  4. overset 小间隙-多浮体算例 计算结果明显有误
10 帖子 5 发布者 12.4k 浏览
    hachikoi
    最近在做同轴双浮体装置,目前是内浮体不动(后续会动,所以做成了overset),外浮体初始位移为-1做自衰减
    内浮体的overset较大,将外浮体overset包裹,四面消波处理
    目前计算结果,外浮体在最初的几秒存在负速度,这是完全不合理的,之前尝试过单独外浮体/单独内浮体/外浮体overset+内浮体背景扣除都是没有问题的。怀疑是overset插值引起的错误结果,请大家帮忙看看是什么问题引起的呢?:chouchou:
    fvSchemes:
    |  \\    /   O peration     | Version:  v2306                                 |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      fvSchemes;
    ddtSchemes
        default                             Euler;
    gradSchemes
        default                             Gauss linear;
    divSchemes
        div(rhoPhi,U)                       Gauss limitedLinearV 1;
        div(U)                              Gauss linear;
        div(phi,alpha)                      Gauss vanLeer;
        div(phirb,alpha)                    Gauss linear;
        div(phi,k)                          Gauss upwind;
        div(phi,epsilon)                    Gauss upwind;
        div(phi,omega)                      Gauss upwind;
    laplacianSchemes
        default                             Gauss linear corrected;
    interpolationSchemes
        default                             linear;
    snGradSchemes
        default                             corrected;
    oversetInterpolation
        method                              inverseDistance;
    fluxRequired
        default                             no;
        p_rgh;
        pcorr;
        alpha.water;
    wallDist
        method                              meshWave;
        //method                              Poisson;
    oversetInterpolationSuppressed
        grad(p_rgh);
        surfaceIntegrate(phiHbyA);
    oversetInterpolationRequired
        k;
        epsilon;
        omega;
        nut;
        alpha.water;
    fvSolution:
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      fvSolution;
    solvers
        "cellDisplacement.*"
            solver               PCG;
            preconditioner       DIC;
            tolerance            1e-06;
            relTol               0;
            maxIter              100;
        "alpha.water.*"
            nAlphaCorr           2;
            nAlphaSubCycles      1;
            cAlpha               1;
            icAlpha              0;
            MULESCorr            yes;
            nLimiterIter         5;
            alphaApplyPrevCorr   no;
            solver               smoothSolver;
            smoother             symGaussSeidel;
            tolerance            1e-08;
            relTol               0;
        "pcorr.*"
            solver               PCG;
            preconditioner       DIC;
            tolerance            1e-09;
            relTol               0;
        p_rgh
            solver               PBiCGStab;
            preconditioner       DILU;
            tolerance            1e-09;
            relTol               0.01;
        p_rghFinal
            $p_rgh;
            relTol               0;
        "(U|k|omega|epsilon).*"
            tolerance            1e-08;
            relTol               0;
        yPsi
            solver               PBiCGStab;
            tolerance            1e-6;
            relTol               0.0;
        yPsiFinal
            $yPsi;
            relTol               0;
    PIMPLE
        momentumPredictor        no;
        nOuterCorrectors         5;
        nCorrectors              2;
        nNonOrthogonalCorrectors 1;
        ddtCorr                  yes;
        correctPhi               no;
        moveMeshOuterCorrectors  no;
        turbOnFinalIterOnly      no;
        oversetAdjustPhi         yes;
    relaxationFactors
        fields
        equations
            ".*"                 1;
    cache
       grad(U);
    dynamicMeshDict
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      dynamicMeshDict;
    dynamicFvMesh                    dynamicOversetFvMesh;
    solvers
        dynamicPlatform
            motionSolverLibs         (libfvMotionSolvers);
            motionSolver             multiSolidBodyMotionSolver;
            multiSolidBodyMotionSolverCoeffs
                zonePlatform
                    solidBodyMotionFunction  linearMotion;
                    linearMotionCoeffs
                        velocity             (0 0 0);
        dynamicWECMiddle
            motionSolverLibs         (librigidBodyMeshMotion);
            motionSolver             rigidBodyMotion;
            report                   on;
            cellSet                  cellWECMiddle;
            cOfGdisplacement         CofG;
            bodyIdCofG               1;
            solver
                type                 Newmark;
            accelerationRelaxation   0.8;
            accelerationDamping      0.9;
            nIter                    3;
            bodies
                dynamicWECMiddle
                    type             rigidBody;
                    parent           root;
                    mass             2.0126e+06;
                    centreOfMass     (0 0 0); // COG in the local coordinate system, based on transform
                    inertia          (1.3312e+08 0 0 1.3312e+08 0 2.1384e+08); // (Ixx Ixy Ixz Iyy Iyz Izz)
                    transform        (1 0 0 0 1 0 0 0 1) (0 0 -1);
                    joint
                        type         Pz;
                    patches
                        WECMiddle
                    innerDistance    100;
                    outerDistance    101;
            restraints
            motionSolverLibs   (sixDoFRigidBodyMotion);
            motionSolver       sixDoFRigidBodyMotion;
            patches            (WECMiddle);
            innerDistance      100;
            outerDistance      101;
            centreOfMass       (0 0 -1);
            mass               2.0126e+06;
            momentOfInertia    (1.3312e+08 1.3312e+08 2.1384e+08);
            report             on;
            solver
                type           Newmark;
            constraints
                zAxis
                    sixDoFRigidBodyMotionConstraint line;
                    direction  (0 0 1);
    0:
    FoamFile
        version     2.0;
        format      ascii;
        class       volScalarField;
        object      alpha.water;
    dimensions      [0 0 0 0 0 0 0];
    internalField   uniform 0;
    boundaryField
        #includeEtc "caseDicts/setConstraintTypes"
        inlet
            type            zeroGradient;
        outlet
            type            zeroGradient;
        "(rightSide|leftSide)"
            type            zeroGradient;
        lowerSide
            type            zeroGradient;
        atmosphere
            type            inletOutlet;
            inletValue      $internalField;
        oversetWECMiddle
            type            overset;
        WECMiddle
            type            zeroGradient;
        oversetPlatform
            type            overset;
        platform
            type            zeroGradient;
    FoamFile
        version     2.0;
        format      ascii;
        object      p_rgh;
    boundaryField
        inlet
        outlet
        lowerSide
        atmosphere
            type            totalPressure;
            p0              $internalField;
        oversetWECMiddle
            type            overset;
        WECMiddle
        oversetPlatform
            type            overset;
        platform
    FoamFile
        version     2.0;
        format      ascii;
        class       pointVectorField;
        object      pointDisplacement;
    dimensions      [0 1 0 0 0 0 0];
    boundaryField
        inlet
            type            fixedValue;
        outlet
            type            fixedValue;
            type            fixedValue;
        lowerSide
            type            fixedValue;
        atmosphere
            type            fixedValue;
        oversetWECMiddle
            patchType       overset;
            type            zeroGradient;
        WECMiddle
            type            calculated;
        oversetPlatform
            patchType       overset;
            type            zeroGradient;
        platform
            type            fixedValue;
    FoamFile
        version     2.0;
        format      ascii;
        class       volVectorField;
        object      U;
    boundaryField
        inlet
            type            waveVelocity;
        outlet
            type            waveVelocity;
            type            waveVelocity;
        lowerSide
            type            fixedValue;
        atmosphere
        oversetWECMiddle
            type            overset;
        WECMiddle
            type            movingWallVelocity;
        oversetPlatform
            type            overset;
        platform
            type            fixedValue;
    请大家帮忙看看是不是哪里设置有问题
    hachikoi
    计算结果
    |  \\    /   O peration     | Version:  2306                                  |
    Build  : _fbf00d6bf2-20230626 OPENFOAM=2306 version=v2306
    Arch   : "LSB;label=32;scalar=64"
    Exec   : overInterDyMFoam -parallel
    Date   : Nov 24 2023
    Time   : 21:42:20
    Host   : DESKTOP-KVQEVMV
    PID    : 617
    I/O    : uncollated
    Case   : /mnt/d/Tutorials/UMaine/decay/decayRASkOmegaSST/decayWECMiddleSpar/decayHeave1V0/background
    nProcs : 8
    Hosts  :
        (DESKTOP-KVQEVMV 8)
    Pstream initialized with:
        floatTransfer      : false
        nProcsSimpleSum    : 0
        nonBlockingExchange: 0 (tuning: 0)
        exchange algorithm : -1
        commsType          : nonBlocking
        polling iterations : 0
    trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
    fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
    Create time
    Create mesh for time = 0
    Selecting dynamicFvMesh dynamicOversetFvMesh
    Selecting motion solver: multiSolidBodyMotionSolver
    Applying motion to entire mesh
    Selecting solid-body motion function linearMotion
    Applying solid body motion linearMotion to 1449278 points of cellZone zonePlatform
    Selecting motion solver: rigidBodyMotion
    Applying motion to cellSet: cellWECMiddle
    Selecting rigidBodySolver Newmark
    PIMPLE: no residual control data found. Calculations will employ 5 corrector loops
    Reading field p_rgh
    Reading field U
    Creating cellMask field to block out hole cells
    --> FOAM Warning :
        From bool Foam::oversetPolyPatch::master() const
        in file oversetPolyPatch/oversetPolyPatch.C at line 145
        The master overset patch is not the first patch. Generally the first patch should be an overset patch to guarantee consistent operation.
    --> FOAM Warning :
    Creating interpolatedCells field
    Reading transportProperties
    Selecting turbulence model type RAS
    Selecting RAS turbulence model kOmegaSST
    Selecting patchDistMethod meshWave
    RAS
        RASModel        kOmegaSST;
        turbulence      on;
        printCoeffs     on;
        alphaK1         0.85;
        alphaK2         1;
        alphaOmega1     0.5;
        alphaOmega2     0.856;
        gamma1          0.555555555556;
        gamma2          0.44;
        beta1           0.075;
        beta2           0.0828;
        betaStar        0.09;
        a1              0.31;
        b1              1;
        c1              10;
        F3              false;
        decayControl    false;
        kInf            0;
        omegaInf        0;
    Reading g
    Reading hRef
    Calculating field g.h
    No MRF models present
    Reading/calculating face velocity Uf
    Courant Number mean: 0 max: 0
    Starting time loop
    Interface Courant Number mean: 0 max: 0
    deltaT = 0.012
    Time = 0.012
    PIMPLE: iteration 1
    forces forces:
        rho: rho
        Not including porosity effects
    forces forces:
        rho: rho
    forces forces:
        rho: rho
    Rigid-body motion of the dynamicWECMiddle
        Centre of rotation: (0 0 -0.999950388828)
        Orientation: (1 0 0 0 1 0 0 0 1)
        Linear velocity: (0 0 0.00826852870788)
        Angular velocity: (0 0 0)
    inverseDistance : detected 3 mesh regions
        zone:0 nCells:3302728  voxels:(92 92 92) bb:(-1250.00076811 -1250.00076811 -800.000768115) (-749.999231885 -749.999231885 -499.999231885)
        zone:1 nCells:1329243  voxels:(92 92 92) bb:(-17.5000567663 -17.5000567663 -25.0007917663) (17.5000557663 17.5000547663 -1.56244523367)
        zone:2 nCells:1783736  voxels:(92 92 92) bb:(-4.41261149239 5.32858310761 -12.2503453812) (11.2436789924 17.5000299924 10.2504506036)
    Overset analysis : nCells : 6415707
        calculated   : 5795510
        interpolated : 159835 (from local:606  mixed local/remote:100  remote:159129)
        hole         : 455019
    Selecting waveModel shallowWaterAbsorption
    Wave model: patch inlet
        Type : shallowWaterAbsorption
        Velocity field name : U
        Phase fraction field name : alpha.water
        Transformation from local to global system : (1 -7.77501308186e-32 7.17951403026e-23 7.77501308186e-32 1 0 -0 -0 1)
        Number of paddles: 1
        Reference water depth : 199.999999317
        Active absorption: 1
    Updating shallowWaterAbsorption wave model for patch inlet
    Wave model: patch outlet
        Transformation from local to global system : (-1 -3.16385813721e-32 7.17951403181e-23 3.16385813721e-32 -1 0 -0 -0 1)
    Updating shallowWaterAbsorption wave model for patch outlet
    Wave model: patch rightSide
        Transformation from local to global system : (-1.61558713389e-32 1 1.05282388693e-18 -1 -1.61558713389e-32 -0 -0 -0 1)
    Updating shallowWaterAbsorption wave model for patch rightSide
    Wave model: patch leftSide
        Transformation from local to global system : (2.15411617852e-32 -1 -5.88975123258e-18 1 2.15411617852e-32 0 -0 -0 1)
    Updating shallowWaterAbsorption wave model for patch leftSide
    Execution time for mesh.update() = 31.64 s
    smoothSolver:  Solving for alpha.water, Initial residual = 2.61985281096e-07, Final residual = 9.3161532224e-09, No Iterations 23
    Phase-1 volume fraction = 0.66655233285  Min(alpha.water) = 0  Max(alpha.water) = 1
    MULES: Correcting alpha.water
    Phase-1 volume fraction = 0.66655233262  Min(alpha.water) = -4.06575814682e-23  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1, Final residual = 0.00934508785126, No Iterations 132
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.93805455326e-05, Final residual = 9.81032812434e-08, No Iterations 157
    time step continuity errors : sum local = 1.31199443232e-09, global = 5.31630376358e-10, cumulative = 5.31630376358e-10
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.05167563797e-05, Final residual = 1.04029750059e-07, No Iterations 144
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.3336587163e-06, Final residual = 6.33395425015e-10, No Iterations 233
    time step continuity errors : sum local = 6.1751513569e-12, global = 5.28990371798e-12, cumulative = 5.36920280076e-10
    smoothSolver:  Solving for omega, Initial residual = 0.000102569828088, Final residual = 2.86343248998e-09, No Iterations 3
    smoothSolver:  Solving for k, Initial residual = 0.999999998453, Final residual = 9.33528038491e-09, No Iterations 66
    PIMPLE: iteration 2
    smoothSolver:  Solving for alpha.water, Initial residual = 1.27402311839e-07, Final residual = 8.81590646774e-09, No Iterations 2
    Phase-1 volume fraction = 0.666552379444  Min(alpha.water) = -3.83779065969e-28  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.666552381689  Min(alpha.water) = -1.621967531e-06  Max(alpha.water) = 1.00000000013
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.61393401599e-05, Final residual = 2.95529990406e-07, No Iterations 137
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.32733975555e-05, Final residual = 8.98829957804e-07, No Iterations 58
    time step continuity errors : sum local = 2.97727638562e-09, global = 1.12545136858e-09, cumulative = 1.66237164866e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 8.25486710901e-05, Final residual = 7.9528642603e-07, No Iterations 111
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.1598896674e-05, Final residual = 2.69740404024e-10, No Iterations 215
    time step continuity errors : sum local = 8.87609898546e-13, global = 2.19947839059e-13, cumulative = 1.6625915965e-09
    smoothSolver:  Solving for omega, Initial residual = 1.05706805697e-06, Final residual = 3.06165398729e-09, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 2.17813199337e-05, Final residual = 8.83104952045e-09, No Iterations 11
    PIMPLE: iteration 3
    smoothSolver:  Solving for alpha.water, Initial residual = 1.08796870261e-07, Final residual = 6.88901360938e-09, No Iterations 3
    Phase-1 volume fraction = 0.666552350255  Min(alpha.water) = -9.78968376404e-18  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.666552348822  Min(alpha.water) = -4.03306452835e-06  Max(alpha.water) = 1.00000000001
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000260128355201, Final residual = 2.38866841716e-06, No Iterations 80
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.97760690631e-05, Final residual = 3.74084676736e-07, No Iterations 98
    time step continuity errors : sum local = 6.45059786074e-10, global = 6.27376936037e-10, cumulative = 2.28996853253e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 5.18893127841e-05, Final residual = 4.93880984564e-07, No Iterations 140
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.00033869064e-05, Final residual = 9.88435829622e-10, No Iterations 215
    time step continuity errors : sum local = 1.79260009404e-12, global = 8.66436780833e-14, cumulative = 2.29005517621e-09
    smoothSolver:  Solving for omega, Initial residual = 2.53541232093e-07, Final residual = 3.5196014854e-09, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 2.94650853902e-05, Final residual = 7.53900830036e-09, No Iterations 11
    PIMPLE: iteration 4
    smoothSolver:  Solving for alpha.water, Initial residual = 7.59424341536e-08, Final residual = 8.47687199918e-09, No Iterations 1
    Phase-1 volume fraction = 0.666552350369  Min(alpha.water) = -1.7236282171e-09  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.666552350436  Min(alpha.water) = -0.000416460503671  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000167246351824, Final residual = 1.40182075997e-06, No Iterations 107
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 5.16507599585e-05, Final residual = 4.37468479875e-07, No Iterations 64
    time step continuity errors : sum local = 6.00063571489e-10, global = -2.63397570915e-10, cumulative = 2.0266576053e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 8.29697246248e-05, Final residual = 8.11491883613e-07, No Iterations 151
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.44922341191e-05, Final residual = 6.85329760483e-10, No Iterations 217
    time step continuity errors : sum local = 1.22184650642e-12, global = -9.18162980737e-13, cumulative = 2.02573944232e-09
    smoothSolver:  Solving for omega, Initial residual = 1.52703236419e-07, Final residual = 7.73512960224e-09, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 8.02738033721e-06, Final residual = 9.37089259035e-09, No Iterations 23
    PIMPLE: iteration 5
    smoothSolver:  Solving for alpha.water, Initial residual = 5.62034902794e-08, Final residual = 8.1720263608e-09, No Iterations 1
    Phase-1 volume fraction = 0.666552346355  Min(alpha.water) = -3.66106998989e-10  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.666552344225  Min(alpha.water) = -0.000289714267251  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000179222117898, Final residual = 1.69745284627e-06, No Iterations 123
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.19874219811e-05, Final residual = 1.89807848936e-07, No Iterations 148
    time step continuity errors : sum local = 3.71990181733e-10, global = 2.12074694904e-11, cumulative = 2.04694691181e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.41850750136e-05, Final residual = 3.01352648671e-07, No Iterations 126
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.45426477763e-05, Final residual = 9.45301356671e-10, No Iterations 178
    time step continuity errors : sum local = 1.78223171988e-12, global = -2.78459422187e-13, cumulative = 2.04666845238e-09
    smoothSolver:  Solving for omega, Initial residual = 1.60789297939e-07, Final residual = 8.69888544542e-09, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 4.85804248814e-06, Final residual = 9.50862177947e-09, No Iterations 7
    ExecutionTime = 557.59 s  ClockTime = 560 s
    Courant Number mean: 1.63749449277e-05 max: 49.9913602954
    Interface Courant Number mean: 6.95403940679e-07 max: 3.55036474521
    deltaT = 0.000240041477749
    Time = 0.01224
    PIMPLE: iteration 1
    forces forces:
        rho: rho
    forces forces:
        rho: rho
    forces forces:
        rho: rho
        Centre of rotation: (0 0 -0.999948351772)
        Linear velocity: (0 0 0.00870400248066)
        zone:2 nCells:1783736  voxels:(92 92 92) bb:(-4.41261149239 5.32858310761 -12.2503433442) (11.2436789924 17.5000299924 10.2504526406)
        hole         : 455019
    Execution time for mesh.update() = 40.12 s
    smoothSolver:  Solving for alpha.water, Initial residual = 8.36900182683e-09, Final residual = 8.36900182683e-09, No Iterations 0
    Phase-1 volume fraction = 0.666552343446  Min(alpha.water) = -0.000289714267251  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.666552342656  Min(alpha.water) = -0.000289584326027  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.0228028713103, Final residual = 0.000158123063473, No Iterations 103
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000476023249144, Final residual = 4.19682603135e-06, No Iterations 132
    time step continuity errors : sum local = 8.93614961201e-11, global = 7.31703459824e-11, cumulative = 2.11983879837e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000192656249381, Final residual = 1.36166337649e-06, No Iterations 163
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 6.70954837961e-05, Final residual = 9.678157846e-10, No Iterations 265
    time step continuity errors : sum local = 1.58991434156e-14, global = -7.99361856081e-15, cumulative = 2.11983080475e-09
    smoothSolver:  Solving for omega, Initial residual = 1.65654710594e-06, Final residual = 9.11101653564e-10, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 9.84944919853e-05, Final residual = 7.48999418113e-09, No Iterations 2
    PIMPLE: iteration 2
    smoothSolver:  Solving for alpha.water, Initial residual = 6.06658567684e-09, Final residual = 6.06658567684e-09, No Iterations 0
    Phase-1 volume fraction = 0.666552341998  Min(alpha.water) = -0.000289373569159  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 6.09071653377e-05, Final residual = 5.86498406611e-07, No Iterations 135
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.67956672479e-05, Final residual = 2.01508297651e-07, No Iterations 149
    time step continuity errors : sum local = 3.3067714853e-12, global = 3.30648753556e-12, cumulative = 2.12313729228e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.18188041175e-05, Final residual = 7.73661385616e-08, No Iterations 156
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 5.55315884803e-06, Final residual = 6.90107537102e-10, No Iterations 213
    time step continuity errors : sum local = 1.07514813361e-14, global = 1.01727697345e-14, cumulative = 2.12314746505e-09
    smoothSolver:  Solving for omega, Initial residual = 1.82307346832e-09, Final residual = 1.82307346832e-09, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 6.07724465011e-08, Final residual = 3.64698977772e-09, No Iterations 1
    PIMPLE: iteration 3
    smoothSolver:  Solving for alpha.water, Initial residual = 4.95615350895e-09, Final residual = 4.95615350895e-09, No Iterations 0
    Phase-1 volume fraction = 0.666552341433  Min(alpha.water) = -0.00028921797597  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 5.34942515551e-06, Final residual = 2.89216757541e-08, No Iterations 153
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.71613055767e-06, Final residual = 1.69845429434e-08, No Iterations 139
    time step continuity errors : sum local = 2.85144328781e-13, global = 2.82486392054e-13, cumulative = 2.12342995145e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 7.57358817177e-07, Final residual = 4.68743757682e-09, No Iterations 148
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.30816263038e-07, Final residual = 7.98377737781e-10, No Iterations 155
    time step continuity errors : sum local = 1.24636818568e-14, global = 1.09792420598e-14, cumulative = 2.12344093069e-09
    smoothSolver:  Solving for omega, Initial residual = 1.92226875551e-09, Final residual = 1.92226875551e-09, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 1.34277181319e-08, Final residual = 2.5244507753e-09, No Iterations 1
    PIMPLE: iteration 4
    smoothSolver:  Solving for alpha.water, Initial residual = 4.14180619703e-09, Final residual = 4.14180619703e-09, No Iterations 0
    Phase-1 volume fraction = 0.66655234095  Min(alpha.water) = -0.000289070037242  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.69585590378e-07, Final residual = 8.74528894708e-09, No Iterations 140
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.81105228656e-07, Final residual = 2.72909179203e-09, No Iterations 126
    time step continuity errors : sum local = 4.56821656802e-14, global = 1.54082829784e-14, cumulative = 2.12345633897e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.25226124652e-08, Final residual = 6.67713245408e-10, No Iterations 124
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 4.2978743237e-08, Final residual = 9.74587014884e-10, No Iterations 109
    time step continuity errors : sum local = 1.66374816607e-14, global = 1.64971601989e-14, cumulative = 2.12347283613e-09
    smoothSolver:  Solving for omega, Initial residual = 1.95628819863e-09, Final residual = 1.95628819863e-09, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 5.62125672229e-09, Final residual = 5.62125672229e-09, No Iterations 0
    PIMPLE: iteration 5
    smoothSolver:  Solving for alpha.water, Initial residual = 3.60189757848e-09, Final residual = 3.60189757848e-09, No Iterations 0
    Phase-1 volume fraction = 0.666552340533  Min(alpha.water) = -0.000288909525708  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.67847330072e-07, Final residual = 1.98395076727e-09, No Iterations 149
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.06975221441e-07, Final residual = 1.02026137309e-09, No Iterations 136
    time step continuity errors : sum local = 1.74929356065e-14, global = 1.46083619252e-14, cumulative = 2.12348744449e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 4.31574420273e-08, Final residual = 9.65472946334e-10, No Iterations 119
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.49455168275e-08, Final residual = 8.73609993614e-10, No Iterations 102
    time step continuity errors : sum local = 1.40323018836e-14, global = 2.66664498002e-15, cumulative = 2.12349011114e-09
    smoothSolver:  Solving for omega, Initial residual = 1.95616404291e-09, Final residual = 1.95616404291e-09, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 5.67015345545e-09, Final residual = 5.67015345545e-09, No Iterations 0
    ExecutionTime = 1116.64 s  ClockTime = 1124 s
    Courant Number mean: 1.23753094205e-06 max: 2.67476268045
    Interface Courant Number mean: 1.22084714043e-08 max: 0.040419192207
    deltaT = 8.97430936596e-05
    Time = 0.0123298
    PIMPLE: iteration 1
    forces forces:
        rho: rho
    forces forces:
        rho: rho
    forces forces:
        rho: rho
        Centre of rotation: (0 0 -0.999947523286)
        Linear velocity: (0 0 0.00975950626086)
        zone:2 nCells:1783736  voxels:(92 92 92) bb:(-4.41261149239 5.32858310761 -12.2503425157) (11.2436789924 17.5000299924 10.2504534691)
        hole         : 455019
    Execution time for mesh.update() = 39.64 s
    smoothSolver:  Solving for alpha.water, Initial residual = 1.89506393044e-09, Final residual = 1.89506393044e-09, No Iterations 0
    Phase-1 volume fraction = 0.666552340293  Min(alpha.water) = -0.000288909525708  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.666552339977  Min(alpha.water) = -0.000288846889594  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.00695412581841, Final residual = 6.58530505703e-05, No Iterations 148
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000208251042114, Final residual = 2.05743333992e-06, No Iterations 125
    time step continuity errors : sum local = 5.895261321e-11, global = -3.50991476391e-11, cumulative = 2.0883909635e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.00010380483611, Final residual = 9.76125551947e-07, No Iterations 112
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 4.2687177802e-05, Final residual = 9.50115732418e-10, No Iterations 213
    time step continuity errors : sum local = 2.05769533909e-14, global = 1.23631828244e-14, cumulative = 2.08840332668e-09
    smoothSolver:  Solving for omega, Initial residual = 6.1051758878e-07, Final residual = 4.82103625934e-10, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 3.01714859593e-05, Final residual = 9.37540222535e-09, No Iterations 1
    PIMPLE: iteration 2
    smoothSolver:  Solving for alpha.water, Initial residual = 1.63714691561e-09, Final residual = 1.63714691561e-09, No Iterations 0
    Phase-1 volume fraction = 0.666552339706  Min(alpha.water) = -0.000288806485034  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.23761401106e-05, Final residual = 2.08661810278e-07, No Iterations 134
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.2229647521e-06, Final residual = 8.84903438452e-08, No Iterations 146
    time step continuity errors : sum local = 1.93794820853e-12, global = 1.93793640713e-12, cumulative = 2.09034126309e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 4.31258175956e-06, Final residual = 3.09958221974e-08, No Iterations 129
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.16173305739e-06, Final residual = 7.61858990072e-10, No Iterations 182
    time step continuity errors : sum local = 1.79845063561e-14, global = -7.97949298118e-15, cumulative = 2.0903332836e-09
    smoothSolver:  Solving for omega, Initial residual = 6.86324608392e-10, Final residual = 6.86324608392e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 2.59199319034e-08, Final residual = 3.72155986805e-09, No Iterations 1
    PIMPLE: iteration 3
    smoothSolver:  Solving for alpha.water, Initial residual = 1.464298727e-09, Final residual = 1.464298727e-09, No Iterations 0
    Phase-1 volume fraction = 0.666552339468  Min(alpha.water) = -0.000288763304213  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.11368632855e-06, Final residual = 9.12572869945e-09, No Iterations 145
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 4.51282511339e-07, Final residual = 4.39016946545e-09, No Iterations 148
    time step continuity errors : sum local = 9.74366513151e-14, global = -9.73777380055e-14, cumulative = 2.09023590586e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.01376950811e-07, Final residual = 9.97729577993e-10, No Iterations 132
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.03614929149e-08, Final residual = 6.77515000163e-10, No Iterations 146
    time step continuity errors : sum local = 1.65113572261e-14, global = -1.60186025025e-14, cumulative = 2.09021988725e-09
    smoothSolver:  Solving for omega, Initial residual = 6.93072732889e-10, Final residual = 6.93072732889e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 4.6403143789e-09, Final residual = 4.6403143789e-09, No Iterations 0
    PIMPLE: iteration 4
    smoothSolver:  Solving for alpha.water, Initial residual = 1.34365518119e-09, Final residual = 1.34365518119e-09, No Iterations 0
    Phase-1 volume fraction = 0.66655233926  Min(alpha.water) = -0.000288719352487  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 7.66014318067e-08, Final residual = 8.71802548845e-10, No Iterations 148
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.2919023473e-08, Final residual = 9.70813176141e-10, No Iterations 97
    time step continuity errors : sum local = 2.14135270487e-14, global = -1.99862439702e-14, cumulative = 2.09019990101e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.08856570606e-08, Final residual = 9.76022773547e-10, No Iterations 58
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 4.07307604617e-09, Final residual = 9.29257136903e-10, No Iterations 21
    time step continuity errors : sum local = 1.67526610845e-14, global = 8.81445888723e-15, cumulative = 2.09020871547e-09
    smoothSolver:  Solving for omega, Initial residual = 6.93390357342e-10, Final residual = 6.93390357342e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 4.67499439824e-09, Final residual = 4.67499439824e-09, No Iterations 0
    PIMPLE: iteration 5
    smoothSolver:  Solving for alpha.water, Initial residual = 1.2520957575e-09, Final residual = 1.2520957575e-09, No Iterations 0
    Phase-1 volume fraction = 0.666552339079  Min(alpha.water) = -0.000288674615659  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.50640815229e-08, Final residual = 9.99499573606e-10, No Iterations 31
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.01438500186e-09, Final residual = 9.86510742554e-10, No Iterations 10
    time step continuity errors : sum local = 1.8597559213e-14, global = 9.98907756168e-15, cumulative = 2.09021870455e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.37064254853e-09, Final residual = 9.87017098349e-10, No Iterations 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.9024984935e-10, Final residual = 9.9024984935e-10, No Iterations 0
    time step continuity errors : sum local = 1.88156236059e-14, global = 9.85210599887e-15, cumulative = 2.09022855665e-09
    smoothSolver:  Solving for omega, Initial residual = 6.93401046968e-10, Final residual = 6.93401046968e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 4.67636350062e-09, Final residual = 4.67636350062e-09, No Iterations 0
    ExecutionTime = 1551.51 s  ClockTime = 1567 s
    Courant Number mean: 7.44659378168e-07 max: 0.33617200472
    Interface Courant Number mean: 5.92610839418e-09 max: 0.0133063005972
    deltaT = 0.000107691712392
    Time = 0.0124375
    PIMPLE: iteration 1
    forces forces:
        rho: rho
    forces forces:
        rho: rho
    forces forces:
        rho: rho
        Centre of rotation: (0 0 -0.999946925817)
        Linear velocity: (0 0 0.00133640649968)
        zone:2 nCells:1783736  voxels:(92 92 92) bb:(-4.41261149239 5.32858310761 -12.2503419182) (11.2436789924 17.5000299924 10.2504540666)
        hole         : 455019
    hachikoi
        hole         : 455019
    Execution time for mesh.update() = 41.86 s
    smoothSolver:  Solving for alpha.water, Initial residual = 8.27297434572e-10, Final residual = 8.27297434572e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552338974  Min(alpha.water) = -0.000288674615659  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.666552338827  Min(alpha.water) = -0.000288619975557  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000659631763981, Final residual = 6.27878556034e-06, No Iterations 129
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.00981519206159, Final residual = 6.50074384625e-05, No Iterations 95
    time step continuity errors : sum local = 5.76258113924e-11, global = 3.76596506058e-11, cumulative = 2.12788820726e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000194046206327, Final residual = 1.08198900443e-06, No Iterations 137
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 5.43945734601e-05, Final residual = 8.53757949514e-10, No Iterations 262
    time step continuity errors : sum local = 3.60665856703e-15, global = -2.65475508792e-15, cumulative = 2.1278855525e-09
    smoothSolver:  Solving for omega, Initial residual = 7.30361462036e-07, Final residual = 3.97781225689e-10, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 3.49789830215e-05, Final residual = 3.4609685557e-09, No Iterations 2
    PIMPLE: iteration 2
    smoothSolver:  Solving for alpha.water, Initial residual = 8.16330553355e-10, Final residual = 8.16330553355e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552338696  Min(alpha.water) = -0.00028861608681  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.64320126049e-05, Final residual = 3.53085923555e-07, No Iterations 139
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.6562573215e-05, Final residual = 1.63348260399e-07, No Iterations 126
    time step continuity errors : sum local = 6.65506742196e-13, global = 6.65113179978e-13, cumulative = 2.12855066568e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 7.05305597495e-06, Final residual = 4.86049614563e-08, No Iterations 143
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.0062961958e-06, Final residual = 3.82850298196e-10, No Iterations 202
    time step continuity errors : sum local = 1.20177987263e-15, global = 2.18943311055e-16, cumulative = 2.12855088463e-09
    smoothSolver:  Solving for omega, Initial residual = 5.22965286878e-10, Final residual = 5.22965286878e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 8.764653366e-09, Final residual = 8.764653366e-09, No Iterations 0
    PIMPLE: iteration 3
    smoothSolver:  Solving for alpha.water, Initial residual = 8.34145135352e-10, Final residual = 8.34145135352e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552338578  Min(alpha.water) = -0.000288612326428  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.26546928799e-06, Final residual = 2.26376259356e-08, No Iterations 133
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 7.73727028489e-07, Final residual = 7.58193596374e-09, No Iterations 142
    time step continuity errors : sum local = 3.32815134752e-14, global = 3.32775001386e-14, cumulative = 2.12858416213e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.24877961418e-07, Final residual = 2.65040195196e-09, No Iterations 151
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.36702609294e-07, Final residual = 9.73556700389e-10, No Iterations 142
    time step continuity errors : sum local = 4.50942836308e-15, global = 3.24662375376e-15, cumulative = 2.12858740875e-09
    smoothSolver:  Solving for omega, Initial residual = 5.24948390428e-10, Final residual = 5.24948390428e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 8.92548068881e-09, Final residual = 8.92548068881e-09, No Iterations 0
    PIMPLE: iteration 4
    smoothSolver:  Solving for alpha.water, Initial residual = 8.39608653245e-10, Final residual = 8.39608653245e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552338472  Min(alpha.water) = -0.000288608472331  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.67244877187e-07, Final residual = 2.53807729896e-09, No Iterations 156
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 8.94717131277e-08, Final residual = 8.39554535244e-10, No Iterations 127
    time step continuity errors : sum local = 3.85428841404e-15, global = 2.11240953212e-15, cumulative = 2.12858952116e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.8066547318e-08, Final residual = 6.21581241679e-10, No Iterations 95
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 6.6868460246e-09, Final residual = 9.95083309543e-10, No Iterations 14
    time step continuity errors : sum local = 3.31155029848e-15, global = 2.63481371504e-16, cumulative = 2.12858978464e-09
    smoothSolver:  Solving for omega, Initial residual = 5.25158396946e-10, Final residual = 5.25158396946e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 8.94269523662e-09, Final residual = 8.94269523662e-09, No Iterations 0
    PIMPLE: iteration 5
    smoothSolver:  Solving for alpha.water, Initial residual = 8.49256382234e-10, Final residual = 8.49256382234e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552338375  Min(alpha.water) = -0.000288604542788  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.63410214157e-07, Final residual = 1.58076469785e-09, No Iterations 115
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.91057467543e-09, Final residual = 9.88772998935e-10, No Iterations 27
    time step continuity errors : sum local = 4.32969109332e-15, global = 3.26463782778e-15, cumulative = 2.12859304928e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 6.98750307525e-09, Final residual = 9.88518391293e-10, No Iterations 14
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.44234940454e-09, Final residual = 9.8025747263e-10, No Iterations 4
    time step continuity errors : sum local = 3.90688904253e-15, global = 3.55096694681e-15, cumulative = 2.12859660025e-09
    smoothSolver:  Solving for omega, Initial residual = 5.25212396357e-10, Final residual = 5.25212396357e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 8.94951618755e-09, Final residual = 8.94951618755e-09, No Iterations 0
    ExecutionTime = 2032.89 s  ClockTime = 2056 s
    Courant Number mean: 6.42988902653e-07 max: 0.749137867548
    Interface Courant Number mean: 7.49720100137e-09 max: 0.0185446989986
    deltaT = 0.000122067132065
    Time = 0.0125595
    PIMPLE: iteration 1
    forces forces:
        rho: rho
    forces forces:
        rho: rho
    forces forces:
        rho: rho
        Centre of rotation: (0 0 -0.999947421749)
        Linear velocity: (0 0 -0.00946196445189)
        zone:2 nCells:1783736  voxels:(92 92 92) bb:(-4.41261149239 5.32858310761 -12.2503424141) (11.2436789924 17.5000299924 10.2504535706)
        hole         : 455019
    Execution time for mesh.update() = 43.03 s
    smoothSolver:  Solving for alpha.water, Initial residual = 5.62693014026e-10, Final residual = 5.62693014026e-10, No Iterations 0
    Phase-1 volume fraction = 0.66655233832  Min(alpha.water) = -0.000288604542788  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.666552338241  Min(alpha.water) = -0.000288600000297  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.00610895566778, Final residual = 1.76062946381e-05, No Iterations 187
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000464626734755, Final residual = 4.31868001907e-06, No Iterations 135
    time step continuity errors : sum local = 8.24477020959e-11, global = 6.57112660894e-11, cumulative = 2.19430786634e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000453800900833, Final residual = 3.94151614699e-06, No Iterations 147
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000147155197186, Final residual = 5.92856342839e-10, No Iterations 256
    time step continuity errors : sum local = 7.18291390647e-15, global = -4.28128690922e-15, cumulative = 2.19430358505e-09
    smoothSolver:  Solving for omega, Initial residual = 8.2278501676e-07, Final residual = 3.51637527097e-10, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 3.84521991436e-05, Final residual = 9.69284044515e-09, No Iterations 1
    PIMPLE: iteration 2
    smoothSolver:  Solving for alpha.water, Initial residual = 5.18632871574e-10, Final residual = 5.18632871574e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552338169  Min(alpha.water) = -0.000288587367539  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 8.26591595287e-05, Final residual = 7.90344473439e-07, No Iterations 112
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.51930809664e-05, Final residual = 3.22380409956e-07, No Iterations 136
    time step continuity errors : sum local = 3.9496037615e-12, global = 3.83624615083e-12, cumulative = 2.1981398312e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.71819636959e-05, Final residual = 1.70602992744e-07, No Iterations 169
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 7.29985597309e-06, Final residual = 3.6900051247e-10, No Iterations 226
    time step continuity errors : sum local = 4.54190924639e-15, global = -2.53540221376e-15, cumulative = 2.1981372958e-09
    smoothSolver:  Solving for omega, Initial residual = 5.7544716098e-10, Final residual = 5.7544716098e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 2.66232952193e-08, Final residual = 3.81501056948e-09, No Iterations 1
    PIMPLE: iteration 3
    smoothSolver:  Solving for alpha.water, Initial residual = 5.38627943033e-10, Final residual = 5.38627943033e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552338103  Min(alpha.water) = -0.000288576915369  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.90201537023e-06, Final residual = 3.77572757143e-08, No Iterations 139
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.67020370565e-06, Final residual = 1.49001158022e-08, No Iterations 133
    time step continuity errors : sum local = 1.86485260925e-13, global = 1.62184431696e-13, cumulative = 2.19829948023e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 8.50239811927e-07, Final residual = 3.72560315988e-09, No Iterations 135
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.74883768517e-07, Final residual = 5.88727468347e-10, No Iterations 143
    time step continuity errors : sum local = 6.87566012445e-15, global = 2.61279932851e-15, cumulative = 2.19830209303e-09
    smoothSolver:  Solving for omega, Initial residual = 5.82349200687e-10, Final residual = 5.82349200687e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 5.00557298894e-09, Final residual = 5.00557298894e-09, No Iterations 0
    PIMPLE: iteration 4
    smoothSolver:  Solving for alpha.water, Initial residual = 5.67042728486e-10, Final residual = 5.67042728486e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552338043  Min(alpha.water) = -0.000288566342977  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.27362568217e-07, Final residual = 2.24680912268e-09, No Iterations 148
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.01785649227e-08, Final residual = 9.24088431816e-10, No Iterations 131
    time step continuity errors : sum local = 1.10699528045e-14, global = 6.27749363094e-15, cumulative = 2.19830837052e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 4.51230608273e-08, Final residual = 9.6696452405e-10, No Iterations 117
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.92996272797e-08, Final residual = 7.57883021183e-10, No Iterations 102
    time step continuity errors : sum local = 8.10115202691e-15, global = 8.02059882017e-15, cumulative = 2.19831639112e-09
    smoothSolver:  Solving for omega, Initial residual = 5.82669063188e-10, Final residual = 5.82669063188e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 5.04746641437e-09, Final residual = 5.04746641437e-09, No Iterations 0
    PIMPLE: iteration 5
    smoothSolver:  Solving for alpha.water, Initial residual = 5.98420767334e-10, Final residual = 5.98420767334e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552337988  Min(alpha.water) = -0.000288555539222  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.69188395856e-08, Final residual = 9.84231165019e-10, No Iterations 51
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 5.26446402637e-09, Final residual = 9.89036434404e-10, No Iterations 4
    time step continuity errors : sum local = 1.00675233117e-14, global = 4.92300885785e-15, cumulative = 2.19832131413e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.20396438674e-09, Final residual = 9.80998673529e-10, No Iterations 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.89421021316e-10, Final residual = 9.89421021316e-10, No Iterations 0
    time step continuity errors : sum local = 1.01490028677e-14, global = 4.93624069931e-15, cumulative = 2.19832625037e-09
    smoothSolver:  Solving for omega, Initial residual = 5.82678554279e-10, Final residual = 5.82678554279e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 5.04987373213e-09, Final residual = 5.04987373213e-09, No Iterations 0
    ExecutionTime = 2526.09 s  ClockTime = 2556 s
        From virtual bool Foam::regIOobject::readIfModified()
        in file db/regIOobject/regIOobjectRead.C at line 271
            Re-reading object fvSchemes from file "/mnt/d/Tutorials/UMaine/decay/decayRASkOmegaSST/decayWECMiddleSpar/decayHeave1V0/background/system/fvSchemes"
            Re-reading object fvSolution from file "/mnt/d/Tutorials/UMaine/decay/decayRASkOmegaSST/decayWECMiddleSpar/decayHeave1V0/background/system/fvSolution"
    Courant Number mean: 4.99784351636e-07 max: 0.569730783454
    Interface Courant Number mean: 5.92138108728e-09 max: 0.0209198035939
    deltaT = 0.00014349253782
    Time = 0.012703
    PIMPLE: iteration 1
    forces forces:
        rho: rho
    forces forces:
        rho: rho
    forces forces:
        rho: rho
        Centre of rotation: (0 0 -0.999948522777)
        Linear velocity: (0 0 -0.00588418016272)
        zone:2 nCells:1783736  voxels:(92 92 92) bb:(-4.41261149239 5.32858310761 -12.2503435152) (11.2436789924 17.5000299924 10.2504524696)
        hole         : 455019
    Execution time for mesh.update() = 41.31 s
    smoothSolver:  Solving for alpha.water, Initial residual = 4.31650457418e-10, Final residual = 4.31650457418e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552337956  Min(alpha.water) = -0.000288555539222  Max(alpha.water) = 1
    Phase-1 volume fraction = 0.666552337912  Min(alpha.water) = -0.000288542572206  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.00236165217602, Final residual = 2.3271010307e-05, No Iterations 107
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 0.000412146953105, Final residual = 4.00471828788e-06, No Iterations 119
    time step continuity errors : sum local = 5.53488316472e-11, global = -3.70246236732e-11, cumulative = 2.1613016267e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 5.71606087261e-05, Final residual = 5.21097796183e-07, No Iterations 138
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.35125965116e-05, Final residual = 9.88359006305e-10, No Iterations 215
    time step continuity errors : sum local = 1.51332173524e-14, global = 4.52701018796e-15, cumulative = 2.16130615371e-09
    smoothSolver:  Solving for omega, Initial residual = 9.65248956233e-07, Final residual = 3.75230694262e-10, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 4.42745824449e-05, Final residual = 4.43358495994e-09, No Iterations 2
    PIMPLE: iteration 2
    smoothSolver:  Solving for alpha.water, Initial residual = 5.14219964389e-10, Final residual = 5.14219964389e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552337866  Min(alpha.water) = -0.000288456349238  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.58024318209e-05, Final residual = 1.50927926767e-07, No Iterations 135
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.73850293211e-06, Final residual = 5.74727092462e-09, No Iterations 165
    time step continuity errors : sum local = 6.69721692409e-14, global = -3.03450383446e-14, cumulative = 2.16127580867e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.49876301523e-06, Final residual = 1.39670720646e-08, No Iterations 123
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 6.76715177075e-07, Final residual = 7.98008738186e-10, No Iterations 148
    time step continuity errors : sum local = 1.22344536329e-14, global = -5.78068108562e-15, cumulative = 2.16127002799e-09
    smoothSolver:  Solving for omega, Initial residual = 6.32837304089e-10, Final residual = 6.32837304089e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 1.53271768735e-08, Final residual = 2.46952790962e-09, No Iterations 1
    PIMPLE: iteration 3
    smoothSolver:  Solving for alpha.water, Initial residual = 5.76591398138e-10, Final residual = 5.76591398138e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552337822  Min(alpha.water) = -0.000288366845858  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 5.77537562021e-07, Final residual = 5.48225168085e-09, No Iterations 102
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.56677431916e-07, Final residual = 1.4141887376e-09, No Iterations 140
    time step continuity errors : sum local = 2.23087432416e-14, global = -1.32089190452e-15, cumulative = 2.1612687071e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 6.59080063594e-08, Final residual = 9.9295509487e-10, No Iterations 132
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 3.25757162506e-08, Final residual = 9.37883485476e-10, No Iterations 103
    time step continuity errors : sum local = 1.46786743791e-14, global = -1.4653311533e-14, cumulative = 2.16125405379e-09
    smoothSolver:  Solving for omega, Initial residual = 6.49111444261e-10, Final residual = 6.49111444261e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 4.0118490653e-09, Final residual = 4.0118490653e-09, No Iterations 0
    PIMPLE: iteration 4
    smoothSolver:  Solving for alpha.water, Initial residual = 6.1973337999e-10, Final residual = 6.1973337999e-10, No Iterations 0
    Phase-1 volume fraction = 0.66655233778  Min(alpha.water) = -0.000288274846298  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 5.74398048665e-08, Final residual = 9.82136138533e-10, No Iterations 120
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 7.02405804242e-09, Final residual = 9.98479118902e-10, No Iterations 9
    time step continuity errors : sum local = 1.27292028318e-14, global = -7.9193313664e-16, cumulative = 2.16125326185e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 2.30850519151e-09, Final residual = 9.51027282588e-10, No Iterations 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.75182912812e-10, Final residual = 9.75182912812e-10, No Iterations 0
    time step continuity errors : sum local = 1.26570808677e-14, global = -4.64721120315e-16, cumulative = 2.16125279713e-09
    smoothSolver:  Solving for omega, Initial residual = 6.49171974338e-10, Final residual = 6.49171974338e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 4.0055169094e-09, Final residual = 4.0055169094e-09, No Iterations 0
    PIMPLE: iteration 5
    smoothSolver:  Solving for alpha.water, Initial residual = 6.63999797793e-10, Final residual = 6.63999797793e-10, No Iterations 0
    Phase-1 volume fraction = 0.666552337738  Min(alpha.water) = -0.00028818033445  Max(alpha.water) = 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.61804964183e-08, Final residual = 9.64384311072e-10, No Iterations 8
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.73777456394e-09, Final residual = 9.66855572087e-10, No Iterations 1
    time step continuity errors : sum local = 1.11810878112e-14, global = 1.93801378722e-15, cumulative = 2.16125473514e-09
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 1.14956370447e-09, Final residual = 9.54095995662e-10, No Iterations 1
    DILUPBiCGStab:  Solving for p_rgh, Initial residual = 9.55825543332e-10, Final residual = 9.55825543332e-10, No Iterations 0
    time step continuity errors : sum local = 1.1122693211e-14, global = 1.9981078044e-15, cumulative = 2.16125673325e-09
    smoothSolver:  Solving for omega, Initial residual = 6.49156613018e-10, Final residual = 6.49156613018e-10, No Iterations 0
    smoothSolver:  Solving for k, Initial residual = 4.00623653355e-09, Final residual = 4.00623653355e-09, No Iterations 0
    ExecutionTime = 2914.54 s  ClockTime = 2959 s
    hachikoi
    背景网格的插值区,计算区和hole
    中心柱overset的插值区,计算区和hole
    外环柱overset的插值区,计算区和hole
    hachikoi
    大佬有没有什么建议呀 @队长别开枪
    队长别开枪队 1 条回复 最后回复
  • 队长别开枪队 离线
    队长别开枪队 离线
    队长别开枪 超神
    在 中回复了 hachikoi 最后由 编辑
    @hachikoi 还没做过多浮体的例子,最近做了一个overset+AMR+PLIC的算例,结果还行。你的算例几何尺寸可以分享一下么,圣诞节放假的时候我可以用我的求解器试着算算。
    hachikoi
    在 中回复了 队长别开枪 最后由 编辑
    @队长别开枪
    内柱:Cylinder z1(0 0 -20) z2 (0 0 15) 半径 6.25
    外环:z1(0 0 -7.25) z2(0 0 5.25) 内半径 7.5 外半径 12.5
    外环原先是关于水面对称,下降一米让其上浮
    decayHeave1V0.rar
    麻烦大佬给看看
    据另一位做六自由度双浮箱的同学说,他也遇到了类似的问题 只要overset之间相互接触就会发散,不知问题到底出在哪
    Z S 2 条回复 最后回复
  • 王 离线
    王 离线
    王长宏
    @hachikoi 您好,能帮忙问一下做六自由度双浮箱的同学,他做的双浮箱涉及两个浮体之间的耦合吗,想交流一下。
    zbxia
    @hachikoi 你好,请问你说的外浮体overset➕内浮体背景网格扣除,内浮体通过什么工具在背景网格里面扣除呢?最近遇到类似的问题,卡住了,我的案例是浮体通过overset实现,背景网格内紧邻浮体有一个固定式结构,我用Toposet和sanppyHexMesh工具在背景网格里扣除固定式结构时,第一个时间步计算压力就发散,尝试修改网格尺寸,浮体与背景网格固定式结构距离,压力求解方式等均未解决,谢谢回答!
    Sichan
    @hachikoi 您好,请问您的问题现在解决了吗?我现在也在做和您相似的双浮体模拟,但是在模拟时出现了第一部就会发散的问题,重叠网格挖的洞数量很大。
