  4. [菜鳥求救] K-omega SST 头几秒就崩溃了
18 帖子 5 发布者 24.3k 浏览
  • J 离线
    J 离线
    jinjolee
    我在模𣝅单车行驶的外部流场,主要是想求CdA。湍流模型用了k omega SST,求解器则是用了simpleFoam。我借用了motorBike的范例,稍为修改了一下。我设了初始速度为15m/s,0Pa。以下是log.simpleFoam里的头几个iteration:
    Create time
    Create mesh for time = 0
    [AdminPC:02105] 5 more processes have sent help message help-btl-vader.txt / cma-permission-denied
    [AdminPC:02105] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
    SIMPLE: Convergence criteria found
            U: tolerance 0.0001
            p: tolerance 0.0001
            "(k|omega)": tolerance 0.0001
    Reading field p
    Reading field U
    RAS
        RASModel        kOmegaSST;
        turbulence      on;
        printCoeffs     on;
        alphaK1         0.85;
        alphaK2         1;
        alphaOmega1     0.5;
        alphaOmega2     0.856;
        gamma1          0.555556;
        gamma2          0.44;
        beta1           0.075;
        beta2           0.0828;
        betaStar        0.09;
        a1              0.31;
        b1              1;
        c1              10;
        F3              false;
    No MRF models present
    Starting time loop
    streamLine streamLines:
        automatic track length specified through number of sub cycles : 5
    Reading surface description:
        yNormal
    forces forceCoeffs1:
    forceCoeffs forceCoeffs1:
    Time = 1
    smoothSolver:  Solving for Ux, Initial residual = 0.176082, Final residual = 0.0175161, No Iterations 8
    smoothSolver:  Solving for Uy, Initial residual = 0.0854752, Final residual = 0.0078422, No Iterations 6
    smoothSolver:  Solving for Uz, Initial residual = 0.0535574, Final residual = 0.00446781, No Iterations 9
    GAMG:  Solving for p, Initial residual = 1, Final residual = 0.00968802, No Iterations 15
    time step continuity errors : sum local = 9.19838e-08, global = 1.35003e-09, cumulative = 1.35003e-09
    smoothSolver:  Solving for omega, Initial residual = 0.999998, Final residual = 2.29698e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 1, Final residual = 6.96747e-05, No Iterations 1
    ExecutionTime = 252.73 s  ClockTime = 563 s
    forceCoeffs forceCoeffs1 write:
        Cm    = 0.404453
        Cd    = 0.754425
        Cl    = -0.0101646
        Cl(f) = 0.399371
        Cl(r) = -0.409535
    Time = 2
    smoothSolver:  Solving for Ux, Initial residual = 0.114146, Final residual = 0.00945059, No Iterations 8
    smoothSolver:  Solving for Uy, Initial residual = 0.03572, Final residual = 0.0033767, No Iterations 7
    smoothSolver:  Solving for Uz, Initial residual = 0.268761, Final residual = 0.023381, No Iterations 8
    GAMG:  Solving for p, Initial residual = 0.00423399, Final residual = 3.88164e-05, No Iterations 14
    time step continuity errors : sum local = 7.09901e-08, global = 1.05225e-09, cumulative = 2.40228e-09
    smoothSolver:  Solving for omega, Initial residual = 0.786768, Final residual = 6.02541e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.347618, Final residual = 8.09935e-05, No Iterations 1
    ExecutionTime = 358.52 s  ClockTime = 941 s
        Cm    = 0.372383
        Cd    = 0.710432
        Cl    = -0.0032843
        Cl(f) = 0.370741
        Cl(r) = -0.374025
    Time = 3
    smoothSolver:  Solving for Ux, Initial residual = 0.134328, Final residual = 0.0118087, No Iterations 8
    smoothSolver:  Solving for Uy, Initial residual = 0.116996, Final residual = 0.0105707, No Iterations 7
    smoothSolver:  Solving for Uz, Initial residual = 0.0580452, Final residual = 0.00576293, No Iterations 7
    GAMG:  Solving for p, Initial residual = 0.00317963, Final residual = 3.03476e-05, No Iterations 18
    time step continuity errors : sum local = 7.20084e-08, global = 7.35963e-10, cumulative = 3.13824e-09
    smoothSolver:  Solving for omega, Initial residual = 0.373588, Final residual = 9.57613e-05, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.103448, Final residual = 8.1809e-05, No Iterations 1
    ExecutionTime = 509.1 s  ClockTime = 1274 s
        Cm    = 0.28686
        Cd    = 0.550375
        Cl    = 0.0178247
        Cl(f) = 0.295772
        Cl(r) = -0.277947
    Time = 4
    smoothSolver:  Solving for Ux, Initial residual = 0.581453, Final residual = 0.0506933, No Iterations 7
    smoothSolver:  Solving for Uy, Initial residual = 0.438063, Final residual = 0.0375534, No Iterations 14
    smoothSolver:  Solving for Uz, Initial residual = 0.28364, Final residual = 0.0228554, No Iterations 19
    GAMG:  Solving for p, Initial residual = 0.100663, Final residual = 0.000964993, No Iterations 24
    time step continuity errors : sum local = 2.71584e-06, global = -6.86095e-08, cumulative = -6.54713e-08
    smoothSolver:  Solving for omega, Initial residual = 0.156237, Final residual = 0.000151387, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.0248487, Final residual = 9.03384e-05, No Iterations 1
    ExecutionTime = 625.86 s  ClockTime = 1558 s
        Cm    = -2.36372
        Cd    = 5.23947
        Cl    = -45.4406
        Cl(f) = -25.084
        Cl(r) = -20.3566
    Time = 5
    smoothSolver:  Solving for Ux, Initial residual = 0.748694, Final residual = 0.0654467, No Iterations 6
    smoothSolver:  Solving for Uy, Initial residual = 0.707975, Final residual = 0.0671149, No Iterations 10
    smoothSolver:  Solving for Uz, Initial residual = 0.645301, Final residual = 0.0580618, No Iterations 11
    GAMG:  Solving for p, Initial residual = 0.331992, Final residual = 0.00325251, No Iterations 29
    time step continuity errors : sum local = 4.57856e-05, global = 1.35323e-06, cumulative = 1.28776e-06
    smoothSolver:  Solving for omega, Initial residual = 0.0619606, Final residual = 0.000791318, No Iterations 1
    smoothSolver:  Solving for k, Initial residual = 0.00576973, Final residual = 0.000313824, No Iterations 2
    ExecutionTime = 753.75 s  ClockTime = 1825 s
        Cm    = 48393.6
        Cd    = 355643
        Cl    = -193536
        Cl(f) = -48374.2
        Cl(r) = -145161
    Time = 6
    smoothSolver:  Solving for Ux, Initial residual = 0.77583, Final residual = 0.0469625, No Iterations 11
    smoothSolver:  Solving for Uy, Initial residual = 0.647136, Final residual = 0.0587523, No Iterations 9
    smoothSolver:  Solving for Uz, Initial residual = 0.801675, Final residual = 0.0450629, No Iterations 11
    GAMG:  Solving for p, Initial residual = 2.42318e-05, Final residual = 2.34325e-07, No Iterations 43
    time step continuity errors : sum local = 0.000116095, global = 5.64454e-06, cumulative = 6.9323e-06
    smoothSolver:  Solving for omega, Initial residual = 0.0295412, Final residual = 0.00216916, No Iterations 2
    smoothSolver:  Solving for k, Initial residual = 0.00243104, Final residual = 0.000230323, No Iterations 3
    ExecutionTime = 908.36 s  ClockTime = 2133 s
        Cm    = -735398
        Cd    = -1.66962e+06
        Cl    = -1.74826e+07
        Cl(f) = -9.47672e+06
        Cl(r) = -8.00593e+06
    Time = 7
    smoothSolver:  Solving for Ux, Initial residual = 0.577761, Final residual = 0.0517967, No Iterations 47
    smoothSolver:  Solving for Uy, Initial residual = 0.570563, Final residual = 0.0531017, No Iterations 47
    smoothSolver:  Solving for Uz, Initial residual = 0.546372, Final residual = 0.0538754, No Iterations 36
    GAMG:  Solving for p, Initial residual = 0.0134, Final residual = 0.0431707, No Iterations 1000
    time step continuity errors : sum local = 500.302, global = -256.052, cumulative = -256.052
    smoothSolver:  Solving for omega, Initial residual = 0.726855, Final residual = 0.0688681, No Iterations 4
    smoothSolver:  Solving for k, Initial residual = 0.053017, Final residual = 0.00485332, No Iterations 4
    ExecutionTime = 2723 s  ClockTime = 4119 s
        Cm    = 1.42517e+06
        Cd    = 7.85747e+06
        Cl    = -2.46218e+07
        Cl(f) = -1.08857e+07
        Cl(r) = -1.37361e+07
    Time = 8
    smoothSolver:  Solving for Ux, Initial residual = 0.612081, Final residual = 0.0499664, No Iterations 29
    smoothSolver:  Solving for Uy, Initial residual = 0.562296, Final residual = 0.0483684, No Iterations 28
    smoothSolver:  Solving for Uz, Initial residual = 0.628358, Final residual = 0.0614706, No Iterations 14
    GAMG:  Solving for p, Initial residual = 0.999964, Final residual = 0.0500564, No Iterations 1000
    time step continuity errors : sum local = 1.61271e+08, global = -40286.8, cumulative = -40542.9
    smoothSolver:  Solving for omega, Initial residual = 0.00412419, Final residual = 0.000290188, No Iterations 4
    smoothSolver:  Solving for k, Initial residual = 0.00274375, Final residual = 0.000233623, No Iterations 5
    ExecutionTime = 4529.61 s  ClockTime = 6088 s
        Cm    = -6.60893e+13
        Cd    = -5.13466e+14
        Cl    = 1.211e+14
        Cl(f) = -5.53934e+12
        Cl(r) = 1.26639e+14
    Time = 9
    smoothSolver:  Solving for Ux, Initial residual = 0.804576, Final residual = 13.5575, No Iterations 1000
    smoothSolver:  Solving for Uy, Initial residual = 0.785135, Final residual = 82.7634, No Iterations 1000
    smoothSolver:  Solving for Uz, Initial residual = 0.874744, Final residual = 9.53614, No Iterations 1000
    a non-zero exit code.. Per user-direction, the job has been aborted.
    mpirun detected that one or more processes exited with non-zero status, thus causing
    the job to be terminated. The first process to do so was:
      Process name: [[12118,1],0]
      Exit code:    145
    可见在第四秒就崩溃了。Boundary Condition我都是参考motorbike的, 只改了velocity, k和omega:
    • flowVelocity (0 0 15);
    • pressure 0;
    • turbulentKE 0.00135;
    • turbulentOmega 900;
    k和omega的值是我参考了其他文章,用了turbulence intensity level = 0.2%, 和eddy viscousity ratio = 0.1,从而算出來的。
    以下是snappyHexMeshDict, fvScheme 和 fvSolution,求求大佬指点一下问题出在哪,谢谢
    snappyHexMesh:
    castellatedMesh true;
    snap            true;
    addLayers       true;
        figure
            type triSurfaceMesh;
            file "figure.stl";
        refinementBox
            type searchableBox;
            min ( -750 0 -1000);
            max ( 1830 2685 2640);
    castellatedMeshControls
        maxLocalCells 1000000;
        maxGlobalCells 30000000;
        minRefinementCells 15;
        maxLoadUnbalance 0.15;
        nCellsBetweenLevels 3;
        features
                file "figure.eMesh";
                level 7;
        refinementSurfaces
            figure
                level (7 7);
                patchInfo
                    type wall;
                    inGroups (figureGroup);
        resolveFeatureAngle 20;
        refinementRegions
            refinementBox
                mode inside;
                levels ((1E15 4));
    	figure
    		mode distance;
    		levels
    			(2 8)
    			(10 6)
        locationInMesh (402.1 1802 1002.7) ;
    snapControls
        nSmoothPatch 5;
        tolerance 2.25;
        nSolveIter 30;
        nRelaxIter 5;
            nFeatureSnapIter 10;
            implicitFeatureSnap false;
            explicitFeatureSnap true;
            multiRegionFeatureSnap false;
    addLayersControls
        relativeSizes true;
        layers
            "(lowerWall|figure).*"
                nSurfaceLayers 10;
        expansionRatio 1.2;
        thickness 0.8;
        minThickness 0.0001;
        nGrow 0;
        featureAngle 180;
        slipFeatureAngle 30;
        nRelaxIter 5;
        nSmoothSurfaceNormals 1;
        nSmoothNormals 3;
        nSmoothThickness 10;
        maxFaceThicknessRatio 0.6;
        maxThicknessToMedialRatio 0.3;
        minMedianAxisAngle 90;
        nBufferCellsNoExtrude 0;
        nLayerIter 15;
    meshQualityControls
        #include "meshQualityDict"
    writeFlags
        scalarLevels
        layerSets
        layerFields
    mergeTolerance 1e-6;
    fvSchemes:
    ddtSchemes
        default         steadyState;
    gradSchemes
        default         Gauss linear;
        grad(U)         cellLimited Gauss linear 1;
    divSchemes
        default         none;
        div(phi,U)      bounded Gauss linearUpwindV grad(U);
        div(phi,k)      bounded Gauss upwind;
        div(phi,omega)  bounded Gauss upwind;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
    wallDist
        method meshWave;
    fvSolution:
    solvers
        p
            solver          GAMG;
            smoother        GaussSeidel;
            tolerance       1e-7;
            relTol          0.01;
        Phi
            $p;
        U
            solver          smoothSolver;
            tolerance       1e-8;
            relTol          0.1;
            nSweeps         1;
        k
            tolerance       1e-8;
            relTol          0.1;
            nSweeps         1;
        omega
            tolerance       1e-8;
            relTol          0.1;
            nSweeps         1;
    SIMPLE
        nNonOrthogonalCorrectors 0;
        consistent yes;
        residualControl
    	U		1e-4;
    	p		1e-4;
    	"(k|omega)"	1e-4;
    potentialFlow
        nNonOrthogonalCorrectors 10;
    relaxationFactors
        equations
            U               0.9;
            k               0.7;
            omega           0.7;
    cache
        grad(U);
    排版满分。
    你用自带的摩托车网格试试?
    你这个只能看出是发散了原因有很多不好判断
    J 1 条回复 最后回复
  • J 离线
    J 离线
    jinjolee
    @东岳 在 [菜鳥求救] K-omega SST 头几秒就崩溃了 中说:
    排版满分。
    你用自带的摩托车网格试试?
    谢谢老师的指教 我降低了网格refinement level, 也尝试了把松弛因子调低,结果还是发散。
    有其么其他的建议吗?:papa:
    CFD发散并没有一阵见血的解决办法。目前很难判断哦,但我觉得你一定会搞定的 :ok2:
    J 1 条回复 最后回复
  • J 离线
    J 离线
    jinjolee
    老师你太高估我了 我只是个新手渣渣 光凭我自己一个始终有点吃力:mihu:
    其实我在怀疑这会不会是k和omega的初始值所造成的问题,毕竟这都是估算的,没有实验根据,而且听说k omega对初始值很敏感。请问老师有没有方法可以验证初始值是否合适?
    F 1 条回复 最后回复
  • F 离线
    F 离线
    Foamer24
    在 中回复了 jinjolee 最后由 编辑
    @jinjolee k和omega可以用fluent里面初始化的值做参考
    J 1 条回复 最后回复
    @jinjolee 在 [菜鳥求救] K-omega SST 头几秒就崩溃了 中说:
    听说k omega对初始值很敏感
    是的,kOmega模型是这样的。不过Omega可以从epsilon计算出来:$\Omega=\frac{\varepsilon}{0.09 k} $
    你这个我感觉完全是边界条件设置的问题,因为不涉及到算法,你会会搞定的 :duang:
  • tidedrinkerT 离线
    tidedrinkerT 离线
    tidedrinker
    simpleFoam是稳态求解器,你这个问题是不是用瞬态比较好?如果你模拟的流场达不到稳态可能会这样。建议用pimpleFoam试试。
    而且,k-omega SST稳定性很好,对初值没有k-omega模型这么敏感吧。
    更高的主频,更多的核心
  • J 离线
    J 离线
    jinjolee
    在 中回复了 Foamer24 最后由 编辑
    @Foamer24 在 [菜鳥求救] K-omega SST 头几秒就崩溃了 中说:
    我的模型放进Ansys后貌似有点问题,无法顺利生成enclosure,要把其中一个部件去除才行,而且每次生成boundary later都会报错,无法生成。因此ansys fluent对我来说可能不是最佳方案
    @tidedrinker 在 [菜鳥求救] K-omega SST 头几秒就崩溃了 中说:
    我试过用pimpleFoam,但貌似设置有点问题,发散问题更严重。所以想先用simpleFoam试试看。
    听说k omega对初始值很敏感
    可是我怎么算怎么试,结果还是发散。:zoule:
    有方法可以分辨出k和omega的初始值是太大或太小吗?
  • F 离线
    F 离线
    Foamer24
    我指的是fluent选择k omega初始化的时候,就可以看到fluent里面的初始值。可以拿来和你现在的初始值对照下。
    J 2 条回复 最后回复
  • J 离线
    J 离线
    jinjolee
    能请教一下怎么查看吗? 我没怎用ANSYS,不太清楚。
    是不是要先汇入模型,生成网格,然后进了setup才可以看到omega的初始值?
  • J 离线
    J 离线
    jinjolee
    我上面的留言格式弄错了, 我再发一次。
    D 1 条回复 最后回复
    dzw05 超神
    @jinjolee 你拿个最简单的模型导入fluent就可以了,只是借用一下fluent的初始化k和omega值。其实k和omega的值与速度的关系是有理论公式的,fluent也是用这个理论公式算出来的,看一下fluent的帮助手册。或者看这个网址湍流边界条件
    自主匠心,普惠仿真。
    J 1 条回复 最后回复
  • J 离线
    J 离线
    jinjolee
    在 中回复了 dzw05 最后由 编辑
    @dzw05 在 [菜鳥求救] K-omega SST 头几秒就崩溃了 中说:
    我就是用你给的那个网址里的论坛的工具去算的。只是我摸拟的是外部流场,turbulence length scale比较难预测,只能用eddy viscosity ratio去算,而那论坛里好像也没有相关的资料(例如在什么情况下,eddy viscosity ratio大约是多少之类的)。
    至于ansys fluent,可能是我还没弄清楚设置,试了一下还是发散了。看来得再研究一下。:wanan:
    话说在一个普通的室外环境里(零风速),eddy viscosity ratio大约是多少?有参考值吗?
    D 1 条回复 最后回复
    dzw05 超神
    @jinjolee eddy viscosity ratio一般设大于1小于10,给个10应该就行。另外,你这个不一定是湍流模型导致的发散,直接用层流先试试,逐个排除原因。
    自主匠心,普惠仿真。
    J 1 条回复 最后回复
    感谢大家畅所欲言,看起来正在往正确的方向走,祝收敛!
    :xiexie:
  • J 离线
    J 离线
    jinjolee
    在 中回复了 dzw05 最后由 编辑
    #17
    可是奇怪的是我之前用k-epsilon模型来算,当时用了:
    turbulentKE=0.17557;
    turbulentEpsilon=0.05677;
    这样来算,反而结果有收敛,另外reynold number也得出为1638000,所以我认为基本上得用湍流模型。不过这个CdA比正常的低(我的结果只有0.26左右,而从其他的实验结果得来是0.46左右)。我当时用的是:
    flowVelocity=12.5;
    ,而k是用turbulence intensity level = 2.73%。至于这个2.73%和epsilon的值是怎得来的,老实说我忘了...:chigua:
    我之后从不同文献中看到湍流的k和epsilon初始值应该要以模拟的环境在现实中的特征来作基础(例如我在模拟单车在行驶,虽然在CFD中我给了个15m/s的风速,但turbulence intensity level的初始应该不是以这个15m /s的速度来算,而是以真实环境(0风速)来算,所以turbulence intensity level应该很低,大约0.2~0.02%左右)。然而我换了turbulence intensity level=0.2%后,结果就一直发散。
    快烦死了:mihu: :mihu:
    D 1 条回复 最后回复
    dzw05 超神
    #18
    @jinjolee openFOam里的湍流模型有些时候确实不好用。(1)用你现在的条件计算出k、omega和nut的值,保证初始场initialValue也等于计算出的值;(2)检查壁面函数是否合适;(3)检查空间离散格式fvSchemes。
    自主匠心,普惠仿真。
