  4. 浮点数例外(核心已转储) 问题
浮点数例外(核心已转储) 问题
3 帖子 2 发布者 5.2k 浏览
  • 七 离线
    七 离线
    七辆战车
    先对路过的大佬表示下感谢!在运行overOlaDyMFlow时没一会就出现了如下问题,看了网上的大部分解答,也没清楚自己的原因在哪,
    PIMPLE: Operating solver in PISO mode
    Reading field porosityIndex
    Porosity NOT activated
    Reading field p_rgh
    Reading field U
    Creating cellMask field to block out hole cells
    Creating interpolatedCells field
    Reading transportProperties
    Selecting turbulence model type RAS
    Selecting RAS turbulence model kOmegaSST
    Selecting patchDistMethod meshWave
    RAS
        RASModel        kOmegaSST;
        turbulence      on;
        printCoeffs     on;
        alphaK1         0.85;
        alphaK2         1;
        alphaOmega1     0.5;
        alphaOmega2     0.856;
        gamma1          0.555555555556;
        gamma2          0.44;
        beta1           0.075;
        beta2           0.0828;
        betaStar        0.09;
        a1              0.31;
        b1              1;
        c1              10;
        F3              false;
        decayControl    false;
        kInf            0;
        omegaInf        0;
    Reading g
    Reading hRef
    Calculating field g.h
    No MRF models present
    DICPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
    Reading/calculating face velocity Uf
    Courant Number mean: 0 max: 0
    Starting time loop
    Interface Courant Number mean: 0 max: 0
    deltaT = 1.19997600048e-05
    Time = 1.19998e-05
    PIMPLE: iteration 1
    forces forces:
    --> FOAM Warning :
        From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const
        in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 868
        Cannot find any patch or group names matching floatingObject
        rho: rho
        Not including porosity effects
    6-DoF rigid body motion
        Centre of rotation: (2 0.5 0.999999999647)
        Centre of mass: (2 0.5 0.999999999647)
        Orientation: (1 0 0 0 1 0 0 0 1)
        Linear velocity: (0 0 -5.88588228235e-05)
        Angular velocity: (0 0 0)
    inverseDistance : detected 1 mesh regions
        zone:0 nCells:2096472  voxels:(127 127 127) bb:(-4.472135955e-06 -0.100004472136 -4.472135955e-06) (4.00000447214 1.10000447214 1.60000447214)
    Overset analysis : nCells : 2096472
        calculated   : 1800000
        interpolated : 0 (interpolated from local:0  mixed local/remote:0  remote:0)
        hole         : 296472
    Execution time for mesh.update() = 7.21 s
    smoothSolver:  Solving for alpha.water, Initial residual = 0, Final residual = 0, No Iterations 0
    Phase-1 volume fraction = 0  Min(alpha.water) = 0  Max(alpha.water) = 0
    MULES: Correcting alpha.water
    alpha.water BC on patch inlet
    #0  Foam::error::printStack(Foam::Ostream&) addr2line failed
    #1  Foam::sigFpe::sigHandler(int) addr2line failed
    #2  ? addr2line failed
    #3  StokesIFun::waveLength(double, double) addr2line failed
    #4  Foam::waveAlphaFvPatchScalarField::updateCoeffs() addr2line failed
    #5  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate()
    #6  ?
    #7  ?
    #8  ?
    #9  __libc_start_main addr2line failed
    #10  ?
    浮点数例外 (核心已转储)
    此前还存有一个warning
    --> FOAM Warning :
    不知道是否对求解造成了影响
  • 一 离线
    一 离线
    一颗鸭蛋
    浮点数溢出(核心已转储)应该是你网格有问题,刚开始做的时候我也经常遇到,到,可以先查查网格,长宽比不要太大。warning 的话一般没有问题的,只要不出现错误。
    七 1 条回复 最后回复
  • 七 离线
    七 离线
    七辆战车
    在 中回复了 一颗鸭蛋 最后由 编辑
    @一颗鸭蛋 谢谢你的回答,我用的重叠网格,贴体网格和背景网格的长宽都是1:1且一样大,然后就不知道问题出在哪里了:zoule:
