  4. 关于用lookupObject引用变量报错,求大佬们指点。
10 帖子 3 发布者 10.7k 浏览
    Chen_hao
    错误如下:
    lnInclude/linearViscousStress.C: In constructor ‘Foam::linearViscousStress<BasicTurbulenceModel>::linearViscousStress(const Foam::word&, const alphaField&, const rhoField&, const volVectorField&, const surfaceScalarField&, const surfaceScalarField&, const transportModel&, const Foam::word&)’:
    lnInclude/linearViscousStress.C:81:75: error: expected primary-expression before ‘>’ token
       81 |     const volScalarField& omega_ = this->mesh_.lookupObject<volScalarField>("omega_");
    make: *** [/home/dyfluid/OpenFOAM/OpenFOAM-7/wmake/rules/General/transform:26: /home/dyfluid/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/src/TurbulenceModels/turbulenceModels/derivedFvPatchFields/wallFunctions/fWallFunctions/fWallFunction/fWallFunctionFvPatchScalarField.o] Error 1
    代码如下:
    #include "linearViscousStress.H"
    #include "fvc.H"
    #include "fvm.H"
    // * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
        const word& modelName,
        const alphaField& alpha,
        const rhoField& rho,
        const volVectorField& U,
        const surfaceScalarField& alphaRhoPhi,
        const surfaceScalarField& phi,
        const transportModel& transport,
        const word& propertiesName
            modelName,
            alpha,
            rho,
            U,
            alphaRhoPhi,
            phi,
            transport,
            propertiesName
        nonlinearStress_
                IOobject::groupName("nonlinearStress", alphaRhoPhi.group()),
                this->runTime_.timeName(),
                this->mesh_
            this->mesh_,
            dimensionedSymmTensor
                "nonlinearStress",
                sqr(dimVelocity),
                Zero
        tensor I(1,0,0,0,1,0,0,0,1);
        volSymmTensorField S(twoSymm(fvc::grad(this->U_)));
        volTensorField W(twoSkew(fvc::grad(this->U_)));
        nonlinearStress_ =
         1.0/omega_
           S&S
           - (1.0/3.0)*magSqr(W)*I
           + twoSymm(S&W)
           + (2.5)*(W&W - (1.0/3.0)*magSqr(W)*I));
    bool Foam::linearViscousStress<BasicTurbulenceModel>::read()
        return BasicTurbulenceModel::read();
    Foam::tmp<Foam::volSymmTensorField>
    Foam::linearViscousStress<BasicTurbulenceModel>::devRhoReff() const
        return volSymmTensorField::New
            IOobject::groupName("devRhoReff", this->alphaRhoPhi_.group()),
            (-(this->alpha_*this->rho_*this->nuEff()))
           *dev(twoSymm(fvc::grad(this->U_)))
    Foam::linearViscousStress<BasicTurbulenceModel>::divDevRhoReff
        volVectorField& U
    ) const
        return
          - fvc::div((this->alpha_*this->rho_*this->nuEff())*dev2(T(fvc::grad(U))))
          - fvc::div((this->alpha_*this->rho_*this->nuEff())*nonlinearStress_ )
          - fvm::laplacian(this->alpha_*this->rho_*this->nuEff(), U)
    Foam::linearViscousStress<BasicTurbulenceModel>::divDevRhoReff //
        const volScalarField& rho,
        volVectorField& U
    ) const
        return
          - fvc::div((this->alpha_*rho*this->nuEff())*dev2(T(fvc::grad(U))))
          - fvc::div((this->alpha_*rho*this->nuEff())*nonlinearStress_ )
          - fvm::laplacian(this->alpha_*rho*this->nuEff(), U)
    void Foam::linearViscousStress<BasicTurbulenceModel>::correct()
        BasicTurbulenceModel::correct();
    在线性项里加入一个非线性部分,引用omega_出问题(omega_未在linearViscousStress文件中定义),这个引用方式是按照论坛其他帖子写的,需要怎么改正~
    编译器认为volScalarField不是一个类型。所以要把定义 volScalarfield 类型的头文件包含进来
    Chen_hao
    @bestucan
    谢谢老师的指点,编译已通过!顺着老师的思路,我找到问题的解决办法:
        this->mesh_.objectRegistry::template
    原文地址:链接文本
    最后想问一下:我直接修改了komegaSSTbase.C原文件,在~/OpenFOAM/OpenFOAM-7/src/TurbulenceModels/turbulenceModels中wmake,是不是就可以了?
    bestucanB 1 条回复 最后回复
    在 中回复了 Chen_hao 最后由 编辑
    @chen_hao 应该跑到最外面wmake all(会把文件都过一遍,速度不说多快,也不慢) 。这样依赖komegaSSTbase的文件也会重新编译。
    或者 wmake update: https://openfoam.org/download/source/compiling-openfoam/
    我猜这样也可以:chigua2:
    Chen_hao
    @bestucan
    :xinxin: 谢谢,刚才的wmake通过的太轻松了哈哈哈,还好问了一下,
    果然很多错才是该有的样子。我先自己改改,有问题可能还会麻烦老师~
    Chen_hao
    @bestucan @李东岳
    虽然上面编译通过了,可兴致勃勃开始运行算例提示错误如下:136:
    --> FOAM FATAL ERROR:
        request for volScalarField omega_ from objectRegistry region0 failed
        available objects of type volScalarField are
    15
    sigmaMag
    alphas
    nu.pos
    muMag_0
    rho
    nu.molten
    p_rgh
    nu
    alpha.molten
    nu.neg
    muMag
    rho_0
    alpha.neg
    alpha.pos
    sigmaMag_0
        From function const Type& Foam::objectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]
        in file /home/dyfluid/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 193.
    还是关于omega_的引用问题,我在想是不是因为linearVicousStress.C是父类,而omega是在SSTbase.C中定义的(类似于子类),所以找不到?难道我要在linearVicousStress.C中重新IObject?
    还是说这个引用方式有问题...但我用
    会编译不通过......不知道老师们有没有想法,十分需要帮助,再次感谢老师们:wanan:
    C 2 条回复 最后回复
    Chen_hao
    @wwzhao
    老师,可以帮忙解答一下吗~:xinxin:
    Chen_hao
    @chen_hao 在 关于用lookupObject引用变量报错,求大佬们指点。 中说:
    @bestucan @李东岳
    15
    sigmaMag
    alphas
    nu.pos
    muMag_0
    rho
    nu.molten
    p_rgh
    nu
    alpha.molten
    nu.neg
    muMag
    rho_0
    alpha.neg
    alpha.pos
    sigmaMag_0
    还是说这个引用方式有问题...但我用
    我的分析原因是:执行求解器的时候linearStress.C先执行,所以此时omega还没注册进表里,显示找不到它,我现在在linearStress.C中加入一个omega的IOobject可不可行,毕竟在SST.C中还会IOobject一次,一个变量可以注册多次吗,会不会影响计算结果?:140:
    你看一下其他的雷诺数 ShihQuadrat模型怎么调用的k epsilon?
    Chen_hao
    针对 ncompressible::turbulenceModel 模板特化后的 ShihQuadraticKE 模型 ,仔细研究了一下其怎么实现非线性项的实现,发现其是在 NonlinearEddyViscosity.H 中定义 nonlinearStress_ 项,然后用 ShihQuadraticKE 作为子类继承父类 NonlinearEddyViscosity 以便在 ShihQuadraticKE.C 中直接引用omega_。
    但由于我修改的是SSTkomegabase.H( 继承于TurbulenceModel类 )与 linearViscousStrss.H ( 继承于BasicturbulenceModel原则类 ) 没有特例化,不能简单类似上面的ShihQuadraticKE 模型。需要从新仿造框架,是一项大工程!
    我的策略是:在现有的文件上直接硬植入,简单很多,毕竟涉及到湍流模型的类错综复杂,针对找不到omega,按照我的分析应该是对的,运行求解器时linearViscousStrss.C先运行此时并未运行SSTkomegabase.C 所以没有omega场注册,找不到他,所以我在creatfield.H中IOobject一下omega场,目前可以算了,结果还未检查,不知道我的理解有没有问题。
