CompressibleInterIsoFoam边界条件设定
各位老师,晚上好。
 我根据一个interIsoFoam的case,想把他按照原来的工况在compressibleInterIsoFoam中重新跑一下,主要是模拟横射流的,示意图如下图所示,但是出现以下问题:
 其中,p_rgh、U和alpha.water都是之前interIsoFoam的设置
 0/p:dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { INLET_AIR { type fixedFluxPressure; value uniform 0; } INLET_LIQUID { type fixedFluxPressure; value uniform 0; } WALL { type fixedFluxPressure; value uniform 0; } SYMMETRY { type symmetry; } OUTLET { type totalPressure; p0 uniform 0; U U; phi phi; rho rho; psi none; gamma 1; value uniform 0; } }0/alpha.water dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { INLET_AIR { type inletOutlet; inletValue uniform 0; value uniform 0; } INLET_LIQUID { type fixedValue; value uniform 1; } OUTLET { type zeroGradient; } SYMMETRY { type symmetry; } WALL { type zeroGradient; } }0/U /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { INLET_AIR { type fixedValue; value uniform (10 0 0); } INLET_LIQUID { type fixedValue; value uniform (0 0 1); } WALL { type noSlip; } SYMMETRY { type symmetry; } OUTLET { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } } // ************************************************************************* //我自己主要添加了p、T、thermophysicalProperties.air和thermophysicalProperties.water文件,主要设置如下
 pdimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { INLET_AIR { type calculated; value $internalField; } INLET_LIQUID { type calculated; value $internalField; } WALL { type calculated; value $internalField; } SYMMETRY { type symmetry; } OUTLET { type inletOutlet; inletValue uniform 0; value uniform 0; } }T dimensions [0 0 0 1 0 0 0]; internalField uniform 300; boundaryField { INLET_AIR { type fixedValue; value uniform 300; } INLET_LIQUID { type fixedValue; value uniform 300; } WALL { type zeroGradient; } SYMMETRY { type symmetry; } OUTLET { type inletOutlet; inletValue uniform 300; value uniform 300; } }thermophysicalProperties.water thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst;//认为其不可压缩,或许采用perfectfluid也可以? specie specie; energy sensibleInternalEnergy; } mixture { specie { molWeight 18.0; } equationOfState { rho 1000; } thermodynamics { Cp 4195; Hf 0; } transport { mu 1e-3; Pr 7; } }thermophysicalProperties.air thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } mixture { specie { molWeight 28.9; } thermodynamics { Cp 1013; Hf 0; } transport { mu 16.337e-06; Pr 0.7; } }想问一下我的这些设置是否存在不合理的地方,当出现报错的时候,有没有什么方法可以找到出错的原因(我每次总是百度+论坛),怎么能够查看自己的边界条件是否合理呢,以及在thermophysicalProperties中的Pmin应该根据什么来进行设置?
 问题有点多,麻烦各位老师啦!
@Rachel0096 省流版就是 IBM他等不及了
好的好的,我去试试,谢谢李老师
 因为后期想要做到燃烧,所以需要改到可压缩的求解器里面
