  4. OpenFOAM小代码
OpenFOAM小代码
41 帖子 15 发布者 63.6k 浏览
    这些是我感觉对初学者有用的一些代码,收藏在此,持续更新。有问题回帖提问,我会对我贡献的代码负责回答。
    计算Patch的面积
        // 计算某个patch的面积 http://www.cfd-china.com/topic/3498
            label patchID = mesh.boundaryMesh().findPatchID("inlet");
            // Create a polyPatch for looping
            const polyPatch& myPatch = mesh.boundaryMesh()[patchID];
            // Initialize patchArea
            scalar patchArea = 0.0;
            // Loop trhough all faces on the polyPatch, adding their magnitude surface
            // area vectors
            forAll(myPatch, faceI)
                patchArea += mesh.magSf().boundaryField()[patchID][faceI];
    获得Patch的名字
    Info << "patch name is " << U.boundaryField()[patch].patch().name() << nl;
    网格相关量
    const scalarField& V = mesh.V();                            // 网格体积
    const surfaceVectorField& Sf = mesh.Sf();                   // 网格面矢量
    const surfaceScalarField& magSf = mesh.magSf();             // 网格面积的模
    const surfaceVectorField& N = Sf/magSf;                     // 网格面法向
    更改壁面一层网格值
            label patchID = mesh.boundaryMesh().findPatchID("wall");
            const scalarField TfaceCell =
                T.boundaryField()[patchID].patchInternalField();
            k.boundaryFieldRef()[patchID] == sqrt(TfaceCell);
    #include "wallFvPatch.H"
    forAll(nu.boundaryField(),patchi)
        if (isA<wallFvPatch>(mesh.boundary()[patchi]))
            nu.boundaryFieldRef()[patchi] == 0.5*nu.boundaryField()[patchi].patchInternalField();
    给定patch调用网格
    如果p是一个fvPatch
    const fvMesh& mesh = p.boundaryMesh().mesh();
    类内调用时间步长
    假定mesh_是类内可以调用的成员变量。
    const scalar deltaT = mesh_.time().deltaT().value();
    如果mesh_不可获取,U_可获取:
    const scalar deltaT = U_.mesh().time().deltaT().value();
    声明一个tmp变量
    tmp<volScalarField> deltaLambdaT
        volScalarField::New
            "deltaLambdaT",
            mesh_,
            dimensionedScalar(dimless, 1.0)
    简写边界场
    volScalarField::Boundary& meanUb = meanU_.boundaryFieldRef();
    forAll(meanUb, patchi)
        fvPatchScalarField test = meanUb[patchi];
    判断是否是固定值边界、processor边界
        forAll(mesh_.boundary(), P)
            if
                isA<fixedValueFvPatchScalarField>
                    T.boundaryField()[P]
                isA<processorPolyPatch>(mesh_.boundaryMesh()[P])
    codedFixedValue
    inlet
            value           uniform (0 0 0); //default value
            name           linearTBC; //name of new BC type
            code
                //const fvPatch& boundaryPatch = patch();
                //const scalar &t = this->db().time().deltaTValue();
                scalar inletS = 0.0;
                const fvPatch& inletPatch = this->patch();
                forAll(inletPatch, faceI)
                    inletS += inletPatch.magSf()[faceI];
                scalar outletS = 0.0019304;
                scalar alphain = 0.1;
                vectorField& vf = *this;
                forAll(vf, i)
                    vf[i].y() = 0.01*outletS/inletS/alphain;
                    vf[i].x() = 0.0;
                    vf[i].z() = 0.0;
    努塞尔数
    下列代码可以添加到controlDict中执行
    functions
        coded
            functionObjectLibs ( "libutilityFunctionObjects.so" );
            enabled         true;
            type            coded;
            redirectType    printMinU;
            writeControl   timeStep;
            writeInterval  1;
            codeOptions
            codeExecute
                const volScalarField& T
                    mesh().lookupObject<volScalarField>("T")
                const fvPatchList& patches = mesh().boundary();
                forAll(patches, patchi)
                    if (mesh().time().value() == 30001)
                        if (currPatch.name() == "downwall")
                            fvPatchScalarField nus = T.boundaryField()[patchi];
                            scalar L = 0.014231;
                            scalar Tref = 309.1;
                            scalar Timp = 347.6;
                            nus = T.boundaryField()[patchi].snGrad()*L/(Timp - Tref);
                            forAll(T.boundaryField()[patchi], facei)
                                Pout << mesh().C().boundaryField()[patchi][facei].x()/0.014231
                                     << " " << nus[facei] << nl;
    获取某个函数的计算时间
    #include <chrono>
    auto start = std::chrono::steady_clock::now();
    // Functions here
    auto end = std::chrono::steady_clock::now();
    auto diff = end - start;
    Info<< "Calculate nodes and weights, using "
        << std::chrono::duration <double, std::milli> (diff).count()
        << " ms" << endl;
    在某个文件夹下输出scalarField
    by @Samuel-Tu
        IOField<scalar> utau
                "utau",
                 runTime.constant(),
                "../postProcessing",
                mesh,
                IOobject::NO_READ,
                IOobject::AUTO_WRITE
            scalarField(totalFSize,0.0)
    BlockMesh-simpleGrading
    处理非均一网格
    blocks
        hex (0 1 2 3 4 5 6 7) (100 300 100)
        simpleGrading
            1                  // x-direction expansion ratio
                (0.2 0.3 4)    // 20% y-dir, 30% cells, expansion = 4
                (0.6 0.4 1)    // 60% y-dir, 40% cells, expansion = 1
                (0.2 0.3 0.25) // 20% y-dir, 30% cells, expansion = 0.25 (1/4)
            3                  // z-direction expansion ratio
    输出yplus
    functions
           yplus
             type                   yPlus;
             functionObjectLibs      ("libutilityFunctionObjects.so");
             outputControl           outputTime;
             enabled                 true;
    by @Sloan
    在流场中添加颗粒失踪
    controlDict添加下述内容,同时需要在constant文件夹添加kinematicProperties字典文件
    particles
            libs        ("liblagrangianFunctionObjects.so");
            type        particles;
    在流场中添加欧拉标量传输
    controlDict添加下述内容,同时需要在0文件夹下添加s标量场,以及fvScheme、fvSolution都要做适配
    functions
        scalarTransport1
                type            scalarTransport;
                libs            ("libsolverFunctionObjects.so");
                field           s;
                D               1e-4;
                fvOptions
                    s
                        type            semiImplicitSource;
                        active          true;
                        selectionMode   points;
                        points
                            //(0.57 0.001 0.325)//w/h=5
                            //(0.62 0.001 0.325)//w/h=5
                            (0.67 0.001 0.325)//w/h=5
                            //(0.72 0.001 0.325)//w/h=5
                            //(0.77 0.001 0.325)//w/h=5
                        volumeMode      absolute;
                        sources
                            s
                                explicit 0.0001;
                                implicit 0;
    对网格进行赋值
    forAll(T, C)//遍历网格,T为场
        T[C] = min(nu[C], 100);//对T的第C个网格,赋值第C个网格的nu与100的最小值
    声明多个场PtrList
    PtrList<surfaceScalarField> abPosCoeff(4);
    forAll(abPosCoeff, i)
        abPosCoeff.set
            i,
            new surfaceScalarField
                    "abPosCoeff" + name(i),
                    mesh.time().timeName(),
                    mesh,
                    IOobject::NO_READ,
                    IOobject::NO_WRITE
                mesh,
                dimensionedScalar(inv(dimLength), 0.0)
    OpenFOAM的二维数组
        PtrList<PtrList<scalar>> te(4);
        forAll(te, i)
            te.set(i, new PtrList<scalar>(4));
            forAll(te[i], j)
                te[i].set(j, new scalar (0.0));
    输出最大值最小值
    functions
        minMaxp
            type        fieldMinMax;
            functionObjectLibs ("libfieldFunctionObjects.so");
            fields
                 U
            location        no;
            writeInterval   1;
    dimensionedScalar rho(dimDensity, 1.0);
        dimensionedScalar U(dimVelocity, 1.0);
        dimensionedScalar Ain(dimArea, 0.000481);
        dimensionedScalar sin(dimless, 1);
        dimensionedScalar min = rho*U*Ain*sin;
        tmp<volScalarField> tDEF
            volScalarField::New
                type(),
                mesh_,
                dimensionedScalar(dimless, 0)
        tmp<volScalarField> mwj
            volScalarField::New
                type(),
                mesh_,
                dimensionedScalar(dimMass/dimTime, 0)
        const volScalarField& s = lookupObject<volScalarField>("s");
        const volScalarField::Boundary& sBf = s.boundaryField();
        volScalarField::Boundary& mwjBf = mwj.ref().boundaryFieldRef();
        scalar mw = 0.0;
        forAll(mesh_.boundary(), patchi)
            if (mesh_.boundary()[patchi].name() == "wall")
                scalarField Aj = mesh_.boundary()[patchi].magSf();
                mwjBf[patchi] = -rho.value()*Aj*sBf[patchi].snGrad()*1e-5;
                forAll(mesh_.boundaryMesh()[patchi], facei)
    	        mw += mwjBf[patchi][facei];
        volScalarField::Boundary& DEFBf = tDEF.ref().boundaryFieldRef();
                scalar area = gSum(mesh_.magSf().boundaryField()[patchi]);
    	    Info<< "Wall area is " << area << nl;
                //DEFBf[patchi] = mwjBf[patchi]/Aj/(mw/A);
                DEFBf[patchi] = mwjBf[patchi]/Aj;
        return tDEF;
    单独一个文件输出直径信息
    meanDiameter
            type            coded;
            name            error;
            codeExecute
                const volScalarField& d =
                    mesh().lookupObject<volScalarField>("d.alpha.oil");
                scalar d32 = d.weightedAverage(mesh().V()).value();
                if (Pstream::master())
                    std::ofstream file;
                    file.open ("d32", std::ofstream::out | std::ofstream::app);
                    file << mesh().time().timeName() << " " << d32 << "\n";
                    file.close();
    拉格朗日输出alpha
    cloudFunctions
        f1
            type voidFraction;
    五好青年五 D 2 条回复 最后回复
    yfclark 神
    补充一个CodeStream实现充分发展的湍流入口,请东岳老师不要建议
    $\begin{array}{l}
    \delta_{T}>\delta_{w} \rightarrow u=u_{\infty}\left(\frac{d_{w}}{\delta_{T}}\right)^{1 / 7} \
    \delta_{T}<\delta_{w} \rightarrow u=u_{\infty}
    \end{array}
    \delta_{T}=0.37\left(v / u_{\infty}\right)^{0.2} L_{T}^{0.8}
    dw为到壁面的最短距离
    OpenFoam 7:
    gasinlet
        type            fixedValue;
        value           #codeStream
            codeInclude
                #include "fvCFD.H"
                #include "DynamicList.H"
            codeOptions
    	    //libs needed to visualize BC in paraview
    	    codeLibs
        	    -lmeshTools \
        	    -lfiniteVolume
            code
                const IOdictionary& d = static_cast<const IOdictionary&>
                    dict.parent().parent()
                const fvMesh& mesh = refCast<const fvMesh>(d.db());
                const label id = mesh.boundary().findPatchID("gasinlet");
                const fvPatch& patch = mesh.boundary()[id];
                vectorField U(patch.size(), vector(0, 0, 0));
                const scalar U_inf=93.5;
                const scalar LT=0.2;
                const scalar visco=2.3183558929634845e-06;
                const scalar deltaT=0.37*pow(visco/U_inf,0.2)*pow(LT,0.8);
                scalar dw=0.0;
                forAll(U, i)
                    const scalar x = patch.Cf()[i][0];
                    const scalar y = patch.Cf()[i][1];
                    const scalar z = patch.Cf()[i][2];
                    DynamicList<scalar>  distance(4);
                    distance.append(mag(y));
                    distance.append(mag(y-30e-6));
                    distance.append(mag(z-23e-6));
                    distance.append(mag(z+23e-6));
                    dw=min(distance);
                    distance.clearStorage();
                    scalar Ux=0.0;
                    if(deltaT>dw)
                        Ux=U_inf*pow(dw/deltaT,1.0/7.0);
                    else
                        Ux=U_inf;
    	            U[i] = vector(Ux, 0, 0);
                writeEntry(os, "", U);
    Zhong-combustion
    在 中回复了 yfclark 最后由 编辑
    @yfclark 谢谢贡献代码。有一个疑问还请教,这里没有脉动量,只有平均速度的径向分布。在LES或者DNS中,脉动量比较重要,所以关于脉动量的话有什么看法么?还是说这个入口可以作为一个入口,然后在一个长管道内比较容易自然发展成充分发展的湍流?代码里的U_inf可以理解为平均速度么?
    霜 1 条回复 最后回复
  • 马乔马 离线
    马乔马 离线
    马乔 大神
    wordHashSet unMatchedkeys(dict.toc());
    forAll(names, nameI)
        const word& name = names[nameI];
        const entry* ePtr = dict.findEntry(name, keyType::REGEX);
        if(ePtr)
           unMatchedKeys.erase(ePtr->keyWord());
    装逼没输过,吵架没赢过!
  • 马乔马 离线
    马乔马 离线
    马乔 大神
    class base
    private:
        bool ownedByRegistry_;
    public:
        template<class Type>
        static void store(Type* p)
    	//p->base::ownedByRegistry_ =true;
    	p->ownedByRegistry_ = true;
    	p->printInfo();
    class derived
    :public base
    public:
        derived() {}
        void printInfo()
    	Info << "derived class" << endl;
        derived d;
        base::store(&d);
    装逼没输过,吵架没赢过!
    D.Benjamin
    @东岳 在 OpenFOAM小代码 中说:
    东岳老师,请教几个小问题:
    1. 在编译过程中报错:'mesh_' was not declared,所以mesh_是不可以直接使用的,但是我不太理解什么是类内可以调用的成员变量,感觉速度场U,温度场T等都是类内可以调用的成员变量?
    2. 如果mesh_不可获取,U_可获取。上面说mesh_是类内可以调用的成员变量,然而U_又是什么?
    3. 声明一个tmp变量,mesh_表示什么意思呢?在声明U、T、p等场的时候,mesh_的位置常常写的是mesh
    期待回复,祝好!
    OpenFOAM初学者,希望和大家共同交流
    @D-Benjamin
    我不太理解什么是类内可以调用的成员变量
    我说的这个东西,就是类的成员变量。如果存在成员变量mesh, 它在OpenFOAM类内都被定义为mesh_,在类外那肯定是mesh,后面有没有_只是写法风格,OpenFOAM类里面的变量都带_,类外面的变量都没有_。
    OpenFOAM这面类继承会涉及到好几层。你可以一层一层的找有没有mesh_的声明,你可以直接用mesh_看看是否报错,没报错就是声明了,报错了就是没生命。
  • 霜 离线
    霜 离线
    霜染丹枫
    在 中回复了 Zhong-combustion 最后由 编辑
    @Zhong-combustion 你好,我目前也在用LES做加热管流的湍流研究,关于湍流入口的设置看了一些资料,如有兴趣,可以加个qq:1191364394,共同学习探讨。
    Zhy2022
    东岳老师您好,请问如果是两相流中相分数(比如alpha.particle)随时间变化,它在codeFixedValue中应该怎么定义呢?
    在 中回复了 Zhy2022 最后由 编辑
    @Zhy2022 codedFixedValue上面不是有嘛,你举一反三一下咩
    Z 2 条回复 最后回复
    Zhy2022
    @东岳 东岳老师,没能找出报错原因:135: ,只能再来麻烦一下您:
    INLET1
            name            stepInjection;
            redictType      variedValue;
            code
                 scalar alphapar = this->patch().fluid().phase();
                 scalar t = this->db().time().value();
                 if(t >= 0 && t<=5)
                      alphapar = 0;
                 else
    	          alphapar = 0.15;
    	     operator==(alphapar)
    Zhy2022
    @东岳 东岳老师,问题已解决!无法编译与文件路径有关
  • V 离线
    V 离线
    veen
    fvOption小工具
    根据GitHub上一个python脚本改写了一个生成fvOption的小工具 https://github.com/Veenxz/fvSchemes
    用Foam没有多久,各位大佬可以多提提意见。
    # version 2.0
    # Based on https://github.com/Carlopasquinucci/fvSchemes
    # Generation by Veenxz
    # relaesed under license GPL GNU 3.0
    steady = True
    pseudo_transient = False
    precision = 2    # First order 1 or Second order 2
    unbounded = False
    LUST = False
    secondorder = True
    maxOrtho = 80
    maxSkew = 20
    # Header and Footer
    h = [
        "/*--------------------------------*- C++ -*----------------------------------*|",
        "| \\\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |",
        "|  \\\    /   O peration     | Website:  https://openfoam.org                  |",
        "|   \\\  /    A nd           | Version:  7                                     |",
        "|    \\\/     M anipulation  |                                                 |",
        "FoamFile", "{", "    version     2.0;", "    format      ascii;",
        "    class       dictionary;", '    location    "system";', "    object      fvSchemes;",
    footer = '\n// ************************************************************************* //'
    nonOrthogonalCorrectors = 1
    if (maxOrtho) > 80:
        print(
            'Warning: mesh is not so nice. Use 3 nonOrthogonalCorrectors in fvSolution file'
        nonOrthogonalCorrectors = 3
    if (maxSkew) > 8:
        print('Warning: mesh is not so nice')
    if (maxOrtho) > 80:
        gradSchemes = (
            '{\n    default          cellLimited Gauss linear 0.5;\n'
               '    grad(U)          faceLimited Gauss linear 1.0;\n}'
        divSchemes = (
            '{\n    div(phi,U)       Gauss linearUpwind grad(U);\n'
               '    div(phi,omega)   Gauss upwind;\n'
               '    div(phi,k)       Gauss upwind;\n'
               '    div(phi,e)       Gauss upwind;\n'
               '    div((nuEff*dev(T(grad(U))))) Gauss linear;\n}'
        laplacianSchemes = (
            '{\n    default          Gauss linear limited 0.333;\n}'
        snGradSchemes = (
        blending = 0.2
    if (maxOrtho) > 70:
        gradSchemes = (
               '    grad(U)          cellLimited Gauss linear 1.0;\n}'
        divSchemes = (
               '    div(phi,omega)   Gauss linearUpwind grad(omega);\n'
               '    div(phi,k)       Gauss linearUpwind grad(k);\n'
               '    div(phi,e)       Gauss linearUpwind grad(e);\n'
            '{\n    default          Gauss linear limited 0.5;\n}'
        snGradSchemes = (
        blending = 0.5
    if (maxOrtho) > 60:
        gradSchemes = (
            '{\n    default          cellMDLimited Gauss linear 0.5;\n'
               '    grad(U)          cellMDLimited Gauss linear 0.5;\n}'
        divSchemes = (
            '{\n    default          Gauss linear limited 0.777;\n} '
        snGradSchemes = (
        blending = 0.7
        nonOrthogonalCorrectors = 2
    if (maxOrtho) > 0:
        gradSchemes = (
            '{\n    default          cellMDLimited Gauss linear 0;\n'
               '    grad(U)          cellMDLimited Gauss linear 0.333;\n}'
        divSchemes = (
            '{\n    default          Gauss linear limited 0.95;\n}'
        snGradSchemes = (
        blending = 0.8
    if (LUST):
        gradSchemes = (
            '{\n    default          Gauss linear;\n'
               '    grad(U)          cellMDLimited leastSquares 1;\n}'
        divSchemes = (
            '{\n    div(phi,U)       Gauss LUST grad(U);\n'
               '    div(phi,omega)   Gauss LUST grad(omega);\n'
               '    div(phi,k)       Gauss LUST grad(k);\n'
               '    div(phi,e)       Gauss LUST grad(e);\n'
            '{\n    default          Gauss linear corrected;\n}'
        snGradSchemes = (
        blending = 0.9
    if (steady):
        ddtSchemes = (
            '{\n    default          steadyState;\n}'
        if (pseudo_transient):
                    ddtSchemes = (
                        '{\n    default          localEuler;\n}'
    else:
        ddtSchemes = (
            '{\n    default           CrankNicolson ' + str(blending) + ' ;\n}'
        if precision == 1:
            ddtSchemes = (
                '{\n    default           Euler;\n}'
        if (unbounded):
            ddtSchemes = (
                '{\n    default           backward;\n}'
    wallDist = (
        "{\n    method           meshWave;\n}"
    #open fvSchemes and write inside
    f = open("fvSchemes", "w")
    for i in h:
    	f.write(i + "\n")
    f.write("ddtSchemes" + "\n")
    f.write(ddtSchemes + "\n")
    f.write("\n")
    f.write("gradSchemes" + "\n")
    f.write(gradSchemes + "\n")
    f.write("\n")
    f.write("divSchemes" + "\n")
    f.write(divSchemes + "\n")
    f.write("\n")
    f.write("laplacianSchemes" + "\n")
    f.write(laplacianSchemes + "\n")
    f.write("\n")
    f.write("snGradSchemes" + "\n")
    f.write(snGradSchemes + "\n")
    f.write("\n")
    f.write("wallDist" + "\n")
    f.write(wallDist + "\n")
    f.write(footer)
    f.close()
    print('File fvSchemes created')
    李东岳李 V 2 条回复 最后回复
    在 中回复了 veen 最后由 编辑
    @veen 厉害厉害 :146: :146:
  • V 离线
    V 离线
    veen
    在 中回复了 veen 最后由 编辑
    @veen 这个代码还有些格式没法用……我回头测试了再放到github大家看仓库里边的代码就好了。
    hongjiewang
    @李东岳 在 OpenFOAM小代码 中说:
    "utau",
    runTime.constant(),
    mesh,
    IOobject::NO_READ,
    请问老师,如果我想要在postProcessing中输出一个标量,他只是一个数,并不是场量,我应该怎么定义他的类型。上面这种方法是不是只适应于场量的输出。我想输出的是下面c的数值。
    const volScalarField& b = mesh().lookupObject<volScalarField>("alpha.liquid");
    scalar c= b.weightedAverage(mesh().V()).value();
    在 中回复了 hongjiewang 最后由 编辑
    @hongjiewang
        IOList<scalar> utau
                "utau",
                runTime.constant(),
                mesh,
                IOobject::NO_READ,
        utau[0] = b.weightedAverage(mesh().V()).value();
    H vbcwlV 3 条回复 最后回复
    hongjiewang
      totalLiquid
            libs            (utilityFunctionObjects);
            type            coded;
            name            totalLiquid;
            enabled         true;
            writeInterval   1;
            codeOptions
            codeExecute
                IOList<scalar> liquidFraction
                        "liquidFraction",
                        mesh().time().constant(),
                        mesh(),
                        IOobject::NO_READ,
                liquidFraction[0] = b.weightedAverage(mesh().V()).value();
    东岳老师,我这样添加到controlDict里,运行后postProcessing里并没有出现liquidFraction的值。
    hongjiewang
    在 中回复了 hongjiewang 最后由 hongjiewang 编辑
    @hongjiewang 在 OpenFOAM小代码 中说:
      totalLiquid
            type            coded;
            name            totalLiquid;
            enabled         true;
            writeInterval   1;
            codeOptions
            codeExecute
                        "liquidFraction",
                        mesh(),
                        IOobject::NO_READ,
    需要修改两个部分,
    1.在下方添加 .write()
    2.将codeExecute改为codeWrite
    之后就可以得到想要的相含量结果。
    hongjiewang
    FoamFile
        version     2.0;
        format      ascii;
        class       scalarField;
        location    "constant/../postProcessing";
        object      totalLiquid;
    1(0.2)
    麻烦老师再帮我看一下,为什么每次都只会输出一个时刻的值,不会随时间增加输出的
