  4. 关于成核模型中的UDF问题
关于成核模型中的UDF问题
11 帖子 6 发布者 14.8k 浏览
  • 关 离线
    关 离线
    关伯兰在笑
    各位大佬好,最近在PBM模型中要写入一个关于成核的UDF,按照教程中的示例做了修改,然后再fluent中编译时出现了问题,麻烦各位大佬看看时怎么了
    代码如下:
               UDF that computes the particle nucleation rate
    #include "udf.h"
    #include "sg_pb.h"
    #include "sg_mphase.h"
    DEFINE_PB_NUCLEATION_RATE(nuc_rate, cell, thread)
    real B;/* nucleation rate in #/(s kg-solvent)*/
    real Kb_1 = 4.355; /* primary nucleation rate constant */
    real Kb_2 = 3.968e14;/* secondary nucleation rate constant */
    real b_1  = 1.852;/* primary nucleation law power index */
    real b_2  = 4.226;/* secondary nucleation law power index */
    real x;/*the antisolvent proportion in kg- antisolvent/kg-antisolvent and solvent */
    real y;/*the solubility in kg-solute/kg- antisolvent and solvent */
    real C;/*the solute concentration in kg-solute/kg-solvent*/
    real Solubility;/*the solubility in kg-solute/kg-solvent */
    real delta_C;/*the difference between the solute concentration and the solubility, kg-solute/kg-solvent*/
    real solute_mass_frac,solvent_mass_frac,antisolvent_mass_frac;
    real m;
    Thread *tc = THREAD_SUPER_THREAD(thread); /*obtain mixture thread */
    Thread **pt = THREAD_SUB_THREADS(tc); /* pointer to sub_threads */
    Thread *tp = pt[P_PHASE]; /* primary phase thread */
    solute_mass_frac = C_YI(cell,tp,0);/*mass fraction of solute in primary phase (solvent,antisolvent,Paracetamol)*/
    solvent_mass_frac = C_YI(cell,tp,1);/* mass fraction of solvent in primary phase (solvent,antisolvent,Paracetamol ) */
    antisolvent_mass_frac = 1-solute_mass_frac-solvent_mass_frac;/* mass fraction of antisolvent in primary phase (solvent,antisolvent,Paracetamol)*/
    x=antisolvent_mass_frac/(antisolvent_mass_frac+solvent_mass_frac);/*the antisolvent proportion in kg- antisolvent/kg-antisolvent and solvent */
    y =-2.63748*pow(x,4)+9.04654*pow(x,3)-10.86277*pow(x,2)+5.04399*x-0.57920;/*the solubility in kg-solute/kg- antisolvent and solvent */
    Solubility=y*(1+(antisolvent_mass_frac/solvent_mass_frac));/*the solubility in kg-solute/kg- solvent */
    C=solute_mass_frac/solvent_mass_frac;/*the solute concentration in kg-solute/kg- solvent*/
    delta_C = C-Solubility; /* Definition of Supersaturation */
    m=C_VOF(cell,pt[1])*1293;
    if (delta_C == 0.)
    B = 0.;
    else
    B = (Kb_1)*pow(delta_C,b_1)+(Kb_2)*pow(delta_C,b_2)*m;
    return B;
    Build的时候提示是这样的
    然后点击Load的提示是这样的
    编程功力不太行,只能按照示例在上面修改,很多地方不太懂,还请各位大佬帮忙看看,这究竟是咋回事呢?@东岳
    袁宝强袁 1 条回复 最后回复
  • lee459317530L 离线
    lee459317530L 离线
    lee459317530
    你这注释的格式就有问题呀!
    #include "udf.h"
    #include "sg_pb.h"
    	real B;/* nucleation rate in #/(s kg-solvent) */
    	real Kb_2 = 3.968e14; /*secondary nucleation rate constant */
    	real b_1 = 1.852; /* primary nucleation law power index */
    	real m;
    	Thread *pt = THREAD_SUB_THREADS(thread); /*pointer to sub_threads */
    	Thread tp = pt[P_PHASE]; /* primary phase thread */
    	antisolvent_mass_frac = 1.-solute_mass_frac-solvent_mass_frac;/* mass fraction of antisolvent in primary phase (solvent,antisolvent,Paracetamol)*/
    	x = antisolvent_mass_frac/(antisolvent_mass_frac+solvent_mass_frac);/*the antisolvent proportion in kg- antisolvent/kg-antisolvent and solvent */
    	y = -2.63748*pow(x,4)+9.04654*pow(x,3)-10.86277*pow(x,2)+5.04399*x-0.57920; /* the solubility in kg-solute/kg- antisolvent and solvent */
    	Solubility = y*(1+(antisolvent_mass_frac/solvent_mass_frac)); /*the solubility in kg-solute/kg- solvent */
    	C = solute_mass_frac/solvent_mass_frac;/*the solute concentration in kg-solute/kg- solvent*/
    	m = C_VOF(cell, pt[1])*1293.;
    	if (delta_C == 0.)
    		B = 0.;
    	else
    	return B;
    代码的部分问题我帮你修改了,不一定都正确,你自己再检查检查,然后再按上面这图中提示的信息自己查阅资料(无论UDF手册还是C语言基础书籍还是其他什么资料)去进行调试吧,加油!:146:
    一直在学习,从未放弃过~
    bestucanB 关 2 条回复 最后回复
    在 中回复了 lee459317530 最后由 bestucan 编辑
    @lee459317530 他注视格式不对是因为代码部分的"*"被当成正文里的markdown标记,被吃了:chigua2:
    @关伯兰在笑 开fluent的时候在“开始”里搜"commander",开那个带“x64”的,是commander tool还是啥。然后在那个终端里输入fluent,回车,这样的打开的fluent带64位编译功能。如果没有64位commander,需要安装visual studio。
    关 2 条回复 最后回复
  • 关 离线
    关 离线
    关伯兰在笑
    @bestucan 多谢多谢!
  • 关 离线
    关 离线
    关伯兰在笑
    在 中回复了 lee459317530 最后由 李东岳 编辑
    @lee459317530
    请问为什么要将Thread **pt = THREAD_SUB_THREADS(tc);改成Thread *pt = THREAD_SUB_THREADS(thread); 呢?
    我使用Thread **pt = THREAD_SUB_THREADS(tc);的时候就显示“生成成功”了
    但还是有之前同样的问题
  • 关 离线
    关 离线
    关伯兰在笑
    @bestucan
    在开始里面搜commander是这个吗
    bestucanB I 2 条回复 最后回复
    在 中回复了 关伯兰在笑 最后由 编辑
    @关伯兰在笑 试试,我搜出来的是 x64 Native Tools Command Prompt for VS 2019。兴许不同版本的不一样,也可能是中英文的区别。
  • I 离线
    I 离线
    ibelief
    @关伯兰在笑 在 关于成核模型中的UDF问题 中说:
    @bestucan
    在开始里面搜commander是这个吗
    对
    以管理员身份运行
    努力收敛
  • I 离线
    I 离线
    ibelief
    在 中回复了 关伯兰在笑 最后由 编辑
    @关伯兰在笑 https://www.bilibili.com/video/BV1KZ4y1g7i6/
    可以参考此视频
    努力收敛
    Maud
    请问楼主问题解决了吗?~
  • 袁宝强袁 离线
    袁宝强袁 离线
    袁宝强
    在 中回复了 关伯兰在笑 最后由 编辑
    @关伯兰在笑 楼主的代码是没问题的,我在自己电脑编译通过了。应该是编译环境的问题,试试重装个编译器吧,我一直用VS2010,比较稳定
