Z
Zhoujq
@Zhoujq
  • 请教各位大神PIMPLE算法全称是什么
    Z Zhoujq
    谢谢老师,太牛逼了。
    Z Zhoujq
    PIMPLE算法是OpenFOAM提供的,由PISO和SIMPLE融合来的,网上找到了两个全称。即,第一个:PISO IMplicit Pressure-Linked Equation;第二个:pressure-implicit method for pressure linked equations。
    请教下各位大神,哪个是对的呢,还是有第三种。
    谢谢各位:xinxin3:
  • OpenFOAM循环壁面生成
    Z Zhoujq
    ICEM建模
      1. 本研究基于ICEM建模,首先在构建计算域两侧循环壁面时 (称源面;source) 要和后续OpenFOAM中循环壁面的名字不同;OpenFOAM中重命名的循环壁面被称新面(new):
      1. ICEM进行循环设置:先在Global Mesh Setup—》Global Mesh Parameters 里设置periodicity
        进行网格更新和生成:
    OpenFOAM
      1. 在OpenFOAM中进行网格转化: " fluentMeshToFoam 文件名.msh "。通过checkMesh,无报错:
    checking geometry...
        Overall domain bounding box (-1.925 -0.60993 -0.05) (2.98 0.16507 0.0500586)
        Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
        Mesh has 3 solution (non-empty) directions (1 1 1)
        Boundary openness(1.79143e-17 -2.73076e-15 7.27475e-15) 0K.
        Max cell openness = 4.16732e-16 0K.
        Max aspect ratio = 30.0788 0K.
        Minimum face area = 1.31023e-06.
        Maximum face area = 0.00216234.
        Face areamagnitudes OK.
        Min volume = 4.46199e-09,Max volume = 697531e-06. Total volume = 0.371859. Cell volumes OK.
        Mesh non-orthogonality Max: 38.5733 average: 2.71723
        Non-orthogonality check OK.Face pyramids OK.
        Max skewness = 0.530396 0K.
        Coupled point location match (average o) OK.
    Mesh OK
    End
      1. 检查"boudnary",这时的壁面类型是 wall,需要改进:
    RIGHT
        type      wall;
        inGroups  List<word> 1(wall);
        nFaces    17939;
        startFace 1669453;
    LEFT
        type      wall;
        nFaces    17939;
        startFace 1687392;
      1. 如果直接在"boundary"文件里修改:
    RIGHT
        type           cyclic;
        inGroups       1(cyclic);
        nFaces         17939;
        startFace      1669453;
        neighbourPatch LEFT;
    LEFT
        type           cyclic;
        inGroups       1(cyclic);
        nFaces         17939;
        startFace      1687392;
        neighbourPatch RIGHT;
      1. 进行 checkMesh,报错:
      **Error in coupled point location: 3 faces have their 0th or consecutive vertex not opposite their coupled equivalent. Average mismatch 4.63216e-07.
      <<Writing 3 faces with incorrectly matched 0th (or consecutive) vertex to set coupledFaces
    Failed 1 mesh checks.
    End
      1. 尽管在 ICEM 中进行了结构网格划分,严格对等。但是由于网格数量较大,导入到 OpenFOAM中很容易出现不兼容,报错现象。这时候,需要通过 "createPatchDict"文件对循环壁面进行设置,"createPatchDict"文件需要放到 system目录下:
    pointSync false;
    // Patches to create.
    patches
            // Name of new patch (最好与源面的名字不同,例如示例中的CYCLIC1 (new)和LEFT(source))
            name CYCLIC1:
            // Type of new patch
            patchInfo
                type            cyclic;
                neighbourPatch  CYCLIC2;
                matchTolerance  0.002;
            constructfrom patches;
            patches (LEFT);   //源面
            set f0;
            name CYCLIC2:
            patchInfo
                type            cyclic;
                neighbourPatch  CYCLIC1;
            patches (RIGHT);
            set f0;
      1. 设置完成后,要运行 createPatch。在本案例中生成了一个新的 "0.001" 文件。里面为重新生成的 "polyMesh" 文件,在"boundary"文件包含了正确的循环壁面类型(源面"LEFT" 和"RIGHT"变成了新面"CYCLIC1"和"CYCLIC2"):
    CYCLIC1
        type           cyclic;
        inGroups       List<word> 1(cyclic);
        nFaces         17939;
        startFace      1669453;
        transformType  translational;
        separation     (-1.707449737153865e-10 1.376923575158173e-11 -0.1000000014894364);
    CYCLIC2
        type           cyclic;
        nFaces         17939;
        startFace      1687392;
        separation     (1.707449737153865e-10 -1.376923575158173e-11 0.1000000014894364);
      1. 把正确的"polyMesh"替换到"constant"文件中,重新 checkMesh,没报错:
    Checking geometry ...
        Boundary openness (1.79143e-17 -2.73076e-15 1.01788e-14) 0K.
        Max aspect ratio'= 30.0788 0K.
        Minimum face area = 1.31023e-06. Maximum face area = 0.00216234. Face area magnitudes oK.
        Min volume = 4.46199e-09.  Max volume = 6.97531e-06.  Total volume = 0.371859.   Cell volumes OK.
        Mesh non-orthogonality Max: 38.5733 average: 2.70242
        Face pyramids OK.
        Coupled point location match (average 4.63138e-07) OK.
    Mesh OK.
    End
    参考文献:
    本次教程解决了我面临的问题,主要结合以下教程:
    ICEM 部分:
      1. CFD中文网:
        链接文本
    OpenFOAM部分:
      1. CFDonline:
        链接文本
        附件:createPatchDict.gz
      1. 知乎:
        链接文本
        附件:channel_v0.4.tar.gz
      1. CSDN:
        链接文本
  • OpenFOAM 里计算Cp,Cf等参数
    Z Zhoujq
    @calrel 非常感谢
    Z Zhoujq
    @hoversoar 你好,请问下这个Cp后处理是如何实现的呢,非常感谢
  • 请教关于k和epsilon壁面函数的问题
    Z Zhoujq
    @wwq 在 请教关于k和epsilon壁面函数的问题 中说:
    https://www.openfoam.com/documentation/guides/latest/doc/guide-bcs-wall-turbulence-epsilonWallFunction.html
    非常感谢:146:
  • OpenFOAM 模型编译资料求助
    Z Zhoujq
    @bestucan :xinxin2:
  • 在论文中网格的表达形式大家都用什么
    Z Zhoujq
    @李东岳 :ok3: :ok3: :ok3:
  • 在论文中网格的表达形式大家都用什么
    Z Zhoujq
    在网格的编写上,看论文中有的用Grid,有的用Mesh,大家一般都用什么呢?
  • 请教下在Paraview如何选择区域性的流场显示
    Z Zhoujq
    @tens 非常感谢,好好用:xinxin::146:
    Z Zhoujq
    像这种模型,一半显示流场的流线,一半不显示,在paraview中如何实现呢?
    非常感谢:140:
  • 请教一个求解斯特劳哈尔数(Strouhal number)的Open FOAM操作
    Z Zhoujq
    @李东岳 谢谢老师,非常感谢:140:
    Z Zhoujq
    @cresendo 非常感谢
    Z Zhoujq
    @李东岳 谢谢老师
    Z Zhoujq
    关于钝体的一个斯特劳哈尔数(Strouhal number)的求解: St=fL/V
    一般论文中的方法是根据升力系数的快速傅里叶变化频率分析来得的,其中的 St=fL/V是根据升力的频率f计算的,其给出效果图如下
    真心地请教下各位,对于这个图中的St数在OpenFOAM中是如何实现的呢?
    非常感谢~
  • 请教forceCoeffs中的Cl(f)和Cl(r)的含义
    Z Zhoujq
    @Joann 是的,我的放到了 controlDict 里的 function 的中
  • 请教下在钝体仿真中为什么网格尺度越小,反而效果越不好
    Z Zhoujq
    @李东岳 是的,老师,是VOF,选用的RNG k-e。
    目前来看2D的计算快一些,还是有一些规律能总结出来和PIV的数据对比较好,但是中间一些细节的论证还有些问题,和三维确实差距大,尤其是吃水越深差距越大。等我把这些问题解决了,到时候把结果和规律放在这里,同大家一起学习,同时感谢老师的提携和大力的帮助:140:
    Z Zhoujq
    @李东岳 老师,网格加密后,发现了更多的问题,:136:
    我这个案例一共4种吃水,吃水的影响对于网格的要求特别大,我在加紧做更多的测试,我准备做完后整理成文档,然后我就正式拜师学艺啦,想想都激动,终于快到这个时候了:wolaile:
    这个前期的准备够长的,本来想做三维的,结果周期太长了,这是个战略上的失误,这次二维的先把规律做出来:xiezuoye:
    Z Zhoujq
    @李东岳 好的,老师,我试试
