84 帖子 18 发布者 222.4k 浏览
    http://dyfluid.com/download.html 我这面有全系列的,里面gcc也可以切换。
    你用你的老版本也行,老版本要更新gcc。
    不管咋的你可以试试,有问题反馈我我协助
    1 1 条回复 最后回复
    在 中回复了 1064168551 最后由 李东岳 编辑
    @1064168551 我刚又编译了一个新的程序,没问题。你应该是版本问题。
  • 1 离线
    1 离线
    1064168551
    @李东岳 在 OpenFOAM外挂libtorch 中说:
    不管咋的你可以试试,有问题反馈我我协助
    谢谢东岳老师,我的伴随拓扑优化是用老版本of写的,我试着更新gcc后编译一下,感谢感谢
    更新gcc之后你openfoam就编译不了了。那你尝试安装老版本的libtorch吧
    1 小 chengan.wangC 3 条回复 最后回复
  • 1 离线
    1 离线
    1064168551
    好的老师,我找一下老版本的libtorch
    这是个我写的求解1D对流方程的代码。PINN方法。可以在openfoam下执行。
    #include <torch/torch.h>
    #include "net.H"
    int main()
        int iter = 1;
        int IterationNum = 1000;
        // Computational domain
        double dx = 0.1;
        double dt = 0.1;
        torch::Tensor x = torch::arange(-1, 1 + dx, dx);
        torch::Tensor t = torch::arange(0, 1 + dt, dt);
        torch::Tensor meshAndTime = torch::stack(torch::meshgrid({x, t})).reshape({2, -1}).transpose(0, 1);
        torch::DeviceType device = torch::kCPU;
        torch::nn::MSELoss criterion = torch::nn::MSELoss();
        std::shared_ptr<NN> model = std::make_shared<NN>();
        model->to(device);
        std::shared_ptr<torch::optim::Adam> adam =
            std::make_shared<torch::optim::Adam>(model->parameters());
        torch::Tensor inlet =
            torch::stack
                torch::meshgrid({x.index({0}), t})
        torch::Tensor outlet =
            torch::stack
                torch::meshgrid({x.index({-1}), t})
        torch::Tensor ic =
            torch::stack
                torch::meshgrid({x, t.index({0})})
        torch::Tensor icbc = torch::cat({outlet, inlet, ic});
        torch::Tensor U_inlet = torch::full({11}, 0.5);
        torch::Tensor U_outlet = torch::zeros(outlet.size(0));
        torch::Tensor UiniLeft = torch::full({11}, 0.5);
        torch::Tensor UiniRight = torch::full({10}, 0.);
        //torch::Tensor U_ic = torch::cat({UiniLeft, UiniRight});
            torch::tensor
                {0.5,0.5,0.5,0.5,0.5,0.5,0.5,0.4,0.3,0.2,0.1,0.,0.,0.,0.,0.,0.,0.,0.,0.,0.}
        torch::Tensor U_icbc = torch::cat({U_outlet, U_inlet, U_ic}).unsqueeze(1);
        meshAndTime = meshAndTime.to(device);
        U_icbc = U_icbc.to(device);
        icbc = icbc.to(device);
        meshAndTime.requires_grad_(true);
        model->train();
        // Iteration
        for (int i = 0; i < IterationNum; i++)
            adam->zero_grad();
            torch::Tensor U_icbcPred = model->forward(icbc);
            torch::Tensor loss_data = criterion(U_icbcPred, U_icbc);
            torch::Tensor UIter = model->forward(meshAndTime);
            torch::Tensor dudxt =
                torch::autograd::grad
                    {UIter},
                    {meshAndTime},
                    {torch::ones_like(UIter)},
                    true,
                    true
                )[0];
            torch::Tensor dudt = dudxt.index({torch::indexing::Slice(), 1});
            torch::Tensor dudx = dudxt.index({torch::indexing::Slice(), 0});
            torch::Tensor loss_pde = criterion(dudt, -0.3*dudx);
            torch::Tensor loss = loss_pde + loss_data;
            loss.backward();
            adam->step();
            if (iter % 100 == 0)
                std::cout << iter << " " << loss.item<double>() << std::endl;
            iter++;
        // output results
        torch::Tensor Ufinal = model->forward(meshAndTime);
        Ufinal = Ufinal.reshape({(int)(2/dx) + 1, (int)(1/dt) + 1});
        std::ofstream file("U");
        for (int i = 0; i < Ufinal.size(0); i++)
            for (int j = 0; j < Ufinal.size(1); j++)
                file << Ufinal[i][j].item<float>() << " ";
            file << "\n";
        file.close();
        std::cout<< "Done!" << std::endl;
        return 0;
    上面给的是光滑的数据。在纯的黎曼问题的时候,有震荡如下图。感觉需要附加监督点
    xiezhuoyuX 1 条回复 最后回复
  • xiezhuoyuX 离线
    xiezhuoyuX 离线
    xiezhuoyu
    #include "net.H"
    李老师,不知道是否方便贴一下net.H?
    感谢!:chouchou:
    net.H
    class NN
        public torch::nn::Module
        torch::nn::Sequential net_;
    public:
        NN();
        torch::Tensor forward(torch::Tensor x);
    net.C
        \\  /    A nd           | Copyright (C) 2022-2023 OpenFOAM Foundation
         \\/     M anipulation  |
    License
        for more details.
    Class
    See also
    SourceFiles
    #include "net.H"
    NN::NN()
        net_ = register_module
            "net",
                torch::nn::Linear(2,20),
                torch::nn::ReLU(),
                torch::nn::Linear(20,30),
                torch::nn::ReLU(),
                torch::nn::Linear(30,30),
                torch::nn::ReLU(),
                torch::nn::Linear(30,20),
                torch::nn::ReLU(),
                torch::nn::Linear(20,20),
                torch::nn::ReLU(),
                torch::nn::Linear(20,1)
    torch::Tensor NN::forward(torch::Tensor x)
        return net_->forward(x);
    这个要编译成库,挂到PINNFoam上面
    xiezhuoyuX 水 2 条回复 最后回复
  • xiezhuoyuX 离线
    xiezhuoyuX 离线
    xiezhuoyu
    @李东岳 可运行,👍👍👍谢谢李老师!
    李东岳李 T 2 条回复 最后回复
    在 中回复了 xiezhuoyu 最后由 编辑
    @xiezhuoyu 老铁可以试试求解黎曼问题,这个结果不太好,有spike。
    更新一段代码,简单的做个一维拟合。蓝线是训练数据。黄点灰点是预测值。
    typedef torch::Tensor TT;
    class NN
    public:
        NN()
                "net",
                    torch::nn::Linear(1,20),
                    torch::nn::ReLU(),
                    torch::nn::ReLU(),
                    torch::nn::ReLU(),
                    torch::nn::ReLU(),
                    torch::nn::Linear(30,1)
    int main()
        torch::manual_seed(30);
        TT X = torch::tensor({1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0}).reshape({-1, 1});
        TT Y = torch::tensor({1.0, 0.5, 1.5, 2.0, 2.5, 2.0, 2.5, 3.0, 3.1}).reshape({-1, 1});
        torch::optim::Adam adam(model->parameters(), torch::optim::AdamOptions(0.01));
        const size_t num_epochs = 1000;
        for (size_t epoch = 0; epoch < num_epochs; ++epoch)
            TT output = model->forward(X);
            TT loss = criterion(output, Y);
            adam.zero_grad();
            loss.backward();
            adam.step();
            if ((epoch + 1) % 100 == 0)
                std::cout << "Loss: " << loss.item<float>() << std::endl;
        //model->eval();
        TT test = torch::tensor({4.4, 5.5}).reshape({-1, 1});
        TT predic = model->forward(test);
        std::cout<< "prediction is " << predic << std::endl;
        return 0;
    单变量对多变量变种:
    class NN
    public:
        NN()
                "net",
                    torch::nn::ReLU(),
                    torch::nn::ReLU(),
                    torch::nn::ReLU(),
                    torch::nn::ReLU(),
                    torch::nn::Linear(30,2)
    int main()
        TT Y = torch::tensor({{1.0, 1.0}, {0.5, 0.5}, {1.5, 1.5}, {2.0, 2.0}, {2.5, 2.5}, {2.0, 2.0}, {2.5, 2.5}, {3.0, 3.0}, {3.1, 3.1}}).reshape({-1, 2});
            adam.zero_grad();
            loss.backward();
            adam.step();
        //model->eval();
        return 0;
    下面这个代码是个正儿八经的监督学习。下图左边是OpenFOAM算的,右边是OpenFOAM环境下libtorch训练的。
    #include "argList.H"
    #include "solver.H"
    #define SIZE 64
    class NN
    public:
        NN()
                "net",
                    torch::nn::ReLU(),
                    torch::nn::ReLU(),
                    torch::nn::ReLU(),
                    torch::nn::ReLU(),
                    torch::nn::Linear(30,SIZE)
    using namespace Foam;
        #include "setRootCase.H"
        #include "createTime.H"
        #include "createMesh.H"
        #include "createFields.H"
        scalarField P0internal = P[0].primitiveField();
        scalarField P1internal = P[1].primitiveField();
        float* P0array = new float[SIZE];
        float* P1array = new float[SIZE];
        for (int i = 0; i < SIZE; i++)
            P0array[i] = P0internal[i];
            P1array[i] = P1internal[i];
        TT P0label = torch::from_blob(P0array, SIZE, torch::kFloat32).clone();
        TT P1label = torch::from_blob(P1array, SIZE, torch::kFloat32).clone();
        delete [] P0array;
        delete [] P1array;
        TT X = torch::tensor({1.0, 1.1, 1.2, 1.3, 1.4, 1.5, 1.6, 1.7, 1.8}).reshape({-1, 1});
        torch::Tensor Y =
            torch::cat
                    P0label.unsqueeze(0),
                    P1label.unsqueeze(0)
        //std::cout<< "Y = " << Y << std::endl;
        torch::optim::Adam adam(model->parameters(), torch::optim::AdamOptions(0.001));
        for (int epoch = 0; epoch < 1500; epoch++)
            //Info<< "epoch = " << epoch << nl;
            adam.zero_grad();
            loss.backward();
            adam.step();
        TT test = torch::tensor({2.0}).reshape({-1, 1});
        std::cout<< "prediction is " << predic.reshape({-1,1}) << std::endl;
        return 0;
    xiezhuoyuX leaonL 2 条回复 最后回复
  • xiezhuoyuX 离线
    xiezhuoyuX 离线
    xiezhuoyu
    李老师,这个P[0]和P[1]分别是什么物理量?怎么得到呢?
    @xiezhuoyu 你训练的场,比如温度场压力场
    这是一个顶盖驱动流动的PINN代码。写了一天,最开始的版本植入的是守恒的形式,边界条件除了顶盖都给的零梯度,导致导数特别多。
    下面这个版本我还植入的非守恒形式,然后边界条件都变成了固定值0。不过结果还是不太对。做个记录吧。整了一天这个导数
    :136:
    我目前怀疑边界的导数应该也是从mesh计算,而不能单独计算边界的导数。这需要大改。
    using namespace std;
    class NN
    public:
        NN()
                "net",
                    torch::nn::Tanh(),
                    torch::nn::Tanh(),
                    torch::nn::Tanh(),
                    torch::nn::Tanh(),
                    torch::nn::Linear(20,3)
        auto forward(torch::Tensor x)
    int main()
        int iter = 1;
        int IterationNum = 200;
        auto crit = torch::nn::MSELoss();
        auto model = std::make_shared<NN>();
        auto adam = std::make_shared<torch::optim::Adam>(model->parameters());
        double dx = 0.2;
        double dy = 0.2;
        auto x = torch::arange(0, 1 + dx, dx);
        auto y = torch::arange(10, 11 + dy, dy);
        auto mesh =
            torch::stack(torch::meshgrid({x, y})).reshape({2, -1}).transpose(0, 1);
        mesh.requires_grad_(true);
        auto leftWall =
            torch::stack
                torch::meshgrid({x.index({0}), y})
        auto rightWall =
            torch::stack
                torch::meshgrid({x.index({-1}), y})
        auto bottom =
            torch::stack
                torch::meshgrid({x, y.index({0})})
        bottom.requires_grad_(true);
        auto top =
            torch::stack
                torch::meshgrid({x, y.index({-1})})
        top.requires_grad_(true);
        auto fixedWalls = torch::cat({leftWall, rightWall, bottom});
        auto u_top = torch::full({x.size(0)}, 1.0);
        auto v_top = torch::full({x.size(0)}, 0.0);
        //cout<< "mesh = \n" << mesh << endl;
        //cout<< "leftWall = \n" << leftWall << endl;
        //cout<< "rightWall = \n" << rightWall << endl;
        //cout<< "bottom = \n" << bottom << endl;
        //cout<< "top = \n" << top << endl;
        //cout<< "fixedWalls = \n" << fixedWalls << endl;
        // Iteration
            adam->zero_grad();
            // Top boundary
            auto top_pred = model->forward(top);
            auto u_top_pred = top_pred.index({torch::indexing::Slice(), 0});
            auto v_top_pred = top_pred.index({torch::indexing::Slice(), 1});
            auto p_top_pred = top_pred.index({torch::indexing::Slice(), 2});
            auto loss_top =
                crit(v_top_pred, v_top) + crit(u_top_pred, u_top);
            auto dpdTop =
                    {p_top_pred},
                    {top},
                    {torch::ones_like(p_top_pred)},
                    true,
                    true
                )[0];
            auto dpdyTop = dpdTop.index({torch::indexing::Slice(), 1});
            loss_top += crit(dpdyTop, torch::zeros({dpdyTop.size(0)}));
            //cout << "loss_top\n" << loss_top << endl;
            // Bottom boundary
            auto bot_pred = model->forward(bottom);
            auto u_bot_pred = bot_pred.index({torch::indexing::Slice(), 0});
            auto v_bot_pred = bot_pred.index({torch::indexing::Slice(), 1});
            auto p_bot_pred = bot_pred.index({torch::indexing::Slice(), 2});
            auto dpdBot =
                    {p_bot_pred},
                    {bottom},
                    {torch::ones_like(p_bot_pred)},
                    true,
                    true
                )[0];
            auto dpdyBot = dpdBot.index({torch::indexing::Slice(), 1});
            auto loss_bot = crit(dpdyBot, torch::zeros({dpdyBot.size(0)}))
              + crit(u_bot_pred, torch::zeros({dpdyBot.size(0)}))
              + crit(v_bot_pred, torch::zeros({dpdyBot.size(0)}));
            // Field
            auto UP = model->forward(mesh);
            auto u_pred = UP.index({torch::indexing::Slice(), 0});
            auto v_pred = UP.index({torch::indexing::Slice(), 1});
            auto p_pred = UP.index({torch::indexing::Slice(), 2});
            auto dpdMesh =
                    {p_pred},
                    {mesh},
                    {torch::ones_like(u_pred)},
                    true,
                    true
                )[0];
            auto dpdx = dpdMesh.index({torch::indexing::Slice(), 0});
            auto dpdy = dpdMesh.index({torch::indexing::Slice(), 1});
            auto dudMesh =
                    {u_pred},
                    {mesh},
                    true,
                    true
                )[0];
            auto dudx = dudMesh.index({torch::indexing::Slice(), 0});
            auto dudy = dudMesh.index({torch::indexing::Slice(), 1});
            auto dudxMesh =
                    {dudx},
                    {mesh},
                    true,
                    true
                )[0];
            auto dudyMesh =
                    {dudy},
                    {mesh},
                    true,
                    true
                )[0];
            auto dudxx = dudxMesh.index({torch::indexing::Slice(), 0});
            auto dudyy = dudyMesh.index({torch::indexing::Slice(), 1});
            //cout << "dudxx\n" << dudxx << endl;
            auto dvdMesh =
                    {v_pred},
                    {mesh},
                    true,
                    true
                )[0];
            auto dvdx = dvdMesh.index({torch::indexing::Slice(), 0});
            auto dvdy = dvdMesh.index({torch::indexing::Slice(), 1});
            auto dvdxMesh =
                    {dvdx},
                    {mesh},
                    true,
                    true
                )[0];
            auto dvdyMesh =
                    {dvdy},
                    {mesh},
                    true,
                    true
                )[0];
            auto dvdxx = dvdxMesh.index({torch::indexing::Slice(), 0});
            auto dvdyy = dvdyMesh.index({torch::indexing::Slice(), 1});
            auto loss_cont = crit(dudx, -dvdy);
            auto loss_mom1 = crit(u_pred*dudx + v_pred*dudy - 0.001*(dudxx + dudyy), -dpdx);
            auto loss_mom2 = crit(u_pred*dvdx + v_pred*dvdy - 0.001*(dvdxx + dvdyy), -dpdy);
            auto loss_pde = loss_cont + loss_mom1 + loss_mom2;
            //cout<< "loss_cont\n" << loss_cont << endl;
            //cout<< "loss_mom1\n" << loss_mom1 << endl;
            //cout<< "loss_mom2\n" << loss_mom2 << endl;
            //cout<< "loss_pde\n" << loss_pde << endl;
            // leftWall and rightWall
            auto dpdxLeft = dpdx.index({torch::indexing::Slice(0, 6)});
            auto u_pred_left = u_pred.index({torch::indexing::Slice(0, 6)});
            auto v_pred_left = v_pred.index({torch::indexing::Slice(0, 6)});
            auto dpdxRight = dpdx.index({torch::indexing::Slice(-6, torch::indexing::None)});
            auto u_pred_right = u_pred.index({torch::indexing::Slice(-6, torch::indexing::None)});
            auto v_pred_right = v_pred.index({torch::indexing::Slice(-6, torch::indexing::None)});
            auto loss_leftRight = crit(u_pred_left, torch::zeros({6}))
              + crit(v_pred_left, torch::zeros({6}))
              + crit(dpdxLeft, torch::zeros({6}))
              + crit(v_pred_right, torch::zeros({6}))
              + crit(u_pred_right, torch::zeros({6}))
              + crit(dpdxRight, torch::zeros({6}));
            //cout<< "loss_leftRight\n" << loss_leftRight << endl;
            auto loss = loss_top + loss_bot + loss_leftRight + loss_pde;
            //cout<< "loss\n" << loss << endl;
            loss.backward();
            adam->step();
            iter++;
        model->eval();//neglect
        auto results = model->forward(mesh);
        cout << "results\n" << results << endl;
        return 0;
    都是在OpeNFOAM环境下,左边是我的PINN算的,下面是OpenFOAM自带的simpleFoam算的。:135: :135:
  • T 离线
    T 离线
    tiankai
    @xiezhuoyu 我是小白,想要请教一下,怎么才能运行呢:135:
  • xiezhuoyuX 离线
    xiezhuoyuX 离线
    xiezhuoyu
    在 中回复了 tiankai 最后由 编辑
    @tiankai
    1. 查看/修改OpenFOAM执行wmake时采用的Gcc版本,OpenFOAM/wmake/rules/General/Gcc/c++
      CC          = g++$(COMPILER_VERSION) -std=c++14
    2. pytorch官网下载libtorch
      2.3.0版本依赖C++17
      2.0.0版本依赖C++14
      1.10.0版本依赖C++14
    3. 修改/home/***/.bashrc,设置环境变量
      export LD_LIBRARY_PATH=/home/***/OpenFOAM/libtorch/lib:$LD_LIBRARY_PATH
    4. wmake你的库(比如李老师贴的代码)PINNFoam
    5. 最后调用PINNFoam
    T 1 条回复 最后回复
  • T 离线
    T 离线
    tiankai
    @xiezhuoyu 多谢回复,我查看了g++版本,确实是14,而且我已经成功编译了libtorch库,但是在编译一维对流方程时报错了
    提示指针变量有错误
  • xiezhuoyuX 离线
    xiezhuoyuX 离线
    xiezhuoyu
    @tiankai 看不出来什么问题?问问李老师@李东岳 :papa:
    我已经成功编译了libtorch库
    @tiankai 我这个路子不需要编译libtorch。 你看楼上总结那个也不需要编译。我这面没有编译。就跟OpenFOAM安装一样。OpenFOAM可以直接下载装(apt install那种),也可以编译安装。你不要编译,你按照我1楼的方法用现成的,跟openfoam捆绑起来能跑起来。回头再研究编译libtorch
    T 1 条回复 最后回复
