用fluent3DMeshToFoam转化网格的时候报错
请教一下,我在icem保存用acsii格式保存了msh文件,用fluent3DMeshToFoam转化网格时出现如下报错,不知道是什么原因呢,操作是在天河二号上进行的。
patch 15 from Fluent indices: 59793665 to: 59902377 type: wall #0 Foam::error::printStack(Foam::Ostream&)sh: addr2line: command not found addr2line failed #1 Foam::sigSegv::sigHandler(int)sh: addr2line: command not found addr2line failed #2 ?sh: addr2line: command not found addr2line failed #3 Foam::polyTopoChange::renumberCompact(Foam::List<int> const&, Foam::List<int>&)sh: addr2line: command not found addr2line failed #4 Foam::polyTopoChange::compact(bool, bool, int&, Foam::List<int>&, Foam::List<int>&)sh: addr2line: command not found addr2line failed #5 Foam::polyTopoChange::compactAndReorder(Foam::polyMesh const&, bool, bool, bool, int&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::Map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::Map<int> >&)sh: addr2line: command not found addr2line failed #6 Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool)sh: addr2line: command not found addr2line failed #7 ?sh: addr2line: command not found addr2line failed #8 __libc_start_mainsh: addr2line: command not found addr2line failed #9 ?sh: addr2line: command not found addr2line failed
