  4. 读取变量 segmentation fault
13 帖子 3 发布者 17.3k 浏览
    autoPtr<incompressible::turbulenceModel> turbulence
        incompressible::turbulenceModel::New(U, phi, thermo())
    这里有问题,具体问题还需要debug
    hongjiewang
    @李东岳 可是老师比较奇怪的是,我把turbulence调整顺序,放在前面之后,他是可以读取的,在最后的g又会出现同样的错误。下面是我调整顺序后的createFields.H文件。根据调整变量出现的顺序就导致了segmentation fault位置的不同,我猜测是不是和出现错误本身的变量并没有关系,而是里面的某个数读取错误,导致栈储存满了。但是我看了好几遍,对变量的类型进行了检查,发现并没有这方面的错误~所以不是很清楚我要怎么找这个错误。老师您提到的debug我需要再学习一下怎么使用
    Info<< "Reading field psi0\n" << endl;
        volScalarField psi0
                "psi0",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
                IOobject::AUTO_WRITE
            mesh,
            dimensionedScalar("psi0",dimless, 0.0)
        Info<< psi0<< endl;
        Info<< "Reading field psi\n" << endl;
        volScalarField psi
                "psi",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
            mesh,
            dimensionedScalar("delta",dimless, 0.0)
        Info<< psi<< endl;
        Info<< "Reading field delta\n" << endl;
        volScalarField delta
                "delta",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
            mesh,
        Info<< delta << endl;
        Info<< "Reading field H\n" << endl;
        volScalarField H
                "H",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
            mesh,
            dimensionedScalar("H",dimless, 0.0)
        Info<< H << endl;
        volScalarField C
                "C",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
            mesh,
            dimensionedScalar("C",dimless/dimLength, 0.0)
        Info<< C << endl;
    /*    Info<< "Reading field p\n" << endl;
        volScalarField p
                "p",
                runTime.timeName(),
                mesh,
                IOobject::MUST_READ,
            mesh
        Info<< "Reading field p_rgh\n" << endl;
        volScalarField p_rgh
                "p_rgh",
                runTime.timeName(),
                mesh,
            mesh
        Info<< p_rgh << endl;
        Info<< "Reading wetting fluid velocity field Uwetting\n" << endl;
        volVectorField Uwetting
                "Uwetting",
                runTime.timeName(),
                mesh,
            mesh
        Info<< Uwetting << endl;
        Info<< "Reading wetting fluid velocity field UnonWetting\n" << endl;
        volVectorField UnonWetting
                "UnonWetting",
                runTime.timeName(),
                mesh,
            mesh
        Info<< UnonWetting << endl;
        Info<< "Reading field U\n" << endl;
        volVectorField U
                "U",
                runTime.timeName(),
                mesh,
                IOobject::READ_IF_PRESENT,
            UnonWetting + Uwetting
        Info<< U << endl;
        Info<< "Reading fluid fraction field eps\n" << endl;
        volScalarField eps
                "eps",
                runTime.timeName(),
                mesh,
            mesh
        Info<< eps << endl;
        Info<< "Reading solid indicator\n" << endl;
        volScalarField Solid
                "Solid",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
            mesh,
            dimensionedScalar("solid", dimensionSet(0,0,0,0,0,0,0), 0)
        Info<< "Reading field Tsol (Solid Phase Temperature)\n" << endl;
        volScalarField Tsol
                "Tsol",
                runTime.timeName(),
                mesh,
            mesh
        Info<< Tsol << endl;
    IOdictionary transportProperties
            "transportProperties",
            runTime.constant(),
            mesh,
            IOobject::MUST_READ_IF_MODIFIED,
            IOobject::NO_WRITE
        Info<< "Reading solid density\n" << endl;
        dimensionedScalar rhoSolid
            "rhoSolid", dimMass/dimLength/dimLength/dimLength, transportProperties
        Info<< rhoSolid << endl;
        Info<< "Reading solid specific heat capacity\n" << endl;
        dimensionedScalar CpS
            "CpS", dimAcceleration*dimLength/dimTemperature,  transportProperties
        Info<< "Reading solid heat diffusion\n" << endl;
        dimensionedScalar kappaEffSolid
            "kappaEffSolid", dimForce/dimTime/dimTemperature, transportProperties
        Info<< "Reading interfacial heat transfer coefficient hsf\n" << endl;
        dimensionedScalar hsf
            "hsf", dimEnergy/dimMass, transportProperties
        #include "createPhi.H"
    // Creating e based thermo
    Info<< "Creating e based thermo\n" << endl;
    autoPtr<twoPhaseMixtureEThermo> thermo
        new twoPhaseMixtureEThermo(U, phi)
    Info<< "1" << endl;
    Info<< "Construct incompressible turbulence model\n" << endl;
    // Create mixture and
    Info<< "Creating temperaturePhaseChangeTwoPhaseMixture\n" << endl;
    autoPtr<temperaturePhaseChangeTwoPhaseMixture> mixture =
        temperaturePhaseChangeTwoPhaseMixture::New(thermo(), mesh);
    //Info<< "Reading transportProperties\n" << endl;
    //immiscibleIncompressibleTwoPhaseMixture mm(U, phi);
    volScalarField& alpha1(thermo->alpha1());
    volScalarField& alpha2(thermo->alpha2());
    const dimensionedScalar& rho1 = thermo->rho1();
    const dimensionedScalar& rho2 = thermo->rho2();
    Info<< "Reading nu\n" << endl;
        dimensionedScalar nu1
            "nu1", dimViscosity, transportProperties.subDict("liquid").lookup("nu")
        dimensionedScalar nu2
            "nu2", dimViscosity, transportProperties.subDict("vapour").lookup("nu")
    Info<< "Reading mu\n" << endl;
        dimensionedScalar mu1("mu1",nu1*rho1);
        dimensionedScalar mu2("mu2",nu2*rho2);
        Info<< mu1 << endl;
    Info<< "Need to store rho for ddt(rho, U)\n" << endl;
    volScalarField rho
            "rho",
            runTime.timeName(),
            mesh,
        alpha1*rho1 + alpha2*rho2
    //rho.oldTime();
    Info<< "Mass flux\n" << endl;
        surfaceScalarField rhoPhi
                "rhoPhi",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            fvc::interpolate(rho)*phi
    Info<< "Mass flux by eps\n" << endl;
        surfaceScalarField rhoPhiByEps
                "rhoPhiByEps",
                runTime.timeName(),
                mesh,
                IOobject::NO_WRITE
            rhoPhi*linearInterpolate(1/(eps+SMALL))
    Info<< "Construct interface from alpha1 distribution\n" << endl;
    interfaceProperties interface
        alpha1,
        U,
        thermo->transportPropertiesDict()
        dimensionedScalar deltaX("deltaX", dimless, thermo->transportPropertiesDict());
    dimensionedScalar gamma("gamma", dimless, deltaX.value()*0.75);
    dimensionedScalar epsilon("epsilon", dimless, deltaX.value()*3.5);
    dimensionedScalar deltaTau("deltaTau", dimless, deltaX.value()*0.1);
        dimensionedScalar dimChange
            dimensionedScalar("dimChange", dimLength, 1.0)
        dimensionedScalar sigma
            "sigma", dimMass/dimTime/dimTime, thermo->transportPropertiesDict()
    Info<< "MULES compressed flux is registered in case scalarTransport FO needs it\n" << endl;
    surfaceScalarField alphaPhi
            "alphaPhi",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        phi*fvc::interpolate(alpha1)
    dimensionedScalar Prt("Prt", dimless, thermo->transportPropertiesDict());
    Info<< "kappaEff\n" << endl;
    volScalarField kappaEff
            "kappaEff",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        thermo->kappa()
    Info<< "Need to store rho for ddt(rhoCp, U)\n" << endl;
    volScalarField rhoCp
            "rhoCp",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        rho*thermo->Cp()
    //rhoCp.oldTime();
    Info<< "1" << endl;
    #include "createMRF.H"
    #include "createFvOptions.H"
    Info<< "1" << endl;
    #include "readGravitationalAcceleration.H"
    Info<< "1" << endl;
    #include "readhRef.H"
    Info<< "1" << endl;
    #include "gh.H"
    Info<< "1" << endl;
    Info<< "Turbulent Prandtl number\n" << endl;
    volScalarField& p = thermo->p();
    label pRefCell = 0;
    scalar pRefValue = 0.0;
    setRefCell
        p,
        p_rgh,
        pimple.dict(),
        pRefCell,
        pRefValue
    if (p_rgh.needReference())
        p += dimensionedScalar
            "p",
            p.dimensions(),
            pRefValue - getRefCellValue(p, pRefCell)
        p_rgh = p - rho*gh;
    mesh.setFluxRequired(p_rgh.name());
    mesh.setFluxRequired(alpha1.name());
    #include "createPorousMediaFields.H"
    错误显示:
    Selecting turbulence model type laminar
    Selecting laminar stress model Stokes
    Selecting phaseChange model Lee
    Reading nu
    Reading mu
    mu1 [1 -1 -1 0 0 0 0] 0.0009584
    Mass flux
    Mass flux by eps
    kappaEff
    Segmentation fault (core dumped)
    可以看到turbulence可以正确的选择laminar,我看segmentation faul多是和指针错误有关,下面的mu可以正确的计算,是不是可以说这里面的thermo和mixture指针是不存在问题的。
    hongjiewang
    case
    test.zip
    曾经,我排过一个很狗血的错,一台电脑的某个软件也是这样捉摸不定的出错,不知道在哪里,也没有一点点防备。找了半天发现是磁盘满了。还剩一丢丢空间,所以一开软件,这个空间什么时候被临时文件占满了,就崩了。错误特征完全无法捉摸。
    这个,可以du -h看看各挂载点的空间。然后,开两个窗口。一个开top,监视内存;一个开求解器,看内存的实时占用,不过有捕捉不到的风险。可以把网格尽量缩小再试试。这些变量占的空间基本都依托于网格。
    还有一个点,这两个错误都跟 thermo 有关。thermo好像也和湍流有关
    https://www.openfoam.com/documentation/guides/latest/api/classFoam_1_1ThermalDiffusivity.html
    hongjiewang
    在 中回复了 bestucan 最后由 hongjiewang 编辑
    @bestucan 感谢老师的回复。我先一个一个排除一下可能的错误。
    我查看了一下,看到还有250+GB的空间,而且我的网格数从100✖100✖200减少到5✖5✖10都存在一样的错误,或许可以初步排查是内存的问题。
    我想请问一下老师,是怎么发现这两个错误和thermo有关系的,我不是很明白。
    因为我下面有一个是输出mu的值,而所需要的ρ是从thermo里读取到的,mu输出的值正确也是不能保障thermo指针正确吗。
    turbulence引用的时候需要thermo,如果我把turbulence的定义放在thermo后一个,就可以正确读取turbulence。放到后面几个就读取错误了。
    我先去看一下老师说的监视内存的方法,看具体是什么情况。感谢老师。
    bestucanB 1 条回复 最后回复
    在 中回复了 hongjiewang 最后由 编辑
    @hongjiewang 第二个错误信息我看错了,确实不是都和thermo有关。
    可是你的第二个错误你说 g 出的错,
    这一句后面只跟一个 “1”,在代码里不是这里么
    Info<< "1" << endl;
    Info<< "1" << endl;
    createMRF.H 或者 creat FvOptions.H
    输出第二个“1”才到g
    250的网格都错,和内存无关了。这种面向对象的程序一般写的时候都有脚手架,就像官网的代码有很多框图,但又比那些框图要详细。这留个窟窿那钻个眼都有用,可是只看代码非常费功夫才知道有什么用。不知道有什么用就很容易错。互相之间的依赖关系,先后顺序。那些不报错的是没语法错误了,不一定没语义错误。所以一般都在原有的类似的求解器上增删改;改变结构造个新的,还是挺麻烦的。of的路慢慢熬吧。:xinlei:
    如果还不行,用gdb调试,有gdb的of版,gdbof
    H 2 条回复 最后回复
    hongjiewang
    @bestucan 在 读取变量 segmentation fault 中说:
    Info<< "1" << endl;
    Info<< "1" << endl;
    输出第二个“1”才到g
    这里我看串行了,确实不是到g变量。我还是尝试一下gdb调试吧~有结果的话和各位老师分享~
    感谢老师~
    hongjiewang
    @bestucan 请问我重新编译of的时候,提示错误而终止了,这是什么原因奥~
    step1:修改etc/bashrc中的OPTION为Debug
    step2:在对应版本的openfoam终端下 source etc/bashrc
    step2:.Allwmake -j
    state/lumpedPointState.C: In constructor ‘Foam::lumpedPointState::lumpedPointState(const pointField&, const vectorField&, Foam::quaternion::eulerOrder, bool)’:
    state/lumpedPointState.C:154:49: error: expected ‘;’ before ‘exit’
      154 |             << angles_.size() << " angles" << nl
      155 |             exit(FatalError);
    是在154行nl后添加;就可以了吗
    @hongjiewang 我也编译过 debug 模式的 of ,就是比正常慢点,没出现过这种错误。这种错误看起来很初级不像是源代码带的。我搜我的代码的这个文件也没这句。
    单这个错误,是的,加个分号就行。就是一个语句忘了结尾。
    hongjiewang
    @bestucan
    加了分号确实可以继续编译了,但是我从https://www.openfoam.com/documentation/guides/latest/api/lumpedPointState_8C_source.html找到源文件,他也是没有分号的,我没有改动过这个文件。
    @hongjiewang
    照这个修改,不加引号,加 << 和下面一句连一起。
    https://develop.openfoam.com/Development/openfoam/-/commit/fa86a98482355f28520374069479d63303016c30
    hongjiewang
    @bestucan 谢谢老师 已改:xinxin:
