  4. 聚并破碎的SQMOM方法
聚并破碎的SQMOM方法
1 帖子 1 发布者 2.7k 浏览
    对于给定的NDF,划分为$i$个$N_{pp}$,对每个$i$上定义$k$阶矩$m_k^i$,给定$m_k^i$,可以计算第$i$区间的节点$d^i_0,d^i_1$以及权重$w^i_0,w^i_1$:
    \begin{equation}
    \begin{split}
    w^i_0&=w^i_1=0.5
    d^i_0&=m_1^i-\frac{1}{\sqrt{3}}\sqrt{\frac{m_3^i}{m_1^i}-{m_1^i}^2}
    d^i_1&=m_1^i+\frac{1}{\sqrt{3}}\sqrt{\frac{m_3^i}{m_1^i}-{m_1^i}^2}
    \end{split}
    \end{equation}
    对于仅考虑破碎的PBE:
    \begin{equation}\label{pbe}
    \frac{\p n(d)}{\p t}=\int_d^{d_{max}}g(d')\beta(d|d')n(d')\rd d'-g(d)n(d)
    \end{equation}
    对方程\eqref{pbe}在$i$上取$k$阶矩:
    \begin{equation}\label{m}
    \frac{\p m_k^i}{\p t}=\int_{d_{i-1/2}}^{d_{i+1/2}}\int_d^{d_{max}}g(d')d^k\beta(d|d')n(d')\rd d'\rd d-\sum^2_{j=0} g(d_j^i)w_j^i(d_j^i)^k
    \end{equation}
    \begin{equation}
    \begin{split}
    \int_{d_{i-1/2}}^{d_{i+1/2}}\int_d^{d_{max}}g(d')\beta(d|d')n(d')\rd d'\rd d&=
    \int_{d_{i-1/2}}^{d_{max}}g(d')n(d')\left(\int_{d_{i-1/2}}^{d'}\beta(d|d')\rd d\right)\rd d'
    \sum_{m=i}^{N}\sum_{j=0}^2g(d_j^m)w_j^m\left(\int_{d_{i-1/2}}^{d_j^m}d^k\beta(d|d_j^m)\rd d\right)
    \end{split}
    \end{equation}
    Therefore
    \begin{equation}
    \frac{\p m_k^i}{\p t}=\sum_{m=i}^{N}\sum_{j=0}^2g(d_j^m)w_j^m\left(\int_{d_{i-1/2}}^{d_j^m}d^k\beta(d|d_j^m)\rd d\right)-\sum^2_{j=0} g(d_j^i)w_j^i(d_j^i)^k
    \end{equation}
