  3. openfoam reactingMultiphaseEulerFoam求解器请教有关phaseProperties中饱和模型的一些问题
2 帖子 1 发布者 962 浏览
  • V 离线
    V 离线
    Vanvan0421
    最近我在使用reactingMultiphaseEulerFoam计算模拟垂直管道内水蒸气壁面沸腾,长度为 2m,直径为 15.4 mm,管壁热通量为 570000w.m-2,入口处的平均速度为 1m.s-1,工作压力为 45 bar。两个阶段的湍流模型都是 k-epsilon。我在选用系统自带饱和模型的时候,计算一段时间就会崩溃,只有我将饱和模型选为常数的时候才可以模拟成功,但是模拟得到的结果偏差较大,这种情况怎么解决呢?以下是我选用的三种饱和模型:
    saturationModel
    type constant;
    pSat 100000;
    Tsat 373;
    type polynomial;
    C<8>
    308.0422
    0.0015096
    -1.61589e-8
    1.114106e-13
    -4.52216e-19
    1.05192e-24
    -1.2953e-30
    6.5365e-37
    type polynomial;
    C<8>
    440.9049
    2.5741e-5
    -1.28758e-12
    -1.2014e-28
    2.45488e-35
    -2.94338e-42
    1.92021e-49
    -5.26545e-57
  • V 离线
    V 离线
    Vanvan0421
    这个是当我把水的物性从常数改为多项式后遇到的问题
    Courant Number mean: 0.134868655 max: 0.237479859
    deltaT = 3.4820232e-06
    Time = 0.00378807
    PIMPLE: iteration 1
    MULES: Solving for alpha.gas
    MULES: Solving for alpha.liquid
    gas fraction, min, max = 0.00155200072 1e-15 0.0672465558
    liquid fraction, min, max = 0.998447999 0.932753444 1
    Phase-sum volume fraction, min, max = 1 0.999994574 1.00026614
    gas fraction, min, max = 0.00155951826 1e-15 0.0674835707
    liquid fraction, min, max = 0.998440482 0.932516429 1
    Phase-sum volume fraction, min, max = 1 0.999994794 1.00025528
    gas fraction, min, max = 0.00156703579 1e-15 0.0677203557
    liquid fraction, min, max = 0.998432964 0.932279644 1
    Phase-sum volume fraction, min, max = 1 0.999995014 1.00025493
    Tf.gasAndLiquid: min = 350.131001, mean = 456.035361, max = 549.778465
    iDmdt.gasAndLiquid: min = -0.959612341, mean = 11.8287784, max = 447.419943, integral = 0.000182163188
    wDmdt.gasAndLiquid: min = 0, mean = 138.094307, max = 5727.35791, integral = 0.00212665234
    smoothSolver: Solving for e.gas, Initial residual = 0.104953394, Final residual = 1.40390231e-09, No Iterations 2
    smoothSolver: Solving for e.liquid, Initial residual = 0.282448508, Final residual = 6.30884149e-18, No Iterations 2
    [stack trace]
    #1 Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
    #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0
    #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
    #4 void Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so
    #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so
    #6 Foam::heatTransferModels::RanzMarshall::K(double) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libreactingMultiphaseSystem.so
    #7 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::BlendedInterfacialModelFoam::heatTransferModel::evaluate<double, Foam::fvPatchField, Foam::volMesh, double>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > (Foam::heatTransferModel::*)(double) const, Foam::word const&, Foam::dimensionSet const&, bool, double) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libreactingMultiphaseSystem.so
    #8 Foam::BlendedInterfacialModelFoam::heatTransferModel::K(double) const in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libreactingMultiphaseSystem.so
    #9 Foam::ThermalPhaseChangePhaseSystem<Foam::PhaseTransferPhaseSystem<Foam::TwoResistanceHeatTransferPhaseSystem<Foam::MomentumTransferPhaseSystemFoam::multiphaseSystem > > >::correctInterfaceThermo() in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/libreactingMultiphaseSystem.so
    #10 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/reactingMultiphaseEulerFoam
    #11 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
    #12 ? in /usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/bin/reactingMultiphaseEulerFoam
