  4. 求助:foam-extend-4.1 mergeMeshes 失败
2 帖子 1 发布者 2.8k 浏览
  • G 离线
    G 离线
    Gunther
    用Gambit生成两套网格(背景网格和重叠网格,.msh格式)导入fe41后(fluentMeshtoFoam *.msh),分别将两套网格(cosntant文件夹和system文件夹)放在不同的文件夹中。随后使用mergeMeshes操作出现问题。
    > mergeMeshes .. oversetCylinder_fluentMesh . oversetCylinder
    | \\      /  F ield         | foam-extend: Open Source CFD                    |
    |  \\    /   O peration     | Version:     4.1                                |
    |   \\  /    A nd           | Web:         http://www.foam-extend.org         |
    |    \\/     M anipulation  | For copyright notice see file Copyright         |
    Build  : 4.1-70b064d0f326
    Exec   : mergeMeshes .. oversetCylinder_fluentMesh . oversetCylinder
    Date   : Sep 02 2024
    Time   : 20:54:18
    Host   : "gunther-All-Series"
    PID    : 16409
    CtrlDict : "/home/gunther/TANHAO_fe41/oversetCylinder_fluentMesh/system/controlDict"
    Case   : /home/gunther/TANHAO_fe41/oversetCylinder_fluentMesh
    nProcs : 1
    allowSystemOperations : Disallowing user-supplied system call operations
    Master:      ".." "oversetCylinder_fluentMesh"  region region0
    mesh to add: "." "oversetCylinder"  region region0
    Create Times
    Reading master mesh for time = 0
    Create mesh
    Reading mesh to add for time = 0
    Create mesh
    --> FOAM Warning :
        From function Foam::forces::forces(const word&, const objectRegistry&, const dictionary&, const bool)
        in file forces/forces.C at line 209
        No fvMesh available, deactivating.
    --> FOAM FATAL ERROR:
    Attempt to cast type mergePolyMesh to type fvMesh
        From function refCast<To>(From&)
        in file /home/gunther/foam/foam-extend-4.1/src/foam/lnInclude/typeInfo.H at line 114.
    FOAM aborting
    Aborted (core dumped)
    出现“Attempt to cast type mergePolyMesh to type fvMesh”的提示。在网上没有搜到相关的解决办法,跪求大佬指点!!!
  • G 离线
    G 离线
    Gunther
    搬运大佬🅲🅵🅳.ⓒⓞⓐⓒⓗ的解决办法,实测好用:
    “根据你的描述,估计是 system/controlDict 里面有 functionObjects,可能是一个,也有可能两个都有,针对你的 case,应该是 forces 的部分,如果把这部分屏蔽了,应该可以了。”
