Openfoam源项的自动化处理SuSp的疑问
各位老师好,我对fvm::SuSp处理源项处理有一些困惑。
Openfoam中的fvm::SuSp定义为:190 template<class Type> 191 Foam::tmp<Foam::fvMatrix<Type> > 192 Foam::fvm::SuSp 193 ( 194 const DimensionedField<scalar, volMesh>& susp, 195 const GeometricField<Type, fvPatchField, volMesh>& vf 196 ) 197 { 198 const fvMesh& mesh = vf.mesh(); 199 200 tmp<fvMatrix<Type> > tfvm 201 ( 202 new fvMatrix<Type> 203 ( 204 vf, 205 dimVol*susp.dimensions()*vf.dimensions() 206 ) 207 ); 208 fvMatrix<Type>& fvm = tfvm(); 209 210 fvm.diag() += mesh.V()*max(susp.field(), scalar(0)); 211 212 fvm.source() -= mesh.V()*min(susp.field(), scalar(0)) 213 *vf.internalField(); 214 215 return tfvm; 216 }似乎是在susp.field为正的时候,对变量k的方程将源项化为SpVpk,把SpVp加到fvm.diag()里面去了,当susp.field为负的时候,对变量k的方程将源项化为SuVp,将SuVp加到fvm.source()里面去了。我不太清楚Openfoam是怎么实现下面这样的源项的线化的。
将源项在上一次课的值处Taylor展开,implicit part 加到fvm.diag()里面,explicit part加到fvm.source()里面去? -
Jasak PhD thesis, P112:
In order to improve the solver convergence, it is desirable to increase the diagonal
dominance of the system. Discretisation of the linear part of the source term, Eqn.
(3.36), is closely related to this issue. If Sp < 0, its contribution increases diagonal
dominance and Sp is included into the diagonal. In the case of Sp > 0, diagonal
dominance would be decreased. It is more effective to include this term into the
source and update it when the new solution is available. This measure is, however,
not sufficient to guarantee the diagonal dominance of the matrix.
