  4. OpenFOAM libtorch tutorial step by step
84 帖子 18 发布者 206.8k 浏览
    xyl308120
    在 中回复了 剑金锋 最后由 编辑
    #81
    @剑金锋
    老哥,我把东岳老师那个1D槽道流的代码用AI改成了CUDA版本。然后在https://download.pytorch.org/libtorch/cu117 (我的cuda版本是11.7)下载的gpu版本的libtorch。现在发现已经可以用gpu训练了,但是训练速度还不如cpu,慢不少。 准备后续再捣鼓一下。 我机器配置 GPU: nvidia T400 4G, CPU:I7-12700,供参考
    #include <torch/torch.h>
    #include <torch/cuda.h> // 添加CUDA支持
    using namespace std;
    class NN : public torch::nn::Module {
        torch::nn::Sequential net_;
    public:
        NN() {
            net_ = register_module("net", torch::nn::Sequential(
                torch::nn::Linear(1,8),
                torch::nn::Tanh(),
                torch::nn::Linear(8,1)
        torch::Tensor forward(torch::Tensor x) {
            return net_->forward(x);
    int main() {
        // 设备检测与设置
        torch::Device device = torch::kCPU;
        if (torch::cuda::is_available()) {
            std::cout << "CUDA可用,使用GPU加速训练" << std::endl;
            device = torch::kCUDA;
        int iter = 1;
        int IterationNum = 1000000;
        double learning_rate = 0.001;
        double dy = 0.00125;
        int cellN = static_cast<int>(0.05/dy);
        // 模型迁移至GPU
        auto model = std::make_shared<NN>();
        model->to(device);
        // 优化器
        auto opti = std::make_shared<torch::optim::AdamW>(
            model->parameters(),
            torch::optim::AdamWOptions(learning_rate)
        // 数据迁移至GPU (关键步骤!)
        auto init = torch::full({}, 1.0).to(device);
        auto mesh = torch::arange(-0.05, 0, dy, torch::requires_grad())
                    .unsqueeze(1).to(device);
        auto dpdxByNu = torch::ones({cellN, 1}, torch::kFloat).to(device);
        auto nut = torch::zeros({cellN}).to(device);
        for (int i = 0; i < IterationNum; i++) {
            opti->zero_grad();
            auto upred = model->forward(mesh);
            // 梯度计算(确保权重张量在GPU)
            auto dudy = torch::autograd::grad(
                {upred}, {mesh},
                {torch::ones_like(upred).to(device)}, true, true
            )[0];
            auto dudyy = torch::autograd::grad(
                {dudy}, {mesh},
            )[0];
            auto dudyTop = dudy[cellN - 1][0];
            auto meanU = torch::mean(upred);
            auto ubottom = torch::full_like(upred[0], 0.0375).to(device); // 边界条件迁移
            auto dpdxByNu = torch::full({cellN}, 1.2e-05/1e-08).to(device);
            // 损失计算
            auto loss_bottom = torch::mse_loss(upred[0], ubottom);
            auto loss_top = torch::mse_loss(dudyTop, torch::zeros_like(dudyTop));
            auto loss_bd = loss_bottom + 1000*loss_top;
            auto loss_ini = 1000*torch::mse_loss(meanU, init);
            auto loss_pde = torch::mse_loss(-dudyy.reshape({cellN}), dpdxByNu);
            auto loss = loss_pde + loss_bd + loss_ini;
            // 反向传播
            loss.backward();
            opti->step();
            // 输出需同步到CPU
            if (iter % 500 == 0) {
                double loss_value = loss.item<double>();
                cout << iter << " loss = " << loss_value << endl;
            iter++;
        torch::save(model, "model.pth");
        std::cout << "训练完成!" << std::endl;
        return 0;
    看你GPU占用多少。
    X 1 条回复 最后回复
    xyl308120
    在 中回复了 李东岳 最后由 xyl308120 编辑
    #83
    东岳老师你好,我训练的时候GPU占比%38左右。 我还想顺便请教一下
    loss_ini = 1000*crit(meanU, init)
    这个损失的意义。 因为我发现1D槽道流openfoam基准数据的平均值差不多就是1左右,而这里相当于是要对训练添加一个整体约束之类的东西吗。
    是的,一个整体平均值约束。
    增加神经元看看能不能把GPU拉上100%
