  4. LES定义入口速度的问题(DSRFG方法)
82 帖子 16 发布者 315.5k 浏览
    sunss
    NSRFG湍流入口合成方法分享(我在验证结果的时候发现NSRFG方法和CDRFG方法均存在水平方向流场均一性问题,不知道对不对)。
    %% NSRFG湍流合成方法
    tic
    clc,clear
    %%生成0-fmax Hz范围的功率谱
    fmax=25;df=0.001;fw=df:df:fmax;
    N=length(fw);
    fm=(2*(1:N)-1)/2*df;
    Time_NSRFG=1000;%时间点数量
    h=1/fmax/2;%时间步长
    Fs=1/h;
    %%入口尺寸和模拟点数量设置
    x=1;%流场方向坐标
    y=1;%水平方向坐标
    z=[linspace(0.01,0.1,10),linspace(0.11,0.5,20),linspace(0.55,1,10)];%竖直方向坐标
    N0_Y=length(y);N0_Z=length(z);N0_X=length(x);%X,Y,Z对应u,v,w,各方向上的点数
    xyz=[repmat(x,length(z)*length(y),1),...
        repmat(y',length(z),1),...
        reshape(repmat(z,length(y),1),[],1)]';
    %%切分Time_NSRFG成N0_T段,避免内存溢出
    memory_capacity=0.4*10^9;%16G内存建议取值,内存越大计算速度越快
    N0_t=min(fix(memory_capacity/(N0_Z*N0_Y)/N),Time_NSRFG);
    N0_T=ceil(Time_NSRFG/N0_t);
    %%相关性参数设置,
    c_1=10;c_2=12;c_3=12;
    Gammaix=1.8;Gammaiy=1.5;Gammaiz=1.8;
    %%风场特性-风速
    z_ref=0.4;%标准参考高度
    alpha=0.25;%粗糙度指数
    U_ref=10.0;%参考风速
    I_10=0.23;
    coefv=0.88;
    coefw=0.55;
    Uav=U_ref*(z/z_ref).^alpha;
    Uav_map=(reshape(repmat(Uav,N0_Y,1),[],1))';
    %%风场特性-湍流强度
    Iu=0.1*(z/z_ref).^(-alpha-0.05);
    Iv=coefv*Iu;
    Iw=coefw*Iu;
    I_map=[(reshape(repmat(Iu,N0_Y,1),[],1)),...
        (reshape(repmat(Iv,N0_Y,1),[],1)),...
        (reshape(repmat(Iw,N0_Y,1),[],1))]';=
    %%风场特性-积分尺度
    z_0=0.25;
    Lu=linspace(0.25,1,N0_Z);
    Lv=0.5*coefv^3*Lu;
    Lw=0.5*coefw^3*Lu;
    L_map=[(reshape(repmat(Lu,N0_Y,1),[],1)),...
        (reshape(repmat(Lv,N0_Y,1),[],1)),...
        (reshape(repmat(Lw,N0_Y,1),[],1))]';
    %初始化参数
    Su=zeros(N,N0_Z*N0_Y);Sv=zeros(N,N0_Z*N0_Y);Sw=zeros(N,N0_Z*N0_Y);
    p_uvw=zeros(3,N);
    p_u=zeros(N,N0_Z*N0_Y);p_v=zeros(N,N0_Z*N0_Y);p_w=zeros(N,N0_Z*N0_Y);
    Lx=zeros(N,N0_Z*N0_Y);Ly=zeros(N,N0_Z*N0_Y);Lz=zeros(N,N0_Z*N0_Y);
    q_1n=zeros(N,N0_Z*N0_Y);q_2n=zeros(N,N0_Z*N0_Y);q_3n=zeros(N,N0_Z*N0_Y);
    A_n=zeros(N,N0_Z*N0_Y);B_n=zeros(N,N0_Z*N0_Y);
    k_1n=zeros(N,N0_Z*N0_Y);k_2n=zeros(N,N0_Z*N0_Y);k_3n=zeros(N,N0_Z*N0_Y);
    K_xyz=zeros(3,N0_Z*N0_Y,N);
    x_1n=zeros(N,N0_Z*N0_Y);x_2n=zeros(N,N0_Z*N0_Y);x_3n=zeros(N,N0_Z*N0_Y);
    X_xyz=zeros(3,N0_Z*N0_Y,N);
    U_u0=zeros(N0_t,N0_Z*N0_Y,N);U_v0=zeros(N0_t,N0_Z*N0_Y,N);U_w0=zeros(N0_t,N0_Z*N0_Y,N);
    U_u=zeros(1,N0_Z*N0_Y);U_v=zeros(1,N0_Z*N0_Y);U_w=zeros(1,N0_Z*N0_Y);
    %球面随机采样
    S = randn(N,3);
    sign_n =bsxfun(@rdivide, S, sqrt(sum(S.*S, 2)));
    plot3(sign_n(:,1),sign_n(:,2),sign_n(:,3),'.k', 'MarkerSize',10)    %绘制原始散点数据
    %%生成随机数\thea_n
    thea_n=2*pi*rand(N+100,N0_Z*N0_Y);
    %%生成参数矩阵
    parfor n=1:N%频率范围
        disp('n');disp(n);
        Su(n,:)=4*(I_map(1,:).*Uav_map).^2.*(L_map(1,:)./Uav_map)./...
            (1+70.8*(fm(n)*L_map(1,:)./Uav_map).^2).^(5/6);%Karman
        Sv(n,:)=4*(I_map(2,:).*Uav_map).^2.*(L_map(2,:)./Uav_map).*...
            (1+755.2*(fm(n)*L_map(2,:)./Uav_map).^2)./((1+283.2*(fm(n).*L_map(2,:)./Uav_map).^2).^(11/6));%Karman
        Sw(n,:)=4*(I_map(3,:).*Uav_map).^2.*(L_map(3,:)./Uav_map).*...
            (1+755.2*(fm(n)*L_map(3,:)./Uav_map).^2)./((1+283.2*(fm(n).*L_map(3,:)./Uav_map).^2).^(11/6));%Karman
        p_u(n,:)=sign(sign_n(n,1))*sqrt(2*Su(n,:)*df);
        p_v(n,:)=sign(sign_n(n,2))*sqrt(2*Sv(n,:)*df);
        p_w(n,:)=sign(sign_n(n,3))*sqrt(2*Sw(n,:)*df);
        Lx(n,:)=U_ref./((fm(n)))./c_1./Gammaix;
        Ly(n,:)=U_ref./((fm(n)))./c_2./Gammaiy;
        Lz(n,:)=U_ref./((fm(n)))./c_3./Gammaiz;
        q_1n(n,:)=p_u(n,:)./Lx(n,:);
        q_2n(n,:)=p_v(n,:)./Ly(n,:);
        q_3n(n,:)=p_w(n,:)./Lz(n,:);
        A_n(n,:)=sqrt((q_2n(n,:).^2+q_3n(n,:).^2).^2+(q_1n(n,:).*q_2n(n,:)).^2+(q_1n(n,:).*q_3n(n,:)).^2);
        B_n(n,:)=sqrt(q_2n(n,:).^2+q_3n(n,:).^2);
        k_1n(n,:)=-(q_2n(n,:).^2+q_3n(n,:).^2)./A_n(n,:).*sin(thea_n(n,1));
        k_2n(n,:)=(q_1n(n,:).*q_2n(n,:))./A_n(n,:).*sin(thea_n(n,1))+q_3n(n,:)./B_n(n,:).*cos(thea_n(n,1));
        k_3n(n,:)=(q_1n(n,:).*q_3n(n,:))./A_n(n,:).*sin(thea_n(n,1))-q_2n(n,:)./B_n(n,:).*cos(thea_n(n,1));
        div1(n,:)=q_1n(n,:).* k_1n(n,:)+q_2n(n,:).* k_2n(n,:)+q_3n(n,:).* k_3n(n,:);
        div2(n,:)= k_1n(n,:).* k_1n(n,:)+ k_2n(n,:).* k_2n(n,:)+ k_3n(n,:).* k_3n(n,:);
        K_xyz(:,:,n)=[k_1n(n,:);k_2n(n,:);k_3n(n,:)];%3x9
        x_1n(n,:)=(xyz(1,:))./Lx(n,:);
        x_2n(n,:)=(xyz(2,:))./Ly(n,:);
        x_3n(n,:)=(xyz(3,:))./Lz(n,:);
        X_xyz(:,:,n)=[x_1n(n,:);x_2n(n,:);x_3n(n,:)];%3x9
        kjxj(n,:)=(diag(K_xyz(:,:,n)'*X_xyz(:,:,n)))';
    end;disp('完成构建矩阵');
    %%合成风速
    leq_n=2*pi*rand(3,N);
    t=(1:1:N0_t)*h;
    ru=sign_n(:,1);rv=sign_n(:,2);rw=sign_n(:,3);
    for it=1:N0_T
        for n=1:N
            disp(['N0_T--','it--','n','运行时间:  ',num2str([N0_T,it,n,toc])]);
            U_u0(:,:,n)=p_u(n,:).*sin(repmat(kjxj(n,:),N0_t,1)+2*pi*fm(n).*t'+repmat(leq_n(1,n),N0_t,1));
            U_v0(:,:,n)=p_v(n,:).*sin(repmat(kjxj(n,:),N0_t,1)+2*pi*fm(n).*t'+repmat(leq_n(1,n),N0_t,1));
            U_w0(:,:,n)=p_w(n,:).*sin(repmat(kjxj(n,:),N0_t,1)+2*pi*fm(n).*t'+repmat(leq_n(1,n),N0_t,1));
        end;t=t+N0_t*h;
        U_u=cat(1,U_u,sum(U_u0,3));
        U_v=cat(1,U_v,sum(U_v0,3));
        U_w=cat(1,U_w,sum(U_w0,3));
    end
    U=roundn(U_u(2:end,:)+Uav_map,-4)';
    V=roundn(U_v(2:end,:),-4)';
    W=roundn(U_w(2:end,:),-4)';
    toc
    disp(['运行时间: ',num2str(toc)]);
    disp('=====accomplish======')
    C H B 3 条回复 最后回复
    在 中回复了 sunss 最后由 编辑
    #70
    @sunss 水平方向流场均一性问题,能否具体再说说吗,这个点不太理解具体表现是什么?
    HITSC30
    在 中回复了 sunss 最后由 编辑
    #71
    @sunss 看到我师兄做的DSRFG方法了,我也是做风场模拟的,可以加个联系方式探讨一下吗
    哨声响起的前一秒,我从未停止奔跑。
    对CFD保持间断的兴趣~
    HITSC30
    在 中回复了 xzdbjx 最后由 编辑
    #72
    @xzdbjx 朋友你好,我也是做这个方向的。可以加个联系方式聊一下吗
    哨声响起的前一秒,我从未停止奔跑。
    对CFD保持间断的兴趣~
    HITSC30
    在 中回复了 xjwang 最后由 编辑
    #73
    @sunss
    应该是在constant/boundaryData/inlet文件夹下边有一个points的文件,然后每一个时间步都是一个文件夹,其中包含一个U文件。比如说,我在inlet文件夹下边在terminal中输入ls,会显示:
    0 0.001 0.002 ...... points
    而在每一个时间步文件夹下输入ls,比如在0.001文件夹下,会显示:
    U
    您好,我想请教一下这个数据的事情。在foam中运用并行运算,是在分块前面把inlet坐标输出然后运用算法求出inlet上每个点对应的风速,然后按照您的方法导入到constant/boundaryData/inlet中吗?还是在分块后,按照该方法进行呢?
    哨声响起的前一秒,我从未停止奔跑。
    对CFD保持间断的兴趣~
    AICFD
    在 中回复了 HITSC30 最后由 编辑
    #74
    @hitsc30 decompose前
    HITSC30
    在 中回复了 AICFD 最后由 编辑
    #75
    @aicfd 谢谢你的回复
    哨声响起的前一秒,我从未停止奔跑。
    对CFD保持间断的兴趣~
  • B 离线
    B 离线
    BznW
    在 中回复了 sunss 最后由 编辑
    #76
    @sunss 您好,感谢分享您的入口合成方法,我在使用您的程序生成的风速导入到空流场时似乎遇到了一些文章中提到的入口不满足divergence-free所导致的很大的虚拟压力波动(见后压力方差图),这会对放入建筑时建筑的表面脉动风载产生很大的影响,我看很多采用NSRFG的文章都没有提到这个事情,不知道您有没有遇到这种情况以及是如何解决的呢?1678772197460.jpg
  • B 离线
    B 离线
    BznW
    #77
    @xzdbjx 您好!我看您使用过NSRFG方法导入过OF中计算,请问您在瞬态计算中有遇到过入口附近有非常大的虚拟压力波动的问题吗?我想验证下出现这种情况是否是算法的问题。我看您对湍流强度平均风剖面以及功率谱进行了验证,我这里湍流强度、平均风剖面以及功率谱这些与风速相关的统计量都还正常,就是涉及到脉动压强就会出问题。
    在 中回复了 BznW 最后由 编辑
    #78
    @BznW 压力脉动问题主要是因为入口质量通量不平衡导致的,NSRFG原论文中算出来的脉动压力系数也是非常大。简单的入口质量通量修正可以参考以下文章:
    1.《Kim, Y., I.P. Castro and Z. Xie, Divergence-free turbulence inflow conditions for large-eddy simulations with incompressible flow solvers. Computers & Fluids, 2013. 84: p. 56-68.》
    2.《Wang, Y. and X. Chen, Simulation of approaching boundary layer flow and wind loads on high-rise buildings by wall-modeled LES. Journal of Wind Engineering and Industrial Aerodynamics, 2020. 207: p. 104410.》
    B 1 条回复 最后回复
  • B 离线
    B 离线
    BznW
    #79
    @coolhhh 好的好的,感谢回复!我去学习一下
  • T 离线
    T 离线
    turbulen
    各位前辈,想请教一下,合成入口脉动风的方法有很多,比如AR线性滤波,谐波合成法,RFG系列,那么RFG系列和这些比较,有什么优势嘛!:xinxin:
    xjwang
    在 中回复了 turbulen 最后由 编辑
    #81
    @turbulen 没有见过你说的AR线性滤波, RFG 算是一种谐波合成法吧, RFG DSRFG 以及G.T. Bitsuamlak "A divergence-free inflow turbulence generator using spectral representation method for large-eddy simulation of ABL flows"这个方法,都应该算是一类的。做LES还有用Synthetic Eddy Method 和Digital Filter Method的,这两种方法在openfoam.com中有,如果你在用openfoam.org,可以去找一下这个网址:https://github.com/NHERI-SimCenter/TurbulenceInflowTool/tree/master/openFOAM_code/OpenFOAM6/turbulentInflow
  • 李东岳李 李东岳 被引用 于这个主题
    Chase
    #82
    @xzdbjx 大佬,可以提供一下编译进Fluent里面的udf吗? CFD小白,自己写的总是报错:zoule:
  • C coolhhh 被引用 于这个主题
