  4. 计算作用于cellZone上的压力和剪切力
12 帖子 3 发布者 10.1k 浏览
  • liujmL 离线
    liujmL 离线
    liujm
    各位老师和前辈们好,
    我想要通过划定cellZone区域来计算作用于该区域网格上的压力和剪切力,预期功能类似于forces.H中的void Foam::functionObjects::forces::calcForcesMoments()函数,然而,该函数是基于边界patch计算的【代码片段1】,我想要基于cellZone实现。而计算多孔介质部分的力【代码片段2】正是基于cellZone实现的,因此,
    • i) 我想将基于patch的计算边界力的方法移植于多孔介质模块中,这样可行吗?
    • ii) 评论区我放出改写的代码,烦请各位老师指出需要改进的地方
    (如果有老师能够直接给出示例就更好了:140: )
    以下摘取了forces.H中void Foam::functionObjects::forces::calcForcesMoments()部分源码:
    【代码片段1】
        if (directForceDensity_)
            const auto& fD = lookupObject<volVectorField>(fDName_);
            const auto& Sfb = mesh_.Sf().boundaryField();
            for (const label patchi : patchSet_)
                const vectorField& d = mesh_.C().boundaryField()[patchi];
                const vectorField Md(d - origin);
                const scalarField sA(mag(Sfb[patchi]));
                // Pressure force = surfaceUnitNormal*(surfaceNormal & forceDensity)
                const vectorField fP
                    Sfb[patchi]/sA
                        Sfb[patchi] & fD.boundaryField()[patchi]
                // Viscous force (total force minus pressure fP)
                const vectorField fV(sA*fD.boundaryField()[patchi] - fP);
                addToPatchFields(patchi, Md, fP, fV);
        else
            const auto& p = lookupObject<volScalarField>(pName_);
            tmp<volSymmTensorField> tdevRhoReff = devRhoReff();
            const auto& devRhoReffb = tdevRhoReff().boundaryField();
            // Scale pRef by density for incompressible simulations
            const scalar rhoRef = rho(p);
            const scalar pRef = pRef_/rhoRef;
                    rhoRef*Sfb[patchi]*(p.boundaryField()[patchi] - pRef)
                const vectorField fV(Sfb[patchi] & devRhoReffb[patchi]);
    【代码片段2】
    if (porosity_)
            const auto& U = lookupObject<volVectorField>(UName_);
            const volScalarField rho(this->rho());
            const volScalarField mu(this->mu());
            const auto models = obr_.lookupClass<porosityModel>();
            if (models.empty())
                WarningInFunction
                    << "Porosity effects requested, "
                    << "but no porosity models found in the database"
                    << endl;
            forAllConstIters(models, iter)
                // Non-const access required if mesh is changing
                auto& pm = const_cast<porosityModel&>(*iter());
                const vectorField fPTot(pm.force(U, rho, mu));
                const labelList& cellZoneIDs = pm.cellZoneIDs();
                for (const label zonei : cellZoneIDs)
                    const cellZone& cZone = mesh_.cellZones()[zonei];
                    const vectorField d(mesh_.C(), cZone);
                    const vectorField fP(fPTot, cZone);
                    addToInternalField(cZone, Md, fP);
    祝好~
  • liujmL 离线
    liujmL 离线
    liujm
    此处附上改写的代码,烦请各位老师指出错误所在,不胜感激:
        if (porosity_)
            const volVectorField& U  = lookupObject<volVectorField>(UName_);
            const volScalarField& p  = lookupObject<volScalarField>(pName_);   // Add code.
            const HashTable<const porosityModel*> models = obr_.lookupClass<porosityModel>();
            if (models.empty())
                WarningInFunction
                    << "Porosity effects requested, but no porosity models found "
                    << "in the database"
                    << endl;
                porosityModel& pm = const_cast<porosityModel&>(*iter());
                vectorField fPTot(pm.porousForce(U, rho, mu));  // Modified code.
                    const cellZone& cZone = mesh_.cellZones()[zonei];  // Get cells in zonei.
                    const vectorField Md(d - coordSys_.origin());
                    const labelList& cellsID = cZone;  // Add code: Get cellsID(index) list in zonei.
                    vectorField fN(cZone.size(), Zero);
                    vectorField fT(cZone.size(), Zero);
                    scalar                  pRef                            = pRef_/rho(p);   // Add code: Scale pRef by density for incompressible simulations
                    const                   volSymmTensorField& devRhoReff1 = tdevRhoReff();
                    Info << "cellZoneIDs zonei = " << zonei << "\n"<< endl;
                    Info << "cells in zonei: cZone.size() = " << cZone.size() << "\n"<< endl;
                    Info << "fN.size() = " << fN.size() << "\n"<< endl;
                    Info << "fT.size() = " << fT.size() << "\n"<< endl;
                    Info << "fP.size() = " << fP.size() << "\n"<< endl;
                    forAll (cellsID, celli)
                        label cellID               = cellsID[celli];
                        const labelList& cellFaces = mesh_.cells()[cellID];
                        forAll (cellFaces, facei)
                            label faceID = cellFaces[facei];
                              // fN.
                            vector cellFacesFN  = rho(p) * mesh_.Sf()[faceID] * (p[cellID] - pRef);
                            fN    [celli]      += cellFacesFN;
                              // fT.
                            vector cellsFacesfT  = mesh_.Sf()[faceID] & devRhoReff1[faceID];
                            fT    [celli]       += cellFacesFT;
                            Info << "No." << celli << "cell's ID(index) is " << cellID << "\n" << endl;
                            Info << "fN = " << fN[celli] << "\n" << endl;
                            Info << "fT = " << fT[celli] << "\n" << endl;
                            Info << "fP = " << fP[celli] << "\n" << endl;
                    addToFields(cZone, Md, fN, fT, fP);
                    applyBins(Md, fN, fT, fP, d);
  • liujmL 离线
    liujmL 离线
    liujm
    写于 最后由 liujm 编辑
    总体而言,就是要计算cellZone所有网格上的法向力和切向力,而不是仅仅计算作用在固壁边界上的力。
    这里通过图示表达目的:
    你的力定义在面上,如何对你的cellZone里面的所有cells取力?
    liujmL 1 条回复 最后回复
  • liujmL 离线
    liujmL 离线
    liujm
    @李东岳 老师,可以直接对区域内的所有cell压力求积分得出吗?其实这篇帖子是这个帖子的延申:136: 。
    一方面,要保证动网格能够识别到patch名,另一方面也要计算cell上的力,请问李老师有没有更好的实现方法?
    一般力都定义在面上,压力、表面张力
    当然存在一些体积力,比如重力,但不会产生剪切
    但是你好像需要一个产生剪切的体积力,这是什么情况?
    liujmL 1 条回复 最后回复
  • liujmL 离线
    liujmL 离线
    liujm
    @李东岳 老师,我想要模拟浮式多孔介质模型在流体中的运动,因此需要获得物体的力(矩),这里的剪切力其实对应一楼【代码片段1】的54行和56行。
    在 中回复了 liujm 最后由 编辑
    你这个图里面,第一个图是可以理解的,因为force定义在面上,因此可以做面积分。
    第二个myForce,你要对cell做操作,如何做面积分?
    liujmL 1 条回复 最后回复
  • liujmL 离线
    liujmL 离线
    liujm
    在 中回复了 李东岳 最后由 liujm 编辑
    @李东岳 李老师,这也正是我遇到的问题:136: 。
    退一步我做一个简化,在图示的myForces.H的结构最外层cell上套一层patch边界,可不可以仅用patch计算cellZone最外层网格的力和力矩[1],而不阻碍水体穿越被patch包裹的cellZone区域?
    这个想法可行吗,如果可行的话老师方便指点一下,如何实现水体不穿越patch的功能?
    [1] 只计算外层网格表面的受力是因为网衣通常不会太厚,有文献采用2m厚的多孔介质模型,网格尺寸0.5m来模拟。
    在OF2206中,
    对于patch,有addToPatchFields函数:
    void Foam::functionObjects::forces::addToPatchFields
        const label patchi,
        const vectorField& Md,
        const vectorField& fP,
        const vectorField& fV
        sumPatchForcesP_ += sum(fP);
        sumPatchForcesV_ += sum(fV);
        force().boundaryFieldRef()[patchi] += fP + fV;
        const vectorField mP(Md^fP);
        const vectorField mV(Md^fV);
        sumPatchMomentsP_ += sum(mP);
        sumPatchMomentsV_ += sum(mV);
        moment().boundaryFieldRef()[patchi] += mP + mV;
    对于多孔介质的cellZone,有addToInternalField函数:
    void Foam::functionObjects::forces::addToInternalField
        const labelList& cellIDs,
        auto& force = this->force();
        auto& moment = this->moment();
        forAll(cellIDs, i)
            const label celli = cellIDs[i];
            sumInternalForces_ += f[i];
            force[celli] += f[i];
            const vector m(Md[i]^f[i]);
            sumInternalMoments_ += m;
            moment[celli] = m;
  • liujmL 离线
    liujmL 离线
    liujm
    已经想到合适的解决方案啦! 封楼
    Linzd
    在 中回复了 liujm 最后由 编辑
    @liujm 您好,您最终采用了什么方案呢
    liujmL 1 条回复 最后回复
  • liujmL 离线
    liujmL 离线
    liujm
    在 中回复了 Linzd 最后由 编辑
    @Linzd 多孔介质区域在toposet的时候本身只是选中了cell集合,只有在壁面上才能通过原始代码计算法向力和切向力。
