  4. setFields失败是怎么回事呢?
setFields失败是怎么回事呢?
3 帖子 2 发布者 6.0k 浏览
    cuge
    version 2.0;
    format ascii;
    class dictionary;
    location “system”;
    object setFieldsDict;
    defaultFieldValues ( volScalarFieldValue T 0 );
    regions (
    sphereToCell
    centre (0.0 0.0 0.0);
    radius 1;
    fieldValues
    volScalarFieldvalue T 1
    Create time
    Create mesh for time = 0
    Reading setFieldsDict
    Setting field default values
        Setting internal values of volScalarField T
    Setting field region values
        Adding cells with centre within sphere, with centre = (0 0 0) and radius = 1
    --> FOAM Warning :
        From function Foam::autoPtr<setCellField> setCellField::iNew::operator()(Foam::Istream&) const
        in file setFields.C at line 174
        field type volScalarFieldvalue not currently supported
    --> FOAM Warning :
        field type T not currently supported
    --> FOAM FATAL IO ERROR:
    wrong token type - expected word, found on line 27 the label 1
    file: .sphereToCell.fieldValues at line 27.
        From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::word&)
        in file primitives/strings/word/wordIO.C at line 74.
    FOAM exiting
    volScalarFieldvalue改成volScalarFieldValue
    cuge
    @东岳 thanks
