  3. blockMeshDict报错相邻面数量不一致怎么解决?
10 帖子 3 发布者 2.8k 浏览
  • E 离线
    E 离线
    Elliott
    我运行blockMeshwang画网格报错--> FOAM FATAL ERROR:
    Inconsistent number of faces between block pair 0 and 1
    附上我的blockMeshDict内容,各位大佬帮我看一下我到底是哪里写错了
        \\  /    A nd           | Version:  6
         \\/     M anipulation  |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      blockMeshDict;
    convertToMeters 0.001;//mm
    //radius
    radius        3;//内管内壁半径
    radius_1      3.5;//内管外壁半径
    radius_2      4;//外管内壁半径
    radius_3      5;//外管外壁半径
    radius_4      25;//计算域边界
    //half_side
    box           1;
    hs            2.12130344;
    hs_1          2.474873734;
    hs_2          2.828427125;
    hs_3          3.535533906;
    hs_4          17.67766953;
    boxNeg        -1;
    hsNeg         -2.12130344;
    hsNeg_1       -2.474873734;
    hsNeg_2       -2.828427125;
    hsNeg_3       -3.535533906;
    hsNeg_4       -17.67766953;
    zMax        210;//zMax和zMin定义圆柱体的长度
    zMin        0.0;
    nR          32;//扇形block半径上的节点数
    nR_1        10;
    nR_2        10;
    nR_3        20;
    nR_4        400;
    nBox        40;//矩形block正方形边上的节点数
    nZ          2100;//轴向方向上的节点数
    verbose no;
    geometry
        cylinder
            type      searchableCylinder;
            point1    (0 0 -0.1);//由point1和point2构成的区域要大于zMax和zMin构成的区域
            point2    (0 0  211);
            radius    $radius;
        cylinder_1
            point2    (0 0  211);
            radius    $radius_1;
        cylinder_2
            point2    (0 0  211);
            radius    $radius_2;
        cylinder_3
            point2    (0 0  211);
            radius    $radius_3;
        cylinder_4
            point2    (0 0  211);
            radius    $radius_4;
    scale 1;
    vertices
        // Inner
        ($boxNeg $boxNeg $zMin)//0
        ($box    $boxNeg $zMin)//1
        ($box    $box    $zMin)//2
        ($boxNeg $box    $zMin)//3
        // cylinder
        project ($hsNeg  $hsNeg $zMin) (cylinder)//4
        project ($hs     $hsNeg $zMin) (cylinder)//5
        project ($hs     $hs    $zMin) (cylinder)//6
        project ($hsNeg  $hs    $zMin) (cylinder)//7
        // cylinder_1
        project ($hsNeg_1  $hsNeg_1 $zMin) (cylinder_1)//8
        project ($hs_1     $hsNeg_1 $zMin) (cylinder_1)//9
        project ($hs_1     $hs_1    $zMin) (cylinder_1)//10
        project ($hsNeg_1  $hs_1    $zMin) (cylinder_1)//11
        // cylinder_2
        project ($hsNeg_2  $hsNeg_2 $zMin) (cylinder_2)//12
        project ($hs_2     $hsNeg_2 $zMin) (cylinder_2)//13
        project ($hs_2     $hs_2    $zMin) (cylinder_2)//14
        project ($hsNeg_2  $hs_2    $zMin) (cylinder_2)//15
        // cylinder_3
        project ($hsNeg_3  $hsNeg_3 $zMin) (cylinder_3)//16
        project ($hs_3     $hsNeg_3 $zMin) (cylinder_3)//17
        project ($hs_3     $hs_3    $zMin) (cylinder_3)//18
        project ($hsNeg_3  $hs_3    $zMin) (cylinder_3)//19
        // cylinder_4
        project ($hsNeg_4  $hsNeg_4 $zMin) (cylinder_4)//20
        project ($hs_4     $hsNeg_4 $zMin) (cylinder_4)//21
        project ($hs_4     $hs_4    $zMin) (cylinder_4)//22
        project ($hsNeg_4  $hs_4    $zMin) (cylinder_4)//23
        // Inner
        ($boxNeg $boxNeg $zMax)//24
        ($box    $boxNeg $zMax)//25
        ($box    $box    $zMax)//26
        ($boxNeg $box    $zMax)//27
        // cylinder
        project ($hsNeg  $hsNeg $zMax) (cylinder)//28
        project ($hs     $hsNeg $zMax) (cylinder)//29
        project ($hs     $hs    $zMax) (cylinder)//30
        project ($hsNeg  $hs    $zMax) (cylinder)//31
        // cylinder_1
        project ($hsNeg_1  $hsNeg_1 $zMax) (cylinder_1)//32
        project ($hs_1     $hsNeg_1 $zMax) (cylinder_1)//33
        project ($hs_1     $hs_1    $zMax) (cylinder_1)//34
        project ($hsNeg_1  $hs_1    $zMax) (cylinder_1)//35
        // cylinder_2
        project ($hsNeg_2  $hsNeg_2 $zMax) (cylinder_2)//36
        project ($hs_2     $hsNeg_2 $zMax) (cylinder_2)//37
        project ($hs_2     $hs_2    $zMax) (cylinder_2)//38
        project ($hsNeg_2  $hs_2    $zMax) (cylinder_2)//39
        // cylinder_3
        project ($hsNeg_3  $hsNeg_3 $zMax) (cylinder_3)//40
        project ($hs_3     $hsNeg_3 $zMax) (cylinder_3)//41
        project ($hs_3     $hs_3    $zMax) (cylinder_3)//42
        project ($hsNeg_3  $hs_3    $zMax) (cylinder_3)//43
        // cylinder_4
        project ($hsNeg_4  $hsNeg_4 $zMax) (cylinder_4)//44
        project ($hs_4     $hsNeg_4 $zMax) (cylinder_4)//45
        project ($hs_4     $hs_4    $zMax) (cylinder_4)//46
        project ($hsNeg_4  $hs_4    $zMax) (cylinder_4)//47
    blocks
        hex (0 1 2 3 24 25 26 27) ($nBox $nBox $nZ) simpleGrading (1 1 1)
        hex (0 4 5 1 24 28 29 25) ($nBox $nR $nZ) simpleGrading (1 1 1)
        hex (1 5 6 2 25 29 30 26) ($nR $nBox $nZ) simpleGrading (1 1 1)
        hex (2 6 7 3 26 30 31 27) ($nBox $nR $nZ) simpleGrading (1 1 1)
        hex (3 7 4 0 27 31 28 24) ($nR $nBox $nZ) simpleGrading (1 1 1)
        hex (4 8 9 5 28 32 33 29) ($nBox $nR_1 $nZ) simpleGrading (1 1 1)
        hex (5 9 10 6 29 33 34 30) ($nR_1 $nBox $nZ) simpleGrading (1 1 1)
        hex (6 10 11 7 30 34 35 31) ($nBox $nR_1 $nZ) simpleGrading (1 1 1)
        hex (7 11 8 4 31 35 32 28) ($nR_1 $nBox $nZ) simpleGrading (1 1 1)
        hex (8 12 13 9 32 36 37 33) ($nBox $nR_2 $nZ) simpleGrading (1 1 1)
        hex (9 13 14 10 33 37 38 34) ($nR_2 $nBox $nZ) simpleGrading (1 1 1)
        hex (10 14 15 11 34 38 39 35) ($nBox $nR_2 $nZ) simpleGrading (1 1 1)
        hex (11 15 12 8 35 39 36 32) ($nR_2 $nBox $nZ) simpleGrading (1 1 1)
        hex (12 16 17 13 36 40 41 37) ($nBox $nR_3 $nZ) simpleGrading (1 1 1)
        hex (13 17 18 14 37 41 42 38) ($nR_3 $nBox $nZ) simpleGrading (1 1 1)
        hex (14 18 19 15 38 42 43 39) ($nBox $nR_3 $nZ) simpleGrading (1 1 1)
        hex (15 19 16 12 39 43 40 36) ($nR_3 $nBox $nZ) simpleGrading (1 1 1)
        hex (16 20 21 17 40 44 45 41) ($nBox $nR_4 $nZ) simpleGrading (1 1 1)
        hex (17 21 22 18 41 45 46 42) ($nR_4 $nBox $nZ) simpleGrading (1 1 1)
        hex (18 22 23 19 42 46 47 43) ($nBox $nR_4 $nZ) simpleGrading (1 1 1)
        hex (19 23 20 16 43 47 44 40) ($nR_4 $nBox $nZ) simpleGrading (1 1 1)
    edges
        project 4 5 (cylinder)
        project 5 6 (cylinder)
        project 6 7 (cylinder)
        project 7 4 (cylinder)
        project 28 29 (cylinder)
        project 29 30 (cylinder)
        project 30 31 (cylinder)
        project 31 28 (cylinder)
        project 8 9 (cylinder_1)
        project 9 10 (cylinder_1)
        project 10 11 (cylinder_1)
        project 11 8 (cylinder_1)
        project 32 33 (cylinder_1)
        project 33 34 (cylinder_1)
        project 34 35 (cylinder_1)
        project 35 32 (cylinder_1)
        project 12 13 (cylinder_2)
        project 13 14 (cylinder_2)
        project 14 15 (cylinder_2)
        project 15 12 (cylinder_2)
        project 36 37 (cylinder_2)
        project 37 38 (cylinder_2)
        project 38 39 (cylinder_2)
        project 39 36 (cylinder_2)
        project 16 17 (cylinder_3)
        project 17 18 (cylinder_3)
        project 18 19 (cylinder_3)
        project 19 16 (cylinder_3)
        project 40 41 (cylinder_3)
        project 41 42 (cylinder_3)
        project 42 43 (cylinder_3)
        project 43 40 (cylinder_3)
        project 20 21 (cylinder_4)
        project 21 22 (cylinder_4)
        project 22 23 (cylinder_4)
        project 23 20 (cylinder_4)
        project 44 45 (cylinder_4)
        project 45 46 (cylinder_4)
        project 46 47 (cylinder_4)
        project 47 44 (cylinder_4)
    boundary
        inlet_1
            type patch;
            faces
                (0 3 2 1)
                (0 1 5 4)
                (1 2 6 5)
                (2 3 7 6)
                (3 0 4 7)
        inlet_2
            type patch;
            faces
                (8 9 13 12)
                (9 10 14 13)
                (10 11 15 14)
                (11 8 12 15)
        pipe_1
            type wall;
            faces
                (4 5 9 8)
                (5 6 10 9)
                (6 7 11 10)
                (7 4 8 11)
        pipe_2
            type wall;
            faces
                (12 13 17 16)
                (13 14 18 17)
                (14 15 19 18)
                (15 12 16 19)
        bottom
            type patch;
            faces
                (16 17 21 20)
                (17 18 22 21)
                (18 19 23 22)
                (19 16 20 23)
        wall
            type patch;
            faces
                (20 21 45 44)
                (21 22 46 45)
                (22 23 47 46)
                (23 20 44 47)
        outlet
            type patch;
            faces
                (24 25 26 27)
                (24 28 29 25)
                (25 29 30 26)
                (26 30 31 27)
                (27 31 28 24)
                (28 32 33 29)
                (29 33 34 30)
                (30 34 35 31)
                (31 35 32 28)
                (32 36 37 33)
                (33 37 38 34)
                (34 38 39 35)
                (35 39 36 32)
                (36 40 41 37)
                (37 41 42 38)
                (38 42 43 39)
                (39 43 40 36)
                (40 44 45 41)
                (41 45 46 42)
                (42 46 47 43)
                (43 47 44 40)
    mergePatchPairs
    我的几何结构大概是几个同心圆柱,同心圆柱的底面如下图
    Amadeus 神
    在 中回复了 Elliott 最后由 编辑
    @Elliott 在 blockMeshDict报错相邻面数量不一致怎么解决? 中说:
    nR_1 10;
    nR_2 10;
    nR_3 20;
    nR_4 400;
    nZ 2100;//轴向方向上的节点数
    看排版看的太难受了,一般这种错误都是不同多面体相邻面上网格节点数量不匹配导致的,所以建议仔细检查这个部分
    博士在读,欢迎探讨,共同进步!
    E 1 条回复 最后回复
  • E 离线
    E 离线
    Elliott
    在 中回复了 Amadeus 最后由 编辑
    @Amadeus 感谢您的帮助,您指出的问题非常关键,我重新粘贴一次给您看一下。然后这个问题我也思考过,我的几何体出了中心块是一个长方体,其他块在edge部分投影成圆弧前,block部分应该都是梯形六面体,然后各个方向上的节点数量我也是在前面nR 32;nR_1 10;nR_2 10;nR_3 20;nR_4 400;nBox 40;nZ 2100;定义中定义好了,按道理应该是固定了的,为什么会出现网格节点不一致呢
        \\  /    A nd           | Version:  7
         \\/     M anipulation  |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
    //radius
    radius        3;//内管内壁半径
    radius_2      4;//外管内壁半径
    radius_3      5;//外管外壁半径
    radius_4      25;//计算域边界
    //half_side
    box           1;
    hs            2.12130344;
    hs_1          2.474873734;
    hs_2          2.828427125;
    hs_3          3.535533906;
    hs_4          17.67766953;
    boxNeg        -1;
    hsNeg         -2.12130344;
    zMin        0.0;
    nR_1        10;
    nR_2        10;
    nR_3        20;
    nR_4        400;
    nBox        20;//矩形block正方形边上的节点数
    nZ          1000;//轴向方向上的节点数
    verbose no;
    geometry
        cylinder
            point2    (0 0  211);
            radius    $radius;
        cylinder_1
            point2    (0 0  211);
            radius    $radius_1;
        cylinder_2
            point2    (0 0  211);
            radius    $radius_2;
        cylinder_3
            point2    (0 0  211);
            radius    $radius_3;
        cylinder_4
            point2    (0 0  211);
            radius    $radius_4;
    scale 1;
    vertices
        // Inner
        // cylinder
        // cylinder_1
        // cylinder_2
        // cylinder_3
        // cylinder_4
        // Inner
        // cylinder
        // cylinder_1
        // cylinder_2
        // cylinder_3
        // cylinder_4
    blocks
    edges
    boundary
        inlet_1
            type patch;
            faces
                (0 3 2 1)
                (0 1 5 4)
                (1 2 6 5)
                (2 3 7 6)
                (3 0 4 7)
        inlet_2
            type patch;
            faces
                (8 9 13 12)
                (9 10 14 13)
                (10 11 15 14)
                (11 8 12 15)
        pipe_1
            type wall;
            faces
                (4 5 9 8)
                (5 6 10 9)
                (6 7 11 10)
                (7 4 8 11)
        pipe_2
            type wall;
            faces
                (12 13 17 16)
                (13 14 18 17)
                (14 15 19 18)
                (15 12 16 19)
        bottom
            type patch;
            faces
                (16 17 21 20)
                (17 18 22 21)
                (18 19 23 22)
                (19 16 20 23)
        wall
            type patch;
            faces
                (20 21 45 44)
                (21 22 46 45)
                (22 23 47 46)
                (23 20 44 47)
        outlet
            type patch;
            faces
                (24 25 26 27)
                (24 28 29 25)
                (25 29 30 26)
                (26 30 31 27)
                (27 31 28 24)
                (28 32 33 29)
                (29 33 34 30)
                (30 34 35 31)
                (31 35 32 28)
                (32 36 37 33)
                (33 37 38 34)
                (34 38 39 35)
                (35 39 36 32)
                (36 40 41 37)
                (37 41 42 38)
                (38 42 43 39)
                (39 43 40 36)
                (40 44 45 41)
                (41 45 46 42)
                (42 46 47 43)
                (43 47 44 40)
    mergePatchPairs
    Amadeus 神
    看图,经过仔细检查,请把blockMeshDict文件中的blocks部分改成如下内容
        hex (0 4 5 1 24 28 29 25) ($nR $nBox $nZ) simpleGrading (1 1 1)
        hex (2 6 7 3 26 30 31 27) ($nR $nBox $nZ) simpleGrading (1 1 1)
        hex (4 8 9 5 28 32 33 29) ($nR_1 $nBox $nZ) simpleGrading (1 1 1)
        hex (6 10 11 7 30 34 35 31) ($nR_1 $nBox $nZ) simpleGrading (1 1 1)
        hex (8 12 13 9 32 36 37 33) ($nR_2 $nBox  $nZ) simpleGrading (1 1 1)
        hex (10 14 15 11 34 38 39 35) ($nR_2 $nBox $nZ) simpleGrading (1 1 1)
        hex (12 16 17 13 36 40 41 37) ($nR_3 $nBox  $nZ) simpleGrading (1 1 1)
        hex (14 18 19 15 38 42 43 39) ($nR_3 $nBox $nZ) simpleGrading (1 1 1)
        hex (16 20 21 17 40 44 45 41) ($nR_4 $nBox  $nZ) simpleGrading (1 1 1)
        hex (18 22 23 19 42 46 47 43) ($nR_4 $nBox  $nZ) simpleGrading (1 1 1)
    再次运行blockMesh即可获得如图所示网格,请注意匹配中心立方体和四周圆环体相邻部分的网格数量点关系
    博士在读,欢迎探讨,共同进步!
    李东岳李 E 3 条回复 最后回复
    @Amadeus 大佬你太狠了,稍微复杂点的网格的block字典我一点都看不下去 :135: 你这bug都能找出来 :146: :146:
    Amadeus 神
    @李东岳 李老师谬赞了,我就是写bug写多了自己犯错犯出经验了O(∩_∩)O哈哈~,就是一个普通学生完全不是大佬
    博士在读,欢迎探讨,共同进步!
  • E 离线
    E 离线
    Elliott
    @Amadeus 非常感谢非常感谢,这两天没有工作,回复比较迟,真的很厉害,我先自己试一下理解一下,再次感谢
  • E 离线
    E 离线
    Elliott
    @Amadeus 相当于nBox这个节点数量要在同一个位置上对应才行,我以为都是按照x,y,z轴的顺序进行设置,这么说openfoam的网格节点设置有时候不是按照x,y,z轴顺序设置嘛
    @Elliott 大佬是在国外么 春节也不休息啊
    E 1 条回复 最后回复
  • E 离线
    E 离线
    Elliott
    @李东岳 一个普通的打工研究生罢了。。。
