  4. openfoam串行和并行结果不一致,不知道是什么原因?
4 帖子 2 发布者 3.5k 浏览
  • G 离线
    G 离线
    gzs20
    这是并行计算0.02后的空气电势分布结果;
    这是串行计算0.02后电势分布结果;
    自己写的求解器么
  • G 离线
    G 离线
    gzs20
    是的,李老师
    这是并行计算文件,您方便了帮忙看一下问题出在哪里;
    #!/bin/bash
    cd ${0%/*} || exit 1 # Run from this directory
    # Source PATO run functions
    . $PATO_DIR/src/applications/utilities/runFunctions/RunFunctions
    # Initialize the script
    pato_init
    # source OpenFOAM and PATO if darwin
    if [ "$(uname)" = "Darwin" ]; then
        source $FOAM_ETC/bashrc
        source $PATO_DIR/bashrc
    fi
    # Check number of processors
    if [ -z $1 ];
    then
        echo "error: correct usage = ./Allrun_parallel <number_processors>"
        exit 1
    fi
    re='^[0-9]+$'
    if ! [[ $1 =~ $re ]] ; then
       echo "error: First argument is not a number" >&2
       exit 1
    fi
    NPROCESSOR=$1
    # sed command
        sed_cmd=gsed
    else
        sed_cmd=sed
    fi
    # change the decomposeParDict files
    $sed_cmd -i 's/numberOfSubdomains \+[0-9]*;/numberOfSubdomains '"$NPROCESSOR"';/g' system/air/decomposeParDict
    $sed_cmd -i 's/numberOfSubdomains \+[0-9]*;/numberOfSubdomains '"$NPROCESSOR"';/g' system/core/decomposeParDict
    $sed_cmd -i 's/numberOfSubdomains \+[0-9]*;/numberOfSubdomains '"$NPROCESSOR"';/g' system/upCore/decomposeParDict
    $sed_cmd -i 's/numberOfSubdomains \+[0-9]*;/numberOfSubdomains '"$NPROCESSOR"';/g' system/carbon/decomposeParDict
    # create volume fields (first time step : 50 s)
    #scp -r origin.0 50
    #scp -r constant/porousMat/copy.polyMesh constant/porousMat/polyMesh
    #scp -r constant/subMat1/copy.polyMesh constant/subMat1/polyMesh
    rm log.PATOx
    count=ls -1 processor* 2>/dev/null | wc -l
    if [ $count != 0 ];
    then
        rm -rf processor*
    fi
    # decompose the mesh
    #setFields -region air
    decomposePar -allRegions
    #run case
    #/usr/bin/mpirun -np $NPROCESSOR PATOx -parallel
    #runParallel $(getApplication)
    # 3D post-processing
    reconstructPar -allRegions
    # paraFoam -builtin
    # probe scalar fields (temperature, pressure, density, etc) at desired locations - chosen in system/sampleDict
    #postProcess -func sampleDict -region porousMat
    # grab probed fields and copy them into files
    # postProcessTime <dictName> <regionName> <inputFileName> <outputFileName>
    #postProcessTime sampleDict porousMat surfacePatch_Ta.xy output/plot_surfacePatch_Ta
    自己写的求解器别人很难debug
    有可能是边界条件没处理好
