  4. dynamicMeshDict设置问题
dynamicMeshDict设置问题
5 帖子 2 发布者 7.3k 浏览
    sungda
    计算过程中显示:
    --> FOAM Warning :
        From function Foam::autoPtr<Foam::mapPolyMesh> Foam::dynamicRefineFvMesh::unrefine(const labelList&)
        in file dynamicRefineFvMesh/dynamicRefineFvMesh.C at line 546
        Cannot find surfaceScalarField ((interpolate(grad(psi))|(mag(interpolate(grad(psi)))+(1e-06|dimChange)))&S) in user-provided flux mapping table
    7
    phi none
    rhoPhi none
    rhoPhiH none
    nHatf none
    alphaPhi10 none
    ghf none
    alphaPhi none
        The flux mapping table is used to recreate the flux on newly created faces.
        Either add the entry if it is a flux or use (((interpolate(grad(psi))|(mag(interpolate(grad(psi)))+(1e-06|dimChange)))&S) none) to suppress this warning.
    我在correctFluxes中加入
    但是结果显示格式不正确,有大佬遇到过相类似的情况吗?目前针对这块还不是很熟悉,请大家多多指教
    在 中回复了 sungda 最后由 编辑
    @sungda 这样可以吗
    你为什么会存在这个通量,自己写的求解器么
    sungda
    @李东岳 李老师,这是我自己的求解器,但是这个通量我也不知道为什么会出来:136:
    我在dynamicMeshDict加了您说的这个,结果报错,可能是代码的问题。
    correctFluxes
        (phi none)
        (rhoPhiH none)
        (nHatf none)
        (rhoPhi none)
        (alphaPhi none)
        (ghf none)
        (alphaPhi10 none)
        (phi_0 none)
    [0] --> FOAM FATAL IO ERROR:
    [0] wrong token type - expected word, found on line 56 the punctuation token '('
    [0]
    [0] file: /home/oufool/OpenFOAM/oufool-5.0/run/bubblecol/bubblecol9/constant/dynamicMeshDict.correctFluxes at line 56.
    [0]
    [0]     From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::word&)
    [0]     in file primitives/strings/word/wordIO.C at line 74.
    [0]
    FOAM parallel run exiting
    @sungda
    ('((interpolate(grad(psi))|(mag(interpolate(grad(psi)))+(1e-06|dimChange)))&S)' none)
    这样行么
    sungda
    @李东岳 李老师,这样是可以的,
    ("((interpolate(grad(psi))|(mag(interpolate(grad(psi)))+(1e-06|dimChange)))&S)" none)
