  4. sowfa耦合求解器使用请教
sowfa耦合求解器使用请教
1 帖子 1 发布者 2.1k 浏览
    heyi999
    目前我正在尝试使用sowfa平台,我参考了网上的编译资料进行了编译,但在后续使用过程中出现了耦合fast过程中的.fst文件中的错误,
    [heyi@litian pisofast3]$ cat log1.pisoFoamTurbine.ALM
    No protocol specified
    |  \\    /   O peration     | Version:  2.4.x                                 |
    Build  : 2.4.x-2b147f41daf9
    Exec   : pisoFoamTurbine.ALMAdvancedOpenFAST -parallel
    Date   : Apr 15 2025
    Time   : 17:09:10
    Host   : "litian"
    PID    : 33112
    Case   : /home/heyi/OpenFOAM/SOWFA/run/pisofast3
    nProcs : 8
    Slaves :
    7
    "litian.33113"
    "litian.33114"
    "litian.33115"
    "litian.33116"
    "litian.33117"
    "litian.33118"
    "litian.33119"
    Pstream initialized with:
        floatTransfer      : 0
        nProcsSimpleSum    : 0
        commsType          : nonBlocking
        polling iterations : 0
    Create time
    Create mesh for time = 10
    Reading field, p...
    Reading field, U...
    Creating vorticity field, omega...
    Creating second-invariant of strain-rate tensor field, Q...
    Selecting turbulence model type LESModel
    Selecting LES turbulence model oneEqEddy
    Selecting LES delta type cubeRootVol
    oneEqEddyCoeffs
        ce              1.048;
        ck              0.094;
    [0] nFASTSubSteps has to be the same for all turbines
    [1] nFASTSubSteps has to be the same for all turbines
    [2] nFASTSubSteps has to be the same for all turbines
    [4] nFASTSubSteps has to be the same for all turbines
    [3] nFASTSubSteps has to be the same for all turbines
    [5] nFASTSubSteps has to be the same for all turbines
    [6] nFASTSubSteps has to be the same for all turbines
    [7] nFASTSubSteps has to be the same for all turbines
     OpenFAST
     Copyright (C) 2025 National Renewable Energy Laboratory
     Copyright (C) 2025 Envision Energy USA LTD
     This program is licensed under Apache License Version 2.0 and comes with ABSOLUTELY NO WARRANTY.
     See the "LICENSE" file distributed with this software for details.
     OpenFAST-HEAD-HASH-NOTFOUND
     Compile Info:
      - Compiler: GCC version 9.3.1 20200408 (Red Hat 9.3.1-2)
      - Architecture: 64 bit
      - Precision: double
      - Date: Apr  8 2025
      - Time: 15:03:39
     Execution Info:
      - Date: 04/15/2025
      - Time: 17:09:11+0800
     OpenFAST input file heading:
         FAST Certification Test #18: NREL 5.0 MW Baseline Wind Turbine (Onshore)
     Error in
     FAST_OpFM_Init:FAST_InitializeAll_TFAST_InitializeAll:FAST_Init:FAST_ReadPrimaryFile:Invalid
     logical input for file "NREL5MWRef.1.fst" occurred while trying to read CalcSteady.
     FAST_ReadPrimaryFile:ReadNum:Invalid numeric input for file "NREL5MWRef.1.fst". "False" found
     when trying to read the number, Twr_Kdmp.
     when trying to read the number, Bld_Kdmp.
    terminate called after throwing an instance of 'std::runtime_error'
      what():  FAST_InitializeAll:FAST_Init:FAST_ReadPrimaryFile:Invalid logical input for file "NREL5MWRef.1.fst" occurred while trying to read CalcSteady.
    FAST_ReadPrimaryFile:ReadNum:Invalid numeric input for file "NREL5MWRef.1.fst". "False" found when trying to read the number, Twr_Kdmp.
    FAST_ReadPrimaryFile:ReadNum:Invalid numeric input for file "NREL5MWRef.1.fst". "False" found when trying to read the number, Bld_Kdmp.
    [litian:33112] *** Process received signal ***
    [litian:33112] Signal: Aborted (6)
    [litian:33112] Signal code:  (-6)
    [litian:33112] [ 0] /lib64/libpthread.so.0(+0xf630)[0x7f8c2552f630]
    [litian:33112] [ 1] /lib64/libc.so.6(gsignal+0x37)[0x7f8c25187387]
    [litian:33112] [ 2] /lib64/libc.so.6(abort+0x148)[0x7f8c25188a78]
    [litian:33112] [ 3] /lib64/libstdc++.so.6(_ZN9__gnu_cxx27__verbose_terminate_handlerEv+0x165)[0x7f8c25cb4a95]
    [litian:33112] [ 4] /lib64/libstdc++.so.6(+0x5ea06)[0x7f8c25cb2a06]
    [litian:33112] [ 5] /lib64/libstdc++.so.6(+0x5ea33)[0x7f8c25cb2a33]
    [litian:33112] [ 6] /lib64/libstdc++.so.6(+0x5ec53)[0x7f8c25cb2c53]
    [litian:33112] [ 7] /home/heyi/Programs/openfast-2.4.0/install/lib/libopenfastcpplib.so(+0xdd10)[0x7f8c27d57d10]
    [litian:33112] [ 8] /home/heyi/Programs/openfast-2.4.0/install/lib/libopenfastcpplib.so(_ZN4fast8OpenFAST4initEv+0x4bb)[0x7f8c27d6021b]
    [litian:33112] [ 9] /home/heyi/OpenFOAM/SOWFA/lib/linux64GccDPOpt/libSOWFATurbineModelsOpenFAST.so(_ZN4Foam13turbineModels37horizontalAxisWindTurbinesALMOpenFAST10initializeEv+0x31)[0x7f8c2be99001]
    [litian:33112] [10] /home/heyi/OpenFOAM/SOWFA/lib/linux64GccDPOpt/libSOWFATurbineModelsOpenFAST.so(_ZN4Foam13turbineModels37horizontalAxisWindTurbinesALMOpenFASTC1ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEE+0x1d21)[0x7f8c2be9b141]
    [litian:33112] [11] pisoFoamTurbine.ALMAdvancedOpenFAST[0x429d65]
    [litian:33112] [12] /lib64/libc.so.6(__libc_start_main+0xf5)[0x7f8c25173555]
    [litian:33112] [13] pisoFoamTurbine.ALMAdvancedOpenFAST[0x430ad4]
    [litian:33112] *** End of error message ***
    mpirun noticed that process rank 0 with PID 0 on node litian exited on signal 6 (Aborted).
    错误提示如文,我不知道是我耦合的fast版本不正确还是参数设置还是编译过程有问题?能否有老师指点一下,万分感谢
    NRELOffshrBsline5MW_Onshore_ElastoDyn_Tower.dat NRELOffshrBsline5MW_Blade.dat
