  4. Lagrangian scale-similaritydependent model湍流模型
2 帖子 2 发布者 3.2k 浏览
  • V 离线
    V 离线
    Vortex
    LESGO(一个用fortran编写的基于伪谱法的开源大涡模拟求解器,主要用于大气边界层和风能的模拟,https://lesgo.me.jhu.edu/ )提到了两种LES湍流模型Lagrangian scale-similarity model和Lagrangian scale-dependent model。这两种模型似乎在大气边界层流动模拟用得较多,想请教一下OpenFOAM这边有和这两个湍流模型相关的资料吗?
    注(https://lesgo.me.jhu.edu/subgrid.html ):
    The Lagrangian scale-similarity model dynamically changes the Smagorinsky coefficient Cs,Δ(x,t) by test filtering the flow field at a larger scale, assuming scale invariance, and averaging over Lagrangian trajectories.
    The Lagrangian scale-dependent model dynamically changes the Smagorinsky coefficient Cs,Δ(x,t) by test filtering the flow field at two larger scales and averaging over Lagrangian trajectories. Unlike the Lagrangian scale-similarity model, the Lagrangian scale-dependent model does not assume scale invariance.
    The Lagrangian scale-similarity model:
    https://www.cfd-online.com/Forums/openfoam-solving/90351-dynlagrangian-sgs-model.html
    The Lagrangian scale-dependent model:
    https://core.ac.uk/download/pdf/30828294.pdf
    对着引用文献应该能找到很多:chigua:
