  4. twoPhaseEulerFoam中的ITAE模型
13 帖子 2 发布者 12.4k 浏览
  • U 离线
    U 离线
    upc_ngh
    各位前辈,想要在twoPhaseEulerFoam中的ITAE模型中,添加一个温度传输方程,准备求解液固流沉积后的管内温度场,在ITAE.C中添加完成T的求解方程后,出现了两个问题:
    (1)这里的phase_.phi()只是单纯的离散相的通量,而这个求解温度场需要的是离散相和连续相的通量和即fluid.phi(),这个fluid.phi()应该怎么去表示?
    (2)当植入求解方程T后,报错如下,希望各位老师指点一下,不胜感激
    diameterModels/IATE/IATE.C: In member function ‘virtual void Foam::diameterModels::IATE::correct()’:
    diameterModels/IATE/IATE.C:220:19: error: ‘laplacian’ is not a member of ‘Foam::fvm’
                      -fvm::laplacian(niandu,Tcell_)
    /opt/openfoam4/wmake/rules/General/transform:8: recipe for target '/opt/openfoam4/platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/twoPhaseEulerFoam/twoPhaseSystem/diameterModels/IATE/IATE.o' failed
    更改后的ITAE.C代码如下
    Foam::diameterModels::IATE::IATE
        const dictionary& diameterProperties,
        const phaseModel& phase
        diameterModel(diameterProperties, phase),
        kappai_
                IOobject::groupName("kappai", phase.name()),
                phase_.U().time().timeName(),
                phase_.U().mesh(),
                IOobject::MUST_READ,
                IOobject::AUTO_WRITE
            phase_.U().mesh()
        Tcell_
          //  "Tcell",
            IOobject::groupName("Tcell", phase.name()),
                phase_.U().mesh(),
       phase_.U().mesh()//T
        rho1_("rho1", dimensionSet(1,0,-3,0,0), diameterProperties_),//properties
        rho2_("rho2", dimensionSet(1,0,-3,0,0), diameterProperties_),
        Khydrate_("Khydrate", dimensionSet(1,1,-3,1,0), diameterProperties_),
        Kwater_("Kwater", dimensionSet(1,1,-3,1,0), diameterProperties_),
        Cpwater_("Cpwater", dimensionSet(0,2,-2,1,0), diameterProperties_),
        Cphydrate_("Cphydrate", dimensionSet(0,2,-2,1,0), diameterProperties_),
        dMax_("dMax", dimLength, diameterProperties_),
        dMin_("dMin", dimLength, diameterProperties_),
        residualAlpha_
            "residualAlpha",
            dimless,
            diameterProperties_
        d_
                IOobject::groupName("d", phase.name()),
                phase_.U().mesh(),
                IOobject::NO_READ,
            dsm()
        sources_
            diameterProperties_.lookup("sources"),
            IATEsource::iNew(*this)
    //Tcellnow(phase.TTT)
    // * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
    Foam::diameterModels::IATE::~IATE()
      /* const volScalarField& Tcelliate() const
                return phase.fluid().Tcell();
    Foam::tmp<Foam::volScalarField> Foam::diameterModels::IATE::dsm() const
        return max(6/max(kappai_, 6/dMax_), dMin_);
    // Placeholder for the nucleation/condensation model
    // Foam::tmp<Foam::volScalarField> Foam::diameterModels::IATE::Rph() const
    //     const volScalarField& T = phase_.thermo().T();
    //     const volScalarField& p = phase_.thermo().p();
    //     scalar A, B, C, sigma, vm, Rph;
    //     volScalarField ps(1e5*pow(10, A - B/(T + C)));
    //     volScalarField Dbc
    //         4*sigma*vm/(constant::physicoChemical::k*T*log(p/ps))
    //     return constant::mathematical::pi*sqr(Dbc)*Rph;
        // Initialise the accumulated source term to the dilatation effect
        volScalarField R
                (1.0/3.0)
               /max
                    fvc::average(phase_ + phase_.oldTime()),
                    residualAlpha_
           *(fvc::ddt(phase_) + fvc::div(phase_.alphaPhi()))
        volScalarField niandu
           Khydrate_*phase_/Cphydrate_/rho1_+Kwater_*(1-phase_)/Cpwater_/rho2_
        );//niandu
        // Accumulate the run-time selectable sources
        forAll(sources_, j)
            R -= sources_[j].R();
        fv::options& fvOptions(fv::options::New(phase_.mesh()));
        // Construct the interfacial curvature equation
        fvScalarMatrix kappaiEqn
            fvm::ddt(kappai_) + fvm::div(phase_.phi(), kappai_)
          - fvm::Sp(fvc::div(phase_.phi()), kappai_)
          - fvm::SuSp(R, kappai_)
      //  - Rph() // Omit the nucleation/condensation term
          + fvOptions(kappai_)
        kappaiEqn.relax();
        fvOptions.constrain(kappaiEqn);
        kappaiEqn.solve();
        // surfaceScalarField& phiphi = phase_.phi();
         fvScalarMatrix TEqn//qiu jie T
                      fvm::ddt(Tcell_)
                     +fvm::div(phase_.phi(),Tcell_)
                 TEqn.solve();
        // Update the Sauter-mean diameter
        d_ = dsm();
    添加T方程为什么要去ITAE库中去做?
    另外,你用reactingTwoPhaseEulerFoam里面就有T了
    U 1 条回复 最后回复
  • U 离线
    U 离线
    upc_ngh
    @东岳 我这里求解的是壁面冷却,内部是流体的管内温度分布,不涉及两种流体之间的温度场求解;使用ITAE是因为要把求解出来的温度场传递到ITAE中的Rph中,作为流体相变的驱动力。之前把温度方程直接放到twoPhaseEulerFoam.C中,可以顺利的求解,现在卡了好久也不知道怎么把求解出的温度场再传回ITAE中去,希望东岳老师和各位前辈多指点一下
    U 1 条回复 最后回复
  • U 离线
    U 离线
    upc_ngh
    在 中回复了 upc_ngh 最后由 编辑
    各位老师,经过测试发现问题好像是fvm::laplacian(A,B)中的AB两个的数据类型不正确,对于第一个mesh注册的Tcell是没有问题的,对于第二个注册在phase_.U().mesh()内的Tcell就不可以进行计算。现在主要问题是怎么在ITAE.C中将T注册到mesh中,或者有什么办法能够在ITAE库中进行fvm::laplacian(A,B),标量传输方程正常计算,希望各位老师点拨一下,添加一个标量传输方程咋这么难,哎:135:
    volScalarField Tcell
            "Tcell",
            runTime.timeName(),
            mesh,
        mesh
            "Tcell",
           // IOobject::groupName("Tcell", phase.name()),
                phase_.U().mesh(),
    你在求解器.C层面,将T植入,这个你会的吧。
    然后在ITAE中,通过
    const volScalarField& T = mesh.lookupObject<volScalarField>("T"):
    传入,这样不可以么
    U 2 条回复 最后回复
  • U 离线
    U 离线
    upc_ngh
    @东岳 谢谢东岳老师,好的我按照这个思路试一下:ok2:
  • U 离线
    U 离线
    upc_ngh
    @东岳 东岳老师现在出现这个问题,麻烦老师有时间再给看看,谢谢谢谢:xinxin:
    diameterModels/IATE/IATEsources/randomCoalescence/randomCoalescence.C: In member function ‘virtual Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::diameterModels::IATEsources::randomCoalescence::R() const’:
    diameterModels/IATE/IATEsources/randomCoalescence/randomCoalescence.C:94:40: error: ‘mesh’ was not declared in this scope
         const volScalarField& TcellnowLX = mesh.lookupObject<volScalarField>("Tcell");
    diameterModels/IATE/IATEsources/randomCoalescence/randomCoalescence.C:94:72: error: expected primary-expression before ‘>’ token
    const volScalarField& T = phase_.U().mesh().lookupObject<volScalarField>("T"):
    U 1 条回复 最后回复
  • U 离线
    U 离线
    upc_ngh
    @东岳 东岳老师,现在植入进去也能编译成功了,但是开始计算就发散,错误代码如下,看了论坛上和网上的也没找到啥相关的资料,希望东岳老师再给点指导,谢谢:xiexie:
    Starting jisuan kappai
    smoothSolver:  Solving for kappai.air, Initial residual = 0.164043, Final residual = 3.33679e-07, No Iterations 2
    GAMG:  Solving for p_rgh, Initial residual = 0.0861362, Final residual = 8.71808e-09, No Iterations 55
    GAMG:  Solving for p_rgh, Initial residual = 0.00100705, Final residual = 9.19158e-09, No Iterations 42
    GAMG:  Solving for p_rgh, Initial residual = 9.49796e-06, Final residual = 9.7128e-09, No Iterations 18
    new cannot satisfy memory request.
    This does not necessarily mean you have run out of virtual memory.
    It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
    已放弃 (核心已转储)
    植入代码如下:
    ITAE.C中
         //const volScalarField& T = phase_.thermo().T();
         //const volScalarField& p = phase_.thermo().p();
    const volScalarField& Tcellnow = phase_.U().mesh().lookupObject<volScalarField>("Tcell");
       // scalar Teq = 275;
        //scalar rhohydrate = 850;
       // scalar phaseh = 50;
        //scalar qianre = 43500;
    dimensionedScalar Teq("Teq", dimensionSet(0,0,0,1,0), 275);
    dimensionedScalar rhohydrate("rhohydrate", dimensionSet(1,-3,0,0,0), 850);
    dimensionedScalar phaseh("phaseh", dimensionSet(1,1,-3,-1,0), 50);
    dimensionedScalar qianre("qianre", dimensionSet(0,2,-2,0,0), 43500);
        volScalarField delt(Tcellnow - Teq);
        volScalarField Rph(0.0085*phaseh*delt*phase_*pow(kappai_,5)/rhohydrate/qianre);
        volScalarField Dsm(max(6/max(kappai_, 6/dMax_), dMin_));
         return constant::mathematical::pi*sqr(Dsm)*Rph;
    编译完库之后,重新编译一下求解器,然后再计算
    Um...这个应该是IATE,不是ITAE:threaten:
    U 1 条回复 最后回复
  • U 离线
    U 离线
    upc_ngh
    @东岳 哈哈谢谢东岳老师,一直打错了:136: 。。。
    重新编译库还是不行,将
    更改为
    volScalarField Tcellnow = phase_.U().mesh().lookupObject<volScalarField>("Tcell");
    还是不行,增加虚拟机内存还是不行,但是把湍流改成层流就能顺利计算了,这是怎么回事???
  • U 离线
    U 离线
    upc_ngh
    晚上又测试了一下,在linux系统下是可以顺利的进行计算,谢谢东岳老师的帮助:xinxin:
