  4. CompressibleInterIsoFoam边界条件设定
6 帖子 2 发布者 6.3k 浏览
    Rachel0096
    写于 最后由 Rachel0096 编辑
    各位老师,晚上好。
    我根据一个interIsoFoam的case,想把他按照原来的工况在compressibleInterIsoFoam中重新跑一下,主要是模拟横射流的,示意图如下图所示,但是出现以下问题:
    其中,p_rgh、U和alpha.water都是之前interIsoFoam的设置
    0/p:
    internalField   uniform 0;
    boundaryField
        INLET_AIR
            type        fixedFluxPressure;
            value		uniform 0;
        INLET_LIQUID
            value		uniform 0;
        WALL
            value		uniform 0;
        SYMMETRY
            type        symmetry;
        OUTLET
            type            totalPressure;
            p0              uniform 0;
            U               U;
            phi             phi;
            rho             rho;
            psi             none;
            gamma           1;
            value           uniform 0;
    0/alpha.water
    dimensions      [0 0 0 0 0 0 0];
    boundaryField
        INLET_AIR
            type            inletOutlet;
            inletValue      uniform 0;
            value           uniform 0;
        INLET_LIQUID
            type            fixedValue;
            value           uniform 1;
        OUTLET
            type            zeroGradient;
        SYMMETRY
            type            symmetry;
        WALL
            type            zeroGradient;
    0/U
    |  \\    /   O peration     | Version:  4.x                                   |
    FoamFile
        version     2.0;
        format      ascii;
        class       volVectorField;
        location    "0";
        object      U;
    boundaryField
        INLET_AIR
            type            fixedValue;
            value           uniform (10 0 0);
        INLET_LIQUID
            type            fixedValue;
            value           uniform (0 0 1);
        WALL
            type            noSlip;
        SYMMETRY
            type            symmetry;
        OUTLET
            type            inletOutlet;
            inletValue	    uniform (0 0 0);
    我自己主要添加了p、T、thermophysicalProperties.air和thermophysicalProperties.water文件,主要设置如下
    p
    internalField   uniform 101325;
    boundaryField
        INLET_AIR
            type            calculated;
        INLET_LIQUID
            type            calculated;
        WALL
            type            calculated;
        SYMMETRY
            type        symmetry;
        OUTLET
            type            inletOutlet;
            value           uniform 0;
    T
    internalField   uniform 300;
    boundaryField
        INLET_AIR
            type        fixedValue;
            value	     uniform 300;
        INLET_LIQUID
            type        fixedValue;
            value	     uniform 300;
        WALL
           type            zeroGradient;
        SYMMETRY
            type        symmetry;
        OUTLET
            type            inletOutlet;
            inletValue	    uniform 300;
            value           uniform 300;
    thermoType
        type            heRhoThermo;
        mixture         pureMixture;
        transport       const;
        thermo          hConst;
        equationOfState rhoConst;//认为其不可压缩,或许采用perfectfluid也可以?
        specie          specie;
    mixture
        specie
            molWeight   18.0;
        equationOfState
            rho         1000;
        thermodynamics
            Cp          4195;
            Hf          0;
        transport
            mu          1e-3;
            Pr          7;
    thermoType
        type            heRhoThermo;
        transport       const;
        thermo          hConst;
        equationOfState perfectGas;
        specie          specie;
    mixture
        specie
            molWeight   28.9;
        thermodynamics
            Cp          1013;
            Hf          0;
        transport
            mu          16.337e-06;
            Pr          0.7;
    想问一下我的这些设置是否存在不合理的地方,当出现报错的时候,有没有什么方法可以找到出错的原因(我每次总是百度+论坛),怎么能够查看自己的边界条件是否合理呢,以及在thermophysicalProperties中的Pmin应该根据什么来进行设置?
    问题有点多,麻烦各位老师啦!:xinxin:
    老铁你这啥都算啊,前几天还记得你弄IBM。为啥不用不可压缩呢。变量越多越容易出问题。这个错误就是发散了。
    R 1 条回复 最后回复
    Rachel0096
    @李东岳 李老师,我上个周刚刚被我导师换课题了,现在做横射流雾化:zoule: 因为后期想要做到燃烧,所以需要改到可压缩的求解器里面
    R 1 条回复 最后回复
    Rachel0096
    在 中回复了 Rachel0096 最后由 编辑
    @Rachel0096 省流版就是 IBM他等不及了:136:
    射流雾化这个用VOF算,网格量不小。不太好debug。你这个问题,只能看出来是发散了。我看你最好先用不可压缩整收敛,然后再上弱可压缩。
    R 1 条回复 最后回复
    Rachel0096
    好的好的,我去试试,谢谢李老师
