739099c0-image.png
    请问各位大佬应该这么修改呢?我确定这个报错路径下的CourantNo.H文件是没有问题的,因为这是系统路径下的文件啊,我也没有修改过,之前使用过这个文件编译其他求解器,也是没有问题的,所以现在不知道问题出在哪里了?
    还请各位老师不吝赐教
    yuanliangwojt
    此回复已被删除!
    yuanliangwojt
    下附CourantNo.H文件内容
      \\      /  F ield         | foam-extend: Open Source CFD
       \\    /   O peration     | Version:     5.0
        \\  /    A nd           | Web:         http://www.foam-extend.org
         \\/     M anipulation  | For copyright notice see file Copyright
    License
        This file is part of foam-extend.
        foam-extend is free software: you can redistribute it and/or modify it
        under the terms of the GNU General Public License as published by the
        Free Software Foundation, either version 3 of the License, or (at your
        option) any later version.
        foam-extend is distributed in the hope that it will be useful, but
        WITHOUT ANY WARRANTY; without even the implied warranty of
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
        General Public License for more details.
        You should have received a copy of the GNU General Public License
        along with foam-extend.  If not, see <http://www.gnu.org/licenses/>.
    Global
        CourantNo
    Description
        Calculates and outputs the mean and maximum Courant Numbers.
    scalar CoNum = 0.0;
    scalar meanCoNum = 0.0;
    scalar velMag = 0.0;
    // HR 26.06.18: A parallel run has at least two cells and therefore at least
    // one internal face in the global mesh. It may be a processor boundary, but
    // this is captured by max(mag(phi)).
    // Old formulation hangs on parallel cases where one partition is degenerated
    // to a single cell.
    if (mesh.nInternalFaces() || Pstream::parRun())
        surfaceScalarField magPhi = mag(phi);
        surfaceScalarField SfUfbyDelta =
            mesh.surfaceInterpolation::deltaCoeffs()*magPhi;
        const scalar deltaT = runTime.deltaT().value();
        CoNum = max(SfUfbyDelta/mesh.magSf()).value()*deltaT;
        meanCoNum = (sum(SfUfbyDelta)/sum(mesh.magSf())).value()*deltaT;
        velMag = max(magPhi/mesh.magSf()).value();
    else
        // Single cell mesh: Co is still defined; use cell formulation
        const scalar deltaX = Foam::cbrt(mesh.V()[0]);
        // recover velocity field in a more general way
        const volVectorField& URef
    	    = mesh.db().lookupObject<const volVectorField>("U");
        velMag = mag(URef[0]);
        CoNum = velMag*deltaT/deltaX;
        meanCoNum = CoNum;
    Info<< "Courant Number mean: " << meanCoNum
        << " max: " << CoNum
        << " velocity magnitude: " << velMag
        << endl;
    yuanliangwojt
