  4. 关于multiphaseEulerFoam运算分散相体积分数问题
6 帖子 3 发布者 8.0k 浏览
    Caijinjin
    目前本人在用multiphaseEulerFoam求解器求解孔板中的油水两相流动,孔板架构如图
    模拟过程中水是分散相且体积分数设为了0.005,运算时发现有时候运算会报错,计算过程显示Mules算法求解相分数时,不管连续相还是分散相,最小相分数都为0,偶尔为负。请问各位老师和同学们有没有了解这一问题的?不吝赐教。
    openfoam9这面现在multphaseEULERfoam比之前稳定多了。你看看是不是你设置的有问题。另外你这个是结构网格吧?
    Caijinjin
    @李东岳 老师,我这个网格是三维的,图上展示了二维,用的结构网格,of9计算。目前发现我只要把流速设的大一点,就不会有这种问题出现,但是流速变小就不行了。另外,网格壁面不加密且数量少的时候它也不报错,自己也还在找原因中。
    Caijinjin
    在 中回复了 Caijinjin 最后由 编辑
    @caijinjin 老师,这是我的离散格式和求解器设置
    ddtSchemes
        default         Euler;
    gradSchemes
        default         Gauss linear;
        limited         cellLimited Gauss linear 1;
    divSchemes
        default                         none;
        "div\(phi,alpha.*\)"            Gauss vanLeer;
        "div\(phir,alpha.*\)"           Gauss vanLeer;
        "div\(alphaRhoPhi.*,U.*\)"      Gauss linearUpwind limited;
        "div\(phi.*,U.*\)"              Gauss linearUpwind limited;
        //"div\(alphaRhoPhi.*,Yi\)"       Gauss linearUpwind limited;
        "div\(alphaRhoPhi.*,(h|e).*\)"  Gauss linearUpwind limited;
        "div\(alphaPhi.*,f.*\)"         Gauss linearUpwind limited;
        "div\(alphaRhoPhi.*,K.*\)"      Gauss linearUpwind limited;
        "div\(alphaRhoPhi.*,\(p\|thermo:rho.*\)\)" Gauss linearUpwind limited;
        "div\(alphaRhoPhi.*,(k|epsilon|omega).*\)"  Gauss linearUpwind limited;
        "div\(\(\(\(alpha.*\*thermo:rho.*\)\*nuEff.*\)\*dev2\(T\(grad\(U.*\)\)\)\)\)" Gauss linear;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
    fluxRequired
        default         no;
    wallDist
        method          meshWave;
        nRequired       yes;
    求解器设置
    solvers
        "alpha.*"
            nAlphaCorr      1;
            nAlphaSubCycles 1;
        droplets
            nCorr                   1;
            tolerance               1e-4;
            scale                   true;
            solveOnFinalIterOnly    true;
            sourceUpdateInterval    20;
        p_rgh
            solver          GAMG;
            smoother        DIC;
            tolerance       1e-8;
            relTol          0.01;
            maxIter         20;
            minIter         2;
        p_rghFinal
            $p_rgh;
            relTol          0;
        "U.*"
            solver          smoothSolver;
            tolerance       1e-7;
            relTol          0;
            minIter         1;
        "(e|h).*"
            tolerance       1;
            relTol          0;
            minIter         0;
            maxIter         0;
        "(k|epsilon|omega).*"
            tolerance       1e-7;
            relTol          0;
            minIter         1;
        "f.*"
            solver          PBiCGStab;
            preconditioner  DILU;
            tolerance       1e-6;
            relTol          0;
    PIMPLE
        nOuterCorrectors    3;
        nCorrectors         1;
        nNonOrthogonalCorrectors 0;
        pRefPoint (0.0276 0 0);
        pRefValue 101325;
    relaxationFactors
        equations
            ".*"            0.7;
    你看你图中圈着的上一个Phase-sum volume fractionmin 是正的,圈着的地方变成负的了,当然max那上下都负的。max先数值溢出,min跟着溢出。
    说明这是计算本身的不稳定。
    速度快了,能够不发散,是把不稳定多出来的那部分赶紧吹出去了;慢了,吹不出去就原地爆炸了。
    我看了格式,里面有不少迎风格式,好像迎风格式不能考虑回流?:141:
    这种管子冲快了,刚出狭管上下两个角落应该会有回流涡吧?
    可能因为这个
    Caijinjin
    @bestucan 谢谢老师,这个问题我再去认真了解一下并尝试尝试。
