  4. FLUNET 初始化失败。
FLUNET 初始化失败。
1 帖子 1 发布者 2.8k 浏览
  • 2 离线
    2 离线
    2682577721
    目前是在用重叠网格进行模拟,一个结构是固体,另一个是线弹性。用的是明渠造波,初始化总是崩溃,这是为什么呢?报错代码附在下面,感谢各位大佬抽出时间回答这个问题。
    Grouping and repartitioning the fluid cell zones...
    14 Stored Partitions:
    P Cells I-Cells Cell Ratio Faces I-Faces Face Ratio Neighbors Load
    0 52115 3581 0.069 176927 7246 0.041 5 1
    1 52472 4620 0.088 162295 4236 0.026 4 1
    2 54617 12093 0.221 134005 7412 0.055 9 1
    3 52637 6006 0.114 169686 5664 0.033 4 1
    4 52807 11023 0.209 167910 5289 0.031 6 1
    5 52057 3479 0.067 162444 4597 0.028 5 1
    6 52745 1693 0.032 170269 3362 0.020 2 1
    7 52784 13211 0.250 163205 4296 0.026 5 1
    8 52259 3566 0.068 176157 7128 0.040 5 1
    9 51910 1672 0.032 160241 2070 0.013 1 1
    10 51748 3480 0.067 164291 5004 0.030 3 1
    11 54525 9324 0.171 134306 6166 0.046 8 1
    12 51710 3562 0.069 166038 5640 0.034 4 1
    13 54297 9707 0.179 133333 6836 0.051 9 1
    Collective Partition Statistics: Minimum Maximum Total
    Cell count 51710 54617 738683
    Mean cell count deviation -2.0% 3.5%
    Partition boundary cell count 1672 13211 87017
    Partition boundary cell count ratio 3.2% 25.0% 11.8%
    Face count 133333 176927 2200909
    Mean face count deviation -16.7% 10.5%
    Partition boundary face count 2070 7412 40198
    Partition boundary face count ratio 1.3% 5.5% 1.8%
    Partition neighbor count 1 9
    Partition Method Metis
    Stored Partition Count 14
    Overset partition statistics:
    P Cells Solve-cells Dead-cells
    0 52115 58811 0
    1 52472 52274 66
    2 54617 56753 617
    3 52637 54720 391
    4 52807 46085 6296
    5 52057 52626 0
    6 52745 55832 0
    7 52784 43070 6359
    8 52259 58396 0
    9 51910 51910 0
    10 51748 53430 0
    11 54525 59651 261
    12 51710 54199 0
    13 54297 58997 228
    Overset Partition Statistics: Minimum Maximum Total
    Solve cell count 43070 59651 756754
    Mean solve cell count deviation -20.3% 10.4%
    Dead cell count 0 6359 14218
    Mean dead cell count deviation -100.0% 526.1%
    Done.
     10422 partition interfaces of the 215044 cells aspect ratio > 5
     545456 groups for partitioning (including overlaps)
     Merging groups across partitions:
      1 99888
      2 8996
      3 2718
      4 599
      5 112
      6 20
      7 2
      8 0
     Partition 535235 groups out of 738683 cells
     183 partition interfaces of the 215044 cells aspect ratio > 5
    Grouping and repartitioning the solid cell zones...
    0 3081 778 0.253 163329 1521 0.009 4 1
    1 3081 814 0.264 163934 1432 0.009 5 1
    2 3089 845 0.274 129565 7700 0.059 11 1
    3 3076 819 0.266 164712 1583 0.010 3 1
    4 3080 832 0.270 164935 1464 0.009 6 1
    5 3079 829 0.269 162882 1455 0.009 6 1
    6 3077 1026 0.333 163326 1996 0.012 7 1
    7 3089 795 0.257 165081 1535 0.009 4 1
    8 3092 928 0.300 163821 1637 0.010 5 1
    9 3093 884 0.286 160599 1611 0.010 5 1
    10 3090 761 0.246 161874 1493 0.009 4 1
    11 3075 806 0.262 127548 7289 0.057 9 1
    12 3097 868 0.280 162126 1544 0.010 5 1
    13 3098 319 0.103 126305 4986 0.039 6 1
    Cell count 3075 3098 43197
    Mean cell count deviation -0.3% 0.4%
    Partition boundary cell count 319 1026 11304
    Partition boundary cell count ratio 10.3% 33.3% 26.2%
    Face count 126305 165081 2133715
    Mean face count deviation -18.9% 6.0%
    Partition boundary face count 1432 7700 46322
    Partition boundary face count ratio 0.9% 5.9% 2.2%
    Partition neighbor count 3 11
    0 3081 55196 0
    1 3081 55355 66
    2 3089 54741 617
    3 3076 54989 391
    4 3080 47373 6296
    5 3079 55136 0
    6 3077 55822 0
    7 3089 46159 6359
    8 3092 55351 0
    9 3093 55003 0
    10 3090 54838 0
    11 3075 56138 261
    12 3097 54807 0
    13 3098 55846 228
    Solve cell count 46159 56138 756754
    Mean solve cell count deviation -14.6% 3.9%
    Done.
     42 partition interfaces of the 1073 cells aspect ratio > 5
     43150 groups for partitioning (including overlaps)
      1 6
      2 0
     Partition 43147 groups out of 43197 cells
        *** Subcommunicators recreated (11/14)! ***
     565 partition interfaces of the 1073 cells aspect ratio > 5
    Migrating partitions to compute-nodes.
    Node 1: Process 14244: Received signal SIGSEGV.
    Node 13: Process 4932: Received signal SIGSEGV.
    Node 5: Process 7224: Received signal SIGSEGV.
    Node 11: Process 8716: Received signal SIGSEGV.
    Node 7: Process 6588: Received signal SIGSEGV.
    Node 8: Process 5632: Received signal SIGSEGV.
    Node 9: Process 7040: Received signal SIGSEGV.
    Node 10: Process 3868: Received signal SIGSEGV.
    Node 6: Process 4756: Received signal SIGSEGV.
    Node 4: Process 820: Received signal SIGSEGV.
    = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
    = RANK 0 PID 13864 RUNNING AT DESKTOP-RDMJC80
    = EXIT STATUS: -1 (ffffffff)
    = RANK 2 PID 12200 RUNNING AT DESKTOP-RDMJC80
    The fl process could not be started.
