  4. 添加湍流模型遇到问题(重发)
添加湍流模型遇到问题(重发)
7 帖子 3 发布者 12.1k 浏览
  • 郑 离线
    郑 离线
    郑澄远
    我用of5.0版本,想添加mykEpsilon模型,用sed语句修改kEpsilon,mykEpsilon.C代码如下
    namespace Foam
    namespace RASModels
    // * * * * * * * * * * * * Protected Member Functions  * * * * * * * * * * * //
    void mykEpsilon<BasicTurbulenceModel>::correctNut()
        this->nut_ = Cmu_*sqr(k_)/epsilon_;
        this->nut_.correctBoundaryConditions();
        fv::options::New(this->mesh_).correct(this->nut_);
        BasicTurbulenceModel::correctNut();
    tmp<fvScalarMatrix> mykEpsilon<BasicTurbulenceModel>::kSource() const
        return tmp<fvScalarMatrix>
            new fvScalarMatrix
                k_,
                dimVolume*this->rho_.dimensions()*k_.dimensions()
                /dimTime
    tmp<fvScalarMatrix> mykEpsilon<BasicTurbulenceModel>::epsilonSource() const
            new fvScalarMatrix
                epsilon_,
                dimVolume*this->rho_.dimensions()*epsilon_.dimensions()
                /dimTime
    // * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
    mykEpsilon<BasicTurbulenceModel>::mykEpsilon
        const alphaField& alpha,
        const rhoField& rho,
        const volVectorField& U,
        const surfaceScalarField& alphaRhoPhi,
        const surfaceScalarField& phi,
        const transportModel& transport,
        const word& propertiesName,
        const word& type
        eddyViscosity<RASModel<BasicTurbulenceModel>>
            type,
            alpha,
            rho,
            U,
            alphaRhoPhi,
            phi,
            transport,
            propertiesName
        Cmu_
            dimensioned<scalar>::lookupOrAddToDict
                "Cmu",
                this->coeffDict_,
                0.09
        C1_
                "C1",
                this->coeffDict_,
                1.44
        C2_
                "C2",
                this->coeffDict_,
                1.92
        C3_
                "C3",
                this->coeffDict_,
        sigmak_
                "sigmak",
                this->coeffDict_,
                1.0
        sigmaEps_
                "sigmaEps",
                this->coeffDict_,
                1.3
        k_
                IOobject::groupName("k", U.group()),
                this->runTime_.timeName(),
                this->mesh_,
                IOobject::MUST_READ,
                IOobject::AUTO_WRITE
            this->mesh_
        epsilon_
                IOobject::groupName("epsilon", U.group()),
                this->mesh_,
            this->mesh_
        bound(k_, this->kMin_);
        bound(epsilon_, this->epsilonMin_);
        if (type == typeName)
            this->printCoeffs(type);
    bool mykEpsilon<BasicTurbulenceModel>::read()
        if (eddyViscosity<RASModel<BasicTurbulenceModel>>::read())
            Cmu_.readIfPresent(this->coeffDict());
            C1_.readIfPresent(this->coeffDict());
            C2_.readIfPresent(this->coeffDict());
            C3_.readIfPresent(this->coeffDict());
            sigmak_.readIfPresent(this->coeffDict());
            sigmaEps_.readIfPresent(this->coeffDict());
            return true;
        else
            return false;
    void mykEpsilon<BasicTurbulenceModel>::correct()
        if (!this->turbulence_)
            return;
        // Local references
        const alphaField& alpha = this->alpha_;
        const rhoField& rho = this->rho_;
        const surfaceScalarField& alphaRhoPhi = this->alphaRhoPhi_;
        const volVectorField& U = this->U_;
        volScalarField& nut = this->nut_;
        fv::options& fvOptions(fv::options::New(this->mesh_));
        eddyViscosity<RASModel<BasicTurbulenceModel>>::correct();
        volScalarField::Internal divU
            fvc::div(fvc::absolute(this->phi(), U))().v()
        tmp<volTensorField> tgradU = fvc::grad(U);
        volScalarField::Internal G
            this->GName(),
            nut.v()*(dev(twoSymm(tgradU().v())) && tgradU().v())
        tgradU.clear();
        // Update epsilon and G at the wall
        epsilon_.boundaryFieldRef().updateCoeffs();
        // Dissipation equation
        tmp<fvScalarMatrix> epsEqn
            fvm::ddt(alpha, rho, epsilon_)
          + fvm::div(alphaRhoPhi, epsilon_)
          - fvm::laplacian(alpha*rho*DepsilonEff(), epsilon_)
            C1_*alpha()*rho()*G*epsilon_()/k_()
          - fvm::SuSp(((2.0/3.0)*C1_ - C3_)*alpha()*rho()*divU, epsilon_)
          - fvm::Sp(C2_*alpha()*rho()*epsilon_()/k_(), epsilon_)
          + epsilonSource()
          + fvOptions(alpha, rho, epsilon_)
        epsEqn.ref().relax();
        fvOptions.constrain(epsEqn.ref());
        epsEqn.ref().boundaryManipulate(epsilon_.boundaryFieldRef());
        solve(epsEqn);
        fvOptions.correct(epsilon_);
        // Turbulent kinetic energy equation
        tmp<fvScalarMatrix> kEqn
            fvm::ddt(alpha, rho, k_)
          + fvm::div(alphaRhoPhi, k_)
          - fvm::laplacian(alpha*rho*DkEff(), k_)
            alpha()*rho()*G
          - fvm::SuSp((2.0/3.0)*alpha()*rho()*divU, k_)
          - fvm::Sp(alpha()*rho()*epsilon_()/k_(), k_)
          + kSource()
          + fvOptions(alpha, rho, k_)
        kEqn.ref().relax();
        fvOptions.constrain(kEqn.ref());
        solve(kEqn);
        fvOptions.correct(k_);
        correctNut();
    用wmake libso编译出现错误
    有谁知道是怎么回事吗?
    你主要对哪一行代码进行了改动呢?
  • 郑 离线
    郑 离线
    郑澄远
    李老师,我按照手册上还没有进行改动,只把kEpsilon改成mykEpsilon,但是编译就报错了,不知道是不是和of5.0有关
    就是说你把kEpsilon文件夹下面所有的kEpsilon关键字替换为了mykEpsilon?
    郑 1 条回复 最后回复
  • 郑 离线
    郑 离线
    郑澄远
    @东岳 是的,老师
    明天我试试
  • R 离线
    R 离线
    Rui
    李老师您好,请问这个问题解决了吗?我也遇到类似的问题,就是只改湍流模型的名字,在编译的时候也出现了一些error
