  4. 请教贴:拉格朗日耦合进密度基求解器,能量方程报错
6 帖子 2 发布者 3.5k 浏览
  • R 离线
    R 离线
    Rachel0096
    各位老师们好,目前我在OpenFOAM-v1912中尝试把一个压力基的拉格朗日两相反应求解器(基于coalChemstryFoam)耦合进detonationFoam(密度基)中。目前编译没有问题,可以顺利通过,但是在测试算例时运行会报错(使用的是NS_Sutherland模型):
    === Start Sensible Enthalpy Transport ====
    --> FOAM FATAL ERROR:
    incompatible fields for operation
        [rhoE] - [h]
        From function void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam::fvMatrix<Type>&, const char*) [with Type = double]
        in file /share/home/zhoufan/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude/fvMatrix.C at line 1337.
    FOAM aborting
    #2  void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam::fvMatrix<double> const&, char const*) at ??:?
    #3  Foam::tmp<Foam::fvMatrix<double> > Foam::operator-<double>(Foam::tmp<Foam::fvMatrix<double> > const&, Foam::tmp<Foam::fvMatrix<double> > const&) at ??:?
    #4  ? at ??:?
    #5  __libc_start_main in /lib64/libc.so.6
    #6  ? at ??:?
    Aborted (core dumped)
    这里显示动量方程和组分方程求解都没有问题,在求解能量方程时遇到了赋值不统一的问题。
    这是原本detonationFoam中rhoEEqn的代码:
    surfaceScalarField sigmaDotU
        "sigmaDotU",
            fvc::interpolate(muEff)*mesh.magSf()*fvc::snGrad(U)
          + fvc::dotInterpolate(mesh.Sf(), tauMC)
      & fvc::interpolate(U)
    solve
        fvm::ddt(rhoE)
      + fvc::div(rhoEPhi)
      - fvc::div(sigmaDotU)
        reaction->Qdot()
    e = rhoE/rho - 0.5*magSqr(U);
    e.correctBoundaryConditions();
    thermo.correct();
    rhoE.boundaryFieldRef() == rho.boundaryField()*(e.boundaryField()+0.5*magSqr(U.boundaryField()));
    solve
        fvm::ddt(rho, e) - fvc::ddt(rho, e)
      + thermophysicalTransport->divq(e)
    thermo.correct();
    rhoE = rho*(e + 0.5*magSqr(U));
    p.ref() = rho()/psi();
    p.correctBoundaryConditions();
    rho.boundaryFieldRef() == psi.boundaryField()*p.boundaryField();
    Info<< "min/max(p) = "<< min(p).value() << ", " << max(p).value() << endl;
    Info<< "min/max(T) = "<< min(T).value() << ", " << max(T).value() << endl;
    这是我修改添加颗粒源项之后的代码:
    clock_t t_begin_h = std::clock();
    Info <<  "=== Start Sensible Enthalpy Transport ====" << endl;
    auto dt = runTime.deltaT();
        "sigmaDotU",
    solve
        fvm::ddt(rhoE)
      + fvc::div(rhoEPhi)
      - fvm::laplacian(turbulence->mut()/Prt + turbulence->alpha(), e)
        combustion->Qdot()
      + AlParcels.Sh(e)
      + radiation->Sh(thermo, e)
    thermo.correct();
    solve
    thermo.correct();
    radiation->correct(); //add by vv
    clock_t t_end_h = std::clock();
    double elapsed_secs_h = double(t_end_h - t_begin_h) / CLOCKS_PER_SEC;
    Info <<  "=== Sensible Enthalpy Transport [Done]: "
         << elapsed_secs_h
         << " s ====\n"
         << endl;
    想请教一下大家有没有什么更改的建议。
    具体是哪一行代码有问题?
    R 1 条回复 最后回复
  • R 离线
    R 离线
    Rachel0096
    @Rachel0096 在 请教贴:拉格朗日耦合进密度基求解器,能量方程报错 中说:
    • AlParcels.Sh(e)
    • radiation->Sh(thermo, e)
    李老师,是这个位置有问题,这两行注释了之后就求解器就可以运行了,我尝试过把e更改为rhoE也会报错
    AlParcels.Sh这个是什么,没见过
    radiation->Sh(thermo, e)没有辐射就注释掉,可以
    R 1 条回复 最后回复
  • R 离线
    R 离线
    Rachel0096
    AlParcels.Sh(e)
    这个是自己写的铝颗粒的能量源项,类似于coalChemistryFoam中的coalParcels.Sh(he)和limestoneParcels.Sh(he),表示的是颗粒的能量源项。
    AlParcels.Sh里面哪一行报错?
